PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. a few question about the lq4 for a swap
  2. NA 5.3 with an LS9 cam
  3. Help! My 5.3 Loses Power At Operating Temp
  4. Serial Data Question. Truck Cluster. Tach but no temp or fuel
  5. 5.3 on 4.3 4l60e
  6. Anyone have a CTS-V oil pickup tube laying around? PN 12621299
  7. 98-02 z28 camaro cluster in a 68 shortbed. I have a question.
  8. 5.3 s10 under 3 grand?
  9. T-56 Park Neutral Wire?
  10. o2 sensor placement?
  11. Oil leaking prior to start up? (GTO oil pan)
  12. Another LSx swapped Marauder
  13. Loss of spark due to cam or crank sensor?
  14. Anyone have experience with a Junk Yard alterative to Vintage Air?
  15. lq9, ls3 heads, 68 firebird whats need for intake?
  16. What headers will work with my 1995 Mustang 6.0 swap?
  17. PSI swap harness
  18. New Member with Cam & Crank Sensor Questions
  19. LY6 into a 55 Nomad Swap
  20. ls3+6l80e into 70 nova?
  21. Started on wiring my LQ4 conversion.....I've got questions
  22. Throttle Body difference....
  23. High Side AC pressure when moving?
  24. Borg Warner Model 65 or 66 dimensions
  25. Your sound clip of a 224/232 .568/.575 113+3 or similar
  26. ls1 swap gauge questions
  27. 2pc case 4l60e with 4472 awd xfer case
  28. Tick master cylinder in a 68 camaro
  29. Is this too much for labor cost
  30. Air intake tube and mass air flow sensor compatibility ?
  31. T56 need advice/help
  32. Problem with return line leaking excessively
  33. best ratio for a 6l80 ?
  34. Ls2 burning oil ?
  35. which headers or manifold
  36. 4.3 v6 to a 6.0
  37. 93 Sonoma with 5.3 a/c question
  38. '82 Supra 6.0, S480, glide, 3.45s
  39. LQ9 does not seem to cool?...
  40. g body with f body manifolds
  41. A-body 4l60e column shift linkage?
  42. LS bravada
  43. Vortec Hood Clearance
  44. Pickup Tube O-Ring
  45. List of OEM rear sump pickup tubes?
  46. Chevy II LQ4/T56 Header help!
  47. Having DBW issues on new swap
  48. MEMBER Chrome_Rust!!!! BUYER BEWARE
  49. Injector input 84 Z28 LS1
  50. Show your gauges
  51. Rewired F-Body Harness for Stand Alone and th400
  52. 97 lt1 Ls1 swap harness question
  53. starter signal wire
  54. Help with Pinouts GMPP LS3 E67 ECM
  55. 97 S10... 5.3/4l60e swap with air ride
  56. LS2 starter wiring
  57. 06 Lexus IS250 LS1 Build
  58. 1983 gmc k20
  59. Has anyone tried the CXracing swap kit yet?
  60. 6.0LQ4 to TH350 issues
  61. headers for 5.3 in 90 foxbody
  62. What are you guys doing to insure your daily driver LSx cars?
  63. Mustang guys...what steering shaft?
  64. 2001 ecu, 2000 fbody flash and harness, which O2 sensors?
  65. Edelbrock 8895 Waterpump 70 Corvette LQ4
  66. Ls1 z33
  67. A body air conditioning.
  68. questions on fuel rails for truck motor?
  69. Impala tank in a-body gauge works w/power off to pump, but not when running
  70. Tunnel mods
  71. 6.0l running on a 5.3l tune?
  72. carburated 4.8
  73. carburated ls1
  74. Transmission line question
  75. Steering pump/box help from steering gurus
  76. a/c wiring and bracket help
  77. New paint for my FFR LS Daytona Coupe
  78. 94 Jeep YJ swap 5.3L LM7
  79. 2000 sonoma 2.2l ecu pinouts
  80. Setting transmission angle in fox. 4l80e
  81. 4.8 turbo’d or 5.3 turbo’d
  82. exhaust system help
  83. ECM values for MPH about half of actual
  84. 1980 trans am procharged lq4
  85. 97 camaro LS1 swap fuel gauge
  86. My 72 Buick Skylark Ls conversion build
  87. Anyone use Moroso 20143 Swap Road Race Oil Pan for GM LS Engine...?
  88. 375 miles no problems! What is your longest?
  89. Harness Pinouts
  90. My track/street 240sx LS Swap
  91. 5.3 Conversion
  92. 01 LSX Twin Turbo Mustang
  93. cooling at speed
  94. 88mustang BP Automotive ls wiring harness install
  95. Gauge cluster options for 94 mustang lsx swap
  96. LS 2 swap
  97. Show your trunk set up w/Impala Tank on GM A-bodies!
  98. Wiring harness question.
  99. 5.3 4l60e into 77 dodge b200 ?s
  100. tranny lines
  101. 3rd Gen F-body LSx Mounts....Input!!!!
  102. cam
  103. ls motor in fox. need suggestions
  104. 94 TA conversion questions
  105. 70 Camaro LS1 build thread
  106. G- body guys what ???
  107. Electrical: Painless wiring harness no 12v to dlc or pcm
  108. check engine light ?
  109. Need pinouts for C1, C3, and C4. Please help.
  110. Shit just got real.
  111. Issues I need help!!
  112. A/C fan and relay question
  113. Green Goblin start
  114. IS300 LS1/T56 Daily Driver Build
  115. 1st Gen F-Body radiator hose help.
  116. 5.3 in 58 f100 front acc help
  117. walbro 255 squeeling
  118. a4 with a/c cam/stall help!
  119. How to wire 4 plug alternator (no computer), and amp questions
  120. Need Help in Memphis...ASAP...
  121. 5.3 ecu programming and transmission question
  122. C6 Vette Accessory drive for sale w/balancer
  123. Psi Conversion Harness o2 Wiring
  124. LS swaps are king
  125. Accessory Drive- AC & Belt Fuel Pump??
  126. LQ4 in an early 90's Cavalier
  127. Curbchecks LS1 S14
  128. 2000 sonoma pin outs
  129. 1998 car with 1999 wiring harness none of my gauges work
  130. 1972 C20 Suburban LS swap
  131. 14 camaro pump VS truck pump
  132. Coolant volume and type?
  133. F-body Water Pump, Fox Body Radiator What Hoses to use
  134. 5.3 swap with 700r4 --No Speedo or fuel gauge work HELP!
  135. my turbo 5.3 notch build pics and video
  136. installing a check engine light
  137. 98 engine in a 99 z28...oil pressure sending unit
  138. Where to find pcm connector pins
  139. Simple wiring Harness question
  140. Interesting find concerning scanners
  141. Place Your Bets! 1/4 Mile Estimate for Stock Carb'd 5.3 Nova
  142. 68 C10 Twin Turbo LSX
  143. Meyers Manx 327 Restoration
  144. 6L80E with 4.8 LY2
  145. where to buy 1/2" power brake vacuum hose?
  146. LS1 Into a 107 Mercedes SLC
  147. windstar fan fuse rating
  148. Help me make a List of what I need: LQ4/T56 Swap into 95 Camaro set up for a Ls1
  149. Mustang swap guys...how you hooking up speedometer?
  150. Which Windage Tray?
  151. ls/lq4 computer to LT1 style 4l60E HELP!
  152. Single bolt cam sprocket 4x modified to 1x
  153. What is needed to swap LS7 into 3.8 Firebird?
  154. tach signal to can bus?
  155. LS2 in a BRZ is complete
  156. Pacesetter Header Mods For Gbody- Update
  157. Craigslist Searching + My Apartment Room + LSx + Thirdgen = ?????
  158. 97 RCSB AES 390 + F1A + 4L80E swap:)
  159. Dougs 2nd gen F-body headers
  160. Anybody used S & P adapter plates for LM7 into a 63 Impala?
  161. fused switched power
  162. FWD 5.3L LS4 oil pan to LQ9
  163. TPS reading backwards in my swap
  164. 05 GTO motor in a 32 starts but dies
  165. 94-98 mustang Radiator options
  166. 1973 Stingray and a 5.3 questions
  167. Need help with setting up an E67 ECM LS3
  168. foxbody guys
  169. Gen 2 Mazada RX8 LS2 500rwhp plus and snapped swap Torgue arm
  170. Ls1 to 5.3 swap help please!
  171. Hey 2nd Gen Camaro Guys! Need a car for Hooker Headers
  172. accessory brakets
  173. bbf or lsx swap fox
  174. blinkers with turn signals with standalone
  175. 2005 Silverado donor truck for my 68 camaro questions?
  176. So, who's going to be the first to do the new 6.2L LT1 swap?
  177. Power Steering Port Identification
  178. quick second generation s10 clearance question.
  179. 1-7/8 headers in 64-67 chevelle?
  180. LQ4 swap into my 67 Chevelle
  181. LS7 powered 1967 Corvette Convertible at Drags - Video
  182. Fox swap questions.
  183. What to grab from donor car LT1 to LS1
  184. 02 LQ4 value..
  185. i was told this is the highest hp stock bottom end 5.3 is this true
  186. In need of ls swap headers for 1990 mustang
  187. Corvette regulator/filter ?
  188. What is this wiring harness connector for?!?!
  189. 68 Camaro RS LS1 Swap - In progress
  190. ls1 miata project/ ls1 firebird parts car wiring harness questions
  191. Injector Tester, Pulser, Cleaner - Updated circuit card
  192. Size of crank-to-flywheel bolts??
  193. 1st test ls1 69camaro, no tach, bucks hard trying to shift.
  194. coolant crossover
  195. Is the 5.3 really cheaper than the LS1???
  196. shifter question 70 camaro ls2 with 4l60e
  197. 1968 Chevelle Wagon LS1 6-speed swap
  198. Longer 4l60e shifter cable?
  199. 1977 camaro RS 5.3 build
  200. Shaffer's 5.3 s10 build
  201. HELP-- no coolant flow
  202. 97 catera lq4/4l80e.
  203. CANNOT get clamshell mounts to line up
  204. Radiator
  205. 1st time out with LY6 Stang
  206. New to V8's and need help with connections on a 5.3L L33
  207. Hello, help?
  208. 5.3 "Squirter" Project test Rusted & Filled with Water. w/ Videos
  209. Gbody PCM mounting
  210. getting a/c and heat
  211. Subaru SVX LS conversion
  212. Grand national swap for 6LE
  213. 81 Olds Sport Omega- All Wheel Drive, LS4, F40 6 speed.
  214. 95 camaro v6 to lsx 6.0
  215. LS1 / T56 280Z on the dyno
  216. fox swap fuel line ???
  217. Remote mount AC condenser in LS swapped 1999 Dakota RT
  218. Foxbody ls swap manifolds
  219. how do I hook up my alternator wires ???
  220. Ls swap a/c bracket
  221. 12V power for LS2 E40 PCM?
  222. 2nd gen camaro ls swap
  223. 5.3 swap into 02 fbody basics?
  224. 4 wheel drive conversion?
  225. 72 Corvette LS480 / Keisler RS500 Conversion
  226. LSX S10 Swapped Owners Check In!!
  227. 97 3.8 to 98 5.7 swap- 0 volts to fuel sending unit
  228. Anyone charge the vintage air system themself?
  229. options for a ls1/4L60 swap harness?
  230. Fuel question for 5.3 swap foxbody
  231. LS1 GTA Custom Dual Ram Air Intake
  232. Cherokee box into A-body
  233. 1963 MGB tease
  234. How to Wire Up a Starter on LS Swap???
  235. 8 stack injection
  236. Small Block to LS?
  237. 98 M3 Sedan LS1/T56 Daily
  238. Bulkhead or inline connector for engine wiring harness
  239. Coolant Routing 68 Camaro w/'05 LS6/LS1
  240. Which swap is better and y?
  241. Plastic battery cable holder on oil pan.
  242. ECM Mounting
  243. Super Sensitve Steering
  244. Where/How to buy converted car/truck with an ls in them???
  245. Thinking of swapping LQ9 408 into '04 Mach 1
  246. Wiring and ecu question
  247. New Hooker 2nd-gen F-body LS swap components now released
  248. Ls1/t56 going in my 67 Chevelle
  249. S10/ls1 weights?
  250. shifter question 70 camaro ls2 with 4l60e
