PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 [111] 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Anyone seen this bracket conversion?
  2. flexplate spacer confusion
  3. !!06 GTO LS2 to LS3 418!!!
  4. slave cylinder
  5. late model transmission behind a sbc
  6. LS1 240sx Guys Help Me Out Plz
  7. electric temp sender question
  8. '99 L36 V6 to '01 LS1 V8 swap (w/PICS!)
  9. Need Info for 2000 V6 Camaro LS1 Swap??
  10. 69 Nova LQ4 turbo questions
  11. 1967-1969 Chevelle/Camaro LS1 Swap Header
  12. DBW Gas Pedal mount 240sx
  13. LS7 Corvette accessory drive
  14. 67 camaro project
  15. 6.0 emblems
  16. Just wanted a second voice to make sure I am right
  17. fuel rail
  18. which transmission did u choose and why?700r4?th350?th400?
  19. my gt ls swap with updates
  20. In car video at VMP
  21. Mustang lsx begining
  22. 4-67 A body,LS1,2004r swap
  23. LS1 Dipstick Removal
  24. Craziest, Most Original LSX Swap?
  25. lifting a 5.3
  26. 5.3 into nova or jeep
  27. spohn mounts
  28. Stand Alone Question
  29. 6L80E in a G-body?
  30. Wiring Help
  31. Anyone have experience with http://www.lt1conversion.com ?
  32. Conversion folks - Tranny Cross member question
  33. LS1 swap guide to 2 gen Camaro.
  34. odd ls1 problem
  35. LS1 year model?
  36. c10 conversion
  37. 87 cutlass lq4 questions...
  38. Spectra Fuel Tank
  39. VSS for LS on old Muncie style manual....
  40. Odd fan issue
  41. LQ9 DBW Pedal Motor?
  42. Crossmember not lining up
  43. LS1 in 1989 3/4ton Suburban...?
  44. Auto Meter Electric gauges with stock senders
  45. My 67 Camaro Project
  46. Spectra Premium in tank pump failing
  47. e38 pwm cooling fan control
  48. LSX in a foxbody question?
  49. Corvette Fuel Filter, Russell fitting 640940
  50. 04 GTO harness into a 93 TA 4L80E. Conversion help
  51. Stand Alone Harness for LQ4 W/200r4
  52. 4L60E v. T56
  53. Wiring Help
  54. 62 Bel Air sedan 5.3 Turbo build
  55. Just curious
  56. LQ4 swap into camaro
  57. Look what we did today...
  58. 98 LS1 harness mod question, cam sensor plug?
  59. Need Help, Swap fires but doesn't idle
  60. LQ4 6.0L sawp into 96Z, potential problems?
  61. Finished Product '00 S10 4.8 PICS
  62. GTO project
  63. ls2 in my 69 camaro
  64. fox mustang lsx Q's
  65. help with engine stands
  66. '00 S10 4.8 Dyno Results
  67. how do I attack the spark?
  68. Fuel Vapor Canister recomendations
  69. LS6 Intake manifold and cable TB on LS2 with E40 PCM
  70. th400 vac hookup
  71. Ls2 dbw
  72. Cleaning out the garage......what do U need?
  73. A-body headers on the cheap! Check it out
  74. clutch resevoir
  75. Couple of issues after swap...
  76. Starting swap on 73 nova (what motor mounts)
  77. underhood hanress: who's using it?
  78. My wiring seems to be done!
  79. excessive. the 69 camaro
  80. Gauge Question
  81. connector part numbers
  82. trailblazer SS complete swap 4x4 is it possible?
  83. thinking of converting my rad to a dual pass in sted of a single pass?
  84. Headers
  85. Connector C100 Pin N, "Ignition 3 Voltage"??
  86. Camaro Tank Pickup/Wiring/Fuel Line Questions...
  87. I might give up on my LS1 swap after all
  88. Out of the Blue Running Issues
  89. suggestions on possible third gen swap?
  90. Where to buy LS1 manifold exhaust flange?
  91. hud display conversion
  92. LSx Conversions at Hot August Nights
  93. Anyone here running the gauge cluster from an LSx powered vehicle in their hybrid?
  94. GM A body ?????
  95. Preparing to order my radiator, anything special I need to account for?
  96. L92 VVT T56... can it work?
  97. 06 TBSS Motor - ECU Options
  98. Rubber fuel hose for injection?
  99. Best T-56 Solution / Ideas?
  100. EVAP Solenoid
  101. lsx? miata help
  102. 1st gen F-body twin turbo
  103. which oil pan for nova?
  104. can you plug the coolant crossover
  105. ls2 back firing question
  106. LT1 iroc swap need Help!!
  107. Speed sensor signal
  108. How can I tell the year of my lq9?
  109. 96 v6 bird to 00 ls1 wiring??
  110. Coil covers, low budget/plain covers
  111. ls1/ls6 headers for 5.3 vortec ??
  112. us a Mp t70 big egnough for a 6.0
  113. LS3 in a 1969 camaro Vac Lines
  114. LSx/4L60e recommendations for an miata
  115. forced air design
  116. 1st startup.......need help
  117. LQ4 or LQ6 to 2002 Firebird 3.8...
  118. LS1 '35 sedan does "Route 66"
  119. Need some Serious Wiring help please!
  120. LT1 faster than a 5.3
  121. 05 GTO in S14 DBW throttle wiring help
  122. Corrected interference with power steering pump and chassis
  123. New Vid '78 Caprice 99 LS1 TH350 373 gears
  124. Help Ls1 S13 Please help!!!
  125. '65 Buick Special conversion- it has begun!
  126. E40 ECM with 98 Corvette Pedal
  127. Question about Rockauto/Spectra EFI gas tank
  128. New vid - LS1 swap 64 Imp SS
  129. lt1 6speed 98 S10?
  130. Z-Bar ball stud to block relocation?????
  131. G-Body Frame Notch Detail in 1955 Chevy Truck
  132. heads/cam LS1 into a 1968 Firebird
  133. when swapped for a 6.0. whats your MPG
  134. 5.7 to a 5.3 swap
  135. What knock sensors?
  136. MIL light
  137. Need help with 98 PCM pinout chart!!
  138. 5.3 vortec flexplate is it dished or flat?????
  139. need some bellhousing advice
  140. 04 vs 02 LS1 harness
  141. Already picked my motor, not sure on chassis
  142. 8.8" IRS in something other than a Miata?
  143. Speed shops in the MD DC VA area
  144. Carb Legal LS1 Headers for S14
  145. What cars can I cut the injector clip off to match LS1?
  146. Dumb ABS question
  147. going from DBW to DBC
  148. 70 Chevelle-Canton or Moroso oil pan?
  149. F-Body Exhaust Manifold 3 bolt flange drawings
  150. LS2 into 1983 Mercedes 380 SEC
  151. LS2 24x problem
  152. Need Help PS Question for a LSX C4 Corvette Swap
  153. 66 chevy II ss ls7 conversion Help
  154. The goldyloxx thread (lsx into 1980 camaro)
  155. Alternator clearance on A body- 600 box
  156. Has Anyone done a BMW E38 LSX & T-56 swap yet?
  157. LS1 stalling off/idle then back to idle
  158. 5.3 dod swap questions
  159. LS1 into 95 tahoe... Help please
  160. WTB: Mustang coupe / LSX
  161. finding an engine in so cal
  162. 5.3 in my 93 chevy truck
  163. 69 camaro conversion
  164. Question on LS3/7 Air Filter Assemblies
  165. 5.3 wiring question
  166. keeping factory gauges options? 72 chevelle ss 4160E
  167. Who is using a remote electric pump?
  168. Which stall converter should I use?
  169. Ls1 into 95 Buick Roadmaster Wagon?
  170. Aftermarket Kit Inner Fener Panels!! Nova Clip!
  171. Carb'd LS1 edelbrock intake w/ign box
  172. ISIS Intelligent Wiring -
  173. gauge fittings
  174. 6.0 lq9 swap in 55 chevy
  175. 99-02 pcm
  176. Help will not run
  177. where can u buy stock oem ls1 parts?
  178. LS1 K-member
  179. What does this do?
  180. Using old coolant temp sensor on passenger side head
  181. Any known LSx --> Z4 Swaps?
  182. Wish my car would co-operate
  183. Camaro LS3 has arrived for my 65 Malibu
  184. CTSV Shifter conversion
  185. 1994 RX7 5.3 swap
  186. ls1 id
  187. LS2 to 200-4R swap with electronic throttle, is it possible?
  188. LS1 into a CJ7 Jeep
  189. XFI? Stand Alone GMPP or Modded Stock.
  190. howmuch h.p. will a msd 6010 handle
  191. Exhaust manifold choice?
  192. NEW Video, LS2 V8 Miata
  193. 6.0 l with ls2 manifold
  194. Fuel system set up
  195. 4l80e problems
  196. I think i might have to get rid of my aluminum 5.3 l33....
  197. LS2 Harness
  198. lt1 to ls1 wiring harness
  199. Heated O2's
  200. LS1 or 6.0L
  201. 08 5.3 LMG DBW requirements
  202. Anyone have a template for e36 ls1 motor mounts?
  203. 5.3 87 TurboII build
  204. LS3 Oil Pan -vs- Fbody Pan?
  205. what is an el camino classified as
  206. Question: LS3 T6060 G8 GXP vs T-56
  207. ready for my belt setup
  208. Fuel question.
  209. non ls engine in a 2000 camaro?
  210. 5.3 Torque #'s for intake and valley cover?
  211. Blueprints for mountings
  212. 4l60e PNP switch
  213. Installing 5.3Vortec and 4L60E in 71` LeMans
  214. Holy exhaust!!!!!!!!!!!!!!!!!!!!
  215. Thunder Racing/still open?
  216. LT1 pressure plate bolted to LS flywheel?
  217. LS2 knock sensors using my Ls1 harness ?
  218. Low oil pressure switch and inline pump starvation?
  219. Which filter to use ahead of Walbro inline pump.
  220. 1937 Ford LS2 Install
  221. need to do crank angle relearn, but i have no brake signAL SWITCH
  222. 1st Gen Datsun Z car LSx Swap In-Progress
  223. My 88 coupe slowly getting put together.
  224. Is A LS1 Throttle Body Block-Off Necessary???
  225. F-Body Steering
  226. need the camaro fan motor diagram.
  227. 2 questions, intake elbow and idle return?
  228. before build wiring problem
  229. Need help quickly installing the crankshaft!!
  230. c5 ls1 into 95 Z
  231. lq9 in 93 1500 2wd scsb
  232. Time for a swap
  233. injector connectors
  234. Throttle cable?
  235. 66 Nova Ls1 6 speed SWAP
  236. 81 elcamino or 86 short bed swap
  237. trk manifold w/thumper cam LQ4
  238. WANTED: fuel pump wiring schematic
  239. plastic truck fan
  240. LS1 wiring logic
  241. Ls fox with C5/C6 exhaust manifolds???
  242. GTO vs. F-Body compressors.
  243. Which exhaust manifolds?
  244. second engine same f'd up issues.
  245. Aluminum Bellhousing for LS1 T56 Camaro Trans Am GTO
  246. Ls1 Mustang Brakes
  247. Waterpump outlet
  248. Identify a 6.0 or 4.8/5.3?
  249. ATI procharger for a lq4
  250. A-body gas tank question
