PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Gen V l83 swap into 1965 c10
  2. A/c and gauge wiring
  3. New LS swap radiator, have to fab a shroud. 1 16" fan or dual 12" fans?!
  4. 06 5.3 into 80 trans am
  5. 2009 5.3 to 2013 L94/6l80
  6. New Guy Question
  7. Question about LS1 Tremec Magnum Swap in 1982-1992 Camaro
  8. Power door inside switches and keyless entry
  9. Relocating oil filler
  10. 4.3 v6 to 5.3 ls missing connector?
  11. 1998 Z28 Dash wiring
  12. Blue green dbc harness?
  13. 71 cutlass Ls swap
  14. 85 RX-7 13:1 Junkyard Screamer with ITB's
  15. 4.8 Swap
  16. Trying to do a t56 swap
  17. Please Help! LM7 5.3 Not Starting
  18. 4L60E TCC Not Engaging in LS Swapped TJ
  19. LS Swap Radiator for a 67 Chevelle
  20. yet another budget harness question. 24x vs 58x, trans plug, throttle body?
  21. L92/ls3 swap
  22. 1996 Camaro ls3 swap
  23. LS SWAPPING “12 BMW 750li. Need tips and advice
  24. ls1 Dash harness in 55 chevy help
  25. C5 Corvette LS into 3rd gen?
  26. radiator height and steam line
  27. LS3 swap, fuel pressure issue in fuel rail
  28. K10 4x4 swap 2 pin alternator wiring
  29. VVT with manual transmission?
  30. Cam sensor
  31. OEM Steam Crossover adapt to 4AN
  32. Wiring Harness Question
  33. Lq4 Holley Terminator x not cranking on new computer
  34. Can I detune a stock LT1?
  35. 1991 G20 LS/4L80E & 4WD swap!
  36. Mixing GM power steering pumps with a Ford rack. Self induced problems?
  37. Holley Terminator Max and 6l80e manual shift
  38. Oil pan for swap ls to 70 Camaro
  39. tahoe dash in a corvair
  40. LED light door switch light
  41. 98 z28 replacement engine
  42. LS3 Crate Engine 430 and 540HP
  43. LS7 swap and starter motor heat soak
  44. Surge Tank Question
  45. LS3 530hp Swap
  46. 5.3 vortec to a stock powerglide
  47. Anyone using aftermarket fuel rails with Dorman LS2 intake?
  48. 1989 jeep grand wagoneer
  49. OBS LS Swap
  50. E38 / E67 With T87/A
  51. Beware of John's Custom wiring
  52. GEN V LT1/L86 Swap in foxbody questions
  53. Tach dropping out after LS3 swap - yes I searched :)
  54. Camaro 6.2 engine to Silverado
  55. Ethyl the Shamelss Hussy
  56. Harness truck vs car
  57. 98 2dr Tahoe Sport 5.3ls turbo
  58. Fuel Relays being killed - Help :)
  59. 94 caprice LQ4 swap
  60. 6.0 truck build
  61. 84 Rx7 - 13:1 SBE 5.3, ITB, CD009, 8.8
  62. MAT sensor location?
  63. 4L60e (70 or 75) dreaded 1-2 hard shift when warm
  64. How to swap a GenIII 4.8 with a GenIV LFA 6.0..I'll hold the flashlight for you!
  65. How to swap a GenIII 4.8 with a GenIV LFA 6.0..I'll hold the flashlight for you!
  66. Coolant coming out of over flow
  67. LS1 T56 FC3S Ran for years - no fuel pressure - videos
  68. Wild Frankenstein of a Crew Cab
  69. 2002 Suburban dual fuel tank sender help...
  70. New guy, 1st swap
  71. Smog legal 5.3 advice
  72. Guidance on manual swapping a CTS-V2
  73. C5 PCM Questions
  74. Ls swapped 61 impala , questions
  75. Foxbody cruise control
  76. 2017 Caprice PPV wiring and pin outs
  77. Ls3 / 6l80e conversion
  78. Ls3 376/480 initial start up issue
  79. 1953 Chevy pickup AWD build
  80. B Body LS swap brackets - Impala Caprice Roadmaster
  81. 1966 Catalina LS1/T56 swap
  82. C5 Engine Fuse Block
  83. Wondering about dimensions for a swap
  84. Ls1 6 Speed to auto
  85. Vette fuel regulator / 94 Caprice
  86. V6 to v8 swap harness problem
  87. 0psi of fuel pressure but car runs
  88. c1500 5.3 swap
  89. GM OBS Pass Through Under Coolant Bottle
  90. Scratch or crack? cylinder sleeve
  91. Is this my LS376/480 crate engine's manifold vacuum port?
  92. Air Con Nightmare! - Fittings and connections help needed!
  93. Pistons
  94. Help with wiring LM7 w/ 4L60E tranny.
  95. 2011 6.0 l96 high idle on startup
  96. C10 era (63-66) front suspension info
  97. ‘67 C10 shorty part II
  98. Ford starter relay
  99. Another clutch switch question
  100. Gen 3 to Gen 4 6.0
  101. 06 dakota 3.7l swap with a 5.3l v8 from a 93 Buick roadmaster?
  102. I feel dumb LS Manual swap in LT
  103. A body oil pan question
  104. Stand alone wiring and engine internal changes
  105. Will a gen v 6.2LS flywheel work on gen IV 5.3 ls
  106. Accessories layout for twin turbo LS?
  107. Need som comments on the driveline setup on my restomod project
  108. Nissan with LS1 - won't go past 6000 RPM
  109. 72 Malibu LS swap & D1SC full build
  110. 50 Olds 88 resto mod
  111. 66 Nova swap cooling system and front accessory setup.
  112. Steam vent connector Questuons
  113. Cheaper option to fuel and oil pressure sensors? Terminator X
  114. Swap into a 69
  115. Fuse Amperage for Standalone Fuse Box
  116. 66 Chevelle LSA Swap Near Finish Line
  117. Sinister Land Rover Defender Restomod Comes With LS3 Power
  118. Solved: C10 LS swap Terminator X no start issue
  119. Idiot light temp switch?
  120. Closed Loop but O2 sensors Not Ready
  121. Corvette batwing oil pan filter replace
  122. Gen v lt4 engine to 1994 firebird
  123. LS1 to 4L60E
  124. L92 dressed like a LS3 cooling
  125. 1976 Trans Am Full Build.
  126. Datsun 260Z SS All Wheel Drive build
  127. 1980 6.0 LS with 4 speed Muncie.
  128. LQ9 Alternator Wiring
  129. LS Swapped First Gen Monte Carlo’s … where are you at?
  130. 24x reluctor wheel (Suburban Cummins conversion)
  131. What Ratio T56 Magnum to go with?
  132. 4l60e trans identification help E36 ls swap
  133. Wrong Size AC hose
  134. Reflashing ECM/TCM
  135. 2003 Silverado 5 speed 4.3 to 4.8 seap
  136. Stalls when I switch to reverse
  137. What is this hose for?
  138. HELP hood clearance 70 Monte need help ASAP
  139. Choosing DBW parts to LS1 swap
  140. Money shifted, thoughts?
  141. LS Swap 4x4 Wiring Questions
  142. ls3 crate engine issue
  143. 67 Camaro LS Wiring
  144. Need some help
  145. ZF8HP Transmission swap
  146. Difference between a 99 3.8 V6, and a 95 3.8 v6GM wiring harness.
  147. 06 GTO swap into 68 Firebird
  148. Adjusting Trailblazer Shift Cable
  149. Connect and cruise Wiring diagram
  150. 2014 Camaro Helms Manuals
  151. Start no run
  152. LSA swap High IAT
  153. 1969 Mustang fastback
  154. 99 silverado 4x4 chassis swap onto Studebaker
  155. High idle with 0 IAC Counts (solved)
  156. Changing pulleys on a Sanden 508 compressor
  157. 2003 5.3 ls swap fires up and dies instantly.
  158. LS1/4L60E swap
  159. LS7 Belair AAW,Connect and cruise
  160. 5.3 L59 swap initial start up issues
  161. LS1 Swap with 2010 Camaro Console Gauge Pack (wiring question)
  162. 1984 Monte Carlo help!!
  163. ECU not sending signal to Fuel Pump
  164. Help with 4L75e - Slipping
  165. Transmission and transmission vodo!
  166. Chevaro is getting close
  167. turbo 4.8 swaped S10
  168. 04 GTO Alternator Diagnosis Help
  169. 370ci GEN3 6.0L LQ9 being built, forged rods/pistons, then for sale. 24x or 58x??????
  170. CamMotion cam spec for 6.0l L76 into an old Land Cruiser
  171. Prepping ls2 for insertion into 67 nova
  172. Swapping LS1 into Lt1 car
  173. 4th gen LT1 to LS1 and A/C Conversion
  174. Gbody 5.3L Oil Pan
  175. Making an oil pressure sensor work with a Land Cruiser Gauge
  176. Lq9
  177. 2006 Gen III 5.3 in a 99 Silverado
  178. Gen 4 5.3/ 6l80e swap help
  179. New here and need some help with a 8.1L swap into 84 C10
  180. 98 formula t56 swapped to a4
  181. Twin Turbo LS3 Powered 1971 Camaro Restomod Is A Masterpiece
  182. Clean air Dirty Air
  183. i have a 2012 lc9 5.3 liter all aluminum that came from a 2012 gmc yukon 1500 xl
  184. Turbocharged LQ4 GMT400 Suburban
  185. Calling all ls swapped a-body guys!! (64-67)
  186. 3.8 to 5.3 lm7 swap thread
  187. F-150 LS Air conditioning
  188. BMW swap: Extend mounts to make everything work or TR6060?
  189. 1965-70 Impala headers?
  190. 69 C10 LS upgrade Turbo placement + intercooler setup
  191. 99-02 v6 to v8 swap dbw 05+ 5.3L
  192. Stunning 1954 Chevy Pickup Restomod Boasts 630HP LS2 Mill
  193. PRNDL & Factory Tacho, Speedo and other Gauges Wirring
  194. I need an air intake for my LS376/480 swapped Foxbody coupe
  195. O2 sensor plug adapters
  196. 06 4.8LS swap to 70 ford f100
  197. 1994 impala ss 5.3 quick swap?
  198. First LM7 Build, need some help
  199. 243 heads on a stock ls1
  200. LQ9-Powered Chevy K20 Silverado Is Refreshing Restomod
  201. LS Swapped Genesis Coupe Help?
  202. GEN 3 6l80e
  203. Dastun 260Z "LS" / manual trans build
  204. Why does everybody who does LS swaps on 240’s get rid of them?
  205. AC pressure switch for fans
  206. 6l90e/gen3
  207. L33 swap in la vehicle
  208. 1965 Ford Galaxie Wagon Build
  209. LS3 stays on after "key" off, but only when warm
  210. Swap
  211. Stock fuel pump bucket in old school GM tank
  212. LS1 intake on LQ4 question
  213. TBI to Terminator X Maxx speedo
  214. 4l60e issies
  215. What engine perch?
  216. LQ4 with LS1 intake B body swap wiring questions
  217. LS SWAP A 2010 Dakota 2wd v6
  218. TR3550 to LQ9 Clutch
  219. 1996 Nissan D21 Hardbody
  220. New dual electric fans wont activate
  221. Well it's my turn to throw my hat in the LS Swap Ford Ranger Ring. LQ9 in 2007 2WD
  222. CANBUS Reverse Switch/Neutral Safety Switch
  223. Do I need to remove head.
  224. suddenly runs rich
  225. LM7 in 1966 Skylark - DBW Issues, Now Won't Start. Help Troubleshooting?
  226. Who can make a custom accessory bracket?
  227. Speed Engineering Oil Pan
  228. 5.3 TR6060 air gap?
  229. 1964 Dodge A100 pickup. Little Rusty Wagon
  230. 2011 Camaro RS swap to V8
  231. 5.3 into f-body having alternator troubles
  232. Gen 4 swap AC
  233. 1964 Galxie 500 LS swap
  234. 03 Silverado
  235. 280z swap starting issue
  236. L33 tune on 12589161 h/w not accepting Analog A/C request on blue/green ecu?
  237. 1964 Chevelle LS swap headers
  238. Anyone know the former owner of this 6.0 Swapped Geo Tracker?
  239. Battery drain after LS1 swap in Camaro
  240. 70 Camaro. LSx/ 4L80e swap ?
  241. Fan control for aux condenser fan
  242. L76 manual
  243. Wot won’t shift from 1st to 2nd
  244. PCM cooling fan trigger
  245. retro valve cover and pcv
  246. How do you completely remove any coolant from the block?
  247. Pulley alignment issue
  248. Cadillac Escalade engine swap from l94 to l92 help :(
  249. Gen 5, LT4 wiring
  250. LS3 Swapped C2 Corvette Restomod Is One Irresistible Machine
