PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175
  1. Just exactly HOW MUCH of my 4.8 could be used on a ls1?
  2. LS1 VDO oil sending unit.
  3. Into to the hybrid forum
  4. does anyone have a pic of ls1 modified for headers?
  5. PCM Mounting
  6. Tremec M10 question
  7. LS1 instalation price???
  8. 69 Camaro LS1 Motormounts
  9. The perfect camaro for the Beach!
  10. Anyone have the harness pinouts and etc for the 99+ GM truck motors?
  11. question aboot the porsche hybrids
  12. Power Steering Delete
  13. LS1 Swap FAQs
  14. Admin, we need some stickys!!!!
  15. What year is my motor?
  16. ls1 into 90 c4 vette?
  17. Grand Prix to LS1
  18. wheels up! photos & videos from the track
  19. AFFORDABLE custom fuel tanks?
  20. LS1 powered RX7 convertible on Ebay
  21. Dimensional differences between LSx oil pans?
  22. 4l60E and converter
  23. conversions?
  24. painless first gen question
  25. stcok k member with ls1 motor???
  26. '98-02 F-body LS1 fan/shroud dimensions?
  27. whats shakin fellas - 78 le malibu ls1 conversion
  28. voltage range on ls1 oil pressure sensor
  29. s10 what tranny?
  30. Finaly the swap has STARTED
  31. 93 silverado engine swap?
  32. 3rd gen LS1 air cleaner
  33. fan and a/c hookup questions, Speartech harness
  34. 66 Nova LS2/T56 project
  35. LS1 in 86 LX Coupe
  36. Ls1 S10?
  37. HPTuner question
  38. 6.0L Swap Cost Help
  39. '03+ throttle
  40. 55 chevy LS1 transplant
  41. Tb Question
  42. Project "LSZ"
  43. Attn Renegade: ever considered a G50 for your LS1 swap kit?
  44. has anyone tried the LS1 HVAC box in a 67?
  45. 3rd gen Throttle cable
  46. From start to finish...what's a good gameplan?
  47. Paging John at speartech!
  48. 1986 RX7 -> LS1/4L60e swap *Big Pics*
  49. straight water necks
  50. Carbed LS2?
  51. HPTuner
  52. Some wiring questions to throw out there...
  53. How do you make an LT1 IROC-Z??
  54. 68 C10
  55. What year do I have?
  56. 2005 Chevy Silverado
  57. clutch disengagement problem....
  58. 10.9@124 ls1 rx7
  59. looking at doing ls1 in 64 nova need more info.
  60. what are yall doing for fuel tanks/pumps?
  61. who has modified their own ls1 harness?
  62. Front Springs
  63. LQ4 6.0L swap into my 67 chevy pickup, pics at link inside
  64. Just picked up a nice 92 Fox Coupe
  65. belt size when no PS or AC
  66. 3rd gen LS1 guys... what front springs you running?
  67. LS1 into a cutlass supreme?
  68. 5.3 Vortec swap in 98 S10... with a twist
  69. 1997-1998 Corvette Fuel Rail and Regulator Part Numbers
  70. how to wire ignition early GM ignition switch
  71. Look what just came back from the paint shop!
  72. Please don't laugh
  73. Rear 4 Link Clip for unibodys?
  74. Twin turbo LS6 in a sandrail
  75. TRANS DAPT motor mounts SUCK
  76. How hard to mate a T56 to an SR20DET or RB25DETT ??
  77. Whats the best route?? Need info please!!
  78. trying t56 trans w/ 99 tacoma 4x4
  79. LS1 swap in a 3rd gen- AC line question
  80. fueling help please
  81. Im F*&^%D, look inside Texas people.
  82. LS1 in a thirdgen with a twist
  83. Can I use a 700r4 with 3rd LS1 swap?
  84. Viper conversion question
  85. 87 regal grand national clone ls1 swap
  86. 98 LS1 into 94 Chevy pickup
  87. how to wire up alternator
  88. What fuel tank to use in rear of 64 chevy pickup
  89. Looking to do a Jag XJ6 > 5.3/4L60e swap...
  90. Engine Question
  91. LSx to Replace SBC - General Questions
  92. Need Feedback on Conversion
  93. Want to Convert to LS1 Engine
  94. For those of you running 01-02 LS1s - question -
  95. Is there a smaller coil available for an LS1?
  96. 240z with ford 9" rearend for sale
  97. 5.3/4L60E in a 1983 coupe deville (RWD)
  98. If you have done a LS1 into Fox body stang.. come in
  99. Swap questions
  100. Needed - K&N FIPK AIR pump filter
  101. 98 V6 Camaro to heavily modded LS1
  102. Extreme gauge conversions?
  103. 67 camaro/LS1. where did you mount your computers? PICS??
  104. 6.0l and 4l80e are in the Chevelle
  105. Who's gonna be the first??
  106. Starter problem
  107. Ls1 into 1992 S10
  108. mid mounted ls1 with t56 transaxle
  109. Its alive!
  110. FINALY LS1 3rd GEN HEADERS!!!
  111. 72' Chevelle with 5.3 questions
  112. LS1 fuel pressure...YIKES!!
  113. searching for a non-ls1 hybrid...
  114. Who here is buying a Solstice/Sky and putting an LS1/LS2 in?
  115. A/C Compressor wiring
  116. Just bought a 99 Z28, what should i keep?
  117. I screwed up, forgot temp sensor
  118. 1972 monte carlo swap
  119. LS1 Karmann Ghia
  120. 2nd gen camaro pcm mounting ideas
  121. ls1 rx7ers here...
  122. Thinking Of LS1 into a notchback mustang?
  123. air intake question-'67 el camino ls1m6
  124. Brake Servo connection to LS
  125. 1991 Oldsmobile Cutlass Supreme
  126. 91 swap Q's
  127. super lightweight sleeper?
  128. Exhaust question!
  129. LT1 to LS1 conversion
  130. Need some info..
  131. MIL bulb or LED??
  132. T56 into a non LS1 1st gen Camaro??
  133. LS1 3rd gens
  134. LS1/LT1 into A 93-97 Firebird
  135. can a 2002 pcm handle lighting a bulb instead of an led?
  136. 8.1 in a second gen Camaro???
  137. Just A Heads Up
  138. '65 Chevy II
  139. mechanical speedo on T56
  140. 2nd gen headers
  141. 1957 Chevy
  142. Anyone using VDO speed sensor?
  143. LS1 Transplant won't start
  144. Fuel Pump Help!!
  145. Mercesdes with V8?
  146. LS1 in 77 Corvette - Help with questions
  147. 93 fullsize chevy 1500 ls1 conversion need headers
  148. Fuel Delivery Questions
  149. MAF's interchangable for my 6.0?
  150. block hugger/street rod headers pics?
  151. shortest water pump- Meziere- LS2?
  152. ls1 RX7 11.4@121 cam only
  153. Got one!
  154. PCM Connector Pins
  155. ditch the electronic throttle?
  156. Gauge ???????s
  157. Is there a better way out?
  158. Las Vegas weekend for the "project"
  159. Thinking of an turbocharged LS1 Mustang Notchback
  160. LS1 spotters guide
  161. spy pics
  162. nice ls1 s10
  163. Is it possible to make a 96 LS1 Lumina?
  164. plug and play harness
  165. Its Alive!!!!
  166. 240z Lt1/t56
  167. Options on Fuel System -- Return Style vs. Non Return
  168. Anybody need an electronic throttle?
  169. SpearTech TELE#
  170. edelbrock ls1 carb kit question ???
  171. 2nd gen T/A
  172. LS1 into 02 v6 firebird
  173. how difficult to swap ls1 into bmw z3?
  174. Who makes converter for 4 cyl to 8 cyl tach signal conversion?
  175. Anyone know a company that can make custom lines/hoses?
  176. LS1 with LT1 T56 and clutch, possible?
  177. Who cna do a plug and play wiring harness? LS1 into 97 V8 Camaro
  178. HP and TQ numbers
  179. My Baby
  180. I need some actual f****** torque specs
  181. I did IT!
  182. ls1 in a bonneville ssei
  183. ls1 in a Prelude?
  184. cruise control...
  185. LS1/T56 into '64 Chevy C-10
  186. Using C5 Vette suspension. How do I get all the factory pickups to retain geometry.
  187. 355 in rx7 - headers?
  188. PCM question
  189. 4L60E Camaro Trany VS Truck
  190. LS1 into 1993 4cyl Camry
  191. LS1 in 240sx..help
  192. Block hugger headers
  193. mustang guys help
  194. third gen upgrade to a fourth gen
  195. Which gas tank was it that swaps into a Chevelle?
  196. pinion angle
  197. Ls1 in to LT1 body
  198. 355ci Help.
  199. For Sale??????
  200. LS1 86' Monte..would u do EFI or carb ?
  201. Thinking about the M6 swap I am going to be doing.. Questions..
  202. Finally....IT'S ALIVE!!!
  203. cooling system
  204. turbo ls1 in an ultima
  205. LS1 in a RX7
  206. 1st gen ls1/t56 conversion
  207. I've got an idea in my head.
  208. Some swap related parts for sale
  209. Camaro posi in S10 truck rear ?
  210. Ok, VERY wierd problem...need help
  211. second gen headers
  212. Might be selling/parting out my LS1 powered Regal
  213. Motor mounts in 95 chevy 4WD pickup
  214. driveshaft swop 3rd gen
  215. Wiring questions, just real simple.
  216. MSD Shift light hook up
  217. 2wd to 4wd
  218. Anyone have the part # for the S-10 PCM mount?
  219. If I convert my 68 Camaro Vert to
  220. s&p motor plates
  221. 2005 6.0L in iroc-z
  222. Any one ever Try 4th gen camaro headers on A first gen swap??
  223. ls1 3rd gen headers
  224. Turbo LS6 Power into a 1992 AWD Typhoon ***Pics 56k beware***
  225. Interior Wiring Diagram
  226. bell housing???
  227. Anyone been able to use the Electronic T.B.?
  228. LS1 in a 63 impala
  229. Yes, its a talon with an ls1.
  230. LS1 vs. LT1 conversions
  231. Need part # for EGR plug
  232. E30 M3 LS1/ls6 emissions...?
  233. what to do 1st? Computer or heads,cam,etc
  234. Bmw M3 / 02 LS1 T56
  235. ls1 ecu on caddy motor
  236. Please tell me if I am crazy
  237. vortec to ls1 manifold?
  238. 02 camaro brakes on 69 camaro
  239. Fuel return info
  240. carbed ls1/new model s10
  241. Cheapo air filter to connect to MAF
  242. New best of 11.73, but.....
  243. LS1 mini starter motor, same as SBC?
  244. New Style LS1 and Gen three mount
  245. 3rd Gen Ls1 Tubular K-member and Spohn Tubular A-Arms
  246. Quick Change Rear's...?
  247. Need Opinion LS1 BMW 5/7 series
  248. LS1 in a Miata???
  249. steering column wiring question
  250. LS1 in a 93 Vette
