PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Wiring up a LS1 Gauge cluster in a 94 Z/28
  2. Autokraft pan with a corvette windage tray
  3. drive by wire vs. cable throttle---throttle response
  4. 4L80E tranny to fit mustang shifter
  5. Z32 300zx - LQ9 swap
  6. Chasing head bolts
  7. Just another turbo 5.3 in a lt1 bird build
  8. Another MLPS switch question
  9. power steering pump questions for lq4?
  10. Need fuel system help/advice
  11. Questions / preferences
  12. How Do I figure out if I can do Cable throttle with my ecm?
  13. LS2/LS3 valley cover seals/gaskets??
  14. Emissions on LSX conversions in CA or NJ?
  15. Reverse Lockout
  16. Starting a second LSX 3rd gen Camaro swap - '89 IROC-Z
  17. Best Carb for LS?
  18. 68 Nova 4L80E
  19. What mounts work for me?
  20. Ls1 miata
  21. Some ls1 parts for u lsx project builders.
  22. New formula project!
  23. need help what is good cam for 4.8lsx
  24. Auto meter gauge swap
  25. LS1 to t45 5speed Pilot bearing
  26. LS6 Intake Question
  27. TR6060 & LS3 in a 69 Camaro
  28. what dbw pedal can i use?
  29. fastest single turbo ls1 notch back?
  30. anyone in socal to swap my cam?
  31. Need Advise 6 Speed for an LS3 in an F-Body
  32. My Daily driver S10, 5.3l
  33. My 95 S10 Nitrious 5.3 Drag Truck project....
  34. New Modified Magazine../Super Street? LS Conversion
  35. New Modivied Magazine../Super Street? LS Conversion
  36. Thinking about a DD Third Gen Nova...
  37. 68-72 a body.What kit works with an f-body oilpan?
  38. Truck harness
  39. ls7 on F-body
  40. Which MAF's are 5 wire w/built in IAT?
  41. Fuel Shutoff in accident?
  42. LS fox header pics.
  43. DBW / TAC wiring questons
  44. LS1 Powered BMW 325i
  45. need longer shifter cable
  46. Some exhaust manifold measurments
  47. adding to the collection, Typhoon 5.3/4L80E turbo build
  48. 1963 Impala Convertible LQ4/80E Swap
  49. alternator relocation
  50. 89 Notch which mounts?
  51. Move that Alternator??
  52. Weight differences in 5.3 Truck engines versus old school chevy?
  53. Any alternatives on bypassing VSS...
  54. 2002 5.3 PCM Pinout ?
  55. Help - need mini start length
  56. Wiring truck harness
  57. Calling all 67 chevelle Guru
  58. Intake Manifold Questions
  59. Fuel Issues / Starting to get my ducks in a row
  60. Swap Parts in FS Section
  61. water temp. location
  62. 92 Camaro RS LS1/T56. videos added
  63. 92 Toyota Supra 6.0lq4/4l80e
  64. 6.0L questions
  65. another 5.3 in an 85 c10
  66. Shifter relocate HELP
  67. Instrument cluster signals
  68. What is the guage thickness of the stock engine harness wires?
  69. New body style 5.3 wiring question
  70. Vortec Max....Good Motor....Good deal??
  71. 64 ss 5.3 4l65e
  72. best LS pan for my 69 Chevelle?
  73. stock mustang shifter with th400???
  74. Anybody using plastic/Aluminum radiators in A-bodies?
  75. Truck alternator wiring
  76. Nostalgia looking built LS2 in 69 Camaro
  77. 5.3 flywheel question
  78. Picked up an LS1 FD....
  79. Need Gen III bolt size
  80. wrangler JK, 5.3 no throttle dbw
  81. Lincoln Town Car
  82. 5.3 at a reduced price!
  83. LS swap but keep original gauges 84MCSS
  84. Has Anyone: LT1 To LS1 Swap Using LS1 Body Harness?
  85. LS1 Harness into LT1 Headlights
  86. Conversion LS1 Harness to Lt1 Fuel Pump
  87. re-working wire harness
  88. question how to convert a 00v6 camaro to ls1
  89. Best way to put Gen IV into 1999 Z28
  90. Wiring neutral safety switch with AAW harness and stand-alone
  91. PCM Reflash
  92. ls based engines in mustang chasis
  93. Need help with injector part numbers
  94. Didn't someone do a Procharged LSX in a Fox Mustang???
  95. lq4--ls2 clone...gen3 into gen4
  96. Found something for anyone with f-body acc. frame issues!!
  97. ls in fox alternator? with no ps.
  98. MSD 6012 question
  99. ls swap
  100. fox ls1 swap trany question
  101. LS1 in my 55
  102. 08 4.8 Harness
  103. Anyone used these Edelbrock Headers?
  104. lsx miata question
  105. Lsx miata
  106. Any experience with the new retro LSX oil pans
  107. 1986 MK3 Ford Capri (UK Car)
  108. Mustang 6.0/L92
  109. Skyline R33 getting LS1 / t56
  110. Possibly thinking about a LSx in a S10.. looking for some information
  111. LM7 in a 99 S-10, Guage help?
  112. Merry Christmas everyone!
  113. 5.3 wiring harness
  114. Questions about LS1 power steering hose attachement to a older 76 gearbox
  115. 81 Zephyr -Big Pimpin-
  116. fox body guys help
  117. Pics of the LS6 Tj
  118. LQ4: cold air vs complex intake routing
  119. alternator hookup CONFUSION
  120. Are my valve springs shot?
  121. will a ls3 w/p fit a lq4 with stock acc
  122. Im needing some advice
  123. Strange power issue
  124. anyone make Homemade Solid motor mounts?
  125. 70 chevelle- ly6 /4l80e vvt boosted
  126. Modded oil pan - losing 2.5 cups capacity??
  127. Compression Fittings
  128. Anyone Good With EFI Live???
  129. ANY help
  130. LS3 L92 dual plane carb intake
  131. PCM connectors
  132. post pics of your turbo fox
  133. engine harness
  134. hydroboost with drums only?
  135. LS7 into a solstice
  136. Stock ls3 cam
  137. ls1 maf to 5.3?
  138. Twin LQ4s in 30' Scarab on the cheep!!!
  139. 1984 Corvette "LS1" Engine Swap/Build
  140. Bolting 4l60E to 5.3 Problem
  141. Non LSx (yet) fiero need help
  142. G-body insight
  143. To anyone in KC looking for an engine, I DO NOT recommend Midway!
  144. AFM or VVT with a manual transmission
  145. LS conversion...engine & trans opinions?
  146. ls1 monster questions
  147. 5.3 in a 98 blazer questions or info
  148. Anyone know of a good source for trans tunnel/firewall heat shiedling(self adhesive)
  149. What ECM????
  150. Short Style Oil Filler Tube
  151. map sensor & 6010
  152. When did trucks start having DBW TB
  153. 2nd Gen. Camaro Owners
  154. Finally, it runs !!!!
  155. ls1 swap into 94-up firebirds air intake
  156. Jeep XJ 5.3 finally tested (video)
  157. oxygen sensor help!!!!!!!!!!!
  158. Exhaust flanges
  159. ok guys need help a.s.a.p Found a harness i need to know what all to pull.
  160. Need PNP (park neutral switch) wiring diagram or pin outs
  161. ARP LS1 rod bolt install into a 5.3L, need help
  162. How are you cleaning and detailing your 5.3 engine?
  163. best fuel rail ??
  164. rx7 7.0l v8 twin turbo build
  165. My 67 Camaro 5.3/t56 Writeup
  166. 2002 firebird swap
  167. Accessory Bling: Pulley Covers, Chrome, Billet, Paint, Etc.
  168. PCM for 5.3L to 4L60E tranny
  169. GMPP Distributor front drive users...come in.
  170. Anyone ever think about doing an LSX swap in a Porsche 944?
  171. Car Craft Magazine announces Engine Swap Drags Event
  172. 5.3 Idle Issues
  173. Engine controller choices..GMPP...speartec etc.
  174. PCM Tach output to original gauge question
  175. first start w/magnacharger
  176. 5.3 f/s
  177. Temp sensor questions?
  178. th400 or 4l60e
  179. Questions for the Fox guy's
  180. Bolt in LS1 swap kits for 4wd Silverado, K5 and GM trucks 1973-1987
  181. best radiator for a 67 camaro with 5.3
  182. LS1/4L60E E30? Has anyone done one yet?
  183. junkyard engine problem
  184. L98/L76/LS2/LS3 conversion - Knock Sensor Errors
  185. Another LS notch build
  186. 82 Corvette LS1 T-56 Swap Build Thread
  187. Will Any GM LS1/2 Oil Pans Fit a 69 Camaro Conversion?
  188. Has anyone LSx swapped a 3rd gen (73-80) C/K-10?
  189. LSX swap into a 83 Caddy Fleetwood brougham
  190. anyone running a carbed L92 setup yet?
  191. AJE Mustang Kmember-A arm question
  192. LT1 to LS1 Swap
  193. LS1 240sx with a problem - please help!
  194. Does anyone know if the Corvette DBW throttle body uses the same plug as the 4.3 DBW?
  195. 2005 LQ4, 24 tooth or 58 tooth reluctor wheel?
  196. S-10 Header Thread...
  197. Hacked Up Harness... Need Help to ID Wires
  198. fuel pump help please!!! 4.8l
  199. 4L70E with stock C4 tailshaft / VSS question
  200. need help with my fuel system.
  201. Truck died, need help
  202. Truck 6.0 with l92/l76 accesory drive questions
  203. Need Help From You 5.3L Guys
  204. Good deal on a 6.0L?
  205. 5.3 Swap; what am I forgetting?
  206. OBDII question
  207. Ls7 air intake, Hooker block hugger headers on my LS1 Studebaker.
  208. BRP mounts g body
  209. 72 nova ls1 swap
  210. What to check for when buying a pulled engine
  211. Calypso green fox Motown ls hybrid build
  212. Question on removing a fitting from a Corvette FPR
  213. Very basic fuel system question
  214. swap parts for sale: ls1 4l60e, 98 fbody pcm/harness
  215. Which accessories?
  216. finished 5.3 wrangler project, wont start!!
  217. DBW part compatability?
  218. Need Help with Autometer Tach
  219. Couple of errors and no tach
  220. Is anyone using the GMPP 19155166 accessory drive system?
  221. wanna build a lsx silverado got questions
  222. transmissio breather
  223. wiring diagram needed been searching
  224. How can I make this temp switch work on a 6.0?
  225. ECM Mounting locations - waterproof?
  226. Set back motor as as possible
  227. Which MSD to use on a carbed 6.0?
  228. 94 Ls1 powered Z28
  229. lsx fox need some advice.
  230. My Chassis has shoes!
  231. Something a little smaller than usual
  232. roller rocker?
  233. any dyno numbers with th400
  234. Injector connector question
  235. Dirty Dingo lsx adjustable motor mounts???
  236. LQ4 powered Batmobile
  237. truck engine in a 4 gen camaro
  238. What suspension/break system do you run?
  239. awd ls powered?
  240. Temp fitting?
  241. Removing Oil Filler fr Valve Cover
  242. foxbody LS/TH400 SWAP what driveshalf are you using ?
  243. New Russell fitting for Vette filter/regulator
  244. vette fuel filter fittings
  245. LS1 T56 purchasing advise
  246. 87 Buick GN
  247. what radiator A body conversion
  248. What PS pump
  249. Return fuel line help needed...
  250. Definite part numbers F-Body accessory drive anybody have them?
