PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Ls2 dipstick location
  2. intake air temperature sensor ls1
  3. 2013 Turbo Beetle 5.3/t56 swap
  4. Water pump, front accessory question...
  5. Swapping from NV4500 to 4l80e behind LQ4, one wiring question
  6. 74 Nova LQ4/4L80e Pro Touring
  7. LT1 to ls1 with T56 need info on connector 220 and 230 for manual
  8. Saikou Michi OCC on LS2 question...
  9. 1972 C20 BBC 402 swap to 5.3 LM7
  10. 1970 Chevelle Greenbrier Wagon - L96 w/6L90E
  11. Ls2 swap dbw throttle troubleshooting
  12. LS Engine angle question
  13. 8.8 rear for 62 Impala
  14. Difference in crank pulleys?
  15. Are all LS pilot bearings interchangeable?
  16. 1971 impala ls1 conversion
  17. Car fires then dies (neutral safety?)
  18. Boat Keeps Dying
  19. Coolant temp sensor plug
  20. ls6 harness swap question
  21. ly6 w/e38 has no coil or injector pulse
  22. t56 swap
  23. Battery relocation options
  24. Spectra Premium EFI fuel tank
  25. FirstGen S10/LS2/T56 Shake down runs (pics)
  26. 70 chevelle daily driver junk yard build
  27. What do I have LQ4 or LQ9?
  28. nova or 1st gen camaro fuel line questions
  29. Swapping LQ with LS1
  30. Jag XK8 w/ G8 L76 project
  31. where to buy ls dropouts in the surrounding Memphis TN area
  32. Project Turburban! (1956 Plymouth Suburban with a 5.3 and GT45 turbo)
  33. 62 Buick Special
  34. 24x or 58x help
  35. lq4 05-09 mustang s197 swap help
  36. Dakota digital oil sender
  37. 64 c10 ls swap radiator and fuel questions
  38. th350 to 4l60e c10 question about drifeshaft
  39. Little help with GM alternator ID?
  40. 2000 Isuzu Hombre LS1/T56
  41. '88 Fox Coupe. Bringin' it back to life.
  42. Oil pan modifying for GM "X" frame cars.
  43. 6.0L engine swap into an 1984 K10
  44. Oil Pan for 383 on 69 Camaro
  45. New guy LS1 questions
  46. LS 240sx build
  47. Need GTO T56 shifter coupling / will trade for f-body coupling
  48. Any experience with this radiator ?
  49. Hooker Fbody Swap, BAD EXPERIENCE
  50. Harness, MicroSquirt vs. Psi?
  51. Please help identify
  52. 4.8L LR4. Jeep CJ7 conversion
  53. PCM Wiring Question
  54. 1956 Ford F100 LS Swap HELP!
  55. LS 240sx Build
  56. Ls1 240sx cx racing oil pan problems
  57. all in 1 mount kit
  58. 84 Regal T Type needs new heart!
  59. Dbw to dbc with 4150tb
  60. Wiring question
  61. gen 3 to gen 4 swap questions
  62. MAF signal
  63. 98 GMC 3500 7.4 swap to 6.0?
  64. Consensus or Verdict for Shallow 6L90E Pan?
  65. 1987 gmc
  66. Ignition switch / starter wiring problem
  67. ls1 swap ran fine now no spark no fuel
  68. 1965 Cutlass engine mounting location
  69. volvo 960 LS swaper get in here!
  70. Gen3 + 300zx power issues.
  71. LS2 to LS3 Top end and getting full throttle
  72. mustang exhaust
  73. LS3 crank but start only if I press the pedal
  74. 4L60E Park Neutral Signal wiring, AGAIN.
  75. Whats LS1 conversion kit to use 68 camaro
  76. 1989 Chevy truck LS swap headers?
  77. LS3 430 / 4l65e -> Recommended converter?
  78. Engine stand question
  79. LS3/4L60E 1968 Chevelle
  80. LS/T-56 Swap into an Automatic C4...Can I use 4th-gen F-body Clutch/Brake Pedals?
  81. Wiring question
  82. Spectra GN tank
  83. foxbody ls1 with tr3650
  84. E38 cruise control?
  85. backfire in intake
  86. Ls swap, losing throttle response when warm
  87. wire harness identification
  88. 4.8 Fuel issues and wix corvette filter
  89. Any cheap fuse/relay blocks out there?
  90. ls7 in 70 Chevelle headers
  91. Wiring Question '60 Bel Air
  92. *HELP* Monte DBW pedal issue
  93. And so it begins...
  94. 98 K1500 5.3 swap
  95. 5.3 conversion project (66tempest)
  96. will a truck intake fit? '89 Foxbody
  97. Help with transmission decision
  98. 1988 Astrovan M-Body swapped with 98-02 F-Body LS1
  99. keep fouling plugs
  100. Looking for Lower Left Compressor Mount
  101. mustang fuel system
  102. Advise requested from fellow gear heads on listing price
  103. 5.3 truck engine into a 66 GTO
  104. 67 Bel Air LS Conversion
  105. 1964 C10 LQ4/T56 build
  106. Suggested drop on S10
  107. Starting your LS for the first time?
  108. 2001 jimmy diamond edition 4x4
  109. Fuel question, 2005 6.0 in a 88 Gand Wagoneer
  110. 58-64 Bbody help
  111. Corvette alternator wiring question/g body
  112. LQ4/4L80e build for 1993 chevy truck
  113. 5.3 into a 98 2500
  114. Fuel level from OBDii on 04+ S1500?
  115. 1974 mgb roadster 4.8 turbo 350 auto
  116. Speedo way off after swap
  117. LQ4 good starting point?
  118. 2 questions on DIY standalone harness
  119. 08 LH6 5.3 T56 swap questions
  120. Carb 5.3 S10 alternator question
  121. Trying to find the best SBC --> LS motor mount adapters for my Volvo
  122. 5.3 into 87 d21 questions
  123. Which motor mounts?
  124. Will a 4l60 from an i6 trailblazer work for my application.
  125. Do LS1s have water pump issues?
  126. 93 coupe mustang swap.....
  127. Found a Cruise Control That Works w/GenIV DBW
  128. A little overwhelmed, could use some insight.
  129. Swap Headers Suggestions?
  130. Adding a 2014 L83 5.3 to a Jeep TJ any suggestions?
  131. New Ricks (Resto Mod) Tank
  132. Injector Question
  133. LY6 4x4
  134. HELP!!! 700r4 flywheel hole issues
  135. Need pinout help 02 z06 harness
  136. Another Foxbody
  137. Swapping LS1 to 2000 GMC Sierra
  138. HELP!!!! C5 ls1 swap won't start....
  139. Hmm will this 4l80e fit? 72 Chevelle
  140. LS1 in an early 66' Ford Bronco
  141. PCV port in Air Intake?
  142. Playing a game of mix and match
  143. LS2/E40 computer wiring question
  144. Need pics of minitubbed 68-69 chevelle
  145. Going 4l80 or 6l90....goodbye T-56 setup
  146. What to look for in a JY LY6
  147. 5.3 swap into an XJ - I'm clueless on chevy motors
  148. Lower Radiator hose ?
  149. Throttle body EFI or Multiport
  150. best ecu for ls procharger engines
  151. Source for Good Fan Relay/Connector and other wiring supplies?
  152. F-body radiator
  153. Please explain cooling system...
  154. G Body Grand national 3/8 return line?
  155. MSD box problems
  156. LFX pinout spreadsheet
  157. Factory Five LS Daytona Coupe (Update)
  158. Nerd Rods: 32 Ford Roadster, Project Acid Test, C6 Suspension, LS, Turbo, Track Toy
  159. bmw 5.3 bogs when revs up (p1860)
  160. Cost of putting an LS in a suicide-door Lincoln
  161. For those of you using the Holley 302-2
  162. gas pedal controlled?
  163. Dash/Gauges Suggestions?
  164. low mount alternator bracket
  165. 5.3 Mustang HELP!!
  166. 1972 Chevelle LS with supercharger??
  167. Rowdy burnouts and loud noises: The LSX/Subaru swap project
  168. PCM power, single 40a relay?
  169. electrical experts needed please
  170. Any reasonably priced foxbody oil pan options?
  171. 2010 L99 Start up problems
  172. 03 DBW Question
  173. need help please.
  174. Key off kinda
  175. Should I paint it? G body
  176. 06 GTO LS2 Stand-Alone Harness Not Matching GM Schematics
  177. Fans running constantly with PSI harness
  178. Battery has less then 12v, Cranks but won't start, Is this normal
  179. looking for info on using 2004 truck 5.3 computer on swap. What has to be deleted
  180. LS2 Alternator Rear Bracket Interchangeability?
  181. gen 4 lc9 in 97 firebird. has it ben Don?
  182. foxbody guys with AJE K and coilovers
  183. Whats the market like for ls swapped vehicles?
  184. 4.8 in a 1950 Chevy 3100
  185. alternator help
  186. Drive by Wire or Cable
  187. Project: Venom....1985 Monte Carlo SS 6.0 swap
  188. Cam swap quick question
  189. dayco 71132 ???
  190. LFX Swap into 1957 B Body
  191. Question
  192. LS into '94 firebird, what radiator hoses?
  193. C6 2005-2009ish Audi A6 LSx Swap..........
  194. G-body guys. Check out this turbo kit
  195. Gbody LS Swap Hedman Headers P/N 45050 2" Primaries?
  196. 1965 impala ss carbed lq9 swap
  197. 78 cutlass salon 4 door swap
  198. Ls2 into 1997 - ECU Question
  199. CBM Motorsports 2015 Engine Catalogs Available
  200. LS1 Swap
  201. LS1 into 2003 ford f150 harley davidson need help
  202. 5.3 swap fuel line
  203. D&D K-Member - Anyone using one?
  204. DBW Throttle Body to DBC TB
  205. LT1 t56 to LS1 conversion?
  206. wanna use a cable throttle body with carb intake
  207. Does anyone have an Ls In 1984 corvette?
  208. Ls pcm question
  209. 6l80e wiring help please I'm stuck
  210. 1977 C10 5.3 swap fuel set up with stock tank
  211. question
  212. Pinging @ WOT
  213. Ls1 swap
  214. New turbo lsx project
  215. 2000 S10 408/4l80/s475
  216. VVT harness to non-VVT engine?
  217. How to tie my LS1 harness in to my car - PLEASE HELP!
  218. Rat rod lq4/4l80e. Need shifts help
  219. Cam card for Sinnister Cam
  220. Coolant Steam Hose to Jags That Run adapter
  221. 01 Camaro runs occasionally, or just cranks and backfires
  222. Built LQ4/T56 Combo into an '84 Grand National
  223. Need an air filter for this (pic)
  224. ls1 swapped rx8 wont go into 4th or OD
  225. Who has the best deal on a harness?
  226. 4.8 LSx Steam port routing/plumbing?
  227. Newbie D.I.Y. build; 5.3 swap in need of help
  228. Removing 1998 Fbody Fuse box harness that will be used for my 2nd gen swap- questions
  229. New Pro-M EFI Engine Management System for Chevy LS Engines
  230. T56 speed sensor problem
  231. what did you manual foxbody do with your MC?
  232. PCM Swap
  233. Airaid intake coupler system? What pieces do I need?
  234. Wiring E38 ecm/58x + Lincoln Mk8 fan + air conditioning?
  235. F-Body Front Disc Upgrade on 71 Monte with Front Disc Spindle
  236. Future LS1 Fan (240sx/240z/rx7)
  237. 1993 Jeep Wrangler 5.3 - 4L60E swap
  238. '83 Ford Ranger help...
  239. Engine Sources?
  240. Best way to clean the inside of the engine?
  241. Throttle Body
  242. Blow through 5.3 turbo ls
  243. Best 1 7/8" header for 1st Gen camaro. 4l80e trans?
  244. 1978 camaro 5.3
  245. LS1 Xtreme
  246. Power steering fluid
  247. Any FAST XFI 2.0 swaps?
  248. 1995 Camaro LSx Swap
  249. White Trash - 1985 GMC, 5.3 LM7/4L60e Swap
  250. 97 Vette LS1 questions
