PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Adding MAF to Stock Truck Harness
  2. 700r4 questions from a newb
  3. 'Round these wheels in 80 (?) days
  4. 5.3 S10 cranking issues
  5. LQ4 Express van Wiring
  6. 2017 in an 84
  7. LS with 4L80e into a 1972-1974 Mercedes 450 SL
  8. Front Sump Oil Pan Questions
  9. Man Details What He Spent on Porsche 996 LS V-8 Swap
  10. Modified harness- IAT has fixed reading(s)
  11. Battery cables and disconnect wiring?
  12. Which master cylinder to buy LS t56 swap?
  13. Simple Question on Vette idler
  14. 78 Nova LQ4 swap
  15. total cost for third gen camaro ls swap
  16. Truck tac & tb with Vette pedal?
  17. New Camaro steering wheel paddle shifter diagram
  18. ac fitting o-ring?
  19. 1974 C10 - fuel bucket?
  20. 4 wire Harness?
  21. 5.3 Fox Project - To Buy or Not?
  22. Lsx vortec s10
  23. S10 LS Hedman 45900 Headers
  24. Oil temp sensor w/fan powered oil cooler
  25. Explain the Alternator Wiring Please
  26. What trans for a supercharged 68 lemans?
  27. camaro build
  28. Engine heats up at idle
  29. 5.3 LS water pump recommendations
  30. tach output
  31. LS1 in the jeep
  32. First gen camaro, what size brake booster
  33. Question: LT1 K member with LS engine
  34. Flaring brake lines - opinions/thoughts wanted
  35. Ragged Ragtop 68 Malibu carbed LS3
  36. 1968 Pro Touring C3 with an LS7 Gets Wild
  37. vintage tachometer with LS?
  38. L92 + 6L90 wiring and ECU suggestions
  39. info on F body manifolds to S10
  40. Nice kit for swaps...
  41. 5.3 swap 91 GTA fuel system question
  42. 2005 ls6 6sp t-56 clutch upgrades available
  43. Help with 4l60e P1810 code?
  44. ls1 temp sending unit
  45. Vortec 5.7 in Mercedes W140
  46. Ridetech 4-link
  47. Power Steering Pump AN Fittings Size?
  48. Help with LQ4 start up issue
  49. fuel sending unit and electric punp
  50. LS Swap and Electric Fans
  51. 1986 G-Body LS2 Transmission Choice Help!
  52. Need help with body wiring
  53. Planning LQ4 engine @ 4r60 tranny into 1990 F-150… no, seriously!
  54. BMW e36 M3 - LS 6.0L wiring issues
  55. 1990 gmc 1500 4x4 vss
  56. Changing o2 connectors
  57. Emission? What sn95 to start
  58. wireing up stock tj amp guage
  59. Help needed L83 won't fire
  60. Ls 6.0 front o2 sensors
  61. Fuel pump over pressure
  62. ECU suggestions
  63. 1993 gmc yukon 4x4
  64. Steam Vents - whose fittings are these?
  65. looking for some solid advise on starting first project
  66. Steam lines?
  67. LS1 to LS3 coil wiring question
  68. Longest plug wires?
  69. Ly6 harness standalone
  70. bench test of 99 C/K IPC
  71. Cross member help
  72. Cross member help
  73. roadmaster engine in a camaro 2010
  74. Wiring a 2014 L96 with E38 Harness into a 1972 K20
  75. jeep wrangler LS1 Swap
  76. 1968 AMC Rambler American-4.8/4l80e/BW s475/8.8
  77. 2004 Buick Rainier CXL 5.3 AWD swap to '05
  78. E-brake line crimping?
  79. 5.3 Red/blue dbw harness with green/blue dbw ecm
  80. fuel pump and LS swap
  81. Ls1 swap, dies after 1 second.
  82. Fuses
  83. Aftermarket wire harness for 5.3
  84. 1967 Chevelle Moser 9” question
  85. project Pacemaker
  86. Starting ls swap
  87. Great new fuel system option
  88. has anyone purchased from retrolsx
  89. Looking for heat resistant alternative to zip ties
  90. Gen III Engine Connector Part Numbers Inside
  91. 55 Chevy with LS1 engine
  92. Rat truck
  93. Anyone LS swap a Ram 1500?
  94. Vacuum / PCV diagram?
  95. neutral switch
  96. 12x1.5 fan switch?
  97. 66 Chevelle LS3/4L80
  98. Header fitment question
  99. Ls swap OBS Chevy help
  100. Fuel Pump Fitting Help
  101. Issue with ls1 cluster not working.
  102. SFI Flat Flexplate?
  103. where to connect the underhood light for a 1984 z28 hugger
  104. 2001 Suburban 2500 engine swap
  105. 1988 Porsche 944 LM7 swap
  106. 5.3&NFW1050 mated to SM465, clutch issues
  107. LS Powered Airboat
  108. 1967 C2 Gets a Sweet Update with an LS7
  109. The Pos Racing MaliBULL - 1966 Chevelle 4 door hardtop LM7 build thread IT RUNS! VID!
  110. GMPP LS3/430 Controller kit
  111. 72 Nova LS3 FBW throttle question
  112. Jarhead's 1965 F85 with LS3 swap
  113. (Need Help) LS7/LT1 in Cayman
  114. My 71 Chevelle LY6 swap project
  115. G Wizz
  116. 2016 Chevy l83 v8 swap . Manual transmission options t56?
  117. Proper Thermostat Function (Heater hose bungs)
  118. Shifter / Trans noise
  119. Sn95 hood options
  120. Hardtop to Ttop conversion
  121. 67 camaro LS1 Best way to retrofit radiator out of the donor car
  122. LS T56 transmission swap into a 1st gen camaro questions.
  123. P1810 Code 4l60e, VSS problem?
  124. 5.3 swap obd help
  125. Help with no obd communication gs
  126. Bare Bones 6.0 LS Foxbody
  127. LS3 or L99
  128. Corvette-Powered Jeep Can Tackle the World
  129. Pulling a Duramax to install a built LS??
  130. CAMARO 74 project " beginner"
  131. best formula needed
  132. LS manifolds?
  133. T56 into 72 Chevelle
  134. electric fans
  135. Neutrial saftey switch plug wireing diagram for 2008 gmc sierra
  136. Brill Steel Carbon S14 Has Something American Under the Hood
  137. 5.3 swap into 1993 k1500 HELP Plz
  138. 69 chevelle 2dr 5.3 swap help
  139. Brake upgrade questions
  140. ECU wire size
  141. Motor mounts needed 1966 Chevy Nova
  142. 1966 Nova LS motor mounts
  143. Drivers side low mount a/c solution
  144. Speedo Issues
  145. Hey im new to this hope this helps somebody else (Regal swap)
  146. Carberry GMLAN connection?
  147. How do I run vacuum: 2004 gto LS1 in 1970 Cutlass
  148. Gen IV truck harness.
  149. Oil Pressure PID
  150. 1954 Chevy Two-ten Series LS Swap
  151. Mustang/ foxbody 4l60e dipstick and tube.
  152. DBC LQ4 overly sensitive throttle
  153. 02 chevy express 1500 cylinder head gasket install?
  154. 84 Chevy C10 LS Swap
  155. Front coil springs
  156. Bracket to low mount AC on 6 rib???
  157. LSA and Catch Can Install Help
  158. 2007 trailblazer SS 6.0 to 5.3 swap
  159. Hooker turbo manifolds in a A-body
  160. cheap PS pump delete using stock truck accessories
  161. 5th gen Camaro cast manifolds in GM A-Body
  162. PCM recommendations
  163. 1967 Chevelle turbo 5.3
  164. Daily Slideshow: 993 Porsche Carrera 2 Ditches Flat Six For More Power
  165. Help first ls swap need help.
  166. Anyone Successfully Swap Tuck Instrument Cluster?
  167. Knock sensor wire/ Header Heat
  168. Tries to start but won't stay running (after running fine for a year)
  169. Changing gas pedals truck to vette
  170. L94 swap into 1994 checy suburban 4x4
  171. Air ride considerations
  172. LMG to LS3 Swap Questions
  173. Ls in a 59 Cadillac help
  174. Can VATS turn itself back on?
  175. Rocket Bunny BRZ Makes Do With a 6.2-Liter LS3
  176. 8 bolt crank flange with LT1 4l60e?
  177. 93 S10 LS Swap
  178. Truck Cluster in Foxbody, Need Wiring Help
  179. Matching motor to tranny
  180. Spectra SP1188 FUEL PUMP
  181. Spectra SP1188 FUEL PUMP
  182. Starter and Alternator Wiring Question
  183. Throttle cable answer for the fox body guys.
  184. 98 camaro v8 swap
  185. Extra C5 Tac module
  186. Powersteering from a new edge.
  187. Presenting an FD RX-7 That Comes With an LS3
  188. How to LS Swap your second gen Camaro/Firebird - My first Youtube video!
  189. no start / crank position sensor?
  190. 79-93 FOX swap headers
  191. 6L80 tranny in a G-Body Cutlass Supreme 1988?
  192. 7.0-liters of Porsche 930
  193. Need advice and help.
  194. Advice on 5.3 swap; I heard this is the place please be serious
  195. This Miata is Definitely Not Your Hairdresser's Car
  196. PNDL with manual swap
  197. "El Chapo" my 78 C-10 project
  198. K2500 diesel to 6.0 LS
  199. 1972 Plymouth valiant, turbo 5.3, th400, 8.8 build thread
  200. BMW e46 LS1 Conversion Engine Mounts
  201. ls1 engine mounts
  202. Dipstick tube for L33 5.3 with LS3/2 oilpan
  203. LS2 into my 1971 Nova
  204. 66 chevelle build
  205. 1992 volvo 960 wagon 6.0 t56
  206. 84 C20 LS Conversion
  207. 2nd gen f body headers
  208. LS7 vs. LS376/525
  209. Maiden Texas: A USCA Pro Touring Camaro
  210. Gen5 Camaro fuel tank conversion
  211. LQ9 Turbo Mustang
  212. Help stuck axle in a Ford 9"
  213. L83 exhaust pipe flange?
  214. Wiring Help!
  215. 6l90e won't shift
  216. 98 ls1 swap no injector spray no spark from coil
  217. I connected the Battery terminals backward!!!
  218. possessed 5.3 swap.. help
  219. LS7 vs. LS3 physical dimensions?
  220. AC and dual "fans on" one or two relays?
  221. Brake vacuum block off
  222. 72 malibu with LQ9
  223. 74' Squarebody Gen V L83 - 6l80 Swap
  224. 1994 LS1/T6 Nissan 300ZX
  225. 68 C10 LS1/T56 swap clutch line
  226. 1980 Vette Gets the LS Treatment
  227. 2012 LS3 into '55 Chevy swap questions
  228. LS3 steam vent routing
  229. LS Swapped Chevelle/El Camino people - where are you hiding your PCM under the dash?
  230. PCV help needed on ls swap
  231. G8 gt L's motor swap to Lt camaro
  232. Is it Still a Corvette if it's Wearing Mopar Skin?
  233. Can i replace camshaft and lifters to performance without additional work?
  234. 1998 camaro LS1 with 4l60e trans neutral safety switch harness
  235. 66 chevelle
  236. Heated BMW bucket seats in my ls swap wagon
  237. Data Bus Conversion HS CAN >J-1850VPW
  238. Turbo'd LS Raysoncraft
  239. Has anyone tried this pan?
  240. trying to track down engine mounts.
  241. 77 C10 LQ4 Build!
  242. 2003 S10 Xtreme “The Wine-O” 427” Twin 88s
  243. How to Fit 1,100hp in a Lexus IS
  244. LS7 Heater Hose routing
  245. Where can I get part numbers for the connectors on a 6.0 02 GM
  246. LS3 480hp Connect & Cruise Tuning Problems
  247. E38 Harness, what can I eliminate?
  248. Low Profile Oil Pans
  249. A few questions about the TR6060 MG9
  250. 97 corvette fuel pump problem
