PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. You think you hate it now, wait till you drive it.
  2. ls1 fox price build am i close
  3. My ls6 RX7
  4. Alternator wiring '01 F-body
  5. 5.3 into 94 camaro
  6. skip shift threads
  7. Mast Motorsports L92HO/6L90E Powered 1968 Short/Wide---Hot Rod Power Tour Long Hauler
  8. s13 240sx ls1,ls2 swap questions
  9. My LS2 V8 Miata on SPEED Channel
  10. mustang swap ?
  11. I need expert swap advice
  12. 70 k20 4x4 5.3
  13. 68 Lemans LS1 T56 swap
  14. 2nd Gen swaps
  15. Disassembling an alternator?
  16. Functional Shaker Scoop on 2nd Gen TA
  17. Header Flange
  18. LS1 in '82 Firebird
  19. f-body clamshell motor mounts
  20. LS! install in a 95 silverado 1500
  21. Oil Pan Help Requested
  22. after 7 months of sitting by...
  23. Small engine, big power!!! (LC3)
  24. 99 Wrangler LS1
  25. 85 camaro ls1 swap
  26. magnus v6 to ls1 writeup
  27. LQ4 in 1995 impala SS
  28. '76 Datsun + LS1 pictures
  29. Possible StingRay Project - Input Wanted
  30. LS conversion alternator wiring?
  31. Wrote a 3rdgen fbody specific swap manual
  32. Any major differences with a 1st gen S10 LS1 conversion?
  33. O2 sensor pigtail for harness
  34. Maggie in a Fox Body?
  35. '94 Nissan Pickup
  36. 1988 iroc-z/28 6.0L swap WITH TILT TRAILER FOR SALE!
  37. Ok so what oil pan for LS1 in 55-57 Belair?
  38. IT RUNS!! ls1 in 1964 buick wagon...
  39. LS2 Mechanical Throttle Questions
  40. Pinouts (or better yet, wiring diagram) for '07 or '08 L92?
  41. Winter projects FINALLY done!
  42. EGR Truck manifolds for a boat application
  43. pinouts for an 01 gmc sanoma 2.2?
  44. alternator question
  45. CNC Clutch Master Cylinder?
  46. Is there anything I am Missing????
  47. wiring up a 99 dash to speartech mod harness
  48. LS! corvair starting issues.
  49. Anyone know how to hook up kickdown tv cable to 700r4 to ls1?
  50. step by step s10 ls swap?
  51. braided hose for clutch
  52. new car too me...1964 vette
  53. S&P compressor and bracket kit for sale
  54. Cruise Lever for 70-78 F-body w/ LSX for sale
  55. O4 GTO alternator not charging
  56. Second Gen weight reduction?
  57. 1975 Mbg + Ls1 / T56??
  58. EFI w/ no cats = fuel smell?
  59. harness power question...
  60. muffler question
  61. LS1 into 87 Camaro
  62. Anyone have??
  63. Lq4 And T56 In A Fox Body Swap
  64. Upgrade bottom end?
  65. LSx Optimal Header Type
  66. non liquid gas threw injectors?
  67. 240sx+lsx=cool,but add T76 and sy/ty=Nuts?
  68. LS1 in a 52 Studebaker Truck
  69. Looking at a LSX Block..
  70. will a 97 engine harness work with 93
  71. ls1 ls2 swapwhat has to be done
  72. help with DBW
  73. trans-am into corvette?!?!?
  74. Help me decide/Cost analysis
  75. Looking for some pics
  76. Intake question.. LS6 or a truck manifold?
  77. question about "Scan Gauge11"
  78. Cooling fan won't come on
  79. Dyno'd the LS1 Miata
  80. LQ4 in a 97 Dodge Dakota?
  81. that little plug
  82. My 62 Impala Project
  83. DBW trottle is dead
  84. 168 tooth 5.3 flywheel part #
  85. need help
  86. 73 Z/28 LS1 swap - back in action :)
  87. 98 LS1 into 79 Chevy Impala
  88. LS1 in a 2000 chevy silverado classic
  89. 4.8 in 89 formula with 6spd
  90. hide your harness
  91. exhaust flange
  92. 3rdgen Guys HELP!!
  93. Feedback from purchaser's of McLeod Kit to move T-56 Shifter forward
  94. anybody need an S&P modified Fbody oil pan?
  95. vette regulator, which is the inlet and return?
  96. 2002 ls1 4l60e into a 1972 Camaro (looking for the least expensive routes)
  97. 5.3 Fuel system question
  98. Need Help With Fuel Problem!!!!
  99. Steering Column HELP!! CHEVY II aftermarket front
  100. phill99's mustang survey :D
  101. 1st Gen F-body with late Vette drive train.
  102. has anyone EVER seen an LS1 swapped into a mopar???
  103. Worth buying a T-56 setup?
  104. Edlebrock/MSD controller for f/s
  105. Fuel system alternative
  106. who here has used motor plates for their swap?
  107. Maybe a repost...Supra motor in Classic Camaro!
  108. gm performance parts harness
  109. LS1 in a 68 Chevelle
  110. help with fuel!!!!
  111. Canīt get any oil pressure
  112. LS3 Harness Questions
  113. RX7/forged 370/TC78
  114. Oil filter F-body pan
  115. first launch video 1965 olds rocket
  116. 5.3 L460e swap,engine dies when shifted from park?
  117. SN95 to ls1 swap how much??
  118. ???transmission for sale???
  119. 2nd gen camaro 5.3
  120. Need some conversion help
  121. Check engine light wiring?
  122. Doing some clean up on the 63 / LS1 swap
  123. 6.0 Lq4 Relucter Wheel???? 24x Or 52x
  124. "2-way oil sensor connector"???
  125. Does anyone have pics or info on the gmpp acc drive yet?
  126. 4L60E trans oil fitting
  127. would love some input diagnosing ticking engine
  128. LSX Vs. aftermarket EFI small block in 72 monte carlo
  129. lt1 in a 280zx?? help!
  130. LS7 questions
  131. DYNO Results ! 68 Cutlass / LS1 / A4
  132. 2nd Gen Conversion Fuel Delivery
  133. ac ? on '68
  134. The Chevelle runs
  135. Anyone here done a natural gas swap?
  136. 900 hp AWD LS7 Weber Sports Car
  137. Throttle body to MAF hose
  138. LQ4/LQ9 oil tube pickup bolt torque?
  139. does vats disable the injectors and fuel pump?
  140. Video of Nissan 240 w/ LS Magnacharged power!
  141. Custom radiator & Meziere water pump, what inlet size?
  142. HELP! Motor will crank but not fire!
  143. Custom Power Steering Reservoir?
  144. Help with part numbers?
  145. 64 chevelle transmission crosmember
  146. How hard to swap LS1 into v6 Firebird
  147. ls1 extension harness?
  148. ls1 mounts for a 67
  149. 1967 Chevelle LS2 ?'s
  150. 69 Chevelle SS 6.0L
  151. A4 Main Plug diagram
  152. Socket for oilpressure sensor
  153. Where did you get your harness?
  154. Some questions after starting 5.3 for the 1st time
  155. msd 6010 timing graphs
  156. 6.0 LQ4 into Third gen
  157. v6 to ls1 $
  158. Corvette LS2 exhaust manifolds in 1st Gen FB
  159. Ebay swap harness????
  160. LS3 in third gen
  161. Smaller power steering pully?
  162. fuel pump relay control?
  163. 3 pwr steering lines on a LQ4?
  164. how to modify the shift lever on a 4l60e for a ford shifter
  165. How much am I giving up??
  166. Looking to put a 53. or and LS3 in to a 97 Toyota Carolla
  167. ls2 firebird swap
  168. Will 5.3 headers fit on an LS1?
  169. First start-up
  170. '82 Vett
  171. Fuel Pump Wiring
  172. Question On the Engine Sense Fuse
  173. First Mock-up of carb manifold w/TBI..6.0L
  174. Custom pre-made driveshafts..
  175. GP on F-Body LS Swap Headers - Edelbrocks
  176. FS: BRP Power Rack & Pinion Kit for F-Body
  177. Looking for adapter plate for LSx to 240sx 5 speed
  178. LS376 (carbed ls3)?
  179. My carbed 6.0 in my 78 malibu
  180. What kind of Shorty Headers to use?
  181. Is tuning Software Required?
  182. lq4 alternator question
  183. JEEP grand chero ls1 swap?
  184. Milk Truck with LS1!
  185. lq9 in rx7?
  186. Phil at BRP Hot Rods
  187. Stupid windage tray question.
  188. Anyone ever use these headers?
  189. Injector wiring, polarity?
  190. PICs of engine bays
  191. Wiring a carbed 5.3 in '81 C10
  192. Ok fox swap guys....get your T-56 set-up here!
  193. Which LSX for Budget Build?
  194. 98 3.8/4L60 --> 98 LS1/4L60....help!
  195. Plumbing LS1 for rear radiator?
  196. More Drive by Wire Questions
  197. 99 LS1 into a 94 LT1 car
  198. WTT/WTS: C5 Accessories/BRP adapter plates
  199. need straightforward answer. cts-v t56 on trailblazer ss ls2
  200. LS2 A/C problem
  201. 02 ls1 motor in a 98 chasis, need help with wires
  202. Alright One last electrical question.
  203. Will this pump work?
  204. LSx NEWBIE NEEDS INFO
  205. New Swap Idea-Weird-Dumb-Just Plain Cool
  206. 5.7L 350 vortec in 1981 chevy c-10 custom deluxe
  207. Which fuel pump should buy??????????
  208. LS7 in SS truck
  209. 5.3 Vortec in a 97 Jeep Wrangler: Engine Issues
  210. Using Stock Air Compressor with Vintage Air Kit
  211. Help me decipher my wiring harness (Lots of pics)
  212. ls1 from 84 into my 86?
  213. Plate between T56 and bellhousing?
  214. Idea (1949 Anglia)
  215. Swaping V6-V8 Chevy Silverado
  216. its alive
  217. Wiring Harness Auto ---> Stick
  218. A/C compressor mounting
  219. engine mount plates FS
  220. Trade Fbody for GTO Oil pans
  221. Finally the new engine have arrived.
  222. Custom fuel cell questions
  223. Need help smog reffing ls1 motor in lt1 body
  224. LS6/T56 swapped S-10
  225. Bending AC Lines
  226. Any views on this wiring harness?
  227. My 1968 RS Pro-Touring Camaro Project
  228. 2nd gen. camaro motors mounts for ls1 swap
  229. which 4L60 do I need
  230. 93 Camaro Lt1 to Ls1 what hard parts need to change.....
  231. Official Project "In Motion" Thread
  232. Altenator?
  233. ls/carb-i just cant get it to run right-revisited
  234. Aftermarket Clutch resevoir ?
  235. Building your own headers. theory and advice help needed
  236. Way to go GM performance parts
  237. A body fuel lines
  238. Trying to help... ABSOLUTELY STUNNING IN PERSON!! 1997 240SX LS1 M6
  239. ls/carb-i just cant get it to run right
  240. LS2 brackets on LS1
  241. LQ4/LQ9 flywheel for Tremec 3550 Transmission
  242. Drive by wire TAC module pinouts
  243. Easy tranny Q for the pros
  244. GP On A-Body Swap Headers - Edelbrocks!!!
  245. will a lt1 t56 bolt up to a ls2?
  246. how much psi and volume can the vette filter take?
  247. fuel rail help
  248. Jagsthatrun
  249. Anyone use GTO oil pan with fbody dipstick?
  250. what do i need
