View Full Version : Conversions & Swaps
- LS1-Powered Jeep Grand Wagoneer Goes to Auction
- maf reads max engine idle high
- Crank pulley difference
- Radiator recommendations
- Typhoon 52061
- GM Output Speed Sensor That Does BOTH?
- Temp Gauge Wiring - LS Swap into 79 C10
- Injector relay trigger ?
- installing 2020 Corvette engine and DCT 8 speed transmission in 2007 LS2 Corvette
- Tensioner Indicator
- Speed Master Intake
- Wireing
- Mechanical Charcoal canister
- Vintage Air with Gen IV truck ECU
- E30 in a non flex fuel 4.8l
- LQ9 Vs. 5.3 swap
- Ironically beating a deadhorse(85 C10)
- Water pump help
- Tbss on L33
- LS1 swapped and boosted E36 (BMW 328I)
- Bad problems with engine dying, I'm out of town and need help
- 70 Camaro Gen 5 LT1/TR6060
- 6.2 harness question
- Low Pressure PS hose blows off.
- proper belt tensioner
- LS2 Harness To LS1 Injector Adapters
- 67 LS2 Camaro Build - DBW Issue
- O2 sensors not reading after short run time
- Headlight switch wiring help
- Cam Position Sensor Help On GTO LS Swap
- Very First Big Block '67 Camaro Proved to Be a Handful
- Asking for a bit of OT help please
- 1995 Camaro LS3 Swap HELP
- What crossmember/mounts for 4l60e/5.3 nova 70
- 2010 Camaro good donor?
- Ticking sound after trying to start swap?
- Mac Tiedown LS Adapter
- Large Capacity Power Steering Reservoir
- 1968 Sunoco Team Penske Camaro is a Rare One
- Fuel tank purge line
- Attaching an LS3 to engine stand
- Building an LS7 for 01 SS
- LSA swap Gbody
- Oil leak and PCV system linked?
- '69 GTO LS1 Manifold Clearance Issue
- First Start Help Please
- typical ls swapped mustang
- Lt1 to ls1 swap
- Low Mount Alt: PS Question
- 63 Nova Wagon 5.3 Swap - The Patina Mobile...
- LT4 and 10L90 possible in 4th gen?
- Shifter wiring question
- Edelbrock Pro-Flo 4 EFI ECU & Engine Harness
- Restomod with an LS3 376/525hp
- '69 GTO LS Swap-What Headers?
- 2 Fan temp settings
- With the Gen 5 ECM, is a neutral safety switch
- Cutlass Cruiser getting a 4.8L and boost
- 1998 volvo v90 ls1 swap - the "volmaro"
- Very Rich Idle, Holley Terminator X
- Any LS fwd engine to fit in my 1991 Chrysler TC by Masrati 3.0 v6 ...Any ideas
- 2013 c amaro LS3 / 4L80e wiring diagrams
- AF10060 MAF sensor pinout
- new guy lost in swap
- 1970 Super Sport LT4 Nova Burns Down the House
- Isolated Oil Smoke Issue
- 07 GMC Canyon Off Road LM7 Swap
- 71 Ventura/Nova Cooling Questions
- Swap thread - FBody LS3, minor details help
- 4l60e need help with shifting prob
- GMC Sy should get an LS2 now
- Need Help
- 1st gen Camaro LS manifolds?
- fresh fish to Ls world
- Is LT1swap still in business?
- Low mount AC closest to the block?
- Quintin Bros Turn Out Dual Purpose 2018 Camaro 2SS
- LS3 Power surge
- Looking for advice on custom air intake
- any advice on what eletric fans to run ?
- ebay DBW truck swap harness VIDEO
- 79 C10 LS Swap - Ignition wiring question
- 86’ mustang 2.3 carb harness and ecu delete? Please help
- Alternator wiring
- Ls swap
- Jeep Swap Newbie Questions
- LS1 not turning over completely
- C10 DBW TAC problems
- How to check harness causing P0134 code
- LS3 Swap into FBody, best donor car?
- Can I get some help wiring fans through PCM
- LS ? Engine into a Porsche 996
- New Gears: Changing PCM settings
- Thermostat housing
- What dont i need on a LS1
- Steering shaft removal 1965 Cutlass
- Pinout for 6L80 T43 TCM plug to identify “R” signal
- No start issue
- LS3 E-ROD into Buick Roadmaster
- 1979 Pontiac Trans Am LS Swap
- 70 A-body LS swap question about cutting tunnel
- 1964 Cutlass LS2 4l60 swap: Need some help
- LT1-LS1 swap. AC questions
- Throttle position issue
- 2018 6L90e + 2015 LS3, How to Match TCM to E38 PCM?
- 2004 GTO Automatic - build stand alone wiring harness.
- 5 Cars to Buy for LS Power on a Budget
- 2013 l99 6l80e swap no start no spark.
- AIT MAF sensor question
- No cam sensor RPM during crank
- Exhaust Setup For LS Swaps
- Vehicle speed sensor wiring
- NSS and backup lights - 4l60e
- Front steer on a first gen camaro?
- Gen III 2004/LQ4 to 2006/4L60E
- 6.0 swap hard to start when warm
- Rutledge Wood's LS Swapped RWB Porsche
- From paraguai, 54 chevy truck vortec 5.3 swap help
- LS Tech Headache Relief
- Shifting issues
- Swapped mk3 supra 4.8 upgrades?
- 67 camaro 4th gen steering column,headlight switch and wiper motor swap
- 68 camaro LS1 - daily driver No start- no trouble codes
- Idles strong, but P0172/P0175 are lit up...help!!
- My 64 build
- V6 Firebird to LS3
- LS boat conversion
- Steering gear leak after swap.
- 72 el camino swap issues PSI harness and PCM
- Anyone running a dual pass radiator? Mine keeps over flowing out neck
- ls1-4l60e 68 corvette, convert to manual
- 3 wire alternator
- Dual cooling fan wiring with Trinary Switch and LS1 PCM
- 996 Porsche ls1 throttle, convert car to cable, or convert 99 ls1 to DBW?
- Help solving my light throttle surging issue?
- Cold Air Intake
- Who's running Ultimate Headers? Feedback?
- ls engine to low
- Vintage Air/BP Automotive binary or trinary switch
- 1977 Cadillac CoupeDeVille LS3 4L70E Swap
- The Right Parts for a rear end rebuild
- a/c charge in an ls swapped El Camino
- 1985 Toyota Land Cruiser with LS Engine is a Legendary Combo
- LM7 ecu lost memory
- Need Help Identifying Thread Size
- Twin Turbo S300s, LS1, ‘74 Laguna S3
- P1810 4l80/4.8
- Ls3 Overcharging
- Converter on miata
- Vintage air Binary Switch / GM Pressure Sensor
- PCV cap?
- Would this be enough for cooling?
- LS3 / 525 crate motor.... what's a "normal" operating temperature range
- Twin Turbo LS3-Powered Porsche Cayman Is Our Kind of Hybrid
- Square Body Crew Cab Dually 454/NV4500....considering a LS Turbo Swap
- First lm7 swap into 1970 firebird
- LS Swap Driveshaft
- Ls3 (e38) + 2006 4l60e?
- 5.3 hard start
- LS swap squarebody suburban w/tbi
- Tips and ideas
- what is this?
- LM7 Drive-By-Wire (DBW) Throttle Non Responsive
- Intake for 6.0 swap
- 5.3 swap woes
- Need help with a weird gauge cluster sweep/fuel pump issue.
- Thoughts on running intake tube directly downwards in front of motor?
- 89 g20 swap
- Primary VE vs. Secondary VE vs. MAF; Help me understand?
- 1940 Supercharged LS3 Ford Pickup is a Restomod Delight
- Dumb Electrical Question
- Charging question
- Porsche 996 ls1 swap best oil pan?
- Need info - measurements from heads to pulleys?
- dakota digital tach issue.
- Which retro fit pan
- C10 starter/ignition wiring help
- Best place to buy Porsche 996 adapter plate and flywheel for g96.30
- Am I looking at a tow back to the tuner ?
- 69 Camaro...Engine Wont Turn Off!
- Silly question ~ can I keep stock tbi with an LS?
- Ignition cuts out
- Am I overheating? Or worrying about nothing.
- 04 gto parts on f body
- 84 C10 build with LT swap
- Aftermarket wiring harness preferences?
- Which parts for f body pan swap on 5.3
- Throttle Body Position
- Throttle Body Clearance
- Bureko 6x6 is a Very Angry Silverado
- OEM style flange head m12x1.75 100mm bolt 10.9
- Young, Dumb, and Broke 1978 Camaro turbo 4.8 swap
- Hello in need of some help!
- Muncie m21 yoke
- 10 Speed Swap
- Aluminum 5.3 in a 2001 E38 BMW 740i
- Defender 110 L83/6L80
- 84 c10 Turbo 5.3
- tr6060 swap between t56?
- acquiring a '66 GTO
- cruise control from 2k firebird "Cruise lockout"
- LS Swap AC question
- Heater Control Valve or Shut Off Valve
- Deciding between gears: 3:55 or 3:23
- Sound / vibration deadening opinions
- LS2 Cutlass radiator hoses
- 1998 Jeep TJ 2.5l Auto to 5.3 4L60e Swap Complete
- ECM and torque converter programming
- Hooker Blackheart 1967-72 C10 Truck LS/LT Swap System Info Thread
- Lm7/60e (or something of that nature) in a 1989 Mercedes 300SEL
- I.R.S. choices
- 1957 Chevy Convertible, Corvette Suspension, LS3, 4L80, Photo Shoot
- 1970 Chevelle Restomod Boasts LS3 Power
- Over heating
- Questionable ICT Swap Plate Measurements
- Projekt: LS-10 Dash Overhaul
- This may help a lot of guys
- 2 second start not vats
- Battery relocation question
- Swapping help
- 4L65 floor shifter recommendation needed
- C10 LS swap - upgraded radiator - trouble finding trans lines
- Corvette Filter/Regulator - do they suck?
- Need your help, OBD not working.
- LS3 2012 camaroswap no spark
- Question about wiring harness
- 4l80e swap thoughts
- Alternator always on?
- After a 4-1/2+ year silence, the LS7 Monte SS still reigns as King!
- LS6 Valley cover without a PVC Valve??
- 6l80e wont shift on new swap
- Truck MAF w/ separate IAT?
- Vintage Air Front Runner Idle Cooling/Circulation Issue
- The LS Swaps That Trigger Brand Loyalists
- Torque Management/Traction Control
- 4L60E Pinout Wiring - Howell Stand Alone Harness - Park, Neutral, and Reverse Light
- Early LS1 thermostat comparison. Stock, ls3, mr gasket, GTO
- Hall effect sensor? - traction control
- LS Swap on College Budget
- 97 ls swap harness
- Fuel line confusion LS1 into a ‘79 C10
- TTLSXTR7. Twin turbo TR7.
- Firebolt! My 5.3 Turbo Toyota Tacoma build
- bypass traction control
- LS3 into a Hyundai Genesis Coupe
- AC Hoses
- Moving on...70 Camaro
- pcm choice
- Squatch build "98 sonoma 2wd ext cab" 4.8 budget build for 800rwh
- 1971 Ford F100 6.0L 4L60e patina truck
