PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Clutch setup in fox body with ls1 t56.
  2. Spark Plug Wires
  3. 87LSX Monte SS nightime burnout vid.
  4. ls1 t56 swap questions?
  5. 2" exhaust too restrictive?
  6. Where to start.....
  7. Dyno numbers for 5.3 Malibu
  8. Low Alternator for Low Cost
  9. steam vent tube
  10. Lt1/LS1 T56 Swap.... Why?
  11. 87 notch
  12. Question on AC lines for LS1 into 95 Camaro swap.
  13. Kit cars
  14. Air filter suggestions/ideas....
  15. lq4 swap in Pro touring 67 Chevelle
  16. Looking for some custom LS1 harness parts
  17. Best wishes to all in the path of Sandy.
  18. 1977-1978 Trans Am LS Swap
  19. Transmission issues
  20. How do I check oil pressure without starting the motor,
  21. older vortecs vs 03+ question
  22. What starter do I use?
  23. wiring harness question
  24. 5.3 Mustang Build
  25. Computer issues
  26. LS engine in a new Cadillac ATS?
  27. Jeep Grand Cherokee steering box swap on a-body
  28. the right cam
  29. 1969 Pro Street Camaro, 5.3 twin turbo
  30. HELP, guys I think I forgot to check
  31. LS turbo GN.
  32. waterpump leak
  33. Converting fox to 5x4.75 bolt pattern
  34. 1970 GTO LSX Conversion ?'s
  35. HELP! Can someone read my engine serial #
  36. database for junkyard parts?
  37. 91/88 mustang reswap 6.0/T76
  38. Now thay I think I have top dead center
  39. LS or LM swap
  40. QA1 with 6,000 miles blows a seal. CRAP
  41. Wow, I can kick myself :(
  42. New "LT" engine series announced to replace the LS series
  43. Range (PRNDL) switch on 4l60e for conversion
  44. Ford headers on LS1
  45. LY6 Newb Need Some Help
  46. cheap ls fox headers
  47. Plug and play harness for ls g body swap available anywhere ?
  48. 71 Firebird Formula LM7 turbo swap - build thread
  49. weight difference between a stock 92 z28 and a stock 2000 z28
  50. 99 camaro 3.8 to LS1 swap
  51. advance adapters with th3500?
  52. 4th gen camaro fuel tank in third gen camaro
  53. lt1 to ls1 fuel system
  54. 1988 Monte Carlo SS LS7 stock short block H/C/I belts out 660 RWHP N/A on 92 Octane!
  55. E36 swap with a 4L60E
  56. New to the forum with a Cobalt LS2 drivetrain swap
  57. Who has used the trans-go kit on a 4l80e?
  58. mid engine ls2 corvair no spark advance
  59. Tall Deck Fox Questions
  60. Stainless Works to expand LS swap header and exhaust line up. SUGGESTIONS!
  61. what is the torgue for the stock rockers
  62. Fuel return line question
  63. 68 camaro 5.3 swap questions
  64. LS1 t56 s13/240sx reverse lockout wiring
  65. Is AN -4 too small
  66. going rate to wire up a LS1 combo
  67. Power Distribution
  68. LS7 into 2004 C5 Auto?
  69. Quick question about the wiring for my swap......
  70. optimal exhaust design for my LS3 RX7
  71. Electric fan on/off setpoints
  72. Which ly6 accessories with vvt delete?
  73. Budget 1st gen camaro swap info 1969
  74. Which pan and brackets for a 68 chevelle.
  75. Physical size...truck 5.3 and a truck 6.0...same?
  76. Fiero LSX 427 IMSA hits mid 10s at Byron, IL
  77. Holy Crap! I need help! Battery/Alternator
  78. Team Z Fox K member
  79. ls1 swap into 94 k1500
  80. LS1 Fuel Pump Fuse
  81. Need some help with 62 impala build
  82. ECU location for Fox/LS swaps?
  83. Ly5 oil pan swap to gen4 camaro pan ?'s
  84. Making my own LS1 Standalone harness and How to wire the Bussmann Fuse/Relay Box
  85. HUMMER H3 Alpha LS1 Swap
  86. fc + 4l80
  87. Local Tampa guys that weld
  88. Any Success with LT1 to LQ4 AM motor mounts
  89. 67 chevelle 5.3 swap edelbrock intake questions
  90. Need help to identify connector
  91. LS376 525 crate swapped bmw m3 with no tach
  92. how cheap could you swap a ls into a foxbody?
  93. a/c quetion for ls swap into a 94 t/a
  94. 5.0 mustang ls1 swap
  95. Will this 4.6 ls setup work ???
  96. Fuel Line, Over intake or driver side?
  97. Thinking about a Turbo 5.3 build
  98. Post your 75-79 Nova LS swaps.
  99. 6l80e Slip Yoke
  100. Mercedes 280 Four Door W114 with 4.8
  101. ? For Fox Guys
  102. What starter???
  103. Where can you buy this exhaust flange?
  104. 5.3 vortec swap
  105. LS in a Chevelle motor mount and header combo?
  106. "Nadine" and the Fireball...
  107. Dipstick problems
  108. Ls in foxbody ???
  109. Long Crank/Short Crank Questions
  110. Connector ID
  111. Fox Body LsX Turbo dilemma...
  112. good price for LS1 dropout??
  113. 5.3l into 1962 impala
  114. Idiot light sensor
  115. Headers
  116. 81 cutlass factory wiring needed to run standalone 5.3 harness
  117. 74' Laguna S-3, LQ4 6.0L, GT4294 turbo Build
  118. 1999-2002 V-6 Firebird - LS3 Swap ?
  119. LS3 Swap Into a 1999-2002 V-6 Firebird ?
  120. No spark #7, coil and plug wire are good.
  121. 2000 corvette tranny
  122. Range Rover conversion to LS
  123. Fan Wiring Question
  124. Quick steam pipe question -LM7/S10
  125. 2000 truck harness injector connector seal
  126. Anyone use a ctsv tranny in ur LSX swap?
  127. Won't stay running
  128. 4.8/5.3 width?
  129. Shops handling L92 / GM truck conversions?
  130. Lt1 to ls2 harness
  131. lq4 and t56 prices?
  132. 2nd Gen F-body LSx header suggestions needed
  133. Mustang or Camaro
  134. LS1 PCM and Cruise Control Installation in 1933 Willys
  135. rebuilding 4.8 myself
  136. Mustang manifold compatabilty
  137. Ls swap 87 notch. Auto Shifter?
  138. Got an ls1 doner car for $800
  139. 160 thermostat vs, MPG
  140. Anyone running hedman headers in fox body??
  141. dash and heater questions from a 1997 to a 1994 camaro
  142. Best exhaust manifolds for 77-96 B-body?
  143. Dynatech Headers 67 Tempest
  144. LS3 Toyota Tacoma AWD!!!
  145. Need help with PVC line assy install
  146. Intake/ fuel rail help please!
  147. 5.3 in trans am
  148. lq4 into 94 camaro
  149. Stupid Question
  150. Budget 69 camaro swap info needed, anyone go the cheap route on a 1st gen?
  151. 2011 Camaro SS IRS going into my Nova
  152. Newb: L92 into 68 Vette - fuel inject or carburetor??
  153. cross flow radiator hoses
  154. lq4 in 01 cobra ?
  155. Thanks to LS1Tech, she's alive! 1936 Chevy sedan "Mabel".
  156. What motor mounts with my headers?
  157. T5 vs T56 bolt pattern
  158. Corvette Accessories, VVT, and Holley Spacer
  159. fuel tank differences
  160. ProCharger F-1X Cog Transplant Kits Now Available
  161. Should I Pull The Trigger??
  162. Custom Hose? Possible?
  163. Temp Guage/ Fan temp sensor?
  164. LS1 fan ?
  165. Upper hose for 5.3 s10?
  166. Kicking a dead horse.....
  167. Another 89 Mustang Coupe LS Swap
  168. 4.8 swap tach reading high
  169. 5.3 Truck accessories on a 2nd gen fbody, is it possible?
  170. DBW Problem
  171. fairmont wagon... better tracction than mustang
  172. aftermarket wiring harness
  173. lt1 transmission with ls1
  174. Got fuel, got fire....don't have the start that I desire!
  175. Lq4 in my bird
  176. Need help with wiring situation
  177. 3rd Gen LS Swaps in here.
  178. 69 Cutlass, 430hp 6.2, 4L65 trans
  179. ALternator plug question
  180. DataLog?
  181. Camaro Radiator and AC condensor with truck accessories?
  182. Found resistor on the floor. Did it come from my harness? Where?
  183. Correct Lokar throttle cable for my application??
  184. LS1 Fuel Injector Connector Kit
  185. In the prepation stage of my future engine swap, what all can I remove?
  186. A not so hypothetical situation
  187. Camaro nose el camino intake & engine cover update pics
  188. Fox t56 guys question
  189. 1965 c10 ls swap?
  190. New to ls1 tech. Lq9 questions.
  191. 01 5.3 wiring harness ?
  192. 1988 Cutlass-F in a G-LS1/T56, Watts, Cage-Daily driver
  193. R J salvages NY, need quick advice
  194. LS1 Swapped 68' Camaro
  195. GPS to VSS Mod Options
  196. transmission non-responsive lack of power?
  197. 93 Reef Blue LSX Notchback Build
  198. Park/Neutral safety relay control
  199. Nightmare LSX S10 swap...Help?
  200. Hudson
  201. Car Won't Start, Fuel Delivery - PSI Harness
  202. 5.3 swap rev limiter???
  203. Ignition switch problem
  204. Filter INSIDE of intake tube?
  205. Lsxfox-need help wiring brake sw and tcc
  206. Power Steering....old to new set up
  207. Start an exhaust manifold sticky?
  208. converting my 68 to daily driver
  209. So.............. Another Fox Swap
  210. New twin 6.0 build
  211. Will this fitting work with Corvette regulator?
  212. 1972 chevelle with 2002 Camaro Z28 components compatible?
  213. Low idle and stalling issue
  214. Our 89 Notchback Race Car, Restoration. Lots of pics
  215. Twin Turbo LS 1968 Chevelle Malibu Officially For Sale- Link Inside!!
  216. gen IV 5.3 4l60e vibration/noise ONLY in 4th gear??
  217. What kind of power should my LM7 make with this setup?
  218. Truck single inlet fuel rail
  219. WTB: LS2 and T56
  220. Help me find some turbo manifolds
  221. LS into a 95 Bird, AC question
  222. Help needed On LM7.
  223. 2010 up Camaro PWM fuel pump controller - adaptable?
  224. 2005-2007 Corvette alternator output voltage is low
  225. 5.3 in 91 notchback
  226. noob tranny question
  227. Help with pics on clutch master to clutch pedal install
  228. Any luck with un-shrouded fans?
  229. I have a 5.3, NOW WHAT?
  230. 89 Gt lq4,ls3 heads, Pat g cam w/ dyno results
  231. VSS on 5.3 Sonoma
  232. Starter connections questions
  233. 1949 Studebaker 5.3 turbo
  234. sbc mount compared to a lsx mount for s10
  235. Need help installing clutch/brake/gas pedal
  236. Getting with the times 84 s10 with sbc to 5.3 whats needed?
  237. ls2 to t56 bolt sizes
  238. Remote coil plug wire routing
  239. Two alternator wires
  240. Sn95 mustang lq4 swaped
  241. Fender Emblems
  242. "89 stang new ls project"
  243. Where to buy Moroso Oil Pan - Front Sump
  244. DBW gas pedal question, need some help
  245. Aftermarket fuel rails. Questions.....
  246. ******Junkyard Find**** Straight water neck for LS
  247. LS1 944 clutch hitting bellhousing
  248. Newer 5300 Vortec into 1996 Tahoe
  249. Anyone make a solstice ls1 swap parts?
  250. Name that plug
