PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Lm7 swap in mind...but can it be more
  2. ecm flashing for STandalone harness.
  3. ls2 blows fuse
  4. Advise - 1995 Impala SS
  5. Fuel Level Harness
  6. LS3 Conversion in 1967 GTO
  7. lm7 and lq4 cost
  8. 408 Stroker, 67 Chevelle DYNO help / numbers
  9. 69 Chevelle 4L80E possibility
  10. 6.0 LQ4 Swap Questions
  11. Bragging on Compushift
  12. Questions Regarding LY6 6l90 swap into CJ7
  13. LS2 to LS3 acessories
  14. Lh6 to lq4/lq9 swap
  15. 1966 Pontiac Tempest LS Swap
  16. 4l80e 5.3 Foxbody Swap
  17. '85 C10 LS1/4l80e
  18. Need advice LS swap in a 82'C10
  19. 5.3 overheating
  20. 1990 Isuzu Pickup LSx. 4L60, T56, T5, NV3500, NV4500?
  21. Anyone ever ls swap into a 49 ,50, ford shoebox?
  22. 1987 Bmw 325 - LSx drag car
  23. Taurus Cooling Fan?
  24. Lq4 swap p0308
  25. No throttle on LQ4 swap.
  26. Questions about master cylinder for C^ brakes on a-body
  27. LS4 Swap a Jetta
  28. Camaro brake switch
  29. Need some guidance on wire harness modifications and pcm tune
  30. Engine has Hard start and sputters and bogs when you mash on the gas
  31. my turbo 5.3 70 nova
  32. OBS build HELP
  33. Ls motor mounts?
  34. 64-67 A-Body motor mounts
  35. I've got an engine on a test stand, dies when throttle increases, VIDEO
  36. Help with gen IV L76 in gen 3 truck please
  37. Patriot tight tuck street rod headers..anyone using?
  38. First gen 4runner ls swap questions
  39. SC300 LS/LT Swap, Sikky Manufacturing
  40. LS Swap in 87 G body, twin turbos and A/C?
  41. O2 Sensor Question
  42. Vacuum port usage
  43. Oil sending sensor
  44. 1948 Chevy PU with 2007 Classic 5.3/4L60E
  45. Starter Solenoid
  46. G8 Seats
  47. Flywheel cover?
  48. '96 T/A SBE 5.3 Turbo Build
  49. Help: Carb conversion/distributor options
  50. Oil pressure
  51. 2006 v6 silverado to 2000 5.3 swap! need quick answer!
  52. 1963 Belair LS swap
  53. 5.3 swap into my 94 Sonoma
  54. Can I cut the water neck - zero clearence swap solutions?
  55. 91 fox 2010 L96 swap budget build
  56. Arizona Harness Service
  57. Just grabbed a drop out and..
  58. Plastic tip on truck injector
  59. GenIV BCM/VATS disable
  60. 72 Nova 4.8L swap motor mount issue
  61. Gen III to Gen IV conversion pain in the @ss
  62. jeep yj 5.3 swap ax15 issues
  63. 01 Firebird 4.8/4l80e swap
  64. LS into 02 Explorer
  65. 71 Firebird with L76, power steering question.
  66. 5.3 swap into my 94 Sonoma
  67. 1967 Camaro LS2 swap
  68. LS6 powered 1978 trans am restomod!!
  69. 5.3 swap into my 94 Sonoma
  70. 2000 Tacoma ls1/TR6060/241c
  71. Driveline angle
  72. FEAD? Which is best
  73. How to connect a 67 Firebird stock steering box with C5 corvette P/S pump
  74. 5 Great Tuner Shops for The LS Engine
  75. 89 LX Fox 5.3 swap
  76. 96 LT 4l60e to an ls6
  77. 7 Cars Made Great with an LS Engine Swap
  78. Microsquirt V3 EFI Source LS1
  79. Checklist For Donor Engine Removal
  80. 02' Mustang V6 to LS "sporty Daily"
  81. Need More Room Up Front
  82. Is this a baffle in my fuel tank
  83. Looking at an '88 Supra to swap LS in, have a few questions
  84. 2013 Avalanche...L96 Swap
  85. 8.1 vortec and Allison Swap into 1984 Airstream 310
  86. LS Swapped 1996 impala SS Oxygen Sensor Help
  87. LS swap into 68 Camaro
  88. 4.8L Swap Candidate Questions
  89. Constant in and out of lockup
  90. 02 Mustang LS Swap how to keep AC
  91. Cosbysweaters 1979 Volvo 244, 5.3 Turbo
  92. Going to build my own harness...
  93. 411 blue/red ECU
  94. Caddy CTS-V LS-A swap
  95. 98 LS1 5.7l swap to 01 4.3l GMC Sierra
  96. Tips for gas tank fabrication
  97. LS3 Mod 49 Chevy Business coup
  98. another 6.0 nv3500 swap need help
  99. Looking for CX Racing LS1 oil pan dimensions
  100. Balancer Question
  101. L96 swap HELP!
  102. Holley efi fuel pressure sensor placement
  103. 10 LS engines in Weird Places
  104. Fox body alternator wiring
  105. VSS for PCM when using a TH350
  106. LS Swapped MK3 Supra Project
  107. Foxbody LS N/A swap 2017
  108. Chevy II Nova LS Newbie Question(s)
  109. 548it
  110. A-body Mopar Ls swap
  111. AC question OBS truck 5.3 swap
  112. Too Rich.
  113. Head gasket 12610046
  114. 2011 6.0L & 6L90E in 2007 Ford EX-Ambulance
  115. Building LS Powered '63 Dodge Dart GT (LC9/LH6)
  116. 70 camaro lsa install help
  117. My current build : 83 Monte Carlo SS LS Swapped
  118. Mustang ls swap radiator hoses
  119. Dual Pass Radiator Hose ?
  120. F Boyd Oil Pan Question
  121. S10 clutch master cylinder swap
  122. Motor mount questions HELP
  123. Need help with making a stand alone harness
  124. Corvette LS1 into 1979 El Camino
  125. Need help with pressure problem
  126. Wants to die after opening throttle
  127. 7K Fox Body Street Build
  128. bought unfinished Camaro swap
  129. Ls3 coils on a 2002 Fbody?
  130. Idler pulley bracket that bolts to water pump tensioner mount
  131. Holley's LT oilpan
  132. Vapor canister purge valve using timed relay
  133. 4L60E Speed Output and CC hookup
  134. Bmw e60
  135. Oil pan actual capacity
  136. What is this green fuel in my rail??????
  137. L83 Gen V Swap into 1956 Buick Special
  138. ECM mounting (LS Swap)
  139. 5 Things to Know About Swapping an LS Motor Into a Chevy 58-64 X-Frame Car
  140. New Edge swap - AC question
  141. Speedo help
  142. Quality Wire Loom?
  143. LS3.430-> Temp and Oil Warn settings?
  144. Parts Store Application for LS376 Crate Engine
  145. Another oil pan question
  146. Another Where is my Ls1 from
  147. H3 Pan or Grind Crossmember?
  148. 5 Explanations For Why the LS Engine is so Great
  149. 5.3 TH350 into a '65 C10
  150. 5.3 alternator bracket
  151. Ls2 vs ls6 intakes.
  152. 07 Chevy Express harness...swap into ex V6 gmt800 truck
  153. Fuel rail plumbing ,need some advice ??
  154. 4l80e price?
  155. 1984 Cutlass 5.3 turbo keeping it simple
  156. Another LS Corvette
  157. Need help asap please
  158. Gen 3 LS1 swap into 2010 Silverado question
  159. Speed Engineering Fox swap headers?
  160. L83 gen v swap 1954 belair build thread
  161. 4l80e shifter G-body swap
  162. Fuel level sender question - Emissions Control
  163. Sanderson shorties s10 swap
  164. LS CHEVELLE Help
  165. Please help thank you
  166. LQ4 swapped into 87 Crew Cab Chevy
  167. KWIK High Mount AC Bracket for Aftermarket Supercharged Applications
  168. LS7 into a 72 Chevelle Conversion?
  169. parts from 99 Camaro in 68 LS build
  170. Scanner wont connect to OBDII Port
  171. 1991 Jeep Grand Wagoneer LS1/4L60e Build
  172. LM7 Alternator Wiring
  173. '83 LQ9 Monte SS build
  174. What first
  175. need help with stock column shift 4l80e in 71 elcamino
  176. Mustang notch LS build
  177. conversion front end
  178. Fires up, dies immediately (First start, fresh build)
  179. 1969 Cutlass LQ4 GT45 turbo build
  180. Ls2
  181. Heater in a LS swapped 79 Trans Am
  182. GMPP kit
  183. C5 Corvette P/S pulley swap to C6 (spacing difference?)
  184. Grind top of 4l60e ?
  185. 2001 Corvette motor manifold and oil pan questions - Swap into Grand Wagoneer
  186. 5th Gen Camaro exhaust manifolds and GTO bell-housing/starter combo?
  187. 72 chevelle lq9 4l60e swap
  188. Anyone Using An AJE K-Member And Mount In A Fox Body?
  189. LSX Swap K Member for 2002 V6 Mustang
  190. Blazer X with Corvette Acc. Drive
  191. Fuel pressure test
  192. cooling system for 71 nova with 2002 LS6
  193. E38 LH6 5.3 DBW problem
  194. Radiator and fan setup?
  195. LS1 Passenger side head mount accessory spacer for LS1?
  196. Newbie ls swap question. Fuse box
  197. LS swap Newbie
  198. Killing power to ECU
  199. LS9 Stand alone harness
  200. What is this line coming from the TB?
  201. LS swap, question on sourcing the parts
  202. 1965 Cadillac Eldorado LSx conversion- need help/recommendation needed
  203. Need help identifying connector 2012 5.3 - OBD2 related
  204. Drive by wire problem
  205. 6.2 liter to Land Rover Discovery 1
  206. 6.0 lc8 in 2nd gen camaro
  207. Oil priming (topic not covered before)
  208. stock converter vs circle D 3200
  209. Where does green VSS wire go?
  210. '90 5.3 240SX-LOJ Swap Kit w/Z32 5MT
  211. 99 TJ Wrangler 4.8/nv3500 swap questions before i start
  212. 65 Nova street car, 6.0 LQ4, 4L70E, mini tub, rust repair, Holley Dominator
  213. Need help t56 1967 camaro
  214. LS Swap in 69 Camaro
  215. Using Heater core outlets to run a heat exchanger?
  216. 5.3 Nissan 240sx
  217. 69 chevelle holley terminator mounting ?
  218. 5.3L in a Nash Metropolitan
  219. Throttle Body Issues
  220. 4.8L LR4 swapped E36 - Suggestions needed
  221. Where??c4 c beam adapter
  222. Cam Question - Howard's Cam
  223. 02 Silverado 4.3 to 5.3LS Swap Help
  224. Which DBW pedal with Holley dominator?
  225. Rx8 v8
  226. 1971 Toyota Corona 5.3/th400 swap
  227. l33 swap questions about tac, pedal, and tb
  228. LS3 flanges
  229. 1987 944 Turbo --> LS
  230. Lower driver side truck alternator mount
  231. Convert 4 wheel drive 4l65e to 2wheel drive
  232. MAF sensor housing?
  233. Electric fan control
  234. Rocker Covers with comp cams roller rockers.
  235. Turbo 5.3 > 2jz E30
  236. Stock lq4 twin turbo advise
  237. Foxbody ls/t56 swap question
  238. LS Vega..UGH Power steering and alternator mounting issues
  239. How far can you angle an LS engine? custom hot rod
  240. Can the 4l80e transmission fit in a g35
  241. How do I plumb this?
  242. 1989 bmw 635csi lsa conversion
  243. 280z ls3
  244. P1518 please help please
  245. TB post and polish service?
  246. LQ9 Engine swap for my 84 T/A
  247. LS1 Dakota headers
  248. Best retrofit tank and fuel pump
  249. Rams horn manifolds?
  250. Fuel level? Ls fox with everything holley
