View Full Version : Conversions & Swaps
- Alternator & A/C clearance on the '65 Chevelle
- Inline fuel pump, Wire to existing fuel pump relay?
- Where the heck did I see that Camaro at?
- Should I use an aftermarket K-member on my 3rd Gen LS1 swap?
- need wiring help
- Swapping out T/A accessories for CK type?
- Convert Make LS1 400cui?HELP?
- Could be a problem with steering mainshaft
- LS1 is now in the 69.. made it work...
- 98-2003 Camaro Brakes on a 68 Camaro
- finished ls1 in my 69 pis
- connector C105 question, 98 vs 99+
- LS6 Crate engine storage?
- Power Mirror Conversion
- fuel system help
- Fuel Tank Sump
- battery wiring
- What to use best?
- T56/LS1 300zx 90+ conversion.
- LS1 IN 69 Chevelle
- 99 Camaro Body Parts , Cheap, For Pick Up
- 69 LS1 update.. many parts installed.. pics
- What older truck should I dump a LS1 in?
- LS1/LQ4 into '71 Chevelle
- Reprogramming, what to change and remove
- Autometer speedometer, One input terminal?
- Looking for pinouts for the underhood harness on 98 LS1
- 02 Stock Wiring Harness Mod, What do I have to do?
- Sneek peek at my LS1 (now LS6) for the '63 Grand Sport
- 2001-2003 is "Returnless" like the Vette?
- Accessory Routing - No PS or A/C, alt high on left side?
- What wiring harness for LS1 swap
- Autometer gauges with stock LS1/LS6 sending units?
- Vacuum routing help
- Alt. connections.
- LS1 into a '75 Vette - questions?
- LS1 into C4 Conversion
- o2 sensor ????
- 280z and 280zx
- Vacuum source for vette FPR
- looking for pics of radiators in 1st gen with ls1
- will my stock gauges work with the LS1?
- Construction pics: front suspension fabrication
- LS 1 Oxygen Senser
- Ls1 MG?
- Speartech shop shots
- speartech wiring & computer reprogram
- Power steering questions
- ls1 240z update pics
- does anybody have this ls1 emblem?
- ls1 power steering to 69 camaro box, fittings?
- Source for Intermediate Length LS1 headers for 3rd Gen's!!!
- would a '97 corvette igniton switch work?
- wiring/guage questions
- ls1 in a jag?
- LS1 in to an 8 series?
- 18" Magnaflow XL Duel Mufflers 2.5" in a Jeep Wrangler??
- Some insight needed?????
- lS1 emissions test?
- Engine decisions,,,,,,,I need advice
- Custom Header question in External Engine Forum - Help?
- SBC vs. LS1 motor mounts...
- LS1 swap into an 86' IROC
- Old S10s are cool to....wink
- Starting to convert my FD3
- LS1 Edit?
- Need advise, what to buy
- again a fueling question
- Northstar V-8 Camaro info?
- 99 v6 camaro swap help
- Bypassing starter relay and fuse on LS1
- Ls1/t56 To 61 Impala Bubble Top
- Grand Sport Hybrid project update:
- LS1 in a DSM?
- 3rd gen swap - extending wires to mount computer inside
- What type of fuel hose can I use?
- conversion questions????????????
- LS1 oil pressure sending unit resistance?
- looking for ABS technical info.
- c5 alternator wires
- Anyone have an FSM for 97 Suburban/Truck?
- 4.3 Vortec Wiring
- A/C with the LS1?
- Ls1 c4 swap?
- Ls1 swap in c4?
- 93-96 Impala's and Caprices
- 3rd gen LS1 Swap, Ignition relay questions
- 96 V6 to LS1 Conversion questions
- LS1 in third gen-vats
- LS1 Plug Wires
- 02 LS1 using 98 PCM/harness --- will that work?
- ls1 engine in an fwd 04 grand prix?
- 6.0 or 5.7 in a 72 K5 Blazer?
- Vehicross conversion...
- ls1 in 1984 avanti II
- FOR SALE: BRP steering rack for 1st gen F Body
- Power Steering pump reversed?
- Will something go right....
- Where is the cheapest place to get a Walbro 255 LPH inline fuel pump?
- Fuel filter-Regulator Combo, which is the return
- air injection, how do I pass?
- Wiring Issues.. 98 V6 A4 Firebird--->'02 LS1 A4
- Any links or write up's on installing a LS1 in a first gen camaro?
- LS1 240z pics
- ls1 engine harness to painless
- Speed Inc. Fuel Pump
- '80 vette ls1 conversion??
- 4 and 5 speeds behind LS1s
- A few simple wiring Qs
- How to Convert a FWR to RWD with the LS1??? Please your help...
- Why want my clutch pedal push in??
- Updates 1/25/04 - Firewall Smoothing
- Want factory gauges? Run this combo
- Ques about truck/f-body coil harness...
- New updates of my 67 Chevy II
- ls6 in thirdgen
- '99 pinouts the same as '00
- lookin for a ls1 powered sonoma/s-10
- ls1 in 69 camaro, electric fan options???
- LS1 in 2nd Gen Camaro Help needed
- C3 vette guys, what is my weight?
- Need wiring help???
- Conversion folks please list what you are using for headers/exhaust manifolds
- Holden Exhaust manifolds?
- My motor arrived- Wednesday it leaves for the machine shop!
- What torque convertor for 4L65E tranny?
- New color scheme for my Grand Sport!
- Is this the fuel filter with the built in Reg?
- Need help quick, will this combo work?
- Need Feedback For Ls1 Swap!!
- Mark, any update on the GS?
- 96 Mustang GT LS1
- LS1/Miata
- Carbed 350 into ????
- Where to buy an engine?
- single vs two line fuel system
- 97 phantom dually sonoma ls1 swap wiring issues
- looking for a shop to swap an LS1 into my Iroc-Z, In the lower region of Tx (RGV)
- transfer case options with 4L60E...
- VATS bypass?
- Custom pully needed
- New Guy, Henry J LS1 Questions
- pin-out config for 2000 LS1 computer?
- High mount Alternator
- Congrats to jsworkstd
- Fuel System
- another fueling question for the conversion
- anybody attempt to install a hud in a conversion?
- LS1 and Kooks Long Tubes in a 71 Vette??? Will it fit?
- Speed Inc-Fuel rail Opinions
- speedo
- Steam hose???
- Air Conditioner Compressor Compatibility
- Help me find a donor car
- What size?
- how to self modify ls1 harness
- long tube LS1 headers for S-10's/blazers?
- LS6 crate engine?
- Thinking of doing a LS1 swap for into a 70
- Drive Cycle
- R32 Conversion ?
- Oil Capacity
- Help on starting a conversion.
- Weight of LS1 longblock?
- Jeep Liberty
- What does the VSS signal look like? Can I make a simple digital speedo?
- Best Muffler Brand/Type For An LS1???
- am i sick for wanting to swap a LS1 into a 350Z?
- Has anyone modified standard SBC headers to fit an LS1?
- How much $$$
- Extreme-G Camaro update - Jan 1, 2004
- Turbo Diesel Camaro/Firebird
- fuel system for ls1 in 1st gen camaro or other cars
- 1955 chevy pickup LS1 conversion
- ls1 install book for 02 S10
- Ls1 in a Jeep
- F-Body Dual Electric Fan Question...
- Upgrade options
- thinking of LS1 into mazda miata
- LS1 into 1st gen Camaro update
- who makes chrome alternators for 99 z28 ls1 ?
- I need headers for my 97 sonoma swap where should I buy?
- Difference btwn F-body and Vette PCM/Harness?
- LS-1 in an aircraft
- Check out this sweet conversion truck!
- Does March Make Pulleys For Ls1 Motors?
- Got bored, long burnout - My LS1 RX7
- For Sale - 1st Gen F-Body Twin Turbo Headers
- Notched Oil pan questions
- Now this is a burnout!
- Website for Blazers
- LS1 into an 'A' body 67 chevelle
- Finally dyno'd my truck! I'm happy
- I Lost A Sensor??
- street and performance headers
- idling rough after a few days...
- "Bad" ebay deal...
- In car video: My V8 RX-7's
- First Fire Up With Exhaust Done..video
- whos got the info on rx7 swap?
- 99 ls1 power steering hook up to 69 camaro
- new conversion getting started
- I'M ROLLING... Thanks for the Help!!!
- Any ideas???
- New content: pedal and master cylinders
- Engine running finally, now on to tranny woes
- "Reverse" swap help needed... (LS1 to EFI SBC)
- EGR block-off plate
- Motors in, now all the "while I'm at it's"
- Im cranking but it will not start....
- Can I use these 85 Trans Am parts on my 98?
- won't crank, any Ideas???
- Longer Spark plug wires needed
- whats the best cold air intake for LS1?
- egr tube on intake on 99 motor ?
- Motor mounts for a 66'nova
- Which fuel line?
- ca smog legal conversion?
- help with speedo
- LS1 in a LT1 car, Have questions
- Books
- what fuel rails on 99 motor in 69 camaro?
- alternator relocation
- LS1 350z
- Finally Making About To Convert My 68 Camaro To An Ls1 Engine!
- HELP! - wouldn't crank first try....
- Clutch Master Cylinder and booster Fitment
- Plug for oil level sensor bung.
- LS1 rack and pinion steering First Gen Camaro
- Using stock LS1 wiring harness as a stand alone on 3rd gen
- Evap canister question
- How to hook up shift linkage?
- Wire Harness for 1st gen
- Datsun 240-Z swap
- Group purchase of T56 install kits for 1st gen Fbody @ Pro-Touring.com!!!
- LS1 in to a NSX?
- engine angle with custom mounts
- Almost ready to crank for the first time - Quesion
- Black Underhood Paint Color Code?
- Are all the 98+ BCM's the same?
- 67 Nova in Jan issue of Hot Rod Magazine
- 3 month, 5K mile conversion update!
- need help???
- Data Connector Location
- New here, hi
- over heating ???
- LS1 in 1964 Impala SS
- More Ls1 In 69 Camaro Questions, Sorry
- Any 3rd Gen V8 RX7's?
- 97 sonoma swap quwstions
