View Full Version : Conversions & Swaps
- Chevelle Guys, what cam and stall
- Head gaskets
- Odd mix any ideas?
- 1993 LX mustang converting to LQ9 with twin turbo
- couple questions for guys with gen 3 blocks and ls3 top ends
- Drive by wire pedal
- Anyone have good pictures of the spectre 70-73 Camaro EFI fuel Tank?
- what are these fittings on my radiator for?
- LS1 into 1969 Firebird Oil Pan nightmare
- LS2 Miata - first start in need of help
- Direction Please
- TH400 to 5.3 issue
- 98 Firebird LS Swap V6 To V8
- Mustang LS FAQ
- Instrument cluster
- 63 Biscayne with LS conversion
- Intake options?
- 1992 Sonoma GT getting an LS1 drivetrain!
- Opinions. 3rd Gen Celica. To buy or Not?
- running wiring through the firewall ideas
- Fuel line from LS1 rail to vette filter\reg
- 59 Vette
- Nissan 300zx Build - LQ9 with S475
- Could you LS-swap an 85-88 Grand Am
- Anyone tell me what part this is?
- Which motor to go with?
- Desperate - '06 Vortec Cruise Control
- Which 4L60E do i need?
- Factory motor mounts
- Newb needs some help with parts selection
- Rear Disc Converison
- Trying to do a Turbo LQ9 with AC in a G-Body
- LS2 t56 into 1972 Buick Skylark....few questions
- 4L60E from 03 Chevy Express - Will it work with 2000 LS1?
- ls1 swapping into 99-04 mustang. Swap help needed! again!
- 5.3L into Sonoma… Headers
- GM Swap guys need radiator suggestions
- GMPP Controller vs. PSI or Speartech LS3 480 Crate
- Just In! 2014 LT1 C7 Drivetrain!!
- Which ATi Balancer for the 6.0L in my 1978 Malibu?
- C4 LSX swap
- Steering column fit?
- Bobls needs help??
- Engine mount brackets
- We are now a Dakota Digital Dealer, and a new twist on their pulse generator
- My 90 LX LS/Tremec3550 combo
- best alternator for ls swap?
- anyone cut down a vortec tensioner to fit ls1 water pump?
- lq4 6.0 in a 63 nova with a procharger have a few???
- How are you guys insuring your swaps?
- Jeep ly6 tranny
- LQ Fox Build
- V6 to V8 Fbody Swap with a twist!
- My 88 GTA!
- Fox mustang 1350 universal joint conversion.
- 10.31@137mph road race LS7 FD RX-7 thru cats!
- Mounting coils directly to valve covers
- Coil mounts
- 4.8 cj7 startup issue
- built ford tough w/ chevy parts need help!
- Header ideas
- 93 Mustang power window fuse ? (starter)
- g body vs 75-79 x body for 5.3 swap
- 95 V6 Camaro to 5.3L
- John's 69 Chevelle LS1/4L60E
- Motor to frame grounding strap?
- LSX twin turbo 52Mercury
- l76 help from australia!
- 89 (4 Cylinder) Mustang 4l60e Shifter Cable
- Alano Grove Compressor Mounts
- PCM Mounting location questions??
- Another 5.3 mustang notch
- Need info..LS 6.0 into a Gen 2
- possible to use hydroboost out of my mustang
- Break-in oil for turbo 408 lq4?
- Engine mounts 67 camaro restomod
- Anyone done a T56 or T5 trans on a LS Fox?
- 2000 Mustaro Official Build! Area 51 CoNFiDEnTiaL!
- 6.0 liter spits and sputters
- 2000 s10/lq4
- 2008 Pontiac G8 GT - auto to manual swap issues
- Need advice on mail order tuning please
- Fox Swap Engine Choice
- LQ9 injector plugs confused
- oil pressure issue
- LS swap into 1996 GMC 1500 2wd truck
- 98 Fbody wiring.
- DBW problems p1518
- Question for those with a GTO E40 PCM Flashed to SSR/Trailblazer SS OS
- 1999 LT1 4L60E to 1999 LS1 4L60E
- HELP 3rd gen camaro swap
- cooling fan
- Has anyone here done the LS swap into a C3 Corvette?
- Clutch Help-LS3 and Ford tranny with 6037 bell, pedal feels like crap
- GM A-Body aftermarket seat height improvement
- wiring harness help
- 64 chevelle
- Best catch can?
- Updating wiring for Swap and ecm mount 68 Firebird
- Pro touring miata (Build thread)
- Ls2 high idle after lightly pressing gas pedal
- 1964 chevelle
- LS fenderwell headers
- Gen 2 Viper T56 OR Gt500 Tr6060 unto LS
- Datsun Z-car
- 1st gen firebird questions.
- LS fuel system swap
- Weather Proof Fuse/Relay centers
- Wiring questions, alternator/starter
- Lq9 in a 69 nova. What length lokar throttle cable?
- 66 Canadian chevelle
- Decisions....Questions...L33, LQ4, or LQ9
- LM7 build cost
- looking for some1 to do my 2nd swap for me. I'm in Michigan
- Starting issues
- 2010 Camaro 6L80 Swap
- GTO power steering + IROC box
- LS1 vs LS2 for a 68 Firebird?
- Couple Questions for A-body LS swap
- Need help solving p0154 p0134
- LT1 Fbody to LS Swap
- Spark plug wires for distributor swap?
- LS6 CTSV PCM with FBody Harness for K10 LS6/700r4..will it work?
- Jeep Jk Rubicon Lq4 swap
- What's a good floor shifter donor for a 6L80 swap?
- Is there a picture list of all (most) factory motor mounts?
- soldering gas tank
- 68 Vette LQ4/T56 Procharged
- L33 DBW Help. Which pedal?
- Accelerator Pedal
- 5.3 into 68 f body
- LT1 T56 to LM7?
- 64 Corvette LS Build W/ Art Morrison Chassis
- LY6 parts
- 5.3L Wrangler
- VIN location on the 2011 6.0 Block?
- GM Electronic Throttle Control
- L76 from G8GT to GM A-body
- Engine Alignment
- 62 Rambler American Wagon 5.3 swap
- ls swap coupe manifold question, helppp guys
- Which iac? what the differences? please help
- Fox body swap...what will I be getting myself into?
- 64.5 Mustang conversion to 6.0 LY6
- 6.0LSX swap into a 71 Chevy C-10
- Any GM body LS conversions for sale?
- Magnaflow cats - how close is too close?
- Vibration
- Another 89 notchback swap supercharged
- Vendor Intro Post! Scram Speed -LSX swap parts
- oil pan change
- Which trans mount?
- Foxbody brake upgrade ideas?
- 98 Vette LS1 in 91 240SX wiring for fuel pump
- VHX gauges and E38 ECM Speedometer output
- 91 s10 alt on dirty dingo bracket
- What is this plug? L92
- ly6 in a Comanche
- Fuel question need help
- 1st gen F body- are body bushing/spacers required?
- LS3 intake - Why swap it out?
- Question for those who used Ford Headers
- Pcm
- 72 Nova - The Booboo Project LS/4L65e
- Trick Flow Track Max Camshaft ?s
- AmericanRacingHeaders "LS Swap Headers Tech thread"...Camaro, Chevelle, Nova......???
- Wire Harness "Rebuild" - Who Would You Recommend?
- ignition and starter on fox body
- Quick O2 sensor question..
- Gbody floor shifter with 4l60 + b&m cable
- Flexible radiator hoses
- 95 S-10 Blazer and 2000 5.3 4L60E Swap Wiring Question
- Holley 302-2 Pan
- lil fox help please.
- I'm at a loss...yoke is stuck in tranny
- lq4 swap 02 sensor help.
- LS Crown Vic
- lq4/mustang/ turbo or nitrous ???
- Converting DBW to DBC
- 346 s10 build
- Foxbody swap question
- Deleting stock ecm, keeping airbags?
- shifter
- Cam identification help
- Trans compatibility
- Help me find Pro touring look rims on a amateur budget
- 1999 Camaro
- Low Vacuum problem?
- First startup bugs
- Hodgepodge build???
- 78 Nova LSX Budget Build
- Live LS7 Swap with new Holley Kit - ROADKILL
- My 73 camaro gt45 turbo 5.3 build thread
- coolant Recovery Tank for 69 Camaro
- Fox Mustang, LS1/T56, Max Motorsports, IRS, engine relo, custom headers, etc
- LS1 to LQ4 questions.
- Old School LSx 1967 Camaro
- TBI to LS1 fuel setup ??? Help!!!
- F body alt vs gto alt
- catalytic converter insert for headers?
- lsx 376 short block with 799 casting heads
- LS7 alternatives - Best value in large cube LS?
- New swap, Dirty coolant coming out? Also Fans issues?
- Where do these 2 wires go?
- Motor dies when making a quick stop
- 2007 Kia Sorento - 6.0L Ly6 Vortec
- computer under front seat on 1st gen F body
- Lq4 87 foxbody swap, pcm and wiring questions
- Foxbody driveshaft angle
- Fuel vapor line or NOT ?
- I gotta stock LQ4 alternator question
- Can I make these Guages work?
- L92 maf question
- LSx in 91 Fox body vert questions
- 65 Impala SS L92/4L80E Conversion...Update...It Runs!
- 2010 LS3 6L80 swap help
- fox swap exhaust question
- LS1/T56 In IROC, Need Help Filling In Blanks
- Ls6 Steam line help
- Need Help: Smog Legal LS3 into OBD1 240SX...
- Long Awaited 68 Camaro Build
- Scrambler 6 litre won't idle
- Lq4 foxbody exhaust question
- 88-98 truck headers
- lq4 swap, got spark but no signal to the injectors
- New Hooker 1st-gen/Nova swap parts info
- Bob's 77 C-10 Stepside
- Ls1 240sx swap, Coils/Injectors not getting power
- hptuner on older cars???
- CBM water outlet users
- 1973 Trans Am LS3/T56 Project
- Need real time help, where is the TAC on a 2010 Silverado ?
- Austin Healey Sprite w/LS6 200-4r
- 1955 ? International pickup - LSX swap started
- Dash Rebuild, Speedhut Can-bus.
- Turbo 5.3 with t56
- LQ4 Miata HELP!!!
- battery in trunk--best way to distribute power
- Parking lights always on/won't turn off
- ls1 into 2nd gen camaro
- Neutral startup...tires spin??
- Speed Inc 1970 4x4 Blazer LS3/6L80 TT(budget)Pics
- G Body LQ4 with 4L80E - Rear Gear Ratio Recommendations?
- 1986 C10 LQ4 build, looking for advise
- Viper T56 and 5.3
- Need Help:::: 1968 Chevelle Lq9 swap
- On 3 Performance LS1 swapped Foxbody Kit / Build
- crankshaft spacer for 5.3
