View Full Version : Conversions & Swaps
- 408/TH400 in a 93-97 fbody?
- 04 5.3 harness to standalone
- Question about hose....
- Fuel Rail Cover Question
- Fox body, AJE K member, LS2, Kooks 1 7/8, which oilpan?
- Swap a 396 BB for a 5.3?
- Oil Plug
- 6.0 from van, im missing the P/S resevoir. What are my options?
- external fuel pump
- LH8 Oil Pan kit arrived today
- LS1 and 200-4R
- Any Tricks To LS1 Oil Pan Removal In Vehicle?
- cooling issue ?? at idle
- ls1 in 81 vette?
- BRP / Hedman header swap dyno and track #'s
- LH8 oil pan in 3rd gen camaro?
- Project "Scraps" Mast Motorsports Drag Test Car
- Help with mechanical fan removal
- 66 Nova LS1
- clutch assembly
- 5.3L truck motor bolt to T-56?
- 5.3L truck engine, got some questions
- My 72 Chevelle w/LS1,4L60(56K Warning!)
- Third Gen Header ?
- 4.8 into 2nd gen camaro
- Cross reference parts 2004 lm4
- 98 Vette LS1 into 66 Skylark first test fit
- LQ4 VATS bypass . Which pin on the ECM to hook up to?
- Throttle body hose?
- conversion mount question???
- Anyone made custom coolant lines?
- Recent pics of my 73 Camaro.. Much more than a motor trans swap.
- Anybody know if LS motors use a charcoal canister?
- fuel pressure gauge
- 5.3 pan and stock 4.6 k-member?
- Carbed ls1 ignition options?
- What's wrong?
- 99 Wrangler LS1
- 2002 LS1 into 2005 RCSB Silverado 1500
- 6.0 LQ4 parts for sale
- putting an ls2 on an 04 gto
- 69 Impala swap done..
- good deal on ls1
- MSD 6010 user, need some help please
- SS Trailblaser pull out
- Am I crazy? Just a thought.
- Got Heads??
- Fuses, Relays, and Solder.....Oh my
- Stuck master cylinder
- G-body turbo 5.3L
- Suspension on a ls1 to 2004 mustang swap.?
- couple mustang wiring Q's
- need headers for 94-04 S10.....*HELP*
- My searching brings the suck
- Clutch Switch Wiring?
- Is T4 T67 too small for an Ls1???
- Where to find complete LS1 motor and T-56 trans?
- LS1 VS LQ4 Accesories
- A couple of questions... LS1 240sx with 4L60E
- first crank today - intermittent fuel pump
- Anybody have a retro rides 1st gen?
- Silverado Fuse Block/wiring help wanted!
- wiring help pls? (clutch switch, and A/C signal)
- 99+ V6 Harness to 99+ LS1??
- swap that kicks some butt
- wow, this sucks...
- 1994 RX-7 With Mast Motorsports LS3 427 SS
- LS1 vs LQ4 Water Pumps
- Wait4meperformance.com GTM supercars
- Lsx Into 93 Ford Lightning!!!
- '04 LQ4 from van and harness/ecm from '02 truck. Any issues?
- 6.0 a/c brackets
- 6.0L in 240sx
- First startup Bad Idleing... (240sx LS1)
- Ls1 powered '68 Nova
- Fox 8.8 driveshaft to lsx t56 u joint?
- Newbie question on 6.0 truck engine
- muffler selection
- Need help pulling harness out of car
- LS1 into my colorado
- LS1 mini cooper finally an update! (pics)
- Another A-Body: 72 Malibu
- FS: LSX fox swap stuff, LOTS OF STUFF
- LS1/5.3/6.0 in a truck questions
- "Big Red" 1986 5.3 T-6 turbocharged Regal
- started my fox body swap today
- 4.8L vortec into camaro
- Newbie questions
- T56 Mounting Ear
- Anyone here educate me on a turbo ecotec?
- knock sensor check
- FOR SALE 1971 Chevelle SS LS1 6speed
- fuel cell? ls1 fox
- Rubber grommet needed
- question for you guys
- fuel pump fuse
- Any central Ohio swaps?
- LS into 69 camaro project
- carb 5.3 build questions
- The swap begins-04 5.3(lm4) into 76 vette
- Why the HELL are my intake runners CRACKING on my Victor JR intake?!!
- LS2/4L65E Swap c3 vette
- 1971 Buick Skylark: LS2 and 4l65e project
- Grounding my LS1
- ??? about ls7
- 5.3L into 95 Firebird?
- Guages for my 6.0 4l80e Chevelle?
- 84 Silverado 5.3 Swap Trans X-Member Advise Needed
- LS1 Jeep Scrambler----Scrambled!
- Idler pulley relocation brackets back in stock
- IROC Gauge Wiring?
- anyone tried the doug's first gen camaro swap headers
- Has anyone rebuilt a water pump?
- Question about pedestal vette style mounts
- return style fuel with 97 vette rails
- To L33 Or not to L33? BMW Swap
- Took my Teutonic creation to the drag strip
- LS1 into my 95 T/A
- which color wires of Ign. Switch w/PIX
- New swap Project 69 Nova SS!
- Why hasnt anyone put an ls1 in a Lotus 7 Yet?
- NC Engine Swaps
- VSS Adapter
- What to do with fuel tank pressure sens.
- Water Coming Out Of Exhaust Manifold Bolt Holes??
- Need offroad Jeep LQ4 tuned in Sacramento
- LS1 to LS2 Intake Swap
- trans options
- LSx cherokee
- noob here '04 LQ9...is this a good price???
- A body w/LS and mech clutch linkage
- S10 lt's
- Which wiring harness do I need?
- Going to Dyno tomorrow,any guesses on what kind of HP and Torque # I'll make?
- Swapping a 6 speed into 70 chevelle
- clutch slave cyld.
- Help! Engine Stalling a LOT
- Edelbrock Conversion Headers and Exhaust
- speartech har. for the wires that goes to the brake switch for torque converter
- O2 sensor bung plug?
- Will a drive shaft out of 98-02 Fbody work on 67 camaro?
- ls1 fox t56 m/c
- Question about 5.3 accessories
- Charging system woes 57 BelAir W/LS1
- New Third Gen LS1 Swap
- what is this? (LS1)
- water line to throttle body - needed?
- MAP pressure line hookup?
- 350 to 5.3 swap
- a/c unit
- 6.6 Duramax into my T-56 f-body Trans am PICS!! ??????
- Throttle position controller??
- 07 z71 truck...wanna put lsx fbody intake?
- FS: 2003 Chevy 5.3 42k $1300
- a il hepl is all i need
- 91 camaro
- HEEEELP! 69 a body swap PROBLEM!
- First Gen Header options
- 2000 BMW 540 5.3L Turbo Project
- How much gain from LS1 to LS6 intake
- 5.3l vortec swap in c3 vette
- not mine, but parts for conversion
- 1998 harness with 2001 PCM with 2003 LS6?
- 6.0 heads on an LS1 will it work?
- Will an F-body alternator fit on a C5 alternator bracket?
- now my carb is running horrible!
- first gen camaro gas pedal, take 2
- LQ4 upgrades prior to installation
- L59 questions
- LS3 in a '37 Packard
- 66 Skylark Swap
- Educate me on pre-1970 Lincoln Continentals?
- '78 Malibu Motor Poll
- Anyone parting/have 4.8l internals laying around?
- swapping a sbc for an lt1
- 1994 GMC : Sierra 1500
- 68 camaro efi
- EVAP purge solenoid removal question
- Trans Conversion Cross Member For Sale
- Considering a LS Swap into my 90 Trans Am... advice welcome!!
- Super Clean Fox LS swap
- LS Fox Oil Pan
- Christmas came early for me this year!
- BRP conversion kit for 70-81 F-body FS
- My RX-7 build thread:
- engine temp rising in stop and go
- LQ4 into a 3rd Gen/1972 Nova
- ls3 swap, in car acceleration, cutout video
- coolant flow direction ???
- Another fox body build
- LSX Fox body swap...
- Good deal donor car in GA
- Dead fuel pump
- starter wiring
- MSD #6010 users turning 7k and more?
- fox swap radiator?
- Question Lt1 to Lsx swap Related.
- Engine identification
- Ls2 Swap into Triumph Wagon. One of a kind!!
- s10 ls1 swap and built 200r4/ls1 swap
- Fuel system leak
- G-Body Engine Stand Removal?
- New GM Oil Pan Kit with part number
- Carb ls1 Foxbody throttle cable
- Radiator hose splice
- tach and engine temp connection issue
- BMW E39 540i Engine Swap Questions
- 67 Chevelle LS1 Radiator?
- Anyway to read knock sensors with a carb setup?
- Tranny Dipstick Fitment and starter fitment
- 4.8/5.3 with ls intake
- 4L60E in a 72 Elcamino
- Cruise Control w/TBW-ETC Question
- What kind of MPG? 77 Camaro with 4.8, 4L80, and 2.56 gears
- LS1 into my 1987 turbo 2 RX7 !!
- Header\exhaust manifold measurements
- 2000 firebird and a supercharger
- Walbro pump problems
- Borg Warner Turbo s475 1.10 a/r 650$
- Help motor won't start
- AJE k memeber fox body swap
- corvette accessory drive
- C4 ls1 update (new pics)
- GBody LS1 Swap header questions
- What did you pay for a complete 5.3?
- Anyone planning on LT1 to LS1 conversion, look inside
- WHAT THE HELL!! c4 swap problems
- vette accessory belt diagram?
- Gas Tank Opinions?
- f-bodies inc - bad experience with wiring book
- MAF wiring question
- Miata LS1 swap price??
- what temp is stock for coolant relays
- Need Help Hot Wire Mod???
- Ultimate Sleeper---PRIUS
- NEW PB with my lsx v6 mustang
- Ignition Switch Wiring
- LT1 to LS1 swap help
- 2007 5.3 into 1948 Chevy 5 window pickup
- Recent pictures..55 almost finished.
- Advantages of 5.3 over other, bigger options.
- Lookout California Drivers
- project 6.0L s10 pics
- Project cheap and go fast?
- An Fitting Part #
- Help - MAP hose?
- LS2 Alt. and W/P belt out of line
- Whats a good cam for a ls1 thats in a sand rail??
- LS2 carbed fuel pressure PSI??
- 67 camaro Ls1 brake problems
