PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 [125] 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. crank spacer preferance question
  2. S10 Fuel Tank Question!
  3. LS3 Alcohol Funny Car/ Altered
  4. WIRING an ls1 into 240sx
  5. Carb Guys: Timing Question
  6. Map Sensor Question (carbed)
  7. Need some local help
  8. LS1 Starts then Dies after 3 seconds
  9. 6.0L into a 67 Firebird. Few questions
  10. My 2nd swap. 86 Trans AM finally on the road!
  11. my 6.0l 72 c-10 build
  12. harness/pcm compatibility question
  13. Wirng question
  14. 70 Chevelle. Want to put some sort of LSX engine into it
  15. LS4 into a 01 impala
  16. Recomendations on Radiator
  17. Will an LS1 and t56 fit into an (old) 2002 bmw?
  18. L92 Intake Gasket #1222-2
  19. Question about ECM
  20. Engine Change Checklist
  21. got my harness now what
  22. steam vent / hose into lower radiator hose?
  23. Taking a stab at an LS engine in my '99 Sonoma
  24. LT1 into 2nd Gen F-Body (automatic V6) question
  25. what radiator hoses for a body?
  26. Choosing the right LSX engine
  27. edelbrock headers wanted for ls1
  28. Aftermarket fuel rails with vette filter/reg?
  29. 4l60e/4l65e/4l70e >>> 6l80e/6l90e
  30. Iat
  31. Physically removing CAGS Solenoid
  32. Foxbody chassis harness questions
  33. Exhaust Flow Question
  34. Street rod swap/Tall accesory drive ?
  35. mating a 392 hemi to a LS1 style T56?
  36. edelbrock retrofit kit
  37. 6 speed
  38. Interchangeable coil sizes.
  39. My homemade ac comp. brackets a body ls 2
  40. Stock radiators ok in LS swaps?
  41. Engine Shipping
  42. 77 Camaro Gen III Swap: Power steering pulley hits steering box
  43. Nuetral Safety Switch Hook Up\'72 Camaro
  44. Ls1 Fox Swap Questions
  45. Where to order compression fittings?
  46. Need help LS1 into 71 cutty
  47. 3 wire vs. 5 wire maf
  48. What are you L92 VVT guys doing for a harness?
  49. 66 Chevelle Conversion with Factory Air
  50. Lsx in a C-Class??
  51. Custom Air Intake Plumbing,,, Post Your Pics
  52. Timing on LS motors 29 or 36
  53. 97 4.3L --> 02 4.3L in Blazer
  54. 67 chevy II swap. i searched!
  55. 5.3 maf trouble
  56. LS376/480 in 73 Camaro
  57. project silverbullet almost done. pics inside
  58. stock fox k-member?
  59. New swap problems
  60. ls1......in a 240sx
  61. msd 6010 timing accuracy
  62. Carb'd LS2 accel pump size
  63. Special One peice engine cover LSX 454
  64. ls1 fuel tank ideas
  65. LQ4/ 1995 Impala SS Problems
  66. question about '91 Mustang LX 4cyl as donor car!
  67. Question on MAF's
  68. 5.3 or 6.0 swap
  69. C100 Connector and O2 Sensor Wiring
  70. transmission wiring?
  71. shortening c6 dirvetrain?
  72. First gen fuel sender not working, possiblly nicked sender wire? Where does it run?
  73. 67-72 chevy W/LS1 Gauge Help
  74. Evap solenoid
  75. selling s10 project.
  76. Selling my LS1 project car. 90 LX NOTCH Mustang
  77. Gauge hookup question.
  78. Some help 08 frontier
  79. 84 ss 6.0/mp122 and 4l80e swap
  80. Help Gauges not working
  81. Pulled LS1 drivetrain from 04 GTO...what else should I grab?
  82. ? using magnertic pick-up for tach/speedo
  83. dfw area ls1 mustang ?
  84. Who has converted to lever style e-brake on their 1st gen?
  85. 1972 Monte Carlo Gen III/ Conversion questions
  86. header progress pics
  87. LS1 z-car
  88. have a chance to buy a lq4/lq9 complete with wiring harness
  89. Starter problem
  90. ls1 into 1995 TBI Chevy truck
  91. Problem With Starter and GTO 6-Speed
  92. 98 f-body accessories on a 99 onward harness?
  93. ls2 coil harness wiring diagram?
  94. 79 elco swap to 5.3 lm7
  95. 98 starter and flex plate ??????
  96. A/C parts needed
  97. Need some help
  98. 70 camaro edelbrock headers bung location?
  99. 88 Jeep Comanche 5.3 build
  100. GM # for exhaust down pipe flanges
  101. 1972 Chevy Pickup 2001 LS1 Help
  102. LS1 Porsche 911 Conversion
  103. Radiator for a Retro fit LS1
  104. fbody wiring harness newb question
  105. quick k-member question
  106. 77-85 Caprice/Roadmaster peeps I have q's
  107. Does PCM need oil pressure reading?
  108. LS into a 94 caprice wagon?
  109. o2 sensors, do you have to??
  110. Alternator help - keeps dieing -72 nova
  111. LQ9/LS1 Into a 93 LT1
  112. 5.3 c10 will not start after running 1 minute
  113. Accessories - just brackets?
  114. 70 c-10 headers question
  115. oil and trans dipsticks
  116. 66 GTO conversion
  117. I need pinouts for a 99 or 2000 LM7
  118. 1996 silverado ls1 swap
  119. 1969 impala ls1 install questions
  120. Anyone know what this module is and/or does?
  121. LS1 swap Oil pressure sender issues.3 wire??2wire??1wire??
  122. Any one swap an ls1 into a 94-95 mustang gt?
  123. help please! question about ecm's
  124. SBC 350 in Firebird
  125. nelson's performance harness or speartech??
  126. Jet power ;)
  127. ls1 t56 on a sbc 350
  128. Anyone want to trade oil pans?
  129. Debut: USA-LS3RX7 Built by TTP Motorsports & Hotlap Motorsports
  130. New GTO Engine in 67 GTO? Anybody done it?
  131. How To Connect TKO 500 to LS VSS
  132. 4WD and 4WD low with 2000 5.3 and 4l60e
  133. going carbed, gauge question....
  134. what to do? lq9 swap g-body
  135. Cam Question
  136. ls1 swap on 86 V6 camaro questions
  137. msd6010/laptop port question
  138. belt stretch question
  139. i sent my harness to lt1350.com, lt1wiring.com BAD
  140. ls1 foxbody
  141. Urgent Wiring Help Needed
  142. Reverse Rotation P.S. Pumps? Who Makes Them?
  143. Oil amount for 4l60e
  144. LS2 intake/TB options
  145. carbed S10 project for sale.
  146. were to get motorsets?
  147. Whats The Best Tranny?
  148. PCM connector terminal part number inside
  149. Interesting idea....
  150. truck intake on 1st gen fbody
  151. why k&n sucks
  152. Something not seen here before MGB LS1
  153. Harness/ecu for turbo swap car
  154. 5.3l overheating problem
  155. Engine in but have mounting problems
  156. mounts
  157. stock compression w/ a turbo?
  158. Anybody using eldelbrock carb
  159. dash gauges hookup in non f-body ?
  160. **99-02 computer for sale (automatic)
  161. Swap almost done!!
  162. Drive By Wire questions...
  163. question on DBW gas pedal
  164. slave cylinder fitting
  165. 1970-1979F150 5.7(LS1) or 5.3 install.
  166. Nublet Question....is there a off-the-shelf kit for fox/notch mustangs?
  167. 4l60e
  168. angled plug wires
  169. questions for 240sx ls1 swap
  170. Identifying year of LQ9?
  171. Speedo/VSS Issue?
  172. vss question for lsx in 97 s10. abs sensor?
  173. LS2 Carbed w/QTP (LS1 Headers) Starter
  174. lexus gs400 ls1 swap?
  175. Budget 5.3/4l60e 240sx Build
  176. FlexFuel Identification by VIN?
  177. looking for coilpack main connector harness
  178. 88 montecarlo 5.3 truck
  179. 400 crossmember
  180. Sorry everyone
  181. 5.3L Heads
  182. Very Cheap Thrills - LS6 Toyota Pickup
  183. towl/haul quite working
  184. Torn between two drivetrains
  185. LS1 in a 81 Malibu
  186. ls1 swap fuel system problem
  187. 5.3 into '68 C10--factory fuse box questions
  188. To those with the MSD 6010, what does your MAP read and what PV are you using?
  189. Chevy ll SB oil pan for $ale
  190. my 95 v6 to 02 ls1 swap
  191. LM7 ECU reprogram
  192. LS1 + 6 speed in Fox coupe
  193. And The Fun Begins
  194. Brake line vendor choice?
  195. i found a solution for my cooling delima!
  196. both male and female plug connected on passenger side of intake?
  197. 5.3 1968 skylark project
  198. What is the "ORN/BLK PCM 34 PNP Switch Signal" wire for?
  199. K-member, what do you think
  200. EFI Gas Tank
  201. 67 Camaro 383 LS1 exhaust?
  202. LS1 in a 93 silverado?
  203. ? about wiring an G-body with a 6.0 motor
  204. Porsche 914 LS6
  205. 94 Mustang 6.0L
  206. LS Conversion For A 1971 Olds Cutlass
  207. 07 5.3 & 4L60 into 84 1/2 ton Chevy
  208. OK i lied!!! my bad
  209. Lt1-Ls1 swappers inside, a few questions.
  210. LT1 brake booster and master cylinder on 68 Firebird?
  211. Mercedes w202 LSx swap
  212. Post up ur lsx swap sayings, ex. Ford makes it chevy shakes it
  213. LH8 Oil Pan from BRP ?
  214. Edelbrock mounts in 2nd Gen Camaro?
  215. LS1 Mustang: Possible to keep AC?
  216. Can an LS1 powersteering pump take atf?
  217. Drag swap suggestions....
  218. fuel pump wiring
  219. Diode Recommendation
  220. Shrader valve at end of fuel rail?
  221. Vette regulator PSI..
  222. Old dog trying to learn new tricks.
  223. My LT1 to LS1 Fbody Thread
  224. LS1 swap into 95Z. Heater controls wont work now
  225. I lost my prints, need help
  226. Simple MSD-6010 Q...
  227. Sensors & Other Thingamagigs
  228. Cleaning LS blocks
  229. just bought the 02 wrx with ls1
  230. My 72 chevelle build thread
  231. GMPP Gen 4 LS3 (Hot Cam) in Gen 3 2000 Pickup
  232. Carb/Cam ls1 MPG
  233. Questions on EGR
  234. O2 problems and DTC
  235. my project lq9 s-10!!!
  236. ECU Programing
  237. Can anyone recommend a good "mini" starter??
  238. Can't decide BB or LSX?
  239. fox body steering shaft?
  240. aftermarket ac through pcm redux
  241. where does this wire belong?
  242. 1986 el camino with 6.0 need trans help!!
  243. how can i make the computer turn the fan on for the AC?
  244. C5R 427 91 Miata build up
  245. C10 Gen III motor swap Mounts
  246. lq4 electric fans
  247. Chevy Vega, any one put a LSX in one?
  248. Wondering about additional parts
  249. LH8 conversion oil pan, need sensor?
  250. ls1 tach driver setup
