View Full Version : Conversions & Swaps
- Clutch master bore and stroke
- Eclipse lol
- Oil Pressure Sensor or Switch?
- '55 Chevy Truck for Tri5Nerd
- 3rd gen ls1's
- LS1 miata facts plz?
- eng help
- LS1 long tube headers for retrofit
- Long tube VS Short Tube headers
- LQ9 T/B vs LS1 T/B
- Alternator Extender?
- oil pan swaps...
- 1973-1987 Chevy Truck LS1 Swap Guys
- U-Joint angle question
- what year ls1 for my 65 chevelle?
- 66 Nova LS1 Headers
- LS1 swap headers??
- Radiator Search
- 1971 Datsun 240Z hybrid? Advice Please!
- Auto Shift Cable ?'s
- Where do you put your PCM in your Conversion project?
- Are all starters the same?
- So what's the scoop on Hooker headers?
- need 69 camaro long tube headers for ls1
- It's starting to look like a complete LS1!
- A few TT 59 Impala LS1 pics
- LS-2 or LS6 in a camaro...easy to do?
- LS1 coil pack pinouts
- Will an LT1 flywheel bolt up to a Gen1 SBC
- t56 bellhousing
- 6.0 in a '39 Chevy
- Corvette Conversion - What is needed?
- LT1 camaro with a ls1
- Several Questions from an LS-x Newbie...
- Overheating problem - heater circulation??
- two 99 LS1 4l60E wiring questions
- yet another crank spacer question
- ECM outputs - hot or grounds?
- TransDapt Adapter Plates
- 3rd Gen Tach - HP Tuners Settings
- V6 to V8 swap questions
- What parts for manual transmission?
- I NEED PICS LSx 3rd geners and input
- 69 camaro ls1 gauge help?
- LS1 in a GTA
- Wiring question
- Third gen guys please help!
- Fox mustang ??
- ls1 on rx-7
- LSx in Fox body A/C help
- '98 firebird cluster with '00 motor
- LS1 in a 2000 RS Camaro
- VATS and BCM
- LS1 Power Steering Pump
- 97-98 vette fuel rails for sale
- Modified Oil Pickup Tube
- First Generation S10 LS1ers...
- I hate to ask but my search failed...LSX into a GM A-Body?
- Modyfied Oil pan Pics(LS1)
- dash swap
- ls1 motor mounts in mustang ?
- What are some good ideals for an LS1 or 2 swap?
- Waterpump/heater hose fittings.
- pics of first gen dash mods and cus. console
- Complete 98 ls1 engine and harness 30k miles
- Chevelle LS1 Wring Intergration
- Got my manifold painted
- Malfunction light worked then stopped...
- LS1 external dimensions
- Shelby Cobra with an LS1 and 6 Spd?
- LT1 OR LS1 any ideas on what to do?
- Heidt's Nova power steering
- hp Tuners
- ASA LS1 race motor
- Corvette Fuel Filter/Return Unit Question
- T56 swap, need electric?
- under hood fuse panel
- Going carbed on LS1 INSIDE PLEASE!!!!!!
- LS Motor plate ?'s
- Need help with first gen swap wiring!!!
- LS4 + Cadillac Alante?
- LS6 into 95 M3...
- puting LS1 engine into 94 A4 LT1 camaro?
- LQ4 swap for 72 K/5 4x4
- Got my Ceramic coated Sandersons back!
- Ok, im going to need help.
- th400 behind a ls1
- LS1 Conquest Pics
- Need some help with part #'s
- More progress on the Stang
- Failed emisssions and no codes....
- GN rx-7
- Slave Cylinder Quick Disconnect fitting
- LS1/T56 into 'Stude---HELP
- Where does the 4l60e tranny temp sensor go?
- ok what would u guys recommend lt1/ls1
- stock 99 s10 PCM on a 2004 LS2
- HELP - seem to have an ignition problem
- Random stuff - Mustang trans Xmember
- 68 Camaro + LQ9
- corvette V10
- upgrade to LS1 in my 3rd gen?
- Fuel Tank Pressure sensor?
- 4.6 motor mounts on 5.0 k-member
- LS1 Install - Chicago area - Any takers??
- LS1 swap into a 1991 nissan 300zx-can it be done?
- how different is a Corvette LS1 from an F-body LS1?
- Question about Ls1 swap....?
- LS1 MAP sensor removal
- ECU Interface
- Which LSx for '56 Chevy on budget?
- Tach Output - HP Tuners Setting
- f-body ls1 oil pan & A-body(69 chevelle)?
- FS:93 mazda rx7 chassis $6500 ($5500 without options)
- Well, i guess im an S10-LS1 guy now..
- Where to find metric adapters??
- bmr k-member
- Clutch Line Size for Tilton Master
- www.thecarspace.com
- 89 S10 gage cluster
- A lil video for you S10er's
- fuel regulator location?
- Does the engine and trans need to sit level in the car?
- 6.0 LQ4 to LQ9 Truck Conversion Question??
- another ls1 fox body question
- Fun project: 2001 v6 camaro body - 2000 T/A driveline/interior
- LS1 or LT1 in a 1978 Trans Am
- Help. 2002 LS1 in RX-7 wont start.
- ls1 in second gen help
- vortech 5.3
- Pace setter headers modification
- It's looking like I may be doing an RX7 --> LS1 swap soon...
- ls1 in s2000?
- 92 Camaro RS + $7,000 = ??? (help me think of something please!!)
- Tach Output Signal
- 68 firebird with a ls2 396 could it fit??
- lq9 swap
- Auto to Manual swap
- Oil pan
- Using LS1's HVAC...BCM?
- Acc Bracket space difference
- 2000 pcm pins
- will 6.0 ls1 bolt to 200-4r trans
- ls2 cam in a 6.0?
- LQ9 in 95 v6 a4 Questions
- LS1 Engine Conversion!
- 2nd gen auto shifter
- Few more Turbo pics of 59 Impala
- i've got a 65 vette...
- T5?
- O2 sensor actually different?
- 1994 Camaro V6 To Ls1 Any Info.
- PRC heads/Stainless Headers
- Cheapest place to remove VATS?
- ATTN: Mustang Guys, Suggestions for hydraulic clutch (fox mustang)
- ls1 or lq9 into a 98 c1500
- 4.2 ltr swap questions.
- 62ChevyII project need advice
- Master and Slave Cylinder Question
- Chevelle radiator hoses
- VSS signal different A4/T56?
- Using complete 4th gen body harness in a different car
- finally driving the Mustang
- 90* reducing elbow.
- Tremec 6 speed shifter.
- 59 TT LS1 Impala custom gauge pics
- LS1 plate problem with 3rd gen
- Need LS1 emissions info...
- About to buy a motor, need answers
- LSX drop questions
- 95/98 ls1 video finally runs
- LS1 into a Vauxhall Astra Coupe
- Datsun LS280Z Update!
- LS1 Ford Capri starts!!
- 68 C10 LS1 conversion headers
- LS1 in my '60 Pontiac
- LS-1 headers
- 6.0 into 86 monte.
- Pics: 92 TA vert swap, 99% finished
- PCM circuit/wiring questions
- Do you think camaro lt will fit in a fox body?
- Brake Woes... People with brake knowledge please help.
- Question: Hacking stock 98-02 manifold
- LS2 into 57 Chevy
- ls1 to th350, parts needed?
- steel braided line
- Advice and Guidance
- Finally she lives 1995 to 98 ta a4
- Water Pump
- LS1 fan swap
- Difference between a 98 or up LS1 and regular 5.7
- cable clutch set up tko ls1
- Mechanical speedo on T56
- LS1 engine weight?
- Pics of Pacesetter LT, need lil work
- autometer tach hook up
- speedway header kits
- Tremec TKO 500/600 swap for Fox LS1 swap?
- 5.3
- supra sleeper????
- motor for sale
- LS1 in a Porsche 912
- Reverse drivetrain direction
- Pictures of LSx
- Feeling out responses
- I need LS1 S10 help
- I have a question for yall.
- Dual line fuel rail to one line?
- LT1 to LS2 Questions?
- looking for Steel fuel line with GM male EFI connections
- Radiator cap pressure for LS1?
- ls1 and my 68
- Camaro Dash swap??
- advantages of LS1 over Turbo Buick motor?
- ls1 conversion help....
- T56 Shifter Relocation
- LQ4 swap into a C4 corvette in progress
- custom long tubes
- hey steve Your car is a bargin haha!
- 4l80e?
- Gas Pedal Options?
- Bolts?!
- what do i need to install a ls1 into a 69 camaro?
- GENIII in 69 C20 4x4
- Ls1 runs finally
- Stoopid mount question
- My '69 Camaro is done and hit the road
- Mallet Canyon/Colorado LS7 conversion.
- Colorado Canyon LSX swap? How tough?
- Pics of Trans-Dapt MM brackets/notched oil pan/Turbo Headers
- ultimate sleeper
- Silverado, Sierra 2WD 6.0L swap?
- Any LS1 Vega swaps?
- Cheap place to buy an LS1 in the UK ?
- Ls1 Cj7
- AC for my 69 Camaro - LS1???
- my new project
- 69 twin turbo project....
- Third gen LSx motor mounts-help guys!
- Extended LSx wiring harness?
- Swap into Porsche 930?
- Pics of my LS1, what needs to be done?
- Anyone using Painless LS1 EFI harness ?
- Headers finally fit
- Corvette accessory brackets
- what headers will work?
- Engine codes ?
- 5.3 oil pan gasket
- accessory drives
- LS1 Studebaker - Crossmember finished!
