PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. 5.3l in 2nd gen cam help!!!!
  2. LS1 Transverse Mount Kit
  3. V8 Solstice from Mallet
  4. Spohn adjustable torque arm 3rd gen question
  5. Oil Level sensor plug
  6. Any drawbacks to this radiator?
  7. 4L60E mate to 02 LS6 ??? Will it work?
  8. So... SEMA is over right?
  9. Temp or Oil Sender adapter 1/8 NPT ---> Metric
  10. Race-Prep looking for a first 500ci buildup!
  11. TPI neutral safety switch question
  12. What else is needed for the 6 speed swap in a 73 Z28
  13. Stainless steel header flanges
  14. Updated Project Pics - Vette Pick Up
  15. 55 LS1 Chevy Truck project, what do you think?
  16. Cheap v8 for a 98 v6 camaro? what are my options?
  17. Wiring Harness
  18. c-5 vette brake fluid level sensor...how does it wrok
  19. 2005 Suburban 5.3 into 96 4x4 Blazer
  20. Runnig for a second
  21. ls1 into 51 chevy truck Help!
  22. What did you pay for your engine/tranny?
  23. 89 camaro headers ls1
  24. Air intake system for LS1 in second gen
  25. Colorado pickup engine conversion
  26. edelbrock box help. anyone!
  27. injector woes
  28. Where to get clutch master mounting bracket
  29. AWD TT Trans am?
  30. 5.3 Truck Bracket Part #'s
  31. Hardware: where do you get the nuts and bolts?
  32. TPS - Vette vs. F-Body
  33. Chevelle w/ 4L80E... which mounts?
  34. Lingenfelter 383 and more..?'s
  35. front coil selection in '69 ls1 gto
  36. I6 into a nova
  37. ls1 into 79 malibu.... anyone make parts?
  38. Engine bay harness question
  39. Pic of custom homeade drieveshaft for C5
  40. Crankshaft Sensor Learn Procedure?
  41. does ls2 conversion require ls1 ecu
  42. What headers for LS1 in 2nd gen F-body?
  43. ls1 240sx for sale
  44. 59 apache suburban LS1 question
  45. 2005 gto t56
  46. T56 + Carbed LS1 = ?
  47. 5.3l Wont start Any Suggestions
  48. What harness contains OBD II plug?
  49. 5.3 thottle by wire conversion
  50. 68 vert conversion help
  51. LS1 Swap into '02 V6 Camaro
  52. VSS signal out from PCM compatible with '86 S10 cruise control?
  53. LS1 in Solstice
  54. BMW 318i
  55. Advance adapters kit/anyone used it?
  56. steam port 5.3
  57. Finally, a pic of my new frame!
  58. 69 camaro ls1 questions
  59. Isuzu Rodeo LSX Swap
  60. Good Deal????
  61. won't go
  62. 5.3 into 91 Chevy K1500
  63. 5" autometers in '67 camaro bezel
  64. How to mate a 93/97 LT1 T56 on to a GEN 1 block
  65. LS1 In MKIII Supra
  66. 70-72 Chevelle SS dash ?
  67. Transmission Talk - T5
  68. 4th Gen L98 swap
  69. Suppliers of GM connectors / pins?
  70. ls2 mustang header ques.
  71. ? LS6 motor mount
  72. water temp problem
  73. water neck on ls1
  74. 1993 rx7 with ls1 corner weighted versus stock rx7 and autocross vid
  75. LS1 T56 Trans to small block questions
  76. PCM and VIN-number
  77. FINALLY started the project - my OWN LS1 Mustang
  78. LS1 swap tachometer issues
  79. LS1 swap alternator charge issues
  80. Vids of my LS1 GTA
  81. Need Help: 3-wire oil pressure pin outs 05 LS2
  82. What auto trans??
  83. Long tubes on a Chevelle?
  84. Oil Level Sensor
  85. 72 Chevelle ls1
  86. 98 z28 automatic conversion to t56
  87. F-Body oil pan for sale
  88. 5.3 into 96 Blazer
  89. anyone mount the pcm inside the vehicle?
  90. power steering lines
  91. NEED IDEA FOR PICKUP TUBE! help!
  92. Headers for LSX in 67-72 Chevy or GMC?
  93. gen3 in a 2nd gen
  94. f body accessories on a 5.3or 4.8
  95. computer tune
  96. Procharger/LS1/1970 Camaro - has antone done this?
  97. 2004 LS1 Alternator Q (pic)
  98. Stall speed for torque converter
  99. I just ordered my LS1
  100. Pinouts Please
  101. chevelle steering shaft
  102. t56kit transmission crossmember
  103. Need Part Numbers
  104. Fuel lines?
  105. 5.3 or 6.0?
  106. Just finishing up my LS1 240Z
  107. Notching K-member
  108. New pics of '67 Camaro Conversion
  109. NV3500 to small block problems
  110. LS2 Datsun 280Z!
  111. whats the current theory/opinion editing software for the LS1
  112. pic's of the fuel tank so far.
  113. 5.3 to turbo 400 questions
  114. First photos 2010 corvette
  115. **NEW** LSx conversion oil pan
  116. 71 camaro, Radiator mod for LS1
  117. What transaxles will bolt up to an LS1?
  118. will epoxy survive inside a fuel tank.
  119. I need filler neck and other accessories "building fuel tank out of Aluminium "
  120. MAF vs ZO6 MAF
  121. LS1 6-speed to a 327 SBC 2 piece rear main
  122. The Hood is Off!
  123. Fuel rail ?
  124. CROSSFIRE INJECTION 350 to LS1
  125. LS1 harness for 67 Camaro
  126. LS1 not starting
  127. Budget radiator for 68 ls1
  128. Z06, LS6 Exhaust Manifolds
  129. Flywheel problems
  130. traction control in a conversion
  131. ls1 in 73 camaro
  132. LS1 for twin turbo build in a 3rd gen Camaro?
  133. traction control in a 1st gen
  134. ls1 into bmw318
  135. Quirky gas tank issue while filling up....
  136. Trying to convert independent turn light to brake /turn light
  137. A little help probs on convers,, may need to post in another section
  138. 5.3 in a 91 wrangler
  139. took some pics of my truck
  140. LS1 swap into 1986 El Camino - Thank you
  141. need ALL information for ls1 swap to 70 chevelle
  142. C4 Ls1 Conversion
  143. bobbenck
  144. Do any headers fit a Third Gen besides Hawks!
  145. '75 Volvo Wagon 4x4 is done. Would you buy my magazine?
  146. upper rad hose for ls1 70 camaro
  147. wiring diagram for underhood harness
  148. 5.3 in second gen question ?
  149. 86 vette with 94 camaro lt1 and t65 questions
  150. Short Stick Shifter Camaro Firebird T56 LS1
  151. LS1 M6 miata. Anyone have one or links?
  152. Just finished my hybrid with pics
  153. vette vs f-body FPR
  154. fan
  155. Dual tune for and LS1...like a tow/haul but in the PCM not the BCM
  156. cooling fan relay #1 resistance question
  157. Drove it for the first time tonight. AWESOME BABY!
  158. 5.7 vs. 6.0l crankshaft?????
  159. 1981 C10 Swap Exhaust Problems
  160. Anybody need 1" lowering springs for 1st gen Fbody?
  161. Problems with a S10 v8 swap..
  162. Camaro LS1 and C5 T56
  163. is it worth it? 91 v6 camaro
  164. How to bond seal into pump cover on 700r4? It blew out.
  165. need some help on swap
  166. VSS wire
  167. Bastard Wagon
  168. I know its not an LS1, but...
  169. Clutch bleed and starter problem
  170. Is there a solid answer on TB bypass methods?
  171. 4L60E Tailstock Conversion Question?
  172. Anyone else addicted to conversions?
  173. Name that part
  174. My car finally goes 12s!
  175. YEAH, just got my Wayne due frame
  176. Another 63 SWC vette update
  177. Cheap and easy fuel setup for 4th gen F-body & C4
  178. 754rwhp custom blower setup for sale (link w/n)
  179. can everyone post the sites they found helpful for there swap
  180. Wolverine--willie Mejias Do Not Buy From Him!!!!
  181. LS1 and Truck motor alternators dimensionally the same?
  182. wiring harness mess -> too many harnesses! PLEASE HELP!
  183. S10 LS1 headers from Sanderson
  184. putting a t-56 in '92 fox body
  185. Are there any mexican/US LS1 differences???
  186. '67 Vette Hybrid
  187. Updated pics of the body on my tube frame ls1 hybrid
  188. Throttle Cable Needed?
  189. LS1 into E30 M3 need a little help
  190. LS1 Power+ Germen Tech
  191. Wildest LSx conversion
  192. 2nd Gen front sub frame for LS1 swap
  193. 900hp clutch? who makes one?
  194. Cool pic of my LSx hybrid car.
  195. 2000 S10 IT's ALIVE
  196. Looking for general swap help
  197. need your opinions....
  198. Truck LS1 spark plug wires ....
  199. LSX powered Mustang Coupe
  200. What else would be needed to convert from LT1 to LSx?
  201. Wiring harness tape
  202. Please explain steering angle issues (conversions)
  203. who here has done...
  204. 67- 72 chevy pickup LS1 swap
  205. Some pics of my car finished (LS1 3rd gen GTA)
  206. Question about guages
  207. Supradupra!
  208. IF U HAD AN LS1 and A4 JUST LYING AROUND
  209. Looking for the LS1 swap but found a 5.3L truck motor
  210. carb'd ls1 in a 95 Z28
  211. Progress on my S-truck swap
  212. whats up with PT.com
  213. LS1 Fuel Pump / 68 Camaro
  214. v6 89 camaro help
  215. Anyone drop a ls1 engine in a 2nd gen (70-73) Camaro?
  216. Fuel System
  217. QA1's with an LS1 in 69 Camaro
  218. Headers for LQ4 swap into 88 IROC-Z
  219. LS1 air filter
  220. LS1 into 95-98 V6?
  221. trans question
  222. swap out v6 for ls1
  223. Truck & F-body Ex-manifolds difference
  224. what do these wires goto...?
  225. I can't get the differential yoke nut off. This is an IRS DANA 44
  226. LS1 S-10 4x4 Swap Up and Running
  227. What a mess
  228. Aluminium and iron block differences
  229. Volvo P1800
  230. Fuel tank '67 camaro feed question
  231. will corvette manifolds work.
  232. Pinouts from FB vs Camaro
  233. Will LM7 5.3L Truck engine fit in gen 2 F-body?
  234. Been a while on the updates. So I guess I should show you guys what i have been doing
  235. can you use an LT1 maf with an LS1 motor?
  236. Reg mounted on fuel rail? For us conversion folks
  237. a/c compressor dimensions
  238. Some Pics of the Chevelle
  239. TOYOTA SWAP, Bolt patterns?
  240. Big Block in a 94 z28?
  241. Power Steering Question
  242. 2002 5.3L ?'s
  243. 71 chevytruck w 5.3vortec
  244. Can you do a LS1 swap (Ohio) in my 1974 C3
  245. How To Start My Car
  246. LS1 in 98 S-10
  247. gas tank question
  248. keep my fuel pump?
  249. Need advice on a4-m6 swap
  250. LS2 in a new silverado
