View Full Version : Conversions & Swaps
- ls1 in a mustang
- No 64-67 GTO/Tempest/Lemans projects?
- LQ9 accesories compared to LS1
- Where to find these connectors?
- Aternator Not Charging
- ls7 in impala ss
- V6 to V8 Camaro
- Heads and Cam Question
- My vega conversion vs. 5.0
- Ohm range for the stock fuel sending unit ('00 T/A)
- LS1 into kit car- carb sizing query?
- Clutch Master Cylinder
- 944 v. rx7
- Custom Header Questions....
- LT1/LS1 swap question
- Track Performance!
- Anybody with a real BRP mount kit ?
- Has anybody ever swapped an ls1 in an OBD2 car in a state with emissions ?
- Stand Alone Computer For 4l60
- Will GM A body font disc brakes fit on a Nova?
- Any interesting Pulley set-ups
- urboed Ls1 BMW 5 series
- LS2 based amphibious car
- Headers for 5.3 in a Jeep CJ-7...
- Anybody running these block hugger headers on their project ?
- What am I getting myself into?
- which headers can I use... which accessories???
- I started and I have Oil Pressure !
- purge canister
- Need Fuel pump plumbing advise
- LS Chevelle Headers
- Another LS14 Project.
- Lsx. Which Way do I Go?
- What type of fittings
- Interested in a Modified Howe Radiator?
- Gbody guys?
- Fuel level sensor output...only to gauge or to gauge and PCM?? DTC CODE
- Rubber shifter boot?
- It Started - Then It Farted
- Oil Pan Thread
- coils covers
- LS1 connector identification
- ls1 cobra swap is complete with videos
- T56 Kit Motor Mounts and Tranny mount
- LS1 Third gen
- Motor mount bolt part number
- temporary storage ofanls1
- 1983 BMW 320 - Progress update
- LS1'ed chevelle and driveshafts
- 383 stroker in 93 240sx
- Another one comes to life
- HELP-LQ4 + BW ST-10 + 80 fairmont = ????
- Let's see your electric fan setup
- 66 elcomino+cammed ls1=?
- Anybody have this problem with Lokar tranny dipstick?
- My site is back up again!!!
- carbed ls1's
- Original gauges and LSx
- LS2 in 91 Z....
- From LT1 to LQ4
- Ls6 in a 98 gmc 1500
- GM #10108509 Heater Hose Loop
- camaro subframe
- steering question...
- Starter Problem
- s13-s14, curb weight after ls1 swap
- Anyone try this?
- What year is my engine
- pin# for serial data line????
- 1993 ls1 z28 lives
- ls1 in 93 t.a.
- How much for a T-56?
- 1991 Camaro Ls1 Swap cammed Shaved firewall
- Edelbrock timing control module F/S
- lsx ps pump to saginaw steering box
- Procedure for first startup
- Clutch master pushrod modification
- Exhaust Flanges
- 69 camaro horn relay upgrade
- LSX engine/tranny source
- lt1 to ls1 swap
- Need help finding a project
- ls1 in a 74 Datsun b210
- gunna pick up a 5.7 shortblock this weekend!
- camaro subframe assistance
- 03 5.3 Electronic throttle control
- Radiator woes: What radiator for 67-72 GM pickup?
- Cam swap?
- LS1 in '66 Nova?
- AN-4 conversion
- Oil an removal install?
- Need idler pulley in place of power steering pump
- LS1 install into 63 impala?
- PCM harness through firewall grommet?
- A couple "finished" pics, Lots of pics... vids soon to come!
- New 8 Quart oil pan what do you guys think?
- ID this connector?
- T-56 with a 4x4 transfer case ?s.
- Electrical Question
- Header Question For Corvette?
- Flexplate exposed on auto tranny LSx's?
- LS1 to SBC motor mount plate question - Street and Performance plates too thick?
- 2 fuel lines?
- Corvette FPR/filter?
- getting pcm reprogrammed...
- All LS1/Caprice/Impala SS people in here....
- Ok, so no LS1 in Eclipse... but how about...
- Engine advice/Swap question(s)
- Help with Engine ID/Swap advice
- LS1 Mustang Swap Article for Popular Hot Rodding Magazine
- Do LQ4 and LS1 sensors interchange?
- 240sx LS1 swappers, need some help here!
- LS7 crate motor in 79 Z28
- Suggestions for charcoal canister
- Running Donor 02 z28 in SF area - $6300
- Dumb Question?????
- Mods before dropping in the motor?
- CTS-V oil pan, pickup and screen for sale for LSX Swap
- ssr rear end?
- LS1 into 1964 Chevy Malibu S.S.
- Z06 motor in an Escalade???
- Granatelli or factory MAF sensor?
- using ls1 headers??????
- Do I need a pressure Regulator?
- ls1 bmw 5 series conversion
- Carbed 5.3, 6.0 68 Firebird
- How to tell if the VSS is working or not???
- Any turbo fox/sn95 out there????
- Fuel pressure regulator plumbing?
- SBC 383 in a 1994 Firebird 3.4 Car
- Wiring harness ?????'s
- Vehicle Weight
- engine/trans angle vs. rear end angle
- Chassis fabrication.....
- Cheap fuel pressure gauge for schrader valve?
- hp tuners flashing problem
- fuel problems help
- No tach signal
- T56 reverse lockout solenoid plug?
- LS2 Datusn Dyno Results!
- LS1 into a 99GT??
- LS4 oil pan
- Walbro forgeries being sold
- BMW Z3 conversion
- how much will i gain?
- LSx Diamension differences ???
- Plug Size
- oil p/u question for gto ls1
- Need some help w/ conversion
- Built LT1 in 94-96 9C1 Caprice or LS1 Swapped in 98+ S10
- Crate Engine -> No MAF-> What do I need?
- What the heck radiator is this? (6.0L Police Package content)
- 2000 5.3 vortec to a 2003 4l60e out of s10???
- f/s lsx to mustang motor mounts
- anyone went the other way with a swap???
- Any way to tell exactly what engine I bought?
- ALT Light for '02 harness?
- Oil filter/Pan flow direction
- Debating about selling my ls1/fox project...
- 97 gmc z71 conversion
- ls1 fairmont part II
- TT Chevelle went to the drag strip. Update.
- Radiator question
- LS1 S10... questions
- duramax wiring ?
- LT1 motor mount HELP please
- considering a tube chassis fox body with a turboed LX7?
- LS1 in 68 Camaro Cooling system problems... runs hot at idle
- ls1 wiring speartech????
- Wiring harnesses
- GTO LS2 engine into a '68 Camaro?
- TB-to-MAF plumbing
- Ls7 Maserati Conversio
- 69 camaro battery hot wire !help!
- What did you pay for your engine?
- LS2 into Gbody update
- 95 chevy TBI
- Finally hit the track!
- Clutch pedal travel?
- pics lq4/lq9 + fox stang + 4.6 mounts = no workie
- Jeff Schwartz- Ultima Twinturbo 6.6i (LS2) in SilverState Challenge
- What are ECU options when using 5.3+ nv4500 or t56?
- No heat what to do w/ ports? Rad hose?
- Converting M6 to AUTO/ AUTO to M6
- FYI - SW Speedo connections
- ls1 into factory five 65 cobra kit
- LS1 Starter
- no spark
- heater hoses
- heater hoses
- 80Z28- Looking for LH6/LS4 swap.
- Fuel rails?????
- oil pressure sensor help
- Another 240sx project slowly beginning...
- LS1 Wiring Harnesses
- Wire Harness Loom protection
- LS4 in MR
- Need part # help
- northstar
- What vehicles does GM offer the 5.3 in?
- Wiring fans
- Newb questions
- Where to find info for Jeep CJ-7 conversion?
- Steam Vents, Front or Back?
- Drive by Wire-Vette Pedal-> '56 Chevy
- F Body Cruise Control - anyone used this on a swap?
- Review The Rookies Work....
- 05 gto fly by wire pedal
- 5.3 in 1966 Mustang?
- Wiring
- Wiring
- Put an ls1 in a firebird???
- k-member
- Looking for cylinder head coolant passage plug.
- any conversions having fuel problems?
- 6.0 engine ideas wanted
- confused, suddenly
- 240sx....not quite ls1...
- I Need an Fbody Oil Pan Setup
- Source for LS1/T56 cutouts
- LS1 Swap..$$$$
- LS1/LS6 intake on LQ4/9
- Vega getting closer but have PCM Question
- 5.3 into 1958 Chevy Apache Pickup- work underway
- v6 to v8 conversion
- It's Alive!!!!
- LS2 in a Mustang?
- ls1 lt1 t56 differences?
- Best place to find a straight water neck
- tach/ls1 help
- mechanical temp sensor
- Another Chevy II
- Newb: School me on LS1/ T56 swap into a Colorado
- LSx swap with mechanical clutch linkage car?
- LS2 exhaust pipe connection
- Ls2 weight
- fuel tank sump kits
- 5.3 stock comp to HRAir - AC fittings issue
- alternative fuel pump...bosch 69100?
- Some swap updates! 4th gen A/C, air intake, brake setup, exhaust issues...Big pics
- Z06 engine
- s10 ls1 fuel lines????????
- total cost and newbie question
- Couple more LS1 into Z3 pics
- Stock Fuel Rail Question
- my s14 ls1/t56
- First Gen F-body headers
- solid mounts
- reverse hard to get into?
- ls1/4l60e to ls2/4l653 swap?
