View Full Version : Conversions & Swaps
- novak adapters A/C kit
- 93 rx7 ls1 project
- Shiftworks is a PAIN!
- Mod-Request: Looking for a certain 1st Gen underhood pic
- Oil Pan Clearence
- Picking a cam for carb setup
- Autokraft LS1 Swap Oil Pan for Sale 375
- wanted lsx fox street car that runs
- Factory gauge conversion
- 72 C-10 LS1 swap need help
- 5.3 to 700R4 help
- pro flo intake should I cut my hood?
- Automatic harness with t-56.
- Need some advice with a swap
- LQ4 Motor Mount Adapter Plates
- who is the guy in arizona that does the harness
- 2006 corvette accelerator (gas) pedal connector vs. 2007 Silverado
- is there a certain ls engine to stay away from?
- What does this do?
- Question on F-body power steering cooler
- Ca engine swap emissions question
- Fuel mileage of an LSx & 4L80 in a '72 Suburban?
- Where can I find a 98 ls1 fbody engine harness schematic?
- 77 pontaic astre ls1/t56 conversion questions
- 1972 LSx Procharged Nova with T56 build..Pics inside
- Starter bolts
- Post ur pics of ur alternatore custom bracket...
- Anyone use old sbc parts on lsx build?
- weird issue, looking for thoughts
- LY6 Transmission
- 92RSLS2 code problem 2135
- Procedure for LS1 tuning with performance upgrades
- Which T56 do I need with my '01 LQ4 engine?
- Truck DBW pedal modification ideas
- Aluminum with steel fittings?
- Mount the alternator in the AC compressor position?
- 1969 nova 6.0 conversion
- E40 ECM and trying to get tacho signal
- procharger kit for lsx conversions
- Ls2 marine parts???
- DBW costs
- LQ4 Gen 3 or 4
- Harness Black Tape Source ?
- third gen F-body LS1 guys lend me your hands!
- my turbo lq4 02 gt build thread
- mating a 4.6 ac to ls motor
- Big primary long tube headers for 2nd Gen FBody?
- 04 slp gto headers in a 72 camaro?
- Beading fuel hardline?
- Help! Car won't start
- MAF or SD on conversion in mild build?
- 1996 LSX BMW E36 Hatchback
- 5.7 vortec swap
- 1979 c3 ls1 swap
- Aeromotive A1000 issues
- LS1 Factory Exhaust Manifold O2 plugs/Options?
- Help....LSX Newbie!!!
- 6.2 in Trans Am
- LS1 Engine Harness?
- Help with a V6 to LS1 swap in a 97 camaro!
- Help...t56 won't mate up to ls2
- Any other power steering pumps or pulleys work with F-body?
- 71 Chevelle with original Z-bar clutch setup ?
- LQ4 harness mod and ECU reflash
- Swapping 2000 5.3 into 89 rcsb
- No spark! Computer advanceing, ign & grd good, help!!!!!!!!!!!!
- Easiest Way to Shoreten Cable Pull @ TB?
- ls1 gauge cluster in mustang help please
- AllDataDIY.com coupon - 1 year for $19.95 expires 7/30/09
- Cheapest place to get header flanges
- Another PCM controlled A/C question
- Selling my car
- F-body accessory drive for sale
- ls1 parts list?
- Anyone try a tpi ram air setup on an old car?
- LS1 TB Cable Linkage
- Clutch bleeding issues any help please...
- swapping gauge clusters with LSX swap
- Nova/LS-need a measurment
- ls1 s10
- LS1 from GTO... using H3 oil pan... dip stick goes where?
- Adding an oil cooler...Where?
- Help identifying sensors........
- l33 HO Wiring Diagram
- Power Steering Pump and Box Interference
- lt1 to ls1: injector fuse
- truck accessory drive/intake
- I need a plug pinout....
- A-body cooling
- Need LS2 LS3 OR LS7 Throttle body
- LQ4 DBW to Cable TB conversion??
- custom oil pan filter relocatoin question?
- Where do I have a m 16x1.5 for my water temp guage?
- LQ4 exh flange source needed
- 95 Firebird to LS1 - Air intake trouble
- please help.. fried starter?
- LT1 6 SPD Vega...`
- Ls1, t-56, harness, pcm for sale
- building a 1986 mazda rx7 with iron 5.3 and t56 pics inside
- who makes this?
- T56 behind a LSx
- Any pics of truck intake on '78-'81 Malibu?
- 4.8 with LS1 manifolds
- lq4 into 02 gt security system ?'s
- LS1 in a Nova
- Truck throttle body location vs. F-Body throttle body location
- Truck engine into G Body- Will the alternator clear the hood?
- power steering port sizes
- Will a T5 work on a LM7?
- LS1 water pump & cooling
- anyone put an ls in a g body and pass smog
- AN fittings on LS1 steering rack side
- Anyone need a Vette filter/regulator set up with AN fittings installed?
- A/C Compressor Clutch Swap...Guru's Help...
- BMW 557i
- lq4 sensors
- LT1 coolant temp sensor to work with a 65 Chevelle gauge?
- Lt1 vs. Lq4
- Why does the harness have to be modified?
- Will truck injectors work in an LS1 intake?
- 97 LT1 to L76, C100 question
- Help! No spark after clutch pedal install
- Cylinder head temp port
- Canton 13-274A Oil pan in 69 Camaro
- New Project parts !
- LSX weight
- Good deal on a 5.3 and harness near Fredricksberg, VA
- Need to rewire my 6.0 L harness?
- hood clearance on ls1 fbody swap
- Help with Gauges!!
- Oil pump question on carbed LQ4
- pcm/wiring harness question f-body ls swap
- Help identify a DBW Throttle body ????
- Need Help DTC P0106
- Bad Corvette Filter??
- Looking for Diy header advice
- 1966 Caprice (think Impala) 6.0 Swap
- Carb to EFI
- repinning PCM hard???
- LY6 with L76 intake
- Autometer Tach Reading Incorrect
- help mating t56 to lq4
- Ebay Stand Alone
- Fuel fittings
- K member question
- Question for the G-body owners
- Mix & match accessory drives?-1 style alternator bracket mixed with another ac & ps?
- have any of you heard this
- clutch pedal setup
- Where to buy Walbro GSL 392 external pump kit
- LT1 - 2 holes above oil filter??
- what wire is this?
- Lm7 + ????
- A/C problem (or ???)
- need connectors
- DBW Response?
- PCM Mods/Tuning Questions
- Long tubes for a '74 C10
- Help on a leaking theromostat and neck
- lt1 6sp pedals
- 95' LT1 powered by '02 LS1...Question inside...
- stock f-body exhaust manifolds... which ones are not cast iron?
- Camaro 67 Ls1 headers and steerings for best clearing and ground clearanse
- Smog Question - Evap Canister
- Wiring Harness
- Is this engine/harness combo compatible?
- patriot head package vs. CNC porting
- Throttle cable recommendation for A-body swap
- LSX 1986 camaro
- What Do You Think?
- 1981 CJ5 Jeep - 5.3 Swap - Power Steering Pulley Issues
- tube size to an question
- LS muscle car oil pan kit, anyone use it?
- LS2 swap
- Head bolts torque specs
- Interior wiring
- LS1 to a 6.0L
- LS1-F85 hits top speed record
- 68 C20 maybe LS 5.3
- GTO LS2 Oil Pan Assy
- LT1 to LS1 converison
- LSx F150?
- Engine stumbles during acceleration
- Help!!! Stop and look at this!!!!!!!!!
- Need some help w/ carbed 6.0 cam choice
- 98 Wrangler pics
- Yet another 240SX Swap
- 650 Code?
- 70 Camaro LS2 / 6 speed
- Starter works intermittently--any ideas?
- modding oil pump pickup tube (f-body)
- LS swapped yota
- 6.0 swap
- Wiring Harness For LT1 to LS1?
- LS1 ac in an lt1 car
- speedo sender with dakota digital
- mp t70 "1970 chevelle" pics
- 99 model 6.0L swap wiring harness
- Radiator and fan for '56 Chevy with stock core support?
- LS6 or LS2 intake for 5.3?
- New LS1 conversion does not want to start--any suggestions?
- ls1 into 69 GTO (fuel tank)
- 2005 Silverado 5.3 to 4L80E
- ls1 crank pulley onto ls2 crank
- LS1 Swap for a 55 Belair
- Running an LQ4 without o2 and maf?
- OBDII port wiring question.
- LS Carb setup height...
- Anyone here seen an ls1 transplanted into a 04 Mustang?
- Questions for those using CSR 911LS1 thermostat housing
- My SN95 LS1 T56 Mustang project
- help with carb set up on LS motor
- my 70 chevy k5
- Exhaust?
- ground wire/negative battery plan
- ls1 in a 02 v6 camaro
- L92 in an SN95... Questions
- Overheating issue
- removing head to fix
- L33 Datsun 510
- Neutral safty switch
- LS1 in Fox transmission questions, Keep 4L60e or go with TH400 or Glide?
- 85 Monte SS LS1/T56 pics
- 6.0 liter oil pan
- Fox Body 6.0 lsx build
- Another LS1 240Sx
- GM Artwork - "LS6" & "Heartbeat of America"?
- LS1 into a 94 LT1 camaro...
- Cruise on DBW 2004 5.3
- LT1 swap wiring tard.
- Wtf?
- Hot floor pan!
- (5.3l) LS engine swap into a 72 chevelle ss
- need help with wiring 04 gto harness
- 68 LeMans - LS1
- Transmission options
- LY6 - Vacuum port???
- POwer steering reservor cap?
- if only using one fan, which on high or low
- 1981 Chevy C-10 SWB
- 5.3 Struggles
- LS1 to older over drive tranny
- 1989 Chevy Silverado 1500 5.3 swap
- Alternator warning lamp
- Do car and truck balancers interchange?
- 96 3.8 bird to 00' 6.0 swap??
- Fsm?
- 4l80e surging
- Going from a 5.3 to a 6.0, Any Changes Needed?
