PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Anyone using GKI vette filter/regulators and having problems??
  2. Project FlightRisk; Mustang + LS1 = 6.50's
  3. About to order my LH8 oil pan assembly
  4. What do these connectors do?
  5. custom firewall question
  6. Early 4L60e & '04 LM7?
  7. 07 Ls2 + 94 Rx7
  8. Help with LSX Swap in 70 Chevelle
  9. Need Help Picking a Cam
  10. 3.8 to LT1
  11. ls1 into 1989 suburban
  12. Exhaust pipe size
  13. Rebuilt T56 having reverse trouble!
  14. Trans bell housing bolt size?
  15. ???????????????Which TV cable should I get Ls1 swap?!!!!!!!!!!!!!
  16. LS2 Starts sometimes
  17. Blocking off the nipples anyone
  18. 5.3 into Lt1 car... few accesory questions
  19. Another conversion comes to life!
  20. O2 Sensors: Are LS1 and LS2 the same?
  21. truck acc. in a Gen 2 camaro
  22. LQ4 Th350 Do I still need Spacer?
  23. Does anyone have a used G.M vette filter/reg that I can try?
  24. this cant be right
  25. LQ4 Oxygen Sensor Question
  26. 4L80E tailshaft damage due to wrong cooler fitting!
  27. Ls1 Fc Rx7
  28. Need wiring help!!
  29. Recommendation for gas ECU#(may try E85 in the future)?
  30. 71 nova worth swapping 454 for lsx truck motor?
  31. Newest project----69' camaro!
  32. dakota digital help
  33. programing an msd 6010 box
  34. quick question
  35. 1983 G Body wagon LS motor swap
  36. Can I get some quick Opinions/Help?
  37. Buick Reatta?
  38. Old car, new engine, emissions testing?
  39. F Body Oil Pan for sale
  40. Is there a smaller throttle body?
  41. Need drive by wire 10 pin connector
  42. FREE ECM Flash from Painless Performance
  43. lt1 to ls1
  44. 2-inch or 3-inch diverter valve?
  45. ls1 cutlass
  46. GM part number....What is this?????
  47. 2001 LQ4 Stand alone harness
  48. Exhaust and the referee
  49. 4" cutout on a third gen?
  50. LT1 to standarts SBC
  51. LS Swap Fuel Problems
  52. Car dies
  53. Please post the info you should provide a tuner when considering a conversion.
  54. power steering lines
  55. Drive by wire harness issue
  56. draining the block
  57. water pump question
  58. need some wiring pics!!
  59. C5 LS-1 in a '72 Maverick
  60. th400 set up for lsx
  61. '06 corvette engine with a 6 speed harness and a '05 4L60E trans, what to make work?
  62. Porsche Cayman LS7 conversion thread at a P-car site. Very interesting.
  63. FS:GTO Oil pan w/windage & pickup
  64. any s10 guys have manual brakes
  65. Steering column and driver seat.
  66. 1966 chevy"2" ls1/th350
  67. Can anyone tell what Bellhousing this is?
  68. Need help with a ls1 swap into a 90 300zx.
  69. need help
  70. quick disconnect size on LS1 fuel rail
  71. 5.3 (Baby LS2) in a BMW
  72. LQ9, LS1 intake, C5 exhaust, which cam?
  73. 1994 trans am swap to ls6 or ls3 HELP!!!!
  74. Where are people buying vette filter/regulators?
  75. LQ4 Heads Stuck-won't come off!
  76. Radiator hoses A body guys help!
  77. Does anyone have a part number for Datalink connector???
  78. Speed signal not present??
  79. how do you explain ls1?
  80. need some wiring help with my ls1 in the 70 camaro
  81. ls1- getting the fumes from the gas tank to the TB... ??
  82. 5.3 or 6.0?
  83. Cng
  84. VSS Hook up
  85. 2nd gen headers?????
  86. hawks 3rd gen headers?
  87. Need help!
  88. 1985 4wd Chevrolet 4.8 retrofit questions
  89. LSX into my mustang with my TKO600
  90. Header help on my swap!
  91. Who's flipped the ats mounts... lsx in a 70 velle
  92. cooling fans
  93. do i have to cut the floor to fit the t56 on the 67?
  94. TKO 500 5 speed or T56 6 speed
  95. Gauges
  96. does someone make a thinner water pump pulley? for clearance
  97. LS1(98) to LT1(97) Cluster Wiring.....
  98. carbed 5.3 with th400 in 67 camaro question
  99. Guy's with MSD 6010
  100. What ecm should i convert my L92 to?
  101. camaro gen 2 + LQ9
  102. msd 6010 cd
  103. coolant on header bolts?????
  104. Ls1 fox swap come in need help?????????????????????
  105. ls1 in 99 camaro
  106. Finally made it to track
  107. Connector C100 G pin, Connector C105 B pin
  108. edelbrock headers
  109. LS3 swap
  110. pics of 3rd gens lsx based swap
  111. LS1/LT1 Into a 82-91 Camaro???
  112. Progress Pictures
  113. msd 6010 users-chips vs laptop timing
  114. cooling issues.. many details.. help me diagnose!
  115. Heads up on a clean 56
  116. 3rd Gen Corvette swap
  117. Can you use an automatic transmission cooler as oil cooler?
  118. first gen camaro question
  119. Why the !$&@ is thing blowing vette filter/regs????
  120. Cheapest place to buy new GTO pan setup?
  121. Crossmember mods
  122. Stock V6 SN95 Fuel Pump enough for Stock LS1?
  123. ls3 wire harness for crate engine install
  124. Kugel Clutch/Brake Assembly for sale.
  125. 68 camaro rack and pinion question
  126. 5.3 Vacuum port required
  127. 00 Camaro LS1 pan to trade for a rear sump GTO pan
  128. FS: LS1 Fox Body Swap Driveshaft
  129. LQ4 598, 595 do I need valve reliefs
  130. Possible wire issue. Can't go past 3000 rpm
  131. V6 to LS1 (93-02 4th Gen)
  132. ls1 in to 4x4 s10 need mounts
  133. 95 Impala tank for swap...
  134. convertor bushing
  135. harness rework...questions
  136. Seeking G body swap info
  137. Need Flexplate LS to 200-4R
  138. is this an underdrive pulley?
  139. What would cause the vette filter/reg. to blow?
  140. DBW t-body fox body
  141. estimated ET
  142. A-Body Guys, Enter:
  143. 95 mustang 6.0 turbo
  144. LS1 Computer In A Sealed Box?
  145. Does anyone make an extension harness for the LS1 PCM?
  146. Harness Question
  147. Any new ideas for swaps?
  148. spark plug wire question
  149. LS1 and th350 transmission in 69 chevelle
  150. Looking for some ideas?
  151. 04 GTO LS1 fuel pump
  152. reworkin my harness questions???
  153. F-Body Harness w/ Truck PCM/MAF
  154. My "Bitchin Camaro" project
  155. C105 pin H
  156. PCM red connector pin 53
  157. LS2 KOUKI BUILD AKA "HEART OF A GOAT" 56k beware**
  158. 6.0 LQ9 with LS6 intake into a 68 vette recipe
  159. First Gen Mount Kit using stock accessories
  160. For the wiring impaired
  161. 99 Wrangler LS1
  162. 99 Wrangler LS1
  163. Ls1/t56 fox guys... What gears in the rear end?
  164. PCM/Harness Question for 408 lq9 w/ls3 heads in a 94 Camaro
  165. PCM/Harness Question for 408 lq9 w/ls3 heads in a 94 Camaro
  166. walbro fuel system problems NEED HELP!!!
  167. 5.3 tach output signal
  168. Help with gauges on lt1 to ls1 swap
  169. lt1 to ls1 swap pic's???????
  170. 2004 6.0 Denali Engine in 1998 Z28
  171. Remote oil filter? Which port is IN and which is OUT?
  172. carbed 5.3l th350 help
  173. 4wd s10 to 5.3L NEED HELP!!!!
  174. Best Stock Exhaust Manifolds?
  175. ls1 67 camaro radiator
  176. S10 guys.. I need some measurements
  177. Corvette Transmission in 1st Gen Camaro
  178. Any carbed LSx pics?
  179. Carbed intake?
  180. ls1 questions 240sx
  181. LS1 swap to LS2 or LS6
  182. converting a 2000 V6 camaro to a 2002 LS1 drivetrain
  183. Right PCM for the eng/trans combo?
  184. drive by wire inop???
  185. Any ls1 fders go forced induction?
  186. Need an F-Body oil pan, exhaust manifolds?
  187. Someone with the 5.3 Vortec. HELP FAST!
  188. My Procharged LS2 M6 1996 Impala SS
  189. LS1 Swap into Blue SN95. Build thread.
  190. LQ4 in a 64 Chevy Pickup, Need Advice!!!
  191. more track updates 4-16-08 on the 94 ls1 mustang
  192. LSx into a..... NASH?
  193. Fox guys with a Turbo 400??
  194. Swapping rear gears
  195. 94' volvo planning
  196. why are all bolt in crossmembers crap?
  197. Need some help piecing the rest together
  198. Any of you carbed LSx guys!
  199. 5.3 LM7 into 87 El Camino
  200. Adding both oil pressure and oil temp guages
  201. ls1 240sx stuff
  202. A few questions (harness, bHousing)...
  203. Wire removal on SN95 for LS1 swap, pics inside.
  204. LS1 hybrid idles at 950 RPM - seems high??
  205. Connector pinout picture for LS2 Cam and MAP sensors
  206. 02 V6 F-body to V8 9" car
  207. Finally starting to come to a close
  208. New LS Swap book- Need some pics
  209. More Amigo Madness
  210. Source for wiring harness?????????
  211. ls1-67 camaro front clip questions
  212. I'm Dropping in an LS1 into a 4door 04' 3 series BMW!
  213. LS2 GTO HEADS ON A LQ4 how will it work?
  214. MIL stays on scan tool says off
  215. Yes, another LS1 into an F-body, with a few twists...
  216. 78 Mgb?
  217. Update on my 87 Camaro 5.3 build
  218. LS1,2,?? into G body
  219. Autometer Guage Questions, for LS1 into SN95
  220. 3.8 to LS1...whats involved?
  221. t56 hose connector on pass side
  222. Need height of LQ4/6.0 truck intake
  223. GTO LS2 into Iroc
  224. fuel filter before walbro pump
  225. My 86 C10 6.0/4l80e swap
  226. My conversion project - an old Volvo
  227. Will headers require o2 extensions?
  228. Timing chain question/windage screen
  229. Designing headers in SolidWorks
  230. What 4L60E tranny for a-body swap?
  231. '69 Firebird ideas
  232. LS2 battery light hookup
  233. 6.0/LQ4 carb torque curve?
  234. 04 truck PCM Pin Diagram
  235. PCV system on 6.0l lq9 in thirdgen
  236. ls1 s10's/colorado's please chime in..
  237. whats wrong w/ the 5.7?
  238. what do I do with the coolant pipe that exits the throttlebody?
  239. SWapping a 98+dash/gauge into LT1Thirdgen, cluster issue?
  240. 86-92 Ls1 IROC Z
  241. Quick 5.3l and T-56 question
  242. Steam Vent Hose Question
  243. ok guys need help, no injector pulse, no spark, no fuel pump
  244. Sleeper of the century???
  245. Looking for some recommendations from fellow Conversion and Hybrid guys.....
  246. What shifter for 4l60e (and ls1) in SN95 Mustang
  247. LS1 into 64 Malibu SS "A" body car
  248. My '51 Merc (some pics)
  249. Ls1 chevelle headers?
  250. looking for 2001 Camaro colour wiring schematic
