View Full Version : Conversions & Swaps
- 72 Comet with a turbo/LS 5.3 in it's future.....
- Foxbody ls1 swap drag slick size?
- MKIV Supra LS swap, needing shorty header ideas
- Idle up for aircon
- 4-Valve LS Heads at SEMA?
- 98-02 exhaust mainfolds
- LY6 swap now, LSA supercharger later?
- small question about springs and retainers
- Questions regarding coolant crossover line,pvc and egr
- Do i need a fitting in CAI
- LSx conversion mounts, what did you use?
- My S10 ate a 5.3L
- new guy here potential 72 K10 LSX swap
- steamline
- alt fuse keeps blowing
- Ly6 into third gen camaro
- Long tube header
- PRC Radiator Woes - Houston
- 1971 impala lsx
- 1971 impala LS1 carb
- 67 cougar AWD conversion
- LS IS300 guys with working a/c chime in
- t56 viper tranny question
- GTO oil pan plug popped out! Oil everywhere
- Don't Slaughter Me
- 5.3 Vortec in '63 Riviera swap.
- Smaller Power Steering Pulley
- 04 gto clutch hydraulics question
- 98 Camaro 4l60E to 2004 5.3
- Boosted C10 swap
- Gto ls2 in '86 Monte carlo ss
- 1965 Chevelle 6.0L lq4 Build
- Lq9 to ls conversion in 68 camaro
- 1st gen header size and brand
- 64-67 GM A-Body Headers - A list of what fits and what doesn't
- 68-72 nova
- whats needed for an LSX swap for a Cadillac Catera?
- Headers
- T56 Magnum XL...Ford vs GM, what is the difference?
- LT1 4th Gen L96 Conversion
- LS1 Lid on LT1 body that has LS1 front swapped
- 68 Cutlass LS3 conversion, a/c clearance question
- S2K LS1 swap build thread
- E36 Header Choices??
- Hooker 1st-gen F-body/3rd-gen X-body 4L80E crossmember preview
- Booger Trash can nova thread?
- 5.3 steering pulley
- 1984 190e 5.3
- Bellhousing for Muncie 4 spd to LS
- GM performance part number
- Does my ECM/TB/DBW pedal mesh for my l92 swap ?
- Equinox swap?
- Insulating the Engine Bay
- Muscle car swap pan....dipstick?
- 1968 camaro 370/6060 swap
- conversion U joint and drive shaft length
- A little smoke
- lsx Fox body swap questions? ??
- Mustang LSX Swap Headers Headman Who's K Member used ?
- 1970 K10 5.3 SM465 diesel-hunter
- modifying a stock PS line
- 2004 Trailblazer LS conversion
- LS1 swapped 240sx S14 Issue
- Removing Auto Trans from Harness Question
- 408 stroker timing chain choice.
- 99 firebird ls1 swap help....please!
- ls1 with ls7 accesories and procharger?
- Trans help
- Fuel injector problems need a little help
- moroso 20140 oil pan question....
- 996 c2 LQ9 conversion questions
- Blown Methanol ls1 powered ke55 4 link tubed
- 1991 Volvo 240 Wagon, LR4 Turbobrick
- header power steering clearance
- 1970 ford capri x275 5.3 methanol s480 build
- finally got the bugs worked out of the blazer and suprised myself with what it ran
- 01 LS1 harness modification. off road rig questions.
- 5 in pulley to fit corvette ps pump?
- help on options for 4x4 please
- Steam vent o rings
- 72 chevelle LS swap
- E36 m3 ls1/t56
- Ls Swapping Silverado
- First LS build 67 Skylark
- Lq4 block LS2/3 oil pan
- 2001 LS1 with 4L60E flexplate
- Speedometer & Tachometer
- Ignition question
- 4.8 dbw, moving to a Ls6 intake?
- 5.3 into my 71 Elcamino
- 69 Chevelle, 5.3, S480
- Whistle
- Wrong wiring harness?
- Domesticating Imports
- 99 Z28 LQ4 swap
- 1969 Chevrolet El Camino. LS1, 4l60E trans.
- Rag joint replacement
- One cylinder not firing
- 6.0 in 62 swb c10 1/2
- Fuel issues
- What to hook to vacuum
- E46 3 series or S10?
- 59 Parkwood Wagon Project
- injector problems with 5.3L in 76 nova
- 2000 silverado underhood fuseblock c1 connector pinout
- Questions for a 5.3 LS motor into a 1988 Pontiac Trans Am
- LR4 to LQ4 or LQ9?
- tach is way off
- Too much radiator? LS2
- New Gen V project...
- Trans leak at yoke, question....
- cam ls1 vs cam 6.0
- 4L80 conversion--2005 GTO
- thermostat housing
- anyone use a PEM Racing custom driveshaft? Review?
- Turbo 5.3 Fox swap questions
- 99 camaro with 02 6.0l
- MSD PN 8956 on a 5.3
- 700R4 or 4l60e
- Looking for options on wiring harness
- 97 BMW 528 parts car FS for a LS swap?
- LS2 wiring questions???
- NOTICE - All New GM LS Based Engines are Spun at the Factory
- 42# Ford Green Top Injectors
- Ls1 camaro radiator AN fittings
- Drive accesories for s14
- NASTY64 Belair Project
- Blown rear main seal, Lean banks PLEASE HELP.
- LSA from CTS-V
- Convert automatic to 6speed
- 2000 auto mustang 5.3 swap help
- Holley efi ls foxbody questions
- Best Bang for the Buck Code Scanner/reader?
- Question about my 430 Erod Stand Alone Harness
- ls foxbody... vent tube leak? issue
- VSS...again
- 406 efi, hp guesses? possibly going turbo
- GenIII 5.3l in 06 CTS
- 1991 mustang hatch 6.0, ls3 heads, l92 intake pat g cam
- 411pcm to p59 pcm swap
- 58-64 Impala/BelAir/Biscayne builds
- Accessory drive conversion Q's - G body
- 2011 Corvette Ls3...in a 71 Firebird-questions...
- LQ9/T56 into 86 El Camino thread
- Retro Harness wiring problem (02s)
- Automotive Club Fox Body LS project at school
- LS7 E46 Coupe
- 66 Beaumont SD -LQ9/ 200 4R
- 1989 c1500 check engine light
- A-body LS Swap, Engine Location Question
- Vintage Air Gen IV LS1 Integration Colored Diagram
- Lurker. Now I'm diving in with an LQ9
- Colored DBC Cruise Control Wiring Diagram
- '86 C20 Long Bed LS Swap
- Another Friggin 5.3 turbo chevelle
- 83 Monte SS conversion, from 540 to 6.0 turbo
- ls3conversion,engine harness works, not getting power to some lights
- 1973 Camaro - GEN IV 5.3 Swap - it's on!
- Vortec 6.0 TB swap
- Speedo VSS wire
- 5.3 steering pump to 500 gear box
- Introducing Project Old Lady
- cruise not working...please help
- Needed:2013 silverado gauge cluster wiring print out
- 65 Chevelle Suggestions on adapter plates and motor mounts
- Custom adapter shafts?
- 1966 Chevy Impala Wagon LS1
- LS6Yota - 89' Toyota Pickup LS Swap
- Coufal's 66 C10 Build
- GTO LS2 2 yoke/companion flange
- VSS w/ NVU Guages
- Finally made the plunge
- Fuel Line HP Capabilities
- Problem torq. rockerarm
- LS1 Swap-What Are The Two Purple Wires?
- 2009 Malibu LTZ 2.4l ecotec LS Swap
- Thanks
- can I crank without pass key or use of the bcm?
- '03 S-10 Build
- WI junkyard closing 4k cars getting crushed
- LS2/E40 serial bus ?? (can bus)
- Which route would be better for ls swap into lt camaro
- 1992 Nissan 240sx coupe
- Lokar throttle cable length
- 1968 Javelin LS Swap Commencing
- new edge mustang swap headers
- Trans wont shift into GEAR. Shifter not wired correctly? HELP!
- Hey guys, LS swap questions.
- newer lq4 DBC conversion?
- i have a gen 4.small 4.8 harness ?
- See what rolls through our shop!
- LSA blower with corvette accessories?
- First gen t56 reverse lights
- Emission Test ATL area
- Swapping LT1 for LS1 in 1995 Trans Am
- 2007 Gmc vortec max bad engine
- Finishing up my swap - have a charging problem
- Ls1 swap in Mustang GT
- 1965 A-body, which booster fits
- conversion thoughts ??
- TBSS intake in turbo G-Body?
- 89 TBI to vette LS2 CNC H/C + N20 build
- 1968 LeMans Driver with a 5.3/4L80E
- 1978 C10 swap need help
- S-10 project started
- oil pan skid plate pics wanted
- '95 Trans am Lt1 to 6.0
- Some questions about a cheap (for now) ls foxbody swap
- Trans help ASAP
- converting to standalone help
- New Edge swap...master cylinder problems! Any Mustang/m6 swaps welcome!
- LS1 Swap Into 94 Camaro
- Shortening Wires
- Just Another Turbo Fairmont
- 1967 Cutlass LM7 conversion
- LM7-->LS2 and steam vents - need direction
- LT1 to LM7 swap
- truck intake cover ideas
- Power steering ?
- Clutch Master Bore sizes?
- LS foxbody help with issue?
- 5.3 vortec - intake needed
- Hooker exhaust manifolds?
- Cast iron Vs. Aluminum. Builders chime in..
- LS2 with LS1 harness and knock sensors..correct locaiton?
- 2nd gen f body ls swap compressor questions
- 02 6.0 vin N should I buy or not?
- 62-67 Chevy II stock steering, oil pan?
- Cd009 Trans
- Front and Rear oxygen sensors the same?
- ls6 heads and cam i need help
- You're probably tired of seeing them by now but this is my 5.3 Fox build
- Need Help - 2005 Corvette LS2 with truck accessories - AC bracket
- LQ9 into a 96 GMC Truck: 58 rw to 24 rw change
- holley 302-2 pan with stroker?
- mufflers
- Interchangability 2003 LQ4 with 2006 4L80E ???
- 5.3L in 1965 Chevy II
- turbo lq4 Caprice wagon
- mustang 4.6l to ls swap help
- 1991 240sx LQ4 build
- 148t flywheel
- Exhaust size question
- 99 camaro v6 to LSx Swap Project shop car
- 1969 firebird LS1 swap build/progress thread
- 1967 GTO swap LQ9 LS3 Topend Build Help
- 1967 Chevelle 6.0 L LQ4
- Turbo lsx fox only runs in crank position dies in run position.
- I need to have a harness repinned
