View Full Version : Conversions & Swaps
- LQ9/4L80E in 72 chevelle driveline angle?
- Fuel Fitting??
- Ls1 Throttle Cable
- T56 shifter repositioning Q
- Full C5 Drivetrain into C3???
- using a return line
- Megasquirt for sale
- 6.0L belt driven acc.
- Corvette engine to F-body specs help..
- ls1 into 94+ stang questions
- 1080lb 250+mph turbo LSx swap
- Got it running
- Where to buy?
- LS1 Swap into 94 F-Body
- 05 Coil Packs w/ 98 LS1?
- Planning update
- My LS1/T56 swap into '68 Chevy C-10 stepside
- 5.3 vortec newbie w/ questions
- Turn key engine supply harness, 410HP?
- my hybrid in action. RX7 on oad course
- Header lengths? for UK enthusiast!
- Header Flanges
- Can 2001 Computer Control 1996 Anti-Lock Brakes?
- LS1 swap into LT1
- 327 LS1 69 Camaro Turbo AWD Protouring
- LS1 head question
- ls1 in a challenger
- Which engine should I put in my van?
- 4.8/5.3 questions?
- ls-1 conversion question (spindles)
- Ls1 headers for a V8 Miata!!!
- 6.0L questions
- Ls1 in Prowler>?????
- t-top welding
- Lt1 and Ls1 kmember
- Will this work for my tach?
- What's missing from my harness?
- Fuel line upgrade
- My next conversion project car!
- 5.3 vs 6.0
- Engine set back in 2nd gen swap
- 6.0 & 5.3 INTERCHANGE
- Started building headers [PICS]
- Where is Conversion to Carb in LS-1?
- How Do I Wire The A/c Fan?
- 1st Gen F-body LS1 project Ideas
- 12 volt disconnected and computer program lost??
- Power loss and Computer holding program
- 6.0 Id
- Big roots blower on LSx
- About to take the plunge - LSx in 72 Nova
- oil pan help! need slimmer oil pan!
- TH-400 x-member modification?
- Will PCM lock the Torque Convertor of a 700R4?
- Looking for information about the inline walbro fittings Straight to dash
- truck accessories in a first gen
- two fuseable links off the alternator
- How long is TPI kickdown cable?
- Ls1/t56 swap into 95 Lt1/4L60e Trans AM!
- LQ4 into 99 v6
- 99 and new fbody harnesses the same?
- LS1, LS2 or LS7 in a BOAT ???
- LS controls on genI sbc. hybrid help pls!
- 1LE intake elbow help plz
- how long did your conversion take to complete?
- hmmm what to do....
- Help Asap!
- LS1 & T56 drop out - Where?
- motor mount plates
- Trailblazer conversion
- LS1 RX7 slowly in progress
- LS1 Fuel Rail Fittings
- weight of a 6.0L
- 95 K1500,5.7 To Ls1
- adding a pin to the PCM connector.
- harness from turnkey
- ???'s about gauges
- 4th gen front suspension in 3rd gen?
- Warms up then dies.
- Ls1-240
- Free T Shirt from Speed Scene Wiring
- ls-1 conversion question (brakes)
- t56 conversion
- Speartech throttle-by-wire
- Fuel Pump
- A few needed answers please.
- LS1 Trike
- V6 in my SS?
- 6.0L wiring harness
- 4L80E in 1st Gen Camaro
- 3rd Gen - 4th Gen A/c
- C5 drive shaft/torque tube welding, what rod.
- LS1 into S10 swap header pics
- Ls6 Intake manifold on 6.0 engine
- Painless wiring Kit
- ls1+240sx
- LS-1 / T-56 into ´59 Cadillac
- motor mount templates from faq wont load
- ls1 motor in a 97 v6
- Part Numbers needed
- New Sponsor! Speed Scene Wiring
- Rear Mounted Battery Wiring
- good news and bad news...
- 6.0l into 99 v6 firebird
- STS turbo on 3rd gen LS1?
- F-body motor mounts
- F-body fuel rail part number
- ht4100 to ls1?
- 6.0L in 70 nova
- Is BCM necessary if you don't reprobram PCM?
- fs 99 ecm 9000 mile
- Fuel pump wont wrok until out of tank???
- so who's done/doing a SBC (not ls1) into a Fox Body Mustang?
- LSx into a Conquest/Starion?
- How long without a tune?
- No Spark !!!!
- 72 suburban and 71 malibu need swaps!!!
- 6.0L vs 5.7L wiring harness
- 4.8 mods?
- 2002 6.0 truck donor veh up for auction in Tx...
- LSx in a DeLorean....
- ls1 vs 6.0L
- cpu ecm question
- Plastic Mock up engines
- 6.0L harness
- HELP!!!!! LS1 and Turbo 350
- budgets & estimates
- Alternator wiring questions
- Forward Oxygen Sensor Source?
- Ls1 carb question
- Ls1 Radiator Into Third Gen Trans Am
- 79 LS1 motor pics
- cooling...
- Mazda RX7 LS1 with ATI ProCharger '04 GTO kit
- Relocate A/c compressor help
- LS1 installed into 1982 Trans Am, need tech support
- 96 Blazer with 2005 Suburban 5.3
- Question for my buddy
- OBDII Connector
- need an LS1/A4 for your swap?.....
- I Know, I Know This Isnt The Classifieds BUT...
- Weighed my car today...
- Engine mount adapters???
- 84 k5 blazer 99 ls1 swap
- Crank Re-Learn
- Cooling Questions
- LS1 into a replica 66 shelby cobra?
- Which LS1 motor to look for?
- Interior Wiring harness help!
- Wiring for race car??
- Auto to Manual flywheel bolt question
- fs 85mm maf
- 88 s10
- 5.3 Vortec cam,LS-1 intake
- Engines from G&R Auto Parts
- So what do think? Finally got my conversion to the track...
- Anyone seen a GENIII in a 65-66 B-Body Chevy
- '68 Corvette Story...LS1 into a '68???
- 2 speed fan wiring
- ls1 into 3rd gen
- is 4 gauge good enough for starter wiring?
- Ready to fire up the LS1 280Z!
- water pump inlet not lower hose
- Air intake on a 94 3.4 l to ls1 swap
- what about...
- Emissions....
- 1994 LS1 camaro...
- Gauges help
- need some parts?
- Ls1 Electric Fan Help
- ls1 into 84 z28
- No A/C??
- I'm Stumped: need the weight of this long block
- Need help wiring factory gauge cluster to engine harness
- wiring a LS1 Fiero
- Digital Dash for ls1 swap in G-Body cars
- my idea...
- ls2 electric throttle body converted to cable?
- HELP!!!! engine running real bad
- looking for the connectors that go in the back of the dlc
- t56 into a third gen
- I want to put a LS1 in a 73 camaro!
- 2002 SIlverado wiring harness
- S&P plates on first gen with flaming river rack?
- Well today was not a good day...
- pics
- 92 maro rs engine swap...
- 92 camaro ls1 swap....
- More Swap Questions
- Yet another LT1-LS1 swap thread.
- 91 master cyl work with 2001 slave cylinder
- any one need a ecm or other misc parts?
- LSx in an Impala SS????
- LS1 V8 Miata versus Ford 5.0 V8 Miata
- S10 LS1s help
- Oil pressure gauge fitting sizes
- cooling question, need help!
- motor and tranny out of my swap vehicle for sale...LOOK
- Started my Chevelle
- LS2 G-Body Swap
- LSx conversion or stick with GenI Chevy....
- LS1 AWD S-10 question
- ls1 in a 3000gt???
- Don't pull out the search card (yet)
- 68 ls1 firebird project car for sale
- Dual exaust in California
- It's a lowly LT1, but it's finally in my Jag...
- need ls1 transplant pics
- 1955 Belair Install
- is this possible LS1 swap in Sierra 2500
- Finally got some pics together
- FS: LS1 Fbody Oil pan and pickup tube
- How Much?
- 57 Belair w/w 98 LS1/4L60E diagnostics
- exhaust manifolds from the caddy cts-v
- ls1 in third gen
- ls1 in third gen.
- LS2 swap
- fuel/VATS question
- decent looking modern econobox?
- Stock Exhaust Manifolds
- Anyone need a transfer case for 4L60E?
- 6.0 acess drive ?
- Carbed LSx??
- Maf?
- Rear End Gear Ratio for your conversion vehicle
- Looking for a engine/tranny combo
- a couple "what belongs here" questions
- ls1 porsche
- M.A.P. questions ??????
- 1986 mcss 6.0 engine swap
- 4L60E in 88GTA
- LS1 Block core - 1 scratched cylinder
- A/C Pressure Sensor
- 98 LS1 to an 82 v6 camaro
- Newbie, saying hello.
- First Start
- LS1 Fans question
- Oil pressure sensor on 6.0l, Where?
- Autometer Water Temp Gauge Wiring ?
- ls7 in a 69 Camaro
- Car dies at 75
- Will LS1 f-body accesories bolt to an LS2?
- Done
- I have some wilwood master cylinder info
- Drive by wire to cable throttle body conversion?
- ls2 Alternator
- Sure an LS1 fits in a Miata
- Alternator Wiring diag (turn waring light off)
- Early truck eng. swap
