PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. coolant sensor testing
  2. Stock tach with a LS1 in a first gen?
  3. Black plate members?
  4. 69 Camaro factory air car ??
  5. Lsx 65 Corvette
  6. Another 1968 Camaro LS swap
  7. Rx7/ls1
  8. New here thinking about an engine swap
  9. SPI EFI Gas Tank Installation
  10. 5.3 in a 71 C10
  11. The life of my 87 LSX IROC
  12. foxbody swap
  13. Looking for a junk block for mock up
  14. LQ4/4L60E into 67 Chevelle
  15. newbie nova swap
  16. my newest creation 5.3.in a what??????
  17. LS1 Wiring harness pictures
  18. 6.0 LQ4 to FLT 4L60E flexplate part number?
  19. cam recommendation?
  20. motor mount help!
  21. 2006 GTO Pedals
  22. Exhaust Manifolds Options-LS1/68-72 A body Application
  23. 8.1L Oil Pan Question?
  24. v6 swap
  25. LS1 Motor Plates for a 1st Gen Camaro ?
  26. Possible to keep VVT without the GM tranny?
  27. two cars one ls1 motor help me choose
  28. oil pressure and water temp sender
  29. Picture of connection from Power Booster to back of 5.3
  30. Need some dipshits...I mean dipsticks and tubes for swap..
  31. Carb reccomendations for a 5.3?
  32. Is this a good deal or not nobody seems interested?
  33. LS1 Goes Into My 97 Z28 and its Alive and Well 56k No!!!
  34. GTO oil pan and LQ4 truck pump compatible?
  35. LS2 for '88 IROC-Z
  36. foxbody-ls1 swap. exhaust clearance issues!
  37. Need Autometer tach help ASAP!
  38. the colorful relay wiring thread?????help!!!!
  39. motor mounts
  40. Injectors not firing... please help
  41. Fuel System Help
  42. Proper grounds? Where did you put yours?
  43. 5.3/55 Chevy combo??
  44. LS turbo swap in 3rd
  45. 944/LT1 Conversion Kit
  46. Stock K member LS!-Foxbody swaps in here..NOW!!!
  47. My conversion made sport truck magazine !
  48. A few random 5.3 swap questions...
  49. 5.0 FOX swappers....HERE !!!
  50. TBI to TPI help
  51. 5.3 into Wrangler - which oil pan?
  52. coolant cross over-water pump mod.
  53. Header Question
  54. Gto vats bypass
  55. 67-69 Camaro/ 68/72 Nova Dynatech LS1/LS2 swap headers
  56. 76 camaro with LT1/6 speed. Need header help.
  57. HELP-Building LS1/TH350 91 Mustang GT
  58. corvette fuel filter
  59. LT1 to 358 vortec (HELP!!!)
  60. Fuel Pressure Regulator Problem/question?
  61. need opinions please on what to use
  62. LS2 accessories
  63. Power steering pump
  64. american racing headers 67-69 ls swap
  65. G-body swappers step in
  66. F Body Oil Pan modifications for A body Install
  67. Simple Accessory pulley question
  68. Short in PCM Constant Power Circuit
  69. Quick question about A/C and PS on an FD
  70. 79 k5 5.3 &4l60e instal
  71. Nova guys.... What rearend are you using?
  72. Pics of G-body swaps w/pacesetter F-body headers
  73. Trans dapt mounts way off?
  74. mounting the trans cooler to the radiator like you do electric fan
  75. mustang swap guys need fuel line help
  76. 1967 camaro conversion
  77. Turbo 350
  78. nasty performance coil brackets
  79. Gauges not working
  80. Acc ???'s
  81. Newer wiper motor setup. Anybody got details pics?
  82. Looking For A Picture Of the Oil Pressure Sending Unit
  83. Fuel gauge problems
  84. SN95 LQ4 motor mount options?
  85. water pump passage adapter
  86. Need input: carb size on LQ4
  87. So I have this datsun 610.....Readers decide fate!!
  88. IACV and TPS plug wiring
  89. flipping the fuel rail question?
  90. LS Mustang motor mounts
  91. What motor mount / oil pan combo are you running in your G body?
  92. Swap keeps running with key off
  93. will cts v manifolds work on a mustang swap
  94. New to this can any one help
  95. 6.0 heads
  96. Those who have made their own harness...Come in
  97. oil cooler lines on a 6.0
  98. 5.3L Motor Oil
  99. Thinking about doing a swap into my 88 Chevy Pickup Truck
  100. BBC into fox body? what headers?
  101. 1967 Camaro ls conversion
  102. Bored.. made a small video.
  103. How much extra cost to run L92 over otherLS engines
  104. 1989 notch swap
  105. L92 Candidate
  106. starter compatability
  107. How much clearnace do you need between your transmission and trans tunnel?
  108. pro street LS7 ZO6 on ebay for sale
  109. gauges
  110. Wiring Question
  111. Vintage Air with GM compressor will it work ???
  112. LQ4 into 95 Mercedes SL600 R129 body
  113. Injector and fuel rail question
  114. spohn motor mount for gbody
  115. Some HELP please!!
  116. Need F-Body manifold flanges
  117. 6.0 in a g body
  118. Porsche 944 conversion - Dry Sump experience?
  119. Ported L92's
  120. 2nd gen camaro motor mounts
  121. What other connectors are with the C220, C230
  122. Hot rodder modified truck oil pan
  123. 1969 Chevy Nova LS2 Swap....Any Advice???
  124. nissan frontier
  125. another 5.3 powered notch
  126. New to the fourm installing an LS1 in a T/A
  127. SD parts on buying a transmission, any feedback?
  128. 5.3 or 6.0???? Need input guys!!!!
  129. 72 Nova LS1 Swap
  130. I need some help
  131. 88' Toyota 4runner + 96' LT1
  132. G-body swap guys: Which radiator?
  133. Mini fuel system is done! (pics)
  134. need help
  135. When in Rome, Project used parts 1970 C10
  136. Remix-REBUILD- Carbed LSX C3
  137. Fuel system help on chevelle
  138. How much money?
  139. ................ Go to Carb LSX OR injector LSX....???
  140. Ls1 accessory swap question
  141. Finally...LS2 70 nova
  142. Simple accessory drive done!
  143. Looking for some advanced troubleshooting help...
  144. Looking for Pass. side truck exhaust manifold
  145. LS2 Serpentine belt setup with ProCharger ?
  146. Self learning engine managment system
  147. ls1 fox swap
  148. '09 5.3 Colorado, 58X reluctor?
  149. 2006 GTO PCM Pinouts
  150. 2007 lh6 sump swap
  151. ....... Do I need to cut my hood for carb ls1 ?????????
  152. lsfun 240sx style
  153. Engine build
  154. not happy with 1/4 times
  155. Proper Cleaning/Painting Techniques
  156. 4l80e shifter questions
  157. Coolant sensor
  158. 1953 Chevy Pickup "Wild Blue"
  159. LS2 WP Pulley on LS1 WP?
  160. confused on "return line"
  161. ls1 mustang a4 shifter
  162. Ls6 twin turbo n thunderbird turbo coupe
  163. Swap parts for sale: truck pan, cam & crank sensors, covers etc.
  164. LS1 fox body headers and exaust.
  165. PCM pin numbering
  166. crankshaft pulley for carbed LS1
  167. Headers for 67-69 camaro from Edelbrock
  168. Thermostat housing options LS1
  169. 1978 Nova with LS/T56
  170. 6.0 LQ9, 3.08 rear end, help me choose a trans...
  171. Carb'ed Ls1 guys inside
  172. fuel return bung- top or bottom of tank?
  173. Just a heads up for any LS1 guys who are into Mustangs
  174. Truck manifolds????????
  175. Fbody trans options
  176. Building a cruiser...fuel economy
  177. Anyone convert/upgrade a BMW E38 740i?
  178. 63' Nova LQ with stock clip/suspension?
  179. Where's this tube go???
  180. Engine harness question
  181. e30 ls1 swap
  182. LS-soemthing ina Foxbody...engine mount questions..
  183. Which clutch setup with swap?
  184. 63 nova swap questions
  185. Who wants to be the first person to make an LS4 block starter bracket? BRP? Anyone?
  186. 6.o manifolds in 67 chevelle?
  187. Best way to do a conversion for newbies?
  188. 1967 LS conversion
  189. BBC Header+mig welder,grinder = LS1 in a 67 Camaro ????
  190. 1st gen. Camaro with an LS2 with functional cowl hood
  191. lubricant
  192. Lingenfelter 58x to 24x reluctor wheel electronic adapter module
  193. Update,with some questions, off idle stumble
  194. distributor swap question
  195. Don't need low range with 6.0
  196. DBW Throttle Issue: Non-Functioning
  197. ls1 in 97 v6?
  198. Havin' a little ls 5.3 fun!
  199. thought for 93 v6 camaro to lsx?
  200. Ls1 swap into 70 camaro?
  201. 64-67 Edelbrock headers For Sale NEW
  202. LS powered Miata swap- Build Thread
  203. Advise on switching from 4L40-E to T56 w aftermarket harness?
  204. 6.0 Blazer
  205. Pre 2001 LQ4 with an LT1 T56... Possible?
  206. I would love to squeeze a 5.3 into this....
  207. here we go again 05 5.3 in a 1972 shortwide
  208. Merry Christmas
  209. Fox turbo headers
  210. LT1 to LS1
  211. 5.3 in a 2000 escalade anyone do it?
  212. Camaro Performers Magazine feature!!
  213. anyone using the harness from the guy that sells them on ebay for 299?
  214. New Pickup Tube Girdle for LSX engines from BRP
  215. LS1 Accessory drive dimensions
  216. Chevy II guys - what brake booster fits with the LS1
  217. Cleveland Pick-A-Part warranty kicks ass
  218. What kind of rear end?!?!?!?!?
  219. hate to ask this but
  220. ebay cams
  221. Starter issue LQ motor
  222. Camaro/C10 Header Myth
  223. What is "limp mode"?
  224. Power steering Q's
  225. Throttle cable
  226. LS1 in a 40 chevy truck???
  227. Anybody Want A Nice G-Body For LSx Swap??
  228. turbo LQ4 4L80E mustang build
  229. possible to use an LT1 T56 on an LS engine?
  230. ls2 into fbod...
  231. SBC into a fox body mustang... Motor mounts!!!!!!!!!!
  232. Ls1 RX8?
  233. new motown LS engine block!! SBC+LSX heads
  234. Build Books?
  235. Is This A Good Fuel Pump?
  236. Got my LS1 started in the Gt6
  237. My Ls1 240sx Build About 95% Done
  238. LS2 out of a Trailblazer SS in a 99 WS6
  239. Any conversion guys need a blower setup?
  240. Battery relocation and MSD 6010 box
  241. c6 setup in an early f-body
  242. Painless Performance needs test vehicles
  243. Feeler...Speartech harness and L76 intake set-up
  244. '05 4.8 into a '91 240sx
  245. Getting closer, got my intake setup ran.
  246. Can the LS1 ECU & harness be used to run other engines?
  247. Low oil level sensor plug??
  248. LSX oil pumps
  249. LS1 almost ready to fire up - What next?
  250. project 666
