PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. LH8 conversion oil pan, need sensor?
  2. ls1 tach driver setup
  3. lt1 into a gbody
  4. Stock A/C compressor without the PCM
  5. ls1 into 95 z28...questions need answering please!
  6. L92 engine harness options
  7. 1980 TA w/ LSx???
  8. Temp Sensor Location Options
  9. What engine do I have?
  10. gas tank question
  11. A ls6 miata doing something that it shouldn't against boost cars
  12. LS1 Fox Mustangs
  13. fuel rail cover question
  14. Phil99vette runnin 7's
  15. will this work on my lq4 th350
  16. My cheap fuel system
  17. Lt1 swap in an s13 nissan 240sx
  18. Thinking inside the box...
  19. cam/head change on the ls chevelle
  20. Speedometer Pulse per mile
  21. finished rx7 pics
  22. LH8 oil pan questions
  23. IAC Differences = Idle Problems?
  24. FOR SALE: My 1990 LSX Foxbody Notchback/Coupe
  25. Possible Vapor Lock diagnosis help?
  26. Turbo LS1 63 Nova
  27. picture request
  28. 2001 pontiac grand am gt + lsx rwd
  29. LT1 To LS1 Problem
  30. 1932 Pro Street LS7
  31. Help with LS series into a 1985 Nissan 4wd questions
  32. '89 Iroc-z 5.3L Swap running!
  33. want cluster from donor car work in my swap???
  34. edlebrock mounts, exhuast manifolds
  35. Forsale section?
  36. alternator,how big ? how many amps ?
  37. heades for a faox body?
  38. FYI: KPH Speedo
  39. Pin A, C101 Connector
  40. how long will the oil pump stay primed???
  41. Rant about wiring, please read
  42. Anyone wanna trade their F-Body accessory setup for a 'vette setup?
  43. some long promised pics of 71 monte-DONE
  44. 71 monte cavans dashboard pics
  45. What are you auto guys doing for shifter cable?
  46. yet another C3 LS guy
  47. Holley HP 750 for sale used for engine break in only
  48. moror mount question
  49. 6.0L & 6L90 in Jeep TJ
  50. ls1 rx7: cranks but doesn't start
  51. 1987 El Camino Fuel Pump Sending Unit
  52. LS1-T56 or BUICK GN drivetrain into 69Z28
  53. help with alternator issue
  54. my Finished Datsun swap
  55. NEED HELP. 5.3 in 1971 Camaro.
  56. Starting My 5.3 Swap....Computer Questions?
  57. LS1 Swap Headers
  58. ls1 carb question
  59. Almost there...
  60. Powermaster drag alternator?
  61. Help with "Buck"
  62. 1951 Mercury Monarch 5.3 swap PICS thread
  63. 66-67 chevelle brp motor mounts
  64. Trunk mount battery wiring?
  65. 6.0 into 68 firebird
  66. Rearview mirror
  67. Car Craft Minneapolis / St. Paul, Anyone?
  68. LS2 Dipstick tube plug
  69. What Ls engine in a V6 Fbody?
  70. Another LS in a fox
  71. Motor Mounts
  72. lt1 to ls1 hood?
  73. I need some help with a 1998 Chevy truck
  74. Drive by wire pedal travel distance
  75. Carb guys, what fuel pump/system are you running?
  76. Carbed lq4 with stumble just off idle
  77. Stock tach with the LS2?
  78. Which Plate vs which Header....Killing me!!
  79. Engine for conversion - basic questions
  80. L92 truck intakes
  81. ls2 into a 81 2wd blazer
  82. Havent been on here in a while... Update of my LS1 240sx
  83. Finally done....88 Monte SS LQ4 Swap
  84. 5.3 alternator wiring
  85. Here we go, 70 C-20 with a 5.3
  86. '04 GTO ls1/t56 into '00 S10
  87. LS1 AC compressor with variable POA?
  88. just got a fox for swap?????
  89. LQ-4 Crankcase venting
  90. GTO manifold measurement
  91. typical ls1 fox swap
  92. alternator problems
  93. 3 wire MAF
  94. NO A/C in HOUSTON!!!!!!!
  95. 1989 Trans Am GTA
  96. Anyone done a C10 LSX 6Spd Conv?
  97. 82 z28 LS1 swap (56k beware)
  98. wiring question
  99. Question About Current Draw
  100. My brother's C10 454LSX build up
  101. Looking For Opinions On How To Get 150 Hp!
  102. first gen monte carlo conversion
  103. GTO MLPS/Neutral Safety Switch Wiring Pin Out
  104. Carb Guys, what do I want?
  105. MY Junk!
  106. Gauge options
  107. Anyone have an S&P modified Fbody pan?
  108. Need some help
  109. Clutch slipping
  110. What to do with the 5.3/4l60?
  111. Which would you buy? LS1 vs. LS6
  112. Vss..
  113. 1993 Mustang LSX!!! 5.3 t56 mp t-70
  114. Cats on longtubes...and evap
  115. question bout ls7 swap
  116. I'll soon be joining the family...
  117. Adapting to a different radiator...
  118. GMC Typhoon LSX
  119. Need help. Planning on doing a conversion
  120. wiring questions painless
  121. LS1 Into Fox with a different approach
  122. Anyone know how to run mechanical clutch linkage (Tremec tko) behind ls1?
  123. GTO Alternator High Mount
  124. Alternator Question
  125. LS1 plumbing - have I done it wrong?
  126. LS6 intake complete TB injectors and Rails
  127. C4 on a budget
  128. 95 Z with LS1 - battery draining
  129. wich engine mounts to use on c3
  130. 1dirtyZ's conversion conversion :D
  131. Need opinions on what my LSX Mustang is worth...
  132. Motor mounts for Gen III motor swap
  133. 39 Cp LS-1
  134. Accessory belt drive question
  135. Lq9 in my 68 camaro
  136. Energy Suspension "Preload Plate"?
  137. lsx fox body guys, which radiator?
  138. Corsa db mufflers
  139. solstice seem like a nice place to live
  140. 84 GEN III swap-Manual to auto brake pedal swap
  141. O.K.-LETS MAKE THIS EASY (any ls1 swap info u have for C3 put it hear)
  142. Finally had first test fit...couple problems, but LS2 crate manifold fits..
  143. has any one used a truck alter./power stering bracket in stingray swap
  144. has any one used a truck alter./power stering bracket in stingrat swap
  145. Looking to buy LS1 and 6MT for my conversion, suggestions on where to start looking?
  146. car wont start after ls swap
  147. Weight On A 2001 Camaro LS1 Engine?
  148. Which ECM brackets?
  149. Its ALIVE.........!!!!!!!!!!!!!!!
  150. ac pressure sensor end view diagram
  151. is there any car safe from the LSx?
  152. Coil Cover Ideas
  153. how do you convert ur TBW to mechanical?
  154. Some Pix Of...s30 W/ls1/t56
  155. She purrs like a kitten and roars like a lion
  156. LS1 Motor Plates / Mounts
  157. oil filler tube removal
  158. Clutch need more pedal travel.
  159. 92 mustang gt questions for ls swap
  160. NEEDED: 2006-07 GTO Gauge Cluster wiring pinout?
  161. Speedometer problems...
  162. chevelle radiator
  163. Alternator Rebuild
  164. I have a problem
  165. Corvette\Beretta
  166. My carbed 6.0L L92 s-10 at the track
  167. Swapping a 5.3L/4L60e DBW Setup into my 89 iroc
  168. alternator warning light
  169. Decent day at the track
  170. HELP!!! LS1 69 chevelle swap
  171. Covans Classic gauges **BUYER BEWARE**
  172. Drive-by-wire, drive-by-cable, combined
  173. Potential swap headers, might help someone...
  174. 1972 nova lq4-
  175. GM Performance Parts VALVE COVERs - OIL CAP Q?
  176. LS1 conversion for S10
  177. wire question on o2 sensors on 67 nova
  178. 5.3 L into a K-5 Blazer
  179. cracked transmission mount on block
  180. Rubber FI hose Vs. Braided AN line
  181. 04 GTO Vats disabled
  182. 6.0L into 67 Firebird
  183. LQ4 in 1990 F-Body
  184. what engine mounts for my 68
  185. 700r4 ls1
  186. VVT-equipped L92 into my '89 Trans Am GTA (with pics)
  187. ls1 in a 93+ rx7?
  188. Some new Valvecovers from Billet Specialties for the Ls swaps
  189. LQ-4 L92 Mazda RX7 Pics
  190. Wiring harness for 5.3L
  191. 87 supra ls1
  192. battery relocation
  193. Do I Need a Vacuum Reservoir?
  194. could you take my 2003 truck harness and mate it with a ls1 emc and mod the harness
  195. old style water pump LS1
  196. will the truck oil pan work in a fox body with the aje k member?
  197. LS1 T56 Storage
  198. 2007 Mustang with LS3 Swap
  199. Fuel milage with carb
  200. c3 people come inside
  201. 5.3 in a 49 pickup
  202. quick speedometer/VSS question
  203. alt. bracket
  204. 91 Mazda RX7 LQ-4
  205. LS1 ac press switch plug
  206. can a gm 1500 hd harness be used for swaping or will their be to many cpu issues??
  207. Diagnostic Port Wiring Help
  208. HP tuner guys come on in!
  209. bolting up th 350 to 04 lq4 will 5 bolts be enough?
  210. drivetrain clunk?
  211. f-body pan (1st gen)
  212. Coolant temp gauge not working in LT1 swap
  213. 6.0 in an 86 Monte Carlo SS
  214. Are all Fuel Rail Covers the same?
  215. tbss 6.0 any issues with swap?
  216. how to make my wire harness stand alone ?????please help
  217. Cut Harness-What is it missing
  218. 1st gen camaro owners, show me your AC lines!!!
  219. Anyone have harness experience with Techrods
  220. AC Delco EP386 in tank fuel pump output?
  221. 5.3 Turbo'd into fox need advice on tranny and harness
  222. 4l80e shifters
  223. fuel pump question in a 62 chev pickup
  224. Info on the LS7 clutch when using a mechanical linkage
  225. L76 conversion - fan not coming on
  226. How much is my '98 LS1 harness worth?
  227. BRP Hot Rods g-body ls kit installed picts????
  228. 5.3 Flywheel Question
  229. Manifold identification....??
  230. Aeromotive sump in 2nd gen camaro tank?help!! :)
  231. Where is my VIN?
  232. Need Help from the Wire Wizards.
  233. Couple of LSx T-56 pedal/clutch questions
  234. PCM Mounting Photos
  235. LS1 injector/rail clips?
  236. lets talk 02 sensors
  237. Metric Thread Adapter For Temp Sender
  238. 79-85 Rx7?
  239. '70 chevelle 5.3L swap
  240. Have one last L92 FS
  241. how did you tackle electrical
  242. Problem installing Tremec TKO 600 behind LS motor, mech linkage & clutch fork problem
  243. HELP..... 1st gen swap (cold air intake)
  244. 2002 LS1 Wiring Harness Modifications
  245. Engine dies when I stop sometimes....
  246. 96 lt1 swap to 02 6.0 denali motor need info
  247. anyone need an Fbody oil pan??
  248. Who Offers A Water Pump Stud Kit?
  249. LS1 / 4T65E-HD / Fiero
  250. Injected LSX
