View Full Version : Conversions & Swaps
- LS1 in a fox with a Ford Tremec 3550. Is the VSS adaptable to GM computer?
- LS2 intake conversion
- 6 Cyl K Member
- ls1 into my 4wd 1500 PU?
- Trans crossmember won't line up.
- 87 foxbody hatch build need help with tuning/turbo setup
- G Body P/S Pump Question
- Oil pan Q, how low can you go?!
- need help on fox body build
- LSx mustang swap parts, Speartech harness, fuel system and more
- GM T56 in a fox-hydralic or not?
- 404ci won't start with tranny connected!
- Wix Corvette Regulator 3373 cheap next week
- TVR Griffith 500 LS1 swap...in Japan!
- 79 Trans am ls1/turbo
- BMW M3 E36 LS1 swap
- Wiring 99 ls1 computer for race car?
- Newbie needs some advice / donor vehicles
- CTSV accessories in Camaro or Nova?
- ls1 in a 68 camaro
- Picked up an LQ4 today - have some basic questions
- Wiring Harness Grounds?
- 72 LS6 / T56 swap plus suspension upgrades!
- LS1 in a 1991 fox body stang
- Redneck Efi fuel tank a-body;chevelle
- Converting a 99 v6 a4 firebird to a carbed ls1
- Wire harness delima!!!
- LQ4 with LS3 heads/4l80e in a 1968 camaro - Ryan's Official Build thread.
- Godspeed LSX turbo manifold on a fox body?
- I need 8 injector clips! Pic inside..
- Truck PS pump in 69 Camaro
- best oil pan
- 4th gen motor swap
- Lokar tranny dipstick will not fit
- Cheapest/Easiest Turbo setup for LSx Foxbody
- ls2 s2000
- Jax04--88'rx7---88mm?---L33--PowerGlide---8.8"--v1.0
- 98 Firebird V6 to LS Conversion, HELP plz
- Truck long tubes on a 68-72 GM A-Body?
- Wiring help.....
- Gbody lsx th400 trans mount
- 1985 RX7 with LS1 and t56
- LS T56 Bracket
- Finished 474hp LS2 G35
- 67 Chevy II wagon with 443 LSx - update
- 5.3 s10 ...
- 81 tta conversion exhaust question
- Long plug wires
- 1967 camaro swap. what exhaust manifolds??
- Build Thread: Carbd' 5.3L W-200/4R in 71 Chevelle
- duramax trouble shooting
- What adapters, pan, etc. for LS2 and 67 Camaro
- 1993 Camaro Z28 5.3L LS swap header ?
- Michigan HPtuners Users?
- LS1 DeLorean Project, Cincinnati OH
- engine noise
- Good Guys lonestar nationals AX videos
- fuse rating on 4 wire hot rod loom?
- LQ9/4l80e (6l80e?) into 1995 Ford Bronco
- Can I use a E40 ECM on a 06 LQ9?
- Codes on my LQ4/LS3.
- the LS1-39 is movin down the road again
- ? on alternator bracket for LS1 into C2 corvtte
- Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor
- Sn-95 swap guys...driveshaft?
- Info on Intank Fuel Pump
- Dmax and a third gen
- Who seels the adapters for mechanical autometer temp and oil pressure?
- engine finally at home!!
- 4l80E converter on 6L90 flexplate
- What HP are you running with the Corvetter regulator?
- 5.3 harness questions
- Removing Waterpump pulley
- Elec fan control...Need tuner program??
- project 1980 malibu: as if i dont have enough to do... *updated*
- Only 20% throttle! Help?
- Trans maTching
- Engine swap
- swap headers
- 98 Chevy Astro LS1 completed
- Question on electric fans from a 96 Z28
- 4L60E or 80E in a 66 Chevelle?
- 1979 impala lq4 l76 l92 eps cam swap
- AN Hose for Heater?
- 5.3 wiring question
- no spark on lm7, HELP!
- 4th gen NOVA lq4 4l80e
- 4th gen F-Body dash in G-body
- Using a C6 cluster in swap projects?
- Still having DBW problems
- 4th gen radiator fans on 67 radiator
- Can you ID a 6L80E/6L90E?
- LS2 cam ? for my turbo 4.8 build
- Who's going to Good Guys this weekend?
- ls2 honda s2000
- Planning S10/4.8 swap, advice?
- helllp! ls3 and th400
- How to vent, systems that are known to work
- In tank fuel pump in 65 elcamino
- Faking out EVAP sensor?
- Wrong cap sizes on U-Joint in 68 camaro on custom driveshaft?
- Project "Loose Change" 240Z
- ls2000#2
- 67 RS voltage regulator post swap
- What about a 1980 Ford Pinto coupe LSx?
- 66 C10 LWB to LSX truck frame?
- duramax or cummins
- monte carlo trying to put lq4
- LSX or NEW 5.0L SWAP?
- Ls1 / 700r4 questions
- Looking for a LS motor need advice in purchase
- Small radiator? 404ci overheating.
- 1957 Eldorado Brougham
- 3rd Gen LS1 headers? 82-92 Camaro
- 79 Cutlass Wagon, 5.3 G machine
- T6060
- Higher stall for the street for 68 camaro LS swap?
- Build thread-LS4 '65 Corvair- seeking builder- CA prefered
- Where to find engine
- Engine swap vin(s) 6.5L to a 99 L31 need some Help!
- 1984 Chevy C-10 5.3 w/ 4L60e
- Need help troubleshooting new installll
- Transmission crossmember T56 swap third gen.
- 2 general questions
- fuel issue
- Need advice new to LS1
- 1972 nova canidate 5.3l t56 and turbo
- my ls1 swapped 240sx or as i all it the 570sx
- 4l60e crossmember please
- LSX 62 Nova Wagon
- Conversion idea... come inside!!
- how low do f-body headers sit in chevelle
- Need help with flywheel and clutch bolt sizes
- Chevelle guys with LS1/LT1 radiator question
- Hydraulic clutch pedal assembly for mustang
- ls1/4l60e 1949 chevrolet
- Too much gear....
- 4.8 Manual trans flywheel confusion
- F-body accessories on LQ9
- need help passenger side of engine is not firing
- BRP headers for 3G Fbody
- decent priced oil pan
- this ebay header on 72 a-body
- S10 W/ BRP mounts, headers, Holley oil pan and Modular Turbo Alt Relo Kit
- Stock 1st Gen Camaro fuel tank modification for ls swap
- Cost for GT0 Engine swap into LT1 Fbody?? Easy or tough???
- Lq4 240sx, 11.67@121
- LS 82 malibu wagon..do i need this?
- BRP 1st Gen Mounts and 2" headers Issue
- 5.3 swap into 88 chevy HELP!!!
- ls1 gto wiring and ecu
- 4th gen engine going into my camaro 98
- Fox mustang speedo/tach
- Using truck coils, clearance issues
- where can i find headers for a ls1 swap in a 84 chevy kseries
- lsXtreme. lq4+4l60e
- Actual height of LS1
- ls into 93 z71 tbi
- ls1-s14
- what crossmember on first gen
- New to site looking for help with a LS drop into a 71 C10
- o2 sensors
- ls1 swap into 78 nova
- No more dry starts
- 1st startup and burnout after Cam Install on Project S10!!!
- Turbo ly6, 70' Chevelle....Pics...
- 87 buick regal
- LSX Fox mustang radiator?
- Which Pre 1999 4x4 truck is good for an LS1 swap.
- 83 monte SS ls2
- 5.3 Jeep wiring issues
- need help mating richmond 5 speed to 4.8
- Fuel issue?
- Conversion Engine Selection
- LS3 Impala SS
- Avus Blue LS1 M3 Project *With Vids*
- Oil Pan for a '55 Chevy S&P vs. Holley
- Harness Brand Suggestions needed...
- lq9 dbw + t56 -- engine sluggish.
- Ls1 240sx NA 10.49@128
- Holley VS GMPP oil pans
- 85 chevy c10 LQ4 swap
- 69 Camaro w/ LS2, can not get both motor mount bolts installed...
- Alternator question?????
- truck manifolds
- OverDrive, What gears are you running and How do you like it?
- Can Oxygen Sensors Be Cleaned?
- Which bellhousing/clutch for 63 vette/ls1
- Project E36.0 M3
- Cheapest stand alone harness?
- Info on a cam
- 1994 Silverado 4.3 V6 to 5.3 LS engine, got some questions
- 5.3 in a '61 Corvette, T10 4 speed?
- '88 Monte Carlo SS w/ LY6 6.0 swap
- '69 Nova Track Numbers - 4.8L W/ TC76
- 32 Ford 3 Window Coupe w/ Lq4
- LS/S10 Weight?
- 1971 Chevelle -> LS1 + T56
- 200-4r to T-56 swap. Harness Q
- No Link issues with OBDII port on LS1 M3 Please Help!
- LSx into 2006-2009 4runner, any info?
- 5.3 n fox body ????? i need help
- 5.3 into jeep with gm nv3500?
- Fuel Pump Relay Hot
- LS1 Swap
- unloading my turbo setup - '72 chevelle
- 89 Caprice
- Put my Mustang on the scale tonight...
- Heater hose routing
- Another wire harness / ECM/ DBW / TB question
- 5.3L-TH400, which Starter?
- 5.3/nv3550 swap
- 1st drive around town
- Mustang floor options...idea's?
- 71 ls1 procharged....sumped tank or intank pumps???
- LS(very big) 350z take 4????
- 700+ HP turbo fox notchback drag guys come in here
- Dirty Dingo motor mounts for A body swap, thoughts? Also have accsry question
- ??no gauge lights, no crank??
- Road Race/AutoX LSx swap
- Truck 5.3 w/ factory A/C compressor
- lm7 swap Q
- wiring harness
- 6.0L (LQ4) into 68 Impala?
- T56 clutch pedal help
- 70 chevelle shakes violently,,help, pic..
- 5.3 Wagoneer p0120 p1516 Help a Newb out!
- 85 Rx-7 LQ9 Swap
- 4.8 in a jeep tj
- LS6 into 72 Nova..
- Finally finished!!
- Engine harness help
- foxbody swap header/ manifold ?s
- O2 sensor issues
- Can I cut this tab off my tranny?
- fox k member qa1 help
- square body s10 build
- 98 wireharness conversion to 99-02 help
- 6cyl to 6.0 conversion....
- First two o2 sensors
- Help identifying a fuse block
- ??? for L92 owners.
- 95 impala ss coolant sensor Q
- Wiring Harness Solutions?
- 85 C-10 4.8 swap. Help?
- LSx and LTx Third-gen conversions thread possible?
- 4.8 Pistons in a 5.3 Engine, Up Compression?
- LS1 in First gen Camaro and power steering and oil pan hookup
- If you have put a cam in a LY6 and kept VVT please read
- 96 vert to be or not to be LS1
