PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Will Hooker 67-69 Camaro LS1 swap headers work with the AutoKraft oil pan?
  2. LQ9 possibly?
  3. X pipe Or H pipe for my swap
  4. Just pulled the trigger on a engine for my swap
  5. (Not LS1) Need motor mounts for LT1 65 skylark swap.
  6. ls1 truck harness questions
  7. 71 chevelle 5.3 buildup suggestions
  8. Crank Pulley Swap
  9. hybrid help! making a 95 a 99
  10. ls1 foxbody mustang
  11. harness question
  12. Cooling Fan-system for LSX swap- Most reliable?
  13. LSX conversion questions
  14. LS1 in 93 LT1 body - exhaust adapter kit??
  15. 6.0l lq4 oil pressure gauge??
  16. O2 low ref Q
  17. It Started-86 elcamino
  18. Need help on ls2 going into 02 camaro.
  19. ls2000 ls2 honda s2000
  20. Retro Fit Oil Pan
  21. Wrangler pics
  22. Parts compatibility question
  23. Bolt sizes/lengths
  24. Gen IV Wiring Questions
  25. tuning a blow thru carb
  26. Speedometer calibration Error
  27. tb and maf question
  28. Quick 2006 LM7 ECM Wiring question
  29. Schwartz Performance 65 Tempest- LS3
  30. Contemplating a new LSx build, Rat Rod, Twin Turbo 6.0
  31. LS1 300zx Manual?
  32. my 240ISHH build thread
  33. does ls1 ac compressor take straight 12v or resisted?
  34. 5.3 Into FJ40 Land Cruiser
  35. Need a few wires you removed from your harness!
  36. cold air intakes!
  37. transgo hd2 fix low range?
  38. TAC connectorsq
  39. Air Conditioning not getting power
  40. Going from LS2 to LQ9- Sensor question
  41. Radiator Options 64 A-body
  42. Where to buy wire and realays and such for the swap?
  43. GenIII+ stock exhaust manifolds ($ budget)
  44. schematics
  45. 5.3 into 79 trans am
  46. Bench tune needed if dyno later?
  47. LS Swap To El Camino
  48. Doug Thorley headers
  49. DBW: can it run standalone?
  50. G-Body people with LT`s inside
  51. 68 camaro LQ9 turbo build
  52. LQ9 horse power rating
  53. “Ménage à trois”: 1961 Cadillac 2dr body / Impala SS rolling frame / LS power
  54. Relocate Alternator where AC was?
  55. 69 C-10 LQ9 swap, left me stranded - fuel pump wiring question
  56. Autokraft oil pan and windage tray.
  57. fastener sizes and specs
  58. Help--Wont start
  59. 67-69 F body parts
  60. swap questions
  61. Another Connector ID Request
  62. LS1 to LS2 for F-body part list
  63. Edelbrock & Russell swap parts
  64. 5.3 and 4L60E w/ ecm & harness into a '90 S10, 4cyl, 5 speed
  65. ls1 oil pan
  66. need help from the mustang guys
  67. speedometer hook up?!
  68. how to bleed clutch?
  69. 93 LT1 to LS1 Wiring Harness Conversion How To
  70. what kind of master cylinder bracket for 1965 malibu?
  71. Carb'ed & Cammed: low vacuum...
  72. G body Motor Mount Difference
  73. Need Coil Harness
  74. Yet another, BMW E-36 LSx conversion...
  75. 64 Imp SS 5.7L LS1 swap - pics
  76. Penske (Rental) 6.0L engine???
  77. ls1 power steering pump to mustang rack and pinion
  78. NEWBIE+LSx SWAP=OH GOD PLEASE HELP!
  79. GTO fuel rail covers....
  80. NEWBIE+LSx SWAP=OH GOD PLEASE HELP!
  81. oil pressure sensor /temp sensor
  82. stainless lpp ls truck header ????
  83. Ls1 Isuzu Pickup
  84. Need Help Quick
  85. L76 conversion question
  86. LY6 into a 94 firebird retaining VVT
  87. '00 GT 6.0 swap
  88. truck water pump with ls1 intake
  89. What parts do i need from my donor car?
  90. LQ4 in an 80 Trans Am?
  91. LS2 in a 37 Ford
  92. 3 wire -> 1 wire Oil Pressure Sensor?!
  93. Newbie LSx GMC Jimmy swap Questions..
  94. Moroso oil pan, thoughts?
  95. PCM and Harness choices. Which is the best?
  96. 4L60E into Park?
  97. drill mod on a third gen?
  98. Mazda RX-8 LS-1 swap
  99. LS1,1996 ford F-150, 4l60e swap
  100. exhaust questions for A-body
  101. Another stupid coolant crossover-steam pipe question
  102. drive by wire question
  103. useing the tach and speedo in 2nd gen TA
  104. ls1 tacoma shifting problem
  105. Road race/drift Conquest swap
  106. 1966 Nova...LS1 Install...Pictures Inside.
  107. Importance of proper oil pan selection
  108. 5.3 Truck Accessories -Power Steering Pulley
  109. Stupid Water pump question!?
  110. turbo headers for ls g-body swap for sale
  111. Help me complete ls2 into ls1 SS Camaro parts list.
  112. Old Chevy accessory drive system?
  113. Carb and/or MSD6010 tuning...
  114. my fuel injectors. Need help with them
  115. Lq9 power steering ?
  116. My LQ4 turned out to be a LQ9
  117. different engine mounts
  118. LS engine mounts in 71 Firebird?
  119. My LS1 Swap is Complete! (Into a 97 Trans Am)
  120. Edelbrock 7118 box with intake, header flanges, fbody rad
  121. Chevelle swap
  122. Value question
  123. For sell, complete LH8 oil pan kit brand new in box
  124. 5.3 in a 96 t/a
  125. help with wiring PLEASE HELP!!
  126. coolant sensor 3 wire
  127. A body Oil Pan from Pace
  128. Third gen ls1 need help
  129. Ford PS Rack Problem!
  130. cylendar 1 firing only
  131. Need Help with 6-speed in 78 malibu
  132. My LS1 Mustang build
  133. ls1 oil pan 2002
  134. carb + stumble....
  135. I need help from the E36 swapped people!
  136. 1992 Camaro RS, LS1/T56
  137. Sourcing "raw materials" for a build/swap
  138. Engine angle too much??
  139. OBDII Benchtop Test
  140. Need help wiring LS alternator!
  141. G body lsx radiator hoses? Part #'s please
  142. Truck wiring harness Q's...
  143. Will a escalade 6l80e fit to my Corvette LS2 engine? what do I need?
  144. The old "sleeper" gets a facelift
  145. ls1 89mustang a/c
  146. Ls1 into 66' Chevelle
  147. Corvette TAC and Pedal....LS2 throttlebody / Gen IV truck Tbody problems
  148. ls in a 1966 Bel Air wagon
  149. Anyone running the Trailblazer TC from the I6 motor in their conversion?
  150. 6.2 in 80 suburban no tach?
  151. flexplate and coil questions
  152. Hooker swap headers and mounts
  153. LS2 into LS1 car.
  154. question on 5.3
  155. A few Chevelle parts
  156. ls2 into 1998 Mercedes Suggestions and Advice please :)
  157. 69fbody Stainless steel works headders-> will they fit?
  158. I need help...02 Corvette DBW + Fbody 4L60E...which PCM OS???
  159. Shifter Question! You A6 6L80/6L90 Conversion Guys COME IN HERE!!
  160. Anyone swap a lt1/t56 into a mkIII supra?
  161. Fan wiring questions
  162. look how i got my vent line. this ok?
  163. Vats! Help!
  164. 1966 GTO-LQ9-T56 build
  165. Where can I get 1 7/8" Primary Header Flanges?
  166. Possilbe motor purchase without ecm/harness, any issues?
  167. Miata differential upgrade options for LS1..
  168. Vans with DBC
  169. LS/4L60E in a '47 Chevrolet Business Coupe
  170. 67 camaro wiring ls1 harness
  171. ls1 c1500 Chevy VPS problem ?
  172. LS1 trackday /sprint car first timed outing -6th place overall!
  173. Heidt's 70-81 Subframe goes LSX with BRP
  174. Basic ECM reprogram, what to ask for?
  175. reverse lock out wiring question
  176. List for a donor vehicle.
  177. Car an truck pin layout
  178. Painting Alum Ls1 Block for 63 Chevy II
  179. 04 gto alternator in LS1Miata - need help
  180. LQ-4 water pump question
  181. LM7 in a Jeep runs rich
  182. Auto trans choice for 67 Chevy II
  183. dash question
  184. Harness Question
  185. VSS Question...
  186. Need help with a few wires
  187. 79 Trans Am advice?
  188. ????????? Paint
  189. 408 needing accesories etc.
  190. need help identifying conectors in harness!
  191. MSD 6010 Question
  192. firebird '94 engine swap -- Information??
  193. 94 Mustang LQ4 Swap Build Thread
  194. another LS swap in the future? maybe!
  195. L76 swap into 97 SS.
  196. Autokraft Oil Pan Install
  197. Cold air intake - 1st gen camaro
  198. Cowl induction under a 68 vette hood
  199. oil pan and header help please.
  200. Replacing stock variable a/c compressor with something else???
  201. Post your G-Body 5.3 Conversion here please
  202. Trying to sell my 2nd gen install kit
  203. e36 LS1 swap?
  204. Ls1 and t56 out of Gto into 88-90 Rx7
  205. For Sale, Complete LH8 oil pan kit, brand new in box!
  206. few more pics of my 84 camaro on a track day
  207. 1991 camaro ls1 swap, what headers
  208. Need help wiring in ECU
  209. LS? Zx2
  210. f/s corvette calipers
  211. MSD-6010, no fire!
  212. What do you use to clean your wiring harness? Car wash soap and water?
  213. GTO Oil Pan Help
  214. C5 t56
  215. LS1 Foxbody... need some help
  216. LS2 Carb. ground cable from Home Depot/Lowe's??
  217. Turbo LS1 Fox nearing completion!
  218. Should I stick with a 1999 PCM and harness or try to use something newer?
  219. turbo v8 bug, running too hot
  220. 1998 firebird LS1 into a 1996 V6 Camaro
  221. What does the VSS reading tell the PCM?
  222. lq4 question
  223. Which OIL PAN?
  224. 02 sensor question
  225. Rear Engine Combo, LS1 & Audi 01E 6spd
  226. What Can I expect?
  227. Insurance!
  228. 5.7 to Ls1 Swap
  229. cam only carb'd setup with 6010 box
  230. F-Body vs Vette A/C pulleys
  231. corvette reg and fuel line question
  232. 6.0 into F-body
  233. 84 C10 a/c help needed
  234. A body motor mounts and exhaust
  235. Beretta Z26 5.3L fwd swap
  236. A few swap items for sale
  237. Air Intake Tubing Size/Fitment
  238. Anyone have a pic of A/C bracket on a 5.3?
  239. drive by wire throttle? How bad is this swap?
  240. VSS issue
  241. LS1 Remote oil Filter
  242. DBW Confusion
  243. Speedo with cable x box, 4l60e, speartech
  244. DBW startup problem
  245. Gen 2 fuel pump location
  246. LS 6.0 help please
  247. 6.0 ly6
  248. LS1 Miata - PCM & Harness help needed!
  249. Alternative to Abbott Cable X ???
  250. let me see your air intake setups
