View Full Version : Conversions & Swaps
- 48 Studebaker LS-3 conversion
- 1948 Studebaker ,LS-3, TR6060 Conversion
- 99 E36 M3 + 2002 Formula 57k Mile Donor Swap
- Compatibility Tac Modeule PCM
- Back up lights for a 6L90
- 1968 Firebird Conversion - Pan, Mounts, and Headers
- Adding A/C and need wiring help red/blue connector for a gbody
- Swapping a GEN 5 LT1 engine in a 2007 C6 Corvette
- 49' Chevy 3100 LS Swap
- lots of questions for a ls swap.
- Stand alone wire harness.....12 volt acc.....
- New Install: No pedal / Code P0106
- evaporator core fitting stripped
- Converting LM7 Inline MAF Sensor to Drop in Style?
- New issue same truck
- Ls 2003 s10 cc
- '74 C10 - Cooling system
- 2 pin 2006 + alternator. Don't throw it away!!
- Porsche 944LS
- Help with Driveshaft issues
- LQ9 truck swap into caprice95
- 5.3 240sx auto trans and intake questions.
- LS6 intake 4 bolt throttle body flange??
- dirty ground signal help!!
- Thinking about this Mustang drop in fuel cell for the spare tire well.
- Mating L33/ LS TO SUPER T10/DNE transmission
- Gauges for lt4 engine
- Running lean but high fuel psi
- Battery, starter, solenoid wiring issue
- This one is for KWhizz and the guys! (1967 Pontiac Bonneville)
- NEED HELP!!! No spark or injector signal
- need help please😩
- DBW pedal options for 2005 vortec
- boltinga NV3500 to a 6.2 LS engine
- 55/58 Chevy Truck 5.3 4L60e Build.
- Boost reference FPR - vacuum line routing?
- LS Swap into a 63 Impala
- 2008 silverado 2wd 4.3 v6 swap to gen 4 6.0
- 2017 l83 swap Dead pedal
- Lt5/zr1
- 4l80 gbody trans crossmember
- Hydro boost output rod, spring and retainer?
- Ignition relay connection 71 nova
- MSD60143 and Fastefi fuel sys
- I'm going with a crate 480/495hp LS376. What computer?
- Cruise control for 2006/7 LQ9 Conversion inop
- Steam vent question
- Need a DIY for genV LT4 standalone wire harness
- Dakota Digital button wiring: sw1 sw2
- Press in ball joint replacement on GW UCAs
- small external fuel pump
- First Gen Camaro Swaps
- Tko crossmembers
- 700r4 transmission
- Porsche 944 Finds 900 LS2 Horsepower
- LS1 & T56 into a 95 S14
- trans wont shift
- 69 C/10 swap
- 67 gto swap
- 72 Nova LS1 swap help
- Anybody use Be Cool "Universal Bone Yard" radiators?
- Wiring harness 2007 Chev lS 5.3 into 1951 Ford f100
- Aftermarket K member for my Fox swap?
- 4" air intake tube mount
- Vintage air question
- 4L85E in 68 chevelle
- Fox body conversion wiring harness questions.
- New here yall from shreveport. Lq4 swap in a nova. Need help!
- 6.0 6l90 swap crank but no start
- Car shuts off/cuts out at high rpm....
- 02 sensor wire zip tied to Transmission line
- MAF sensor alignment to coupler
- 6L90E no reverse
- Fitech 2004R TV Cable solution
- 2001 5.7/4L60E (Sbc not LS) wiring harness questions
- 1974 C10 DBC throttle
- Hotrodfuelhose-any experiences?
- Power Steering Lines
- 350Z 4l60e Transmission questions
- Holley mid-mount brackets without Power Steering
- 1998 TJ 2.5 to 5.3 Auto Swap Build <> Input Appreciated !! PIC HEAVY
- LS3/525 Hot idle oil pressure
- radiator.....nothing coming out of tubes
- Gen 4 drivetrain in a Gen 3 vehicle
- Fuse sizes on custom fuseblock
- Pigtail for TCC brake light switch connector
- LS wiring harness- bought or self made?
- Anyone running dual intake tubes.
- Stand Alone Harness Question (Mystery Wire)
- 54 gmc
- Explain 3 Relay, Dual Fan wiring like I'm 5
- Ls1 Drift car rear mount radiator? and plugwires
- Injector Pigtail Clips
- Over voltage after swap?
- Where does this go? Wiring harness bracket/spine
- Rocker numbers
- Blue Pin 33, confirmation of 12v+
- ls swap engine grounds
- Lm7 into a 82 z28
- ls3 intake vacum port
- Rubicon LS swap
- Speed Engineering 1 7/8" A-body Swap Headers??
- Converter bolts
- Gen IV / Gen V alternator and starter wiring, starter relay
- Mounts for LS swap into Panther platform? (crown vic etc)
- LT1 Gen V with 8 Speed Trans into 70 Chevelle
- My 1954 Chevy Truck LS swapped
- 95 Jeep YJ 5.3L LS build
- Gearing in turbo a-body
- first start.......popping through exhaust
- Holley EFI controlling 5th Gen Camaro PWM Fuel pump?
- 2 similar PCM wires: Green (c2) 50 and 10
- LS9 C3 swap
- Wiring and Standalone ECM/PCM
- Introduction/Swap Help
- Using an autometer speedometer...
- Fuel pump relay triggered from ECM or factory vehicle wiring?
- 79 camaro with factory 4 speed. Installing 5.3
- Two questions about battery positive cable and alternator
- Old ground strap: What is it? Can I fix it?
- 5.3l swap
- Cfi
- Should I remove the fuel rail or leave it alone?
- First time intake build: Did I miss anything?
- Power steering pump - C10 swap
- 4L80E automatic transmission in 2000 C5 LS1 Corvette
- Driving without air filter
- Hydraulic Clutch Issue...Help
- Fuel Pressure Regulator Question
- 1000 horsepower in a 90 hp bag
- Original wire from '78 Caprice Harness: What is it
- Two ground wires, not sure where they go.
- Pics of my 99 mustang ls 5.3 swap. Current build.
- L99 swap budget fuel tank
- Bare necessities to make the engine run?
- Simple Sn95 5.3 4l60e
- E46 ls swap ac question.
- 1968 Firebird LS1 TKO 600 Build
- Driver Shift Control 6L80
- GM Class 2 & Dodge/Jeep PCI Data Bus
- Help interpreting LTFT+STFT MAF data
- I have a 1958 Impala I'm installing a LY6 in along with a 700R4 transmission.
- Jeep Grand Cherokee steering box - which PS pump?
- Question about PRNDL
- Fitech Ultimate LS wiring help please
- 94 z28 SWAP to fuel pump wires
- C4 Vette - Gen 4 5.3
- OBD Wiring
- Newbie ls swap questions
- 2002 BMW X5 4.6is 6.0/4L80 Turbo RWD
- motor mounts
- E40 LS2 harness connector questions
- L33 into 2003 S10 crew cab
- TAC module location
- T56 magnum Small block to LS
- C1 Pinout colors not matching
- Fuel line
- Dakota Digital Dash plus Torque App
- Ls headers on a lt f body
- 05 Dakota LS swap
- 4TH Gen Camaro Swap
- Overfilled Engine Oil
- Engine/Trans selection for swap
- swapping a LS2 in a 2002 F150 kingranch
- trouble with fuel sending unit
- Alternator
- trancmission C5 corvette
- which tcu for 411 ecu
- 69 Camaro 6l80e yoke/driveshaft?
- oil pan with trans mounts?
- Power Enrichment
- Engine swapped cooling system question
- 64 abody exhaust exit question
- 02 lr4 4.8l swap into 86 chevy g20 van
- Fiero LS4 swap alternator problem
- LQ9 with LS3 heads
- 2006 5.3 need help.
- Coolant line routing
- 2003 SS 6.0 ls1 swap into 98 GMC Serria
- Fuel Tank Vent suggestions
- LC9 vs L92 Physical Size
- SDCB z-bar mount on LM7/LS1 modification
- Pearl, the inexpensive squarebody truck swap
- How do you fund your projects?
- Cheap Knockoff Harnesses - Buyer Beware
- 97 2 door race jeep
- 1gen s10 lq4 swap carbed or efi?
- I want to swap an ls1 into my 280z
- Ok wiring gurus, here’s a wierd one for ya
- LM7 intermittent rough idle, dies at start-up
- lt1 t56 to ls
- Aftermarket builder harness?
- 1971 A body LS swap help
- '54 Bel Air Build Sally O'Malley
- 68 Camaro Build with a Gen V Swap
- Low pressure side power steering line on MII rack
- Surge sometimes
- F150 Swap Exhaust?
- LS1/4L60e harness and ECU
- LS3-Powered '78 Corvette has a Cool Back Story
- C10 5.3 LS Build
- Help w/Fuel System For Swap
- I got 1953 chevy with a s-10 frame ls1 i nmeed new pulleys
- Header Bolt Hole Problem
- 1990 K5 Blazer with LM7 CA SMOG LEGAL HELP NEEDED
- E40 AC Pressure Sensor/Wiring?
- What is the right accelerator pedal for...
- 1972 swap for ls2
- Sanden 508 clutch wire connector
- Quick connect to AN for TR6060 hydraulic line???
- 1989 190LS Swap
- LS2-Powered 1956 Ford F-100
- TTY Bolt Question
- Help from the swappers
- 65 Impala SS Convertible LS3 Conversiona
- 66 Impala L33 swap
- Chevy 4.3 to Porsch 944 stick shift
- Help on vacuum line
- Help! LQ9 Won't rev
- 77 a body
- LS2 E40 swap-- Harness and plug questions
- Help with Be Cool Kit #80246
- L33 LS6 cam?
- 69 c10 with stock 6.2 standalone harness pedal dont work
- s10 with ls1 need new fuel pump
- TR-3650 for LS, options/?s.
- Ls1 c1500 RUNS BAD IN CLOSED LOOP RUNS GOOD IN OPEN LOOP
- 92 Mustang vert LS budget build
- 81 el Camino swap
- Need help bad miss after backfire
- LY6 (van) pulley options
- 4l70 e
- Check out this LSX C3 Swap
- anyone recognize this top mount A/C bracket
- i need an advice on exhaust pipes for the caprice classic
- 1965 C2 Gets Modern Love with a LS2 Engine
- Putting 5th gen lt1 into 75 camaro...transmission questions
- Dakota Digital gauges
- L33 | TR6060 Swap Q's
- Ls2 t56- stand alone harness
- Power steering return line issue
- 09 4.8 swap for 04 LS6
- 1971 Buick GS LS swap help
- Throttle body question
- LS Landrover VSS issue
- fuel tank return line
- Shiftworks column shift for 4L80e....
- 2009 Miata, LS3 tr6060 with ZL1 blower
- 5.3 tps voltage high idle
