PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. 1969 jetboat build thread. (5.3L)
  2. LQ4 bellhousing bolts
  3. How to Build your own Ls1 Fox mustang headers
  4. Anyone needs 5.3/LS1 parts?
  5. 98 Harness VSS Question... Help!!!!
  6. S&p motor mounts,what headers work with them?
  7. TH400 and SES light
  8. I need help with LH6/4L60E standalone wiring
  9. 2nd Generation fuel pump mounting location?
  10. LS1 swap into 94 camaro Z28
  11. Lexus IS300 + LS1 = Drift Machine!
  12. LSx Engine Identification
  13. Fox front spring rate?? (coil over)
  14. New vs re-worked wiring harness
  15. 1969 GTO ls2/T56 build
  16. 6.0+4L60 on a 70 Chevelle
  17. Value LS1 F-body Wire harness ?
  18. LS1 PLUS THIRD GEN! Please post pics and videos of yours!
  19. Wrangler in the snow
  20. Best place to get a crate engine??
  21. Best headers ls1 swap 68 camaro
  22. New Dynatech LSx swap headers
  23. Drive by cable Cruise
  24. DBW Cruise Control Question
  25. ls fox body swap
  26. LS wiring & computer questions
  27. LS guys: SCHOOL ME! (going from carbed SBC to fuel injected LS drivetrain)
  28. Where can I get fresh air for the PCV?
  29. Corvette accessory drive questions in 2nd gen TA
  30. Swap Idea i am having
  31. Cooling fan wiring question for anyone who has used a LS1 from a Holden
  32. Early Mustang swap info
  33. 6 deuce ls manifold
  34. lq4/700r4
  35. 2011 Hot August nights whos going?
  36. 1937 Ford twin Turbo LSX
  37. engine mounts question
  38. o2 sensor wiring
  39. LS engine cover
  40. Swap problems
  41. What the hell are these things
  42. How do you put pics on this web site from photo bucket?
  43. 8.1 into 94 camaro
  44. whos the guy on here that sells low mile LS engines??
  45. Chopping the truck pan
  46. Choosing Right PCM, 411 or newer 1mb style?
  47. SBC/PG swap to LQ4/4L80E: engine mounts
  48. ls1 swap wont start
  49. fox k-member question
  50. 93 coupe lq9
  51. would ya??
  52. Harness reworked to use in a CJ7?
  53. Sally is a Dirty GIRL LS1/99 f-150
  54. LQ4/LQ9 Swap
  55. Are the sizes of the lq4 and ls1 t/b s the same and connector
  56. Build thread: 87 Notch Mustang - Ai 416ci LS3, PG, E85
  57. LQ4/Turbo swap into a 1981TTA
  58. 1970 El Camino 5.3 build
  59. Stainless fuel lines
  60. Porsche Cayenne LSX conversion?
  61. Pinion angle for 67 chevelle
  62. 86 Monte LS Driver- magnacharged LS1 swap
  63. LS1 Fox body swappers, tech question for you.
  64. lq4 question
  65. Engine backfiring, help!
  66. Slick Little Power Steering Hose Adapter
  67. Hot rod impala ss 1964 5.3 swap
  68. does it fit
  69. Swapped 3rd gen guys chime in please.
  70. ls1/th400 c10
  71. 66-67 A body radiator question
  72. Another BMW E36/LSx Swap
  73. Trying to Start and Need Some Help
  74. Request pics of tri-five air intakes
  75. G-body help
  76. how to delete this?
  77. T56 Question?
  78. Mechanical speedo mod directions for T56
  79. turbo ls third gen ?
  80. HELP!! 5.3L carb conversion on a 69 camaro
  81. Help with Speedo question.
  82. no rev or throttle
  83. 5.3 or 6.0?
  84. Fuel delivery to the engine?
  85. Computer reprogram
  86. rebuilder in Nor Cal
  87. Looking for info on Mustang shorty mod (no luck with search)
  88. is this a good price?
  89. 5.3 into 94 camaro
  90. Drive by Wire Gas pedal assy for 69 Camaro conversion
  91. Upright Ignition Coil Brackets - Do these look better?
  92. Different type of bench racing?`s Jeep MPGs
  93. Super Silly Sikky deal on the Sikky swap sway bar
  94. LM7 swap into 81 Firebird
  95. camaro cluster into sn95 mustang?
  96. 1972 Nova Turbo Lsx Build
  97. LQ4/T56 into my 69 Camaro
  98. need to vent
  99. 1996 5.3 s10
  100. Trailblazer SS drivetrain in 97 C1500
  101. what would be the easiest ls1 swap
  102. Engine angle Pinion angle????????
  103. msd carb and DOD
  104. Basic Fox conversion questions
  105. 06' GTO clutch master
  106. LQ4/4l80e swap won't start-injectors not firing
  107. 5.3 into a 66' Impala - Won't start
  108. an fittings
  109. Fuel lines/fittings for third gen camaro swap???
  110. 1973 Pinto wagon LS
  111. QA1 fox K-member
  112. Building my own headers (LS1) any good stainless kits out there?
  113. 99-04 Mustang K member options
  114. Need help on Corvette accessory drive!
  115. Vin decoded
  116. Getting spark but no inj. pulse
  117. 69 skylark 4 door?
  118. DBW cruise control lever
  119. Made it in the recent issue of Hot Rod Magazine (Feb. '11, page 40)!!
  120. Mike's 65 GTO Ls1 T56 Build
  121. Anybody using brp mounts in 2nd gen?
  122. Need Some Power Wire Info
  123. LS3 Transmission Suggestions?
  124. 5.3 Swap in TJ won't run.
  125. 58x to 24x conversion for drive by cable
  126. 4L60E what shifter in foxbody
  127. T56 to a 04-05 truck 6.0
  128. junkyard 6.0L questions
  129. Took the leap...
  130. Porsche 996 LS1 conversion - pretty much done!
  131. throttle body?
  132. What lower radiator hose for ls1 in 79 camaro?
  133. 350Z LS7 F2 Procharger
  134. 4th gen LS1 dual fan assembly & stock style A-body radiator
  135. L99 LS3 tensioner pulley dimensions?
  136. 68 chevelle ls1 P/S whine
  137. Newb question about oil *rx7 LS6
  138. From a 5.3 to a 6.0 what is required
  139. Good source for universal swap mounts?
  140. thirdgen lsx help
  141. f body vs. truck ac compressor
  142. charcoal canister?
  143. 2nd gen pcm mounting/
  144. 2004 LQ4 and a 3 wire VSS, can I do it?
  145. Plug for stock oil sender?
  146. Truck vs Fbody belt system
  147. MIL - Check engine light issue
  148. Catalytic Converters, NJ inspection?
  149. motor question need help asap
  150. Street and Performance header collectors
  151. LS1 K-member on LT1 car
  152. ls3 injector pigtail?
  153. TKO-600 and DBW Cruise Control troubleshooting
  154. Which intake lq4 or LS1
  155. 79 camaro w newer vette wheels?
  156. 5.3L or 6.0L install into '57 Chevy Truck
  157. getting ready to put an ls1 in my 1968 camaro,need some advice!
  158. LS3 ---> 1982 Vette
  159. mounting DBW pedal
  160. PACE auto coil covers
  161. Pro Street 87' Mazda RX-7
  162. Truck engine into 65 Corvette ?????????
  163. Anyone have a problem putting ls6 intake on a LQ4
  164. one wire alternator with aftermarket harness?
  165. Tech Rods harness
  166. F Body Oil Pan measurement needed
  167. 6.0L Silverado engine fire questions
  168. Any 2nd gen lsx guys here?
  169. Need pinout for 2010 Camaro engine harness connectors
  170. ls2 in 79 camaro alternater hitting pitman
  171. Swap 6.0 from 2001 Silverado to an F-body
  172. STEERING WHEEL PEOPLE or any body with great info!!!!!!
  173. Parts you found out you didn't need for your swap afer you bought them?
  174. LSX Datsun Guys, COME ON IN!
  175. LS2 2005 GTO motor......DIPSTICK ISSUE
  176. LS1 Harness Connection Map
  177. fueling questions for a V6 camaro--->ls1
  178. new plan for jet boat build
  179. LS2 Nissan 350z Turbo Stage 3 =)
  180. cost of a conversion
  181. BMW 357i - Startup
  182. 5.3 T-5? How to?
  183. 65 nova wagon 5.3 questions
  184. school me real quick on swap
  185. wiring harness routing
  186. Y pipe for third gen LS1??
  187. kwik bracket
  188. 1987 Monte carlo Luxury Sport LS1 6spd (Camaro Dash and Features)
  189. Starting a 71 Chevelle LS3 swap
  190. Truck water pump, twisting the outlet?
  191. pcm???
  192. lockup switch wire
  193. Lsx 6sp in a 89 s10 2wd
  194. mustang coupe with ls1 questions
  195. adapter for four speed?
  196. 67 chevelle conversion ls2
  197. 05 5.3 LM7 charging module?
  198. spark plugs question
  199. Wiring Harness Question
  200. Completed LSX Monte Carlo Swap
  201. E-Rod Questions
  202. Gotta see this one...
  203. I made the cover of Hot Rod magazine!!!!
  204. Park/Neutral switch wiring
  205. Power steering to gear box question for 79 camaro
  206. 99 Camaro to 69 Camaro
  207. Full length Volvette Video
  208. Please help me decide...
  209. Congratulations Steve Verplank!
  210. No turning back now... 1969 Camaro convertible w/LS-2, 6spd from 2006 GTO
  211. SBC mount question
  212. ls7 swap in 2000 trans am
  213. LQ4 into a 1963 Plymouth Valiant
  214. Fox Mustang ls turbo question
  215. LS7 Question
  216. Making my Stock Ford tach work with an LS1...
  217. Trans Insight
  218. ls bell housing
  219. 4l60e shift cable question
  220. DBW cruise control
  221. f250 swap or not
  222. swap guys griffin 22x19x3 rad and fal 2500cfm low boy PUSHER 16" fan
  223. My 67 Camaro Build/Photos
  224. 67' GTO LSX Swap **4L65E Problems** *TCC Solenoid refuses to disengage*
  225. Trans compatibility questions...
  226. Foxbody LS swap longtubes/exhaust FS
  227. LS6 vs BBC 396 I need HELP making a Decision!!
  228. LQ4 which heads should I use
  229. 79-04 Mustang LSX/T-56 swaps just got a whole lot easier!
  230. ls1 engine connector pinouts
  231. Fbody- V6 to LSx
  232. C105 question pin H
  233. How do you tell if the engine harness is a 98?
  234. Anyone Looking for Shop Space in Sacramento area? Co-op Fabrication Shop?
  235. 99 Firebird L36/A4 to LS1/T56 Formula Firehawk
  236. clutch master cylinder location
  237. LS-1 crate motor
  238. '63 Short Fleet
  239. pcm codes
  240. 1981 Trans Am LS project
  241. T-5 speed + LS1 anyone done it
  242. LS2/TKO-600 1971 Chevelle
  243. My Turn...No Start!
  244. My 1967 dream machine
  245. ?s Windstar Electric fans
  246. Fuel pump wire question C101
  247. ls1 into 85 c10
  248. 4L80E controller or not
  249. Winter storage question...
  250. 1992 525iT LS1 Swapped Station Wagon For Sale
