PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. What rearend gear ratio with stock LS A4
  2. Are lt1 and ls1 cooling fans the same?
  3. Th350/400 angle drive speedo
  4. Have you used a T-5 on an LSX?
  5. Cruise control with drive by wire
  6. Alternator?
  7. Clutch switch wiring questions
  8. G-body + LSX + A/C + Vette CP Covers = ?
  9. lsx into 94 bird, wut harness options?
  10. oil pan modification
  11. This is what i want to do and i want your opinion...
  12. Fox-body w/ AJE LS1 swap k-member, engine position?
  13. 2010 Camaro parts
  14. LS1 starts for 5-10sec's then shuts off
  15. Time for the e30 BMW "GMW 353i" to get tuned.
  16. Anyone done an LSX swap in a 99-04 Mustang?
  17. what is needed to make a ls1 harness stand alone
  18. need help!! asap
  19. anyone relocate the coilpacks on there swap?
  20. another mustang getting the knife
  21. 67 Nova Wagon LSx/T56 project
  22. 6.0 Liter into a 1972 Cutlass
  23. Help with PS pump return tube
  24. 6.0 and ls1 heads?
  25. Starter and alternator wiring
  26. Carbd ls1 help
  27. ls1 megasquirt
  28. Underhood shots of my Firebird
  29. 67 chevelle 6.0 p/s clearance???help
  30. water temp gauge
  31. Project: Wreck (LS1 6-Speed Fiero)
  32. 98 Wrangle pics
  33. Engine Paint
  34. LT1-LS1 tranny brace
  35. 5.3l LM7 into 87 Trans AM
  36. 1985 C4 Corvette LS1, 4L60E Swap update
  37. Need some help identifying these conncetors...
  38. th400 vacuum source for modulator on th400
  39. HEADER TIME FOR 67 Camaro
  40. Best Cam for LQ4 6.0 Liter
  41. Electric fan interference
  42. Dry sump pump pulley
  43. 94 z28 with ls1--ur the man if u got the answers
  44. Will a 4.8/5.3 fit in a Ford Ranger ?
  45. 98+ 4th gen ing 2 fuse
  46. Ls1 into a 1993 GMC Vandura g-35???
  47. QA1 k-member + F-body LS1 ?
  48. Caprice 9c1 LS6 conversion
  49. 1971 Chevelle swap Gas tank question
  50. I know..it's already been asked..but...
  51. is there any way use the truck acc. in fbody
  52. New Harness
  53. Lets see those Custom 3rd Gen Fbody/LSx Swap fuel systems!!!
  54. Ls1 in 1998 blazer 4x4
  55. Needed: 98 & 99 LS1 F-Body Connector Pin-outs
  56. Problem? with blue Holley pump; HELP!
  57. Question about 4wd S10 LSx swap.
  58. alt. Bracket
  59. Fuse/relay block suggestions?
  60. CSR Thermostat Housing, Thermostat Part #
  61. Engine starts but won't stay running
  62. gen 2 z exhaust
  63. 6.0L single turbo 650 hp how?
  64. 67 Nova ls1 twin turbo video
  65. Tips and Tricks on Drivetrain Aligment?
  66. Question regarding swaps & NY state emissions inspections
  67. Hanks S13 LS2/T56 build
  68. Need some help....LQ9 into a G-body.
  69. computer/harness connectors needed
  70. engine covers
  71. Whose mounts are you guys using for 65 chevelle?
  72. EFILive and Moates roadrunner?
  73. Shorter Water Pump?
  74. T56 - Picture reference for connections
  75. 2001 Yukon Denali 6.0 TAC?
  76. LS1 S10 Hydraulic line
  77. Why change the dipstick and tube?
  78. LM7 ecu wiring pinout?
  79. GM bolts
  80. Corvette FPR users, I need some help
  81. 63' Nova wagon 4.8 cruiser?
  82. engie harness swap
  83. 2002 S10 2WD pickup LS1 oilpan
  84. what do I hook my brake booster up to?
  85. Help LQ4 T-56 swap into 1994 V6-5 speed Fbody
  86. how to remove connectors
  87. LS1 in a 82 bmw 320i
  88. Is BCM needed to run VATS on 99 T/A harness/PCM?
  89. msd 6010 box- excellent service with msd after problem
  90. LS1 S14 Midtown Tire car
  91. Anyone having trouble with 6010, look here.
  92. changing frontend of 1997 camaro to a 1998 camaro
  93. help with cooling problem
  94. Who did the GTO cluster in the Chevy II?
  95. valve noise question.
  96. Knock sensor
  97. 6.0 swap.
  98. 'Lack' of power issue
  99. ls into lt1 bird
  100. lt1 to a ls1
  101. '94 f body build/5.3 swap
  102. LS 6.0 Mustang In Car Vid....
  103. 83 Mustang with 5.3 swap
  104. weighed my car today..
  105. Progress of carbed 383 Sonoma!
  106. Someone to do LS SWAP?
  107. quick question on flexplate tooth count
  108. What I'm Missing(Help!!!!)
  109. Wiring?
  110. LS6 corvette water pump interferes with throttle body
  111. Should i use drive by wire or?
  112. transmission question
  113. Where do I send My 2001 A4 Harness for My LSX my swap?
  114. LS1 swap wiring question
  115. torque converter flywheel bolts wont line up... Help!
  116. LSX M3 exhaust suggestions?: question 2, thermal shielding
  117. 4L60E Bellhousing Questions
  118. S10 oilpan problem
  119. 98 camaro PCM upgrade
  120. Just some import....
  121. Fire Up
  122. Weird problem
  123. Hot Rod Air controlled by the computer?
  124. Power steering - First Gen Camaro
  125. 03 5.3L Intake swap.
  126. Oil gauge for 3rd gen F body/ LS1 swap
  127. <<<L92swap>>>for my 95IMPALA
  128. ls1,ls6,or a ls2 for a fc rx7
  129. 67 camaro exhaust
  130. Edelbrock parts for conversions
  131. Starter info
  132. 4L80E trans?
  133. CARB GUYS...can you post pics of your sparkplugs?
  134. Having hell making a/c work
  135. 5.3 swap carbed what fuel pump
  136. help identify ls1 parts
  137. 5.3 harness plugs?
  138. PCM controlled fuel pump relay - Issues
  139. hydraboost pump
  140. GM hybrid-driver-drives & blogs at same time
  141. LS1 383 Stroker In A Fiero
  142. 79 Camaro/LS2
  143. Have yourself a chuckle this morning!
  144. 5.3 cam performance choice
  145. LS3 - Picture reference for connections
  146. DBW vs. Cable throttle
  147. 89 240sx swap help
  148. Tired of searching, Lt1 to LS1 swap
  149. 2000 corvette fuel filter help please!
  150. LS1 engine install angle
  151. Mustang fuel fittings, help!
  152. lq9 differences
  153. Pics of my ls1 powered honda s2000!!!
  154. LQ4 in 68 chevelle clear stock hood
  155. Some Vids of my 88 GTA Ls1
  156. 6.0 Wagon part #2
  157. quick question on power to the fuse block (LT1 body)
  158. 68 camaro ls1 swap
  159. fuel line - HARD or FLEX ?
  160. WTF wrong with this fan?
  161. 98 ls1 with m6 wiring diagram?
  162. Couple Swap Questions
  163. Truck Swap
  164. Who has done a Datsun 280 swap?
  165. Stock LS2 and Procharger in my Ultima
  166. Automatic Transmission Problem
  167. Difference in accessory depth?
  168. Heater hose outlet fittings
  169. what are these electrical components and do i need them?
  170. ls2 into a 1995 trans am LOOK!
  171. 99-00 6-speed corvette ls1 wiring questions
  172. LS1 into Aussie 63 Belair
  173. let the games begin
  174. my gto s13 build.
  175. Intake ducting elbows
  176. Anybody use a custom wiring harness during their swap??
  177. Truck Pan/Windage/Pickup
  178. LS1 A-Body Conversion Headers F/S
  179. Wiring question...MIL Stays On
  180. hydroboost conversion
  181. Switched Fuel Pump
  182. Help me race my LS2
  183. Wierd Problem... wiring issues
  184. Power Steering delete ?
  185. Easiest way to swap a T56 into a chevelle....
  186. LS1 in 69 MGB with carb kit!
  187. oil sending unit question-info needed
  188. Fan temps
  189. AC removal on a third gen ls1 swap???
  190. 3erd gen convert. with 5 tremec TKO & Lsx??
  191. LS1 or LQ4?
  192. need help lt1 to 5.3 swap tranny and intake questions
  193. Ground wires and grounding the block
  194. $100 tothe first person to.....
  195. LS2 Into LT1 Formula?
  196. 240SX ls1 engine install options
  197. putting a 4.8 in an 1999 s10
  198. LSX 3rg gen questions
  199. Exhaust tone and tenor
  200. Pics of Oil Pans in B-Bodies
  201. VSS and brake sensor
  202. flex plate info
  203. LSX Miata Build
  204. 6 Month Old Gas? Still Good?
  205. 95 firebird with 00 ls1 4l60e
  206. Altenator hookup in a 76 vette
  207. LS1 into 3rd gen swap, headers problem!
  208. help with this conversion!
  209. Ls1 ae86????
  210. 91 Z28 6.0 turbo project
  211. Short spark plugs....
  212. 5.3 truck pan in mustang coupe???
  213. Purging coolant system
  214. Turn signal lever messed up, any upgrades?
  215. Which fuel regulator should I get??
  216. Ls flywheel for my Muncie
  217. Engine Swap ... NEED HELP
  218. ls1 into a foxbody
  219. problems with MSD 6010- possible crank pulse issue?
  220. 4l80e in a BMW E36?
  221. problems truck ls1 alt bracket
  222. Advice, please! LS swaps into third gen chevelles/caminos
  223. Oil pressure and temp gage for ls
  224. LSx/ Third Gen Fbody air intake options...
  225. 88 suburban with a 6.0
  226. lt1 to ls2 (SWAP) HELPPP!
  227. Corvette crank pulley
  228. has anyone put a/c on a 1988 mustang ls1 swap?
  229. What A/C compressor on LSX376 in new PHR page 29?
  230. L33 Rehab
  231. 69 f-body Mac mids?
  232. LQ9/LS6 in 1971 El Camino
  233. Looking for LT1 car LS1 swap articles. Help please.
  234. ls1 viper
  235. ls1 carb/distributor HELP
  236. vids of first drive in Ls1 mini cooper
  237. 418
  238. LSX into LT1 K-memeber question..
  239. Please help identify these connections....
  240. ls1/sbc fox k-member the same?
  241. 04 truck wire harness
  242. Peak Power Question
  243. Edelbrock timing pills + MSD 6010 pills
  244. Header Advice for LSX in 69 Camaro
  245. 427cid LS3 with Dry Sump in E36 BMW done and running
  246. Transmission advice...help me decide...
  247. Fuel pump wiring
  248. NEW VIDEO "What it's all about"
  249. Wiring alternator w/o PCM, help
  250. 5.3 ECM help
