View Full Version : Conversions & Swaps
- 1965 LS1 F-85 dragrace video
- GEN 4 L33/LS1 into an 04 Colorado
- Aftermarket gauges using 99 LS1 data line?
- chose a motor help me choose a body
- looking for a good write up on doing an ls1 into a 96 s10
- 69 Camaro vert LME LS7
- mustang suspension question
- what to use ?throttle by wire or cable
- Cruise lever in 1. Gen fbody
- LS1 plugs and connectors. Need help identifying
- custom headers/ o2 bung location?
- ls1 what fuel pump
- LQ9 flywheel/clutch/starter compatibility???
- Need help identifying Connector/Plug - Pix inside.
- LSX build -7.0 goal...Spend my money
- LSX engine mount templates?
- 04 GTO AC wiring question
- I have $5000 to play with for a swap.
- Coolant Overflow Volumes...
- Trying to decide what to do for my S-10
- Incredible deal on Painless 60508 harness
- trans crossmember
- On the road/dyno numbers
- Starting turbo G-body research...
- Wiring a LS1 into a LT1 Car
- LS7 in a Challenger
- Fuel System Mayhem!
- Looking for this fitting ASAP
- LS2 into '72 F-Body, no power in gear
- lq4 swap into a 95 lt1
- 1998 LS1 T56 Camaro as a donor car?
- Christmas wish list for A-body LS1/T56 swap
- another third gen Camaro started
- 1993 Notch Turbo 6.0 M12
- Best search terms for ebay/craigslist/RJ etc...
- Need some help with AN adapters.
- Queation about water pumps
- LS1 Corvette front accessories ????
- E36 BMW M3 LS1/ M6 has begun
- American Racing Headers First Gen LS1 F-body Headers
- LS1 in a 93 corvette
- Dynoed My LS2 Monte @ TTP Today
- Evap can with 2 sensors?
- 1995 mustang 6.0 conversion need info
- nova long tubes
- old 4l60e
- F-Body LS1 to LS3 conversion
- Fox Swaps
- Still no Signal at Injectors ?!?
- Pics of my 84 C10 Project - Finally!
- 4.8 to 5.3 truck
- 1st gen camaro ls1 swap question..
- Converting your AC compressor from variable to fixed
- Engine Swap 3.4 for LS1
- Ricks tank thread size?
- Syclone LQ4/4L80E tc78 build
- Cooling fan relays
- How much is this worth???
- Which to choose?
- Maf or Maf-less for g-body swap
- ´99 LS1 Tach
- 6.0l
- Carb guys, anyone offer swap deals?
- Using 5.3/6.0 truck stuff instead of F-Body/GTO/Vette
- Finally my burnout video
- LS1 into a 1972 MGB GT
- Single piece vette pan VS 2Piece vette pan
- mustang ls1 swap parts list
- lq4 coolant crossover tube
- Has anyone swapped an 07-later 5.3? No signal @ injector.
- wait4me performance reprograms
- LS1 Motor and Now C5 Brakes
- 99 ls1 4l60e in a 96 lt1 caprice
- 88 trans am GTA ls1/6spd
- 5.3 lm4 and vette oil pan problem
- 1968 firebird 4.8 swap
- Have spark but injectors won't spray. vats?
- help
- buddies 6.0, pt88 mustang
- 06 Z06 MAF connector
- long tube headers
- is the 98 engine harness different?
- LS1 or LQ4??
- harness question
- Help with truck harness
- ATI Dampeners on ebay for $287 shipped from ATI, BIN
- 1st post, big question
- i need power steeering lines
- Anyone have a pinout for 06 Chev Express Van w/4L80?
- Painless performance PCM reprogram
- Lets Talk Throttle Cable 72 chev. PU/01 LS1
- vats in 2000 5.3
- Mechanical speedo on a 700r
- Anyone keep VATS
- fuel line question...
- WOOHOO it starts!, 5.3 in 99 wrangler
- 1967 Camaro ls1 conversion
- Fuel level wiring for Flex engine
- Spectre Fuel Tanks
- Yes it just another one.
- The 1977 Camaro LT 4.8/4L80-E is Finished and on the Road!
- Upcoming LSx swapped 83 Malibu wagon
- Swap Finished! Now what is this and can it be moved??
- Which rear end gear in a LS1 powered Rambler?
- Has anyone used the Transadapt SBC motor mount shims?
- LS1 throttle bracket
- Extending shorties????
- Delima
- Is the intake manifold symmetric?
- t56 out of a '99 viper
- fuel pump issues, need help here
- Power steering pump ?'s
- F-body pedal switches (?)
- 4L60e shift linkage
- 62 Cadillac
- Increasing the f-body steering pump pressure
- ls1 swap & parts list (big read)
- 2004r - drive by wire?
- any way to run mechanical fuel pump w/ genIII ?
- Help with 5.3 Fan wiring
- LS1 Miata Automatic??
- Anybody use a Truck harness in their swap??
- Which intake for G-Body swap?
- converter lock-up?
- new info on fox swaps
- carb clearence
- No return line on fuel rail. Do I need special pump?
- LS7 street manners?
- 2nd gen fbody brake booster to ls1 intake manfold questions.
- Billet Specialties New LS Tru Trac From Sema 08
- PCM Mounting and Air Flow
- trade? E-BROCK vic jr carb swap
- Coming over to the "dark side" (half way anyways!)
- Can someone tell me what my lsx s10 is worth???
- Accessory Drive question
- Corvette T56 compatibility????
- Question for 2nd Gen F-body LSx owners
- Adapter plate dimensions?
- Help with a 3800 supercharged Fiero swap
- Has anyone cut the wings off a Batwing pan?
- Carb Jet Size
- Auto pulls through brakes when in gear, ideas?
- 1978 c3 anybody do a ls6 swap?
- LS1 Pinto project
- Speartech harness question!
- clutch master pushrod
- Adapting LS computer to other engines...
- Ls1 into A 72 Chev Pickup
- Ls1 Camaro Vs Corvette Ac Brackets
- 2002 v6 camaro ls1 swap
- Programming brand new PCM?
- 08 5.3 d.o.d carbed blowthru turbo ???
- sending units
- some pics of my 67 SOM ls1 camaro
- 2nd Gen header clearance (right hand drive!)
- Hey cluster /gauge gurus
- Considering a LSx swap, 240SX instead of an SR20/GT3071R
- 4th gen Subframe in a 1st gen?
- Alternate 400 Crossmember method
- Swap LS style 6.0 out of a truck Into a 1963 Impala
- 5.3L or 6.0L in a 71 Riviera Boattail
- Ls1 problems
- 4.8/5.3 in a 91 Firebird
- Everybody please read (ripped off)
- 5.3/4.8 problem
- Please Help with Low Fuel Pressure
- LS Alternator & AC Brackets
- 04 GTO wiring harness.... Need confirmation this looks correct.
- What parts for PS delete?
- Need advice on swapping pcm out of a 01 into a 98 TA
- Can i run a lt1 clutch pedal with ls1 clutch?
- gauge clusters in hybrids
- What will I need??
- Which suspension do I need for Stang Fox LS1?
- Which stock intake to use/avoid?
- what trans to use?
- Tapping the brass block plugs for temp sensor
- '47 Chevy PU supercharged 6.0/4L80E
- Check out the 3 inch mandrel bent dual exhaust that we made for the Solstice (pics).
- Aeroquip AQP high pressure hose for PS
- Tcc
- PCM anti theft removal?
- 1972 Chevelle, LQ4 6.0l/4l80e single turbo
- She's Alive!!!
- ls swap in my 86 notch
- Honda Accord LS1 or LT1 swap planning
- v6 to v8 NNBS GMC
- Does this sound right?
- alt relocation bracket for f-body ls1 engine
- 1 gen 350 swap into LT1 car?
- 4l60e?
- LSx into 64-72 GM A-body
- can a LS4 be squeezed into a 1997 malibu?
- truck harness for build up?
- 5.3L Into a LT1 94 Z worth it?
- Oil pan?
- Tahoe Fusebox diagram??
- 64 Malibu F-body pan, does it fit without mod? Tried search didn't find clear ans
- Which headers and accesories for drop in G-body swap
- tryign to do first start, problems
- Swap
- fuel rail covers
- Is my return line too small???
- LSX iroc times?
- Best Trans
- Gen III LS1 LQ4 fullsize blazer swap stuff for sale
- Perfect poster to describe this forum.LOL
- 2nd Gen F-body.. what frame stands did you use?
- thinking about a 5.3 in jeep yj!!
- LS1 and 6spd into a 66 Rambler American
- Denali Pcm Pinouts
- Harness soldering ok?
- X-member help?
- 5.3 harness, tach module, foot pedal, and TB all for DBW
- truck PCM pinouts?
- LSx Swap into 1998 240SX, exhaust options and maintenace access?
- ............What is better for carb distributor or MSD control?
- 06 4l60e pnp switch wiring
- Pre-75' vehicles? Avoiding smog
- no spark or injector signal for 5.3
- Oil pan options
- .......Can I use this fuel pump in ls1 carb????????
- carb intake gmmp vs edelbrock victor jr
- ls ? into 66 chevelle
- help
- Gen IV swaps without BCM?
- A-Body 6.0/5.3 Ford p/s pulley swap pics
- Turbo Questions
- A Body Motor Mounts and Gen Ques.
- Complete powertrain swap, 00 Z28 to 93 TA?
- .............LS1 Carb guys come in .............
- 4L60E and 4L80E Question
- Swapping an LS1 into a 70' Nova?!
- 1998 Camaro 3800 to 1998 LS1
- A couple questions
- My LSx swap into an '81 Malibu is complete
- Where to buy LH8 oil pan?
- Pics of G-body LS1 swap
- looking to do a conversion, quick question.
- 62-67 Nova guys, please chime in.
- Stainless Works Quality and Fit
- Shifter for fox Mustang question
- wait4me wiring advice?
- Carbed Mustang questions
- 6L80 mate to big block?
- Ls 376/480
- 5.3 fuel rail with return
- LS1 swap into a Austin Healy B "bug-eyed" Sprite?
- cma and crank sensor output voltages....
- 1990 miata
