PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174 175
  1. How did everyone do their gauges??
  2. Where can I hook into for oil pressure guage?
  3. Gremlins
  4. fan trouble....
  5. Engine sputters for first few minutes after start up in '61 Bug
  6. ls1 into lt1 car
  7. Vortech To LS1 Accessories Question?
  8. Vortech To LS1 Accessories Question?
  9. Vortech To LS1 Accessories Question?
  10. Vortech To LS1 Accessories Question?
  11. Where do get a ls1 throttle cable??
  12. LS1 in 91 Vette
  13. How about an Archive for this section?
  14. Those who have done the swap
  15. Do a lot of people do swaps?
  16. 97 Chevy truck with LS1
  17. harness connectors, pass fender? what kind?
  18. LS1 & LS6 intake identification
  19. need source for 98 wiring schematics.
  20. Has anyone put a LS1 engine in a C4 Corvette?
  21. Speartech, about that alternator thread...
  22. Almost done with LS1, i need help, some ??'s
  23. I KNOW IT ISN'T A LS1 BUT>>>>>>
  24. Fbody wiring harness on eBay
  25. All 1999 parts except the PCM
  26. Photos of my 63 Corvette Split Window LS1
  27. Will a T-56 fit..
  28. Putting a LS1 into my 97 V6 firebird....
  29. LS1TECH project 69SS LS1 is here!
  30. 1955 chevy install
  31. Project monster complete
  32. Engine swap
  33. vintage air with factory PCM
  34. PCM Questions Pros and Cons of Different Years of PCMs
  35. Need info on 5.3 swap into a 91 c1500
  36. 78 vet conversion
  37. Autotap won't connect?
  38. Shorting Problem
  39. LS1 conversion to 1966 Chevy 2 SS
  40. Just bought painless LS1 harness for $460.
  41. A/C Unit
  42. 1st gen help! (off topic)
  43. 2002 LS1 engine/trans Price???
  44. What to power my hauler?
  45. Classic car guys - I need more votes!
  46. ~350rwhp LS1 RX7 goes 11.4 @ 120mph!
  47. Not sure where to post vin decode
  48. Decisions ...I need some help
  49. 82 Trans Am and Corvette oil pan
  50. LS1 Into Early Bronco Info
  51. Is a T56 worth it
  52. LS1 SebringMX
  53. Vin Number Location
  54. Can we get a count of all of the 1st gen camaro LS1 swaps?
  55. LS1-powered Z3?
  56. 91Z28 LS1 Swap...Pics Inside.
  57. 94 Z28 Project Complete
  58. What radiator to use?
  59. ls6 in 72 z28
  60. Chevy II Much
  61. LS1 into a 1994 Camaro
  62. Anyone try the hooker long tubes in a first gen camaro
  63. Truck Oil Pan
  64. what do you think
  65. Thinking of switching turbo EFI 67 to NA LS1
  66. LS1 in an IROC
  67. Conversion exhaust!!!
  68. LS1/6 in 69' Camaro ???
  69. LS1 into 94 t/a wiring harness?
  70. Engine install for 97 Z28
  71. Engine Swap, LS1 into a 92 GMC 1500
  72. My stock 91 vette throttle cable wont reach throttlebody, fix?
  73. Vats resistors
  74. Thinking of putting an LS1 in my 96 SS
  75. 5.3 truck harness?
  76. Adapter Mounts
  77. Serial Data: DkGrn, pin 59 from PCM Blue?
  78. My first post
  79. Engine Swap (LT1 for LS1 for LS6)
  80. The Ultimate LS6 powered car?
  81. pcv question?
  82. motor mounts
  83. Signal wire for an ammeter?
  84. tachometer signal wire
  85. malfunction light
  86. Wiring Harness plugs
  87. Running the ac compressor belt without hoses?
  88. clutch bleeding problems
  89. Oil Press,Temp gauge adaptors
  90. 67 Camaro Project Idea
  91. Any LS1 69 Camaros for sale?
  92. LT1, LT4, LS1, LS6, L31, 5.3L, 6.0, or a 1998 Vortec 454?
  93. Two questions? Air and Auto Trans.
  94. LS1 into sonoma
  95. Anyone using double pass radiator?
  96. LS1 in 66 nova
  97. FT FORCE
  98. Speedo/ shiftpoint adustment
  99. LS1 swap how much more than LT1 swap?
  100. Coolant bypass question?
  101. LS1 out...BB in
  102. An LS1 swap isn't cheap but it's worth it to me....full $$$ disclosure inside
  103. How Much Does An F-Body Weigh?
  104. tapping water pump for temp sender??
  105. 58 Vette with LS6/T56 - How do I get the speedo to function?
  106. computer tuning
  107. ls1 conversion into 2k2 sierra
  108. harness conversion
  109. LS1 into a 97 Chevy Truck
  110. Which 16" fan is best.
  111. Radiator Hoses??
  112. NEED HEADER HELP?
  113. LS1 Jeep via Donor Truck?
  114. VSS and Gear Ratio?
  115. Have you guys been here
  116. LS1 master cylinder/brake booster
  117. LS1 conversion on 93 T-A
  118. Fuel Pressure Dilema
  119. LS1 fuel rail covers part number?
  120. ? About wiring and what i will need
  121. playing nice with my regal
  122. more cooling questions, a little different.
  123. 88' GMC S-series LS1 Conversion???
  124. LS1 into a 2002 Monte Carlo
  125. need some tech help please
  126. Wiring Harness Connectors
  127. 4l60E shifter
  128. 422 or 434 in 85 Trans Am
  129. EVAP solenoid
  130. Conversion Question (Driveline)
  131. LS1 Pre-oil before start-up?
  132. ls1 into first gen (again)
  133. Start circuit 1035? (Ppl/wht wire)
  134. Maf wiring
  135. LS1 Power Steering Pump, will it work on an older box?
  136. cooling an LS1 in a S-10???
  137. Better to get vette ls1?
  138. Ok, newbie question(s)
  139. Speedo and Tach hookups
  140. 4L60E question
  141. Steering Rack
  142. switching an lt1 for ls1
  143. Transmission mount on 94ls1
  144. Paging SPEARTECH!!!! UPDATE ?????????,,,,,
  145. VSS signal and scaling
  146. LS1 in 1st gen questions
  147. Help on heater output and inlet
  148. $900 "5.3" in a $200 67 Chevey II sedan!
  149. Fan wiring
  150. What's your fuel milage???
  151. LS1 dimensions?
  152. Gas Pedal?
  153. Items for a perfect hybrid conversion
  154. swapping 305 for a ls1 on a 92 rs
  155. LS-1 into 1970 Monte Carlo
  156. mechanical to electronic speedo adapter?
  157. LS1 help in Houston
  158. Intake duct ideas?
  159. 62-64 Nova.. Next project
  160. LS1 into 1969 Vette
  161. LS1 powered '93 RX7 track testing
  162. Radiator hoses
  163. 68 Chevy Shortwide 2WD corvette LS1
  164. Cooling Fans for Hybrids?
  165. LS1 RX7
  166. Project Car Question
  167. Well, my hybrid swap just got a hell of a lot more interesting!!!
  168. ls1 to a 700r4 -- my new project -- please help
  169. Fuel (pump,sender, etc.) wiring question, confirmation?
  170. Need all 2nd gen LS1 info i can get
  171. 1/4" Return Line for fuel system
  172. temp sending unit
  173. Backup light ???
  174. Here are some pix of the Chevy II
  175. swapping from 4l60e too th400
  176. John B. *Clutch Cylinder Travel*
  177. ls1 help need measurements.
  178. LS1 powered '93 RX7 video
  179. brazed on AN fittings for fuel rail
  180. Altenator wirring question
  181. Which manifols flow better?
  182. In-tank pump or external?
  183. Fuel line size
  184. 67 firebird ls1 swap?
  185. 99 Ls1 fuel systems help
  186. The Chevy II is alive!!
  187. Fuel pumps???
  188. Need some advice...
  189. Primary O2 Connectors Are where?
  190. fuel filters
  191. a/c compressor fittings and Sanden #
  192. vette vs. fbody crank pulley
  193. Silverado V6 to a V8
  194. Jaguar w/ an LS1?
  195. Different Motor mounts for LS1
  196. GM Wiring Harness?
  197. o2 simulator question
  198. ls1 motor
  199. has anyone tried to put 99 guages in a 96 car??
  200. 98LS-1 into an 85 Vette??
  201. Wiring harness gurus. ? Inside
  202. Which 4 wires to hook up to make conversion start?
  203. LS1 C4 Conversion
  204. Traction Control
  205. In too deep to quit swap out 94z28 to 99 LS1
  206. I need some help with VATS. Can someone give me a hand or suggestion?
  207. LS1 in a Jeep
  208. which year to buy and what to look for?
  209. Whats the easiest way to relocate the alternator?
  210. IROC/TA?
  211. C5 seats in monte carlo ss
  212. First gen LS1 headers
  213. How Water proof are the Ls1 Electronics?
  214. New forum for the Trucks/Cars/Hybrids
  215. abs lines
  216. speedometer question
  217. What year & type trans for 98 LS1???
  218. GM LS1 Exhaust Systems
  219. car wont start. little troubleshooting help please?
  220. external fuel pump
  221. Does anyone know of any 93-97 Formulas with an LS1?
  222. Year One makes it right
  223. LS1 Motor Mounts for...
  224. What starter do I need to use???
  225. Anybody put a LS1 in a late 60's early 70's Abody?
  226. Cruise control question
  227. Welcome Speartech Fuel Injection Systems! Newest Sponsor
  228. Aeromotive 13109 question
  229. Fan relay question
  230. Cost of LS1 in S10
  231. LS1 into 58 Impala???
  232. 6.0L swap???
  233. Can True Mileage Be Extracted From Computer?
  234. Need LS1 to look at
  235. 1995 to 1998 camaro gauges
  236. Dropping an LS1 into a 93 Z28
  237. LS1 in a 02 s10 blazer will it work?
  238. Front suspension swap redo abs lines???
  239. WTB. Balancer
  240. ls1 radiator
  241. 1,500 miles on my LS1 powered '93 Mazda RX7
  242. can i use a 98 harness on a 02 engine
  243. 1968 Chevrolet Impala LS1 conversion (Help)
  244. warning! year one ls1 1st gen headers
  245. Extruded Aluminum Fuel Rails
  246. LS1 to mid engine design
  247. headers for conversion??
  248. new to the board
  249. Flywheel ??
  250. Anyone know if i can swap...
