View Full Version : Conversions & Swaps
- 98 Firebird LS1 carb swap
- 408 stroker in my 71.
- how to depin connectors (gauge console specifically)
- PCM near a speaker?
- 83 monte ss ls1
- supercharger question
- T56 Mechanical Speedo
- Trans that don't need tunnel mod in 69 A-body
- 1969 chevelle ls1 fuel tank.
- Dropping a 5.3 ls into a bubble caprice.
- LS1 swap for 2nd gen firebird 1981
- 70 camaro LS1 radiator hose
- 2004 GTO PCM and Truck VSS: Compatible?
- 99 Corvette Wiring Harness
- 81 monte carlo 5.3 carbed
- Buying Shortblock VS Complete Motor
- lq4 build up
- 4 bolt 90mm tb
- 1980 Volvo 242 LQ4/T56
- Need some wiring help!!
- Hooker LTs into Gbody
- working out all the bugs
- ls1 steam line?
- oil pressure sending unit thread??
- Electric fan comes on too early
- A/C Compresor swap
- Another LSx in my nova.....
- Front oxygen sensors... location info sought
- Another FD LS1 swap completed!
- 2001 camaro LS1
- need help understanding the MSD 6010 box
- 05 mustang gt swap,anyone done one??
- Transmission line locations
- LS1 RX7 GUYS, PLEASE COME INSIDE! thanks
- Tach questions in a fox stang
- am i ready?
- which plugs for LQ4 with carb?
- 4L60e questions
- Couple questions to wrap up my Conversion
- can not scan ecm while the car is running.
- runs nice at idle but looses responsiveness in gear!!!
- first gen stock radiator with ls1 swap?
- Mustang LS Swap Headers.. Anybody using 351w headers?
- HELP!! it will only run on 4 cyl.
- GTO Engine Oil Dipstick Plug for Block- LS1 LS2
- bellhousing bolts
- LY6 Build ?'s
- pilot bearing for ls1 for tko600
- ls1 in a 69 camaro whats vss?
- my 5.3 is running pig rich
- noob
- GM LSx Clutch Master Cylinder-hose connection detail/dimensions…
- Fuel Injection Scraped (need suggestions now)
- return line question
- problem with flywheel spacer
- help on problem with ls1, engine dies after 1 min of driving
- 5.3l swap
- 2004 GTO dashhawk type device
- LS2 Wiring ?'s
- 94 white FD LS1, Turbonetics T76, Cobra IRS, C6 manifolds.
- Racing Concepts Miata kit? Did they go under?
- 03 Truck alternator wiring question
- selling my mustang
- can someone confirm tbss pin out
- 4L60 Shifter Choices?
- ls1 or 6.0l
- Does the GTO use a different thermostat housing & stat? S&P one doesn't fit
- Wiring question, power to '98 LS1 PCM
- Tanks inc fuel pump - fitting clearance issues
- 2005 truck wiring
- Have a Wait4me mail order tune problem? please check in
- LS1 in 95 Formula help
- Pics of 4th gen with a carb small block
- Speartech number,site?
- Car keeps cutting out.
- 2007 lq4 and 4l80E wont upshift after kickdown
- Chevelle LS1 Rear End Swap Questions
- Test drive time.
- PCM doesnot fit bracket?
- COPY CAT,Gen2 Fbody CAI Pics
- WTB: Stainless Steel A-body Fuel Tanks
- GM A body swaps....need cold air intake pics......
- Harness questions
- PCM did I buy the wrong PCM?
- Original guages w/LS1 swap '71 Chev-help
- Flex fuel injectors?????
- LS1mustang: I'm having problems with my glide install
- TAC module, pedal, computer compatibility
- Where to buy AJE parts?
- Considering LS3 into Z4M...
- ford t5 behind an ls?
- Vortec 4.8 or 5.3
- tko600 to a ls1 in 69 camaro
- Definitive Fuel system answer - LS3 into 72 Chevelle
- Eldebrock motor mount question
- need help with ls motor in a c4
- 77 Monza LQ4-LS3 carb
- A couple quick wiring questions!
- engine harness conversion question
- Restored 1968 LSx swapped Camaro
- 5.3 and t5? possible?
- Got my LS2... now what!?!
- Foxbody AJE swap stuff good deal found on CL
- LQ4 conversion questions
- 1966 gto lq9/t56
- need to know if this will work
- tuning help im lost here
- Fuel pump question
- Datsun gauge swap help
- lsx 1gen blazerado
- Where did you mount your corvette fuel pressure regulator?
- Misfire at WOT
- ls1 wire harness what did u do
- My late second generation camaro fuel tank mod
- Info needed
- Heater hose bypass idea
- need some help
- schematic for fuel sending unit needed
- Stang lsx swap speedo ?
- LSx engine into series III Jaguar XJ6
- Ls7 oil pan
- Will 6.0 valve covers work on my L92 heads?
- 05 Gas Pedal
- help with taking apart dbw throttle body
- corvette filter/regulator
- Ls1 into 94 camaro v6
- Have a stumper of a question.
- Manual in Fox body
- anyone running a DBW with a non elec trans?
- need help! LSx mustang
- Power steering pump fried--need the help of the pros
- sending unit question
- fuel gauge not working
- '64 Chevelle 5.3/4L60E swap build thread
- Finally picked up my 6.0 motor, yeah!
- a noobs 5.3 turbo
- ARP torque specs
- Power steering pump hose
- 1963 Oldsmobile Cutlass F85 LS1 swap
- extra coolent capacity
- '91 RS LS1/4L60E swap w/ a few pics...
- SBC Crate Motor Smoking *PROBLEM SOLVED* Update Pg.2
- whats a good gear ratio to run with 4l60E?
- Dipstick - LS1 Oil Pan on 2000 5.3l
- Which aftermarket AC for 67 Camaro?
- front wheel drive 5.3
- stock oil temperature sensor thread size
- photoshop help.. 65 chevelle ls2
- another 'is this legal in CA' thread
- Water pump question
- Oil level sensor delete
- Need a 47-46" driveshaft
- RCR Superlite Coupe build
- 58X Crank in 6 liter block w/ older style cam sensor
- Use baffle with S&P pan?
- Woot! All future LS motors will be completely aluminum!
- Drive by wire driving me crazy
- motor mount templates
- L92 with 4l60e
- where can i get a flexplate
- Lsx Charger, considering the swap
- Engine runs, won't rev. Doesn't react to throttle changes. No codes. HELP!
- Turbo 3rd gens
- lsx 2wd geo tracker
- LS1 wiring harness identification
- converting My 69 camro to LS2 Advise please
- ls2+t56+78mm+9"= bads10
- need help with these connectors
- LS2 in my caprice
- issue with 98 auto ls1 harness on 02 5.3/4l60e
- Minimum circuits for swap
- Potential LS1 Swap Filter
- ls1 oil pan for 69 camaro?
- LS2 into another GM A-Body
- securing fuel lines
- 98 auto ls1 wiring harness on 03 5.3 auto swap complications on the trans
- My 1966 Lemans getting LSX
- Truck Water Pump Steam vent question?
- 1977 Chev Monza Spyder LSX454 underway
- windage tray
- Need a little wiring help.
- My LS1 Air conditioning retrofit
- valley cover
- Alternator Plug Identification
- Help prevent me from being Nickel and Dimed to death
- LS3/4L70E into C4 Codes/Problems
- The one and only, GMW! (Now with the baby turbo) PICS
- Thermostat
- fuel system diagram
- ECU for drive by wire
- LS pulley setups
- Bagged LS1 Nissan Hardbody Rat Rod
- Any no what power the maf?
- 4l60e vs. 4l80e size.
- What hoses?
- Drive By Wire pedals
- Edelbrock mounts which crossmember?
- Accessory, Mounts, and computer questions
- 6.0L out of 2007 Van?
- 68 impala/LQ 4 swap EVAP Purge Solenoid
- 2004 gto bcm,
- mounting the ECU
- '87 IROC What to put in?
- HydroDynamic Rock Crawler
- Impala/caprice lq4 swap
- Q's for LS1/4L60E G-Body Owners
- Why are people keeping thier non-OD tranmsssions with thier swap?
- MAF/throttle body position, close or not?
- wrong or upside down motor mounts???
- mounting TV cable on ls carb intake
- Car runs for 5 seconds then dies
- Swap wiring question...
- heater core need to be aluminum?
- Ls1 dodge ram!!!
- Thinking of adding a ls2 engine to a camaro 93' a few questions
- Cleaning up a swap motor?
- 1998 Mustang LSx progress pics
- Digital Dashboards
- Simple LS1 harness
- My Datsun Hybrid Project
- Looking for vendor
- Wire harness questoin ls1 into 95 ta
- jeep 5.3 witout 02 sensors
- g body headers
- Anyone converted a C5 6speed to a Auto?
- 2nd gen swap tranny question LQ4
- 1994 V-6 Camaro Combination Switch Pinout?
- Correct flexplate
- E36 M3 - LS3 New headers finished..
- Turbo 5.3 s10 build...
- New Venue For My LS2
- utility of this tube?
- header info
- 94 formula/ 98 powertrain AC question
- Looking for 9's... which turbo?
- need help on running issue,working on car right now. thanks
- AWD Conversion???
- Transmission Conversion Problems
- Cam Position P0342 Trouble After Swap
- Ls2 v.s. Lq4
- Big Brake conversion on non ABS car. OXYMORON?
- Engine wont fire please help
- BRP HotRods' oilpump girdle
- 2010 Camaro Fuel Rail covers?
- How to get the oil, temperature, and volt gauge to work?
- 06 GTO swapped into 69 camaro
- Fuel Line: Dual or Single
- 1986 SS Monte LS1 Swap
- foxbody starter wire issues
- Swap header for a 71 Chevy truck??
