PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 [152] 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. ls1 t56 into a 71 chevelle?
  2. any one put an ls1 in a 350z or g35?
  3. Wiring up a chevy keyed ignition, help
  4. All this talk about a T56 in a Fox, so here's my swap thread.
  5. fuel tank question
  6. priming the gen III
  7. intake elbows
  8. My Nova getting an LS1
  9. more electrical gremlins taunting me
  10. Crank trigger
  11. diff in harness ?
  12. LSX engine placement Question
  13. Painted my camaro the other day...
  14. LS1 bellhousing bolt pattern or drawing NEEDED!
  15. Drive-By-Wire Gas Pedal Compatibility
  16. Alt. wiring problem,,
  17. Ls1 C3
  18. buick 3.8 turbo motor in a 98-2002 camaro
  19. Cleaned up the wiring some more...
  20. Conversion won't start... baffled
  21. Fuse/Relay Panel - Junkyard
  22. whats it take to hide the power steering resivour?
  23. Any Chevelle guys running hydroboost?
  24. Low profile fans needed for my 55 ChevyTruck
  25. Its Alive!!!
  26. pics of my 69 camaro blackwidow in progress
  27. Tanks inc. sump
  28. ??? Fair Price For Low Mile LS1... & T56 ???
  29. 5.3 intake & cam options
  30. Found a motor have some questions
  31. wtb 1998 ls1 f-body engine harness
  32. Drivability problems have me stumped! Please help!
  33. 02 Sensor question for my LS1 swap
  34. Here is a really stupid question
  35. LT1/T56 into 98+ s10
  36. New to the forum, couple of questions
  37. Accessory Drive pictures
  38. ls1 into '56 bel-air?
  39. bellhousing boss ?????????
  40. lt1 pinouts
  41. LS1 Wire question??
  42. wiring size for the harness that goes to the CPS?
  43. LS1 240sx Hit the dyno today.... Its all Done!
  44. Need some help,68 chevelle th350, ls1
  45. buick century
  46. Harness connectors
  47. Old School LS6
  48. making it idle??? Ls1 all wired fused and relay
  49. turbo LS1 fox ideas
  50. Ls1 Rwd In A 93 Prelude Omg-
  51. Another wiring question? Please help!!
  52. My 93 04 LS1 mustang, mating MN12 ?s.
  53. Cj7 Finally On It's Way
  54. Lengthen PCM harness... what size wire?
  55. A few in depth questions
  56. HELP LSX in 67 II...
  57. Opinions on custom dash arrangement...
  58. are TAC modules interchangable?
  59. 91 Z28 Lives, first Video done.
  60. 3rd gen or 98+ v6
  61. 2003 Silverado air intake temp sensor part#?
  62. Electronic throttle woes... need some help
  63. Who does wiring harness mods?
  64. anybody have pix of an lsx in a 93-97 camaro?
  65. LS1 in a 72' Datsun 510 has it been done ?
  66. fenderwell mounted pcm cover
  67. Thread pitch and size of the F-body AC pressor sensor
  68. Need help on PCM and Harness
  69. Ideas? What Color for my Fuel Rail Covers?
  70. need direction
  71. Stumbles when I get on it?
  72. 92Z LS1 project (come in)
  73. New Engine Choices for S10 swap!!
  74. ls1 6sp in a 74 nova
  75. fuel tank return line
  76. Ready for LSX swap
  77. 4L80e GURU's I have a question for you..
  78. 5.3 Wrangler Picutres here!
  79. Here's a question
  80. LS1 into Nissan Pickup?
  81. Remove VATS from PCM??
  82. 71 Chevelle hooker header pics
  83. 78 Trans am LS1-turbo set up?
  84. C5 fuel level sensor
  85. Dual post coil wiring?????
  86. LS1/2/4/6/7 Fiero???
  87. Oldschool LS1 (71 Camaro)
  88. harrisburg pa hotrod tour
  89. Pic's of my 5.3L swap in an S-10
  90. Big Block Headers on LS1 Motor???
  91. LS1 swap issues- starter isn't working
  92. fuel issues
  93. another one lives! but with issues :(
  94. Revised ATS oil pan
  95. t56 to 4l60 ???
  96. 81 camaro ls1????
  97. KATech Tensioner Install
  98. 1993 1500 silverado guage cluster harness
  99. my hybrid...
  100. Conversion to TurboLS6 Powa' Part Trois
  101. S & P High Mount AC installed
  102. Looking to install a manual trans in the 2000 and up
  103. 72 c/10 ls-1 install?
  104. more progress
  105. LS1 driveshaft to 12-bolt
  106. Another hybrid clutch story!
  107. ls1 stang questions
  108. LS1 240sx....
  109. Another bug fixed
  110. Anyone need P-Ayr replica LS1?
  111. is return fuel line needed, can regulator be placed next to tank?
  112. 5.3 LH6 DOD conversion questions
  113. Volvo 5.0 or LS1
  114. headers for ls1 s-10 swap...f-body?
  115. GTO LS1 into a 72 Malibu
  116. Flex-a-lite Electric Fans??
  117. After 12 years, finally motor swap time, need advice
  118. Custom bending for intake tubing
  119. Help very strange annoying problem.
  120. Help, short O2 sensor? (stock one doesn't fit)
  121. LS1 install. Fellow Chevelle's help.
  122. any ls1 manifolds that clear 56 chevy 605
  123. LS2 E40 Engine Control Module J1 Pin Assignments
  124. What is the thread pitch and size of the oil sending unit?
  125. Walbro Fuel Pump
  126. GM 4th gen camaro w/ ls7
  127. websites/resources for moving brake master
  128. ls1 rx7's for sale... (?)
  129. Ls1/t56 in a e39 5 series?
  130. Change vin after swap????
  131. trying to put LS1 in 92 Camaro RS
  132. LS1 crank and cam snesor types?
  133. Pleae Help an Old F*rt... SBC, LT1, LS1... WHICH ONE?!
  134. the new numbers-ls2stang
  135. 1999 tahoe possible?
  136. Valve Cover Mods
  137. thirdgen ls1 swap questions
  138. coolant lines
  139. Accel ecu and spagetti wiring also updated body pics
  140. Ls1 240sx for sale
  141. Next up.. dropping in the LS2
  142. Injector seals LS1
  143. Another VSS question
  144. tunning question regarding a swap
  145. Opinions
  146. Installing a LS2 in a Older GTO with FI
  147. FD RX7 LSx conversion
  148. 6.0L oil pan ?
  149. lt1 help
  150. Gas tank vent
  151. It Lives
  152. Carroll Shelby did it first...
  153. 3.8l V6 Qs...........
  154. Looking for a temp sending unit
  155. Truck High mount A/C compressor bracket
  156. Temp Gauge
  157. Engine Harness
  158. To Notch Or Not To Notch ???????????
  159. LS1 into 87 T/A WS6
  160. LS-1 Swap
  161. Stock fuel pump 12v wire
  162. Tell me why my car runs like poop if I have the TPS connected
  163. Lokar Steel Braided Dipstick Tube Question
  164. VSS in Muncie 4 speed
  165. Moved Alternator - Need Custom Length Serpentine Belt
  166. monte carlo?
  167. LS1 swap into 95 v6 camaro? help
  168. What pcm to use with my hybrid engine.
  169. T56 VSS Sensor
  170. Smaller flywheel on Gen III?
  171. LS1 on engine stand
  172. Wiring harness question
  173. Ground wires points and or connection
  174. Difference between fbody and c5 steering pump
  175. Will a 6.0 out of a 2004-5 van work for a swap? Is it LS1 or LS2?
  176. Dry Sump LS1/T56 into E30 BMW Conversion parts on ebay
  177. Engine not fitting right
  178. ecm question
  179. Alternator wiring question
  180. LSx/T-56 in a '97 BMW 328 vert?
  181. power steering pulley underdrive
  182. lack of truck conversion headers, forcing me to use my brain
  183. what would you do?
  184. Turbo Nova running video
  185. Who makes IAT and MAF wiring extensions?
  186. engine mounts dumb question of the day
  187. Transmission wiring ques - shift selector
  188. converson wiring harness LS1 to LS2
  189. How to Convert LS1 To LS2
  190. XJ LS1 swap...
  191. 90 RX7 vert chassis 4 sale
  192. What LS? will yield the best fuel mileage?
  193. is this 67/68 RS SS worth anything?
  194. Starting the Swap
  195. Oil Pressure is 60 psi at idle and I puking oil
  196. progress
  197. 5.3 to turbo 350
  198. 5.3 wiring basics
  199. what do you guys think of the 2nd gen trans am for a project car?
  200. LS6-LS2 questions
  201. 10 questions and a few answers
  202. is the necessary to run stuff the same on a 01 5.3 harness to ls1
  203. exhaust for ls1 converted car...
  204. Think i found a roller...What should i look for?
  205. Wiring up my Monza, a few questions
  206. Any LSx motor on a motorcycle?
  207. Soooo...close....
  208. weird ignition problem??????
  209. V8 in yota pickup
  210. my 1st gen swap
  211. LS2 GTO oil pan, windage tray and pickup
  212. lt1 to ls1 convertion
  213. [fuel pump] should I be worried?
  214. I need a simple step by step on Conversion of LS1
  215. Silverado to LS1
  216. can anyone identify this spindle (pinto?)
  217. Is this ok?
  218. Need Tach help
  219. Uber LS1 Newb Help
  220. anyone fab headers for swap?
  221. 8.1ltr swap into 3rd gen camaro
  222. 85 k10 5.3 swap
  223. Longer plug wires?
  224. Pic of the motor in my previous thread
  225. Swapping an LS1 into a 94 Trans Am GT?
  226. LS6 power steering delete
  227. LS1 into 94 Z28 (No stupid questions)
  228. 5.3 LM7 into 1988 Supra project
  229. LS1 into RX7 - Battery/fuse question
  230. Removing TCS cruise control cable
  231. Moped Engine Swap....seriously
  232. Finally...the LS7 Monte SS vid's from the track!
  233. Shocks/Spring for optimal ride height?
  234. Best way to clean block
  235. Can keys stop ignition and spark?
  236. Stock or aftermarket computer/harness?
  237. LS2/57 Belair needs fuel lines
  238. swapping ls1 in to lt1 car
  239. LS1 Notch(PICS)
  240. Newb needs assistance in fuel filter selections
  241. wrecked LSX's
  242. Progress BMW e21
  243. Wiring and trans questions
  244. Installed Fast 90 and Ls2 TB today...
  245. datson z cars
  246. I got a lot done and blown away this weekend
  247. 86 S-10 Project
  248. Convert LS1 Tach output to 4 cyl tach?
  249. Pacesetters width.
  250. LS1 into a 94 Formula
