PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 [141] 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Dash help!
  2. What brand of Hose end fitting is this?
  3. Sensor in the oil pan, will I miss it?
  4. New engine/old trans
  5. V6 to Ls1
  6. want to use my D & D T56 with LSx ?
  7. Few Questions
  8. Can a 06 GTO engine and six speed bolt in my 94 trans am?
  9. Finally some progress on my third gen
  10. Fuel rail question
  11. Fuel pressure reg/filter - lines??? Conversion help?
  12. where does the 4.8L fit in the LS family?
  13. Wiring Harness help?
  14. LS1 El Camino
  15. High-revving problem
  16. Project nearlyt complete
  17. What to do about this cut harness?
  18. Fan and Fuel relays
  19. looking to swap
  20. what stall would you recommend?
  21. LS1 PorVette - Endurance Race Car
  22. Early Classic 5.3 Engine Mounts?
  23. manual lq4?
  24. Newer GM A/C Systems-Hose Fittings Source?
  25. Bout to start a 5.3 project
  26. info on a/c
  27. horsepower help?
  28. 67 camaro fuel question
  29. Gauges
  30. Looking for a -02 6.0/80E harness
  31. pcm and 4L80 connector for sale
  32. S-10, quick questions
  33. 2000 v6 to LS1
  34. 280z ls1 swap
  35. Idle and Running Problem
  36. coversion ? about ABS
  37. Wire Harness on Ebay
  38. have ls1 oil pan & pic up & race tronix crank adapter
  39. Drive by Wire or Cable?
  40. about to attempt the swap...
  41. Should i buy a ls2 or save money and get a ls1.
  42. Would it be worth it to ?
  43. First impressions...LS7 FD3S
  44. Custom A/C system
  45. Some Questions about the 5.3
  46. LS1 Impala SS, Can't find one!!!
  47. Autometer tach and speedo ?
  48. 240/LS1 swap questions and wiring
  49. power to transmission
  50. 4l60 to t-56???
  51. 87 lx swap??
  52. What belt do I need?
  53. Need 2007 5.3L Flex-fuel O2 Sensor Part Numbers
  54. is it possible to make a 98 inside harness work for a 99 on up engine
  55. LQ4 harness to an LS1?
  56. Porsche 944 LS1
  57. LS1 Mustang Brake Booster Question
  58. Any one in need of a 6.0L truck block for conversion
  59. Anybody looking for LS1 longblock
  60. Any 4.8L?
  61. 5.3l questions
  62. transplanting a ls1 into a lt1 camaro
  63. LSX Mount Conversion Plates
  64. T-56 into LT1 caprice
  65. LS engine dimensions?
  66. Quick Fuel line question
  67. how hard? LS1 '79 Fiat Spyder
  68. Product proposal
  69. BMW E30 LS1/T-56 Questions!!
  70. 5.3L Swap Into 1969 C10
  71. Anybody ever wired up a 2000 Trans Am Dash Cluster in their swap?!?! Help Please!
  72. anyone replaced the output shaft in a 4l60e?
  73. The beast from across the pond .. LIVES
  74. Need Help!
  75. write up on swap???
  76. Nearing the completion
  77. ex-SS-ve 93 LS1 Pics!!!
  78. 96 s10 blazer
  79. -an power steering fittings
  80. A few conversion parts for sale
  81. Car opinions?
  82. Starter solenoid activated when turning key off
  83. ls2 in s-10 who can do it
  84. help need coild harness part number
  85. 4L80 tow/haul
  86. Engine harness modofications
  87. LS1 Coolant Temp
  88. taking the ls1 offroad, what should i be careful with
  89. hydraulic throw out bearing fitting question
  90. 5.3 starter question???
  91. what size headers?
  92. Exhaust manifolds - LS2 6.0L vs. Escalade 6.0L
  93. Belt question
  94. LS1 and Chevelle AC setup
  95. Budget LT1 T56 into Miata
  96. tranny swap question
  97. ls7 swap
  98. Mid Engine Swap Thoughts
  99. LS1 into my 94 Z
  100. manifolds/headers
  101. Whats the best rust remover and preventer for my 67 camaro
  102. ls2 swap in caprice wagon
  103. factory harness?
  104. 4.8/5.3 in V6 truck question
  105. Emi?
  106. 6.0 into a '82-'93 S10: Which oil pan?
  107. what intake to use?
  108. drive by wire to cable swap?
  109. +wire going to battery from alternator, what kind of wire?
  110. n e one dyno'd the typhoon yet?
  111. Carb swap guys...wanna sell your fuel injection parts?
  112. heater hose water flow direction
  113. conversion pic's and questions
  114. Smaller alternator?
  115. Speartech
  116. Driveshaft Question
  117. Car runs rough AFTER car goes into closed loop.
  118. all the ls1 vacuum ports, which are important to be connected? and to where?
  119. LQ4 for swap..
  120. Truck A/C compressor sensor?
  121. LS1 To Tremec
  122. Norris Motorsports Wilwood Brake Kits and Hooker Conversion Headers Special Inside
  123. gauges
  124. Finally some Pics
  125. Camaro swap headers
  126. corvette fuel filter
  127. Started my 84GT to LS1 swap
  128. returnless rails
  129. Question about the ECM.....
  130. Hand held tuner for LS1 swap??
  131. Hydraulic line for fuel line
  132. 1st gen Unisteer banjo bolt clearance - engine too low?
  133. motorplate AND kmember? LSX fox.
  134. 5.3 won't rev
  135. LS1 fuel system question?
  136. question for Edelbrock/msd carb conversion
  137. 5.3/4L60E in an 86 monte carlo ss
  138. PCM 4X4 Signal....
  139. Transmission Switch
  140. Mechanical Speedo adaptor?
  141. MSD Ignition problems
  142. CTS-V pan in 1st gen F-Body
  143. LQ4 harness and stuff posted in for sale section
  144. alternator mount for passenger side head?
  145. Need an opinion
  146. How much are you guys getting motors for?
  147. Help...ballpark a figure
  148. how to mount aftermarket electric fan to radiator?
  149. 6.0L NV4500 bellhousing dimensions?
  150. needed small hose for my fuel setup??
  151. GM engine weights(?)
  152. 5.3L/TH400 into a 67 Chevy Pickup
  153. What lt1 body would be better to put a ls1 in?
  154. questions about swap, please correct me if i am wrong..
  155. 1976 amc gremlin ??
  156. Any lightweight 4 drs for a swap?
  157. nice 1996 S14 240sx for sale in FL $5800
  158. LS2 swap for 67 SS camaro
  159. 1972 ls1 project
  160. '87 Monte Carlo SS Aerocoupe lsx hybrid help....
  161. duramax in an f-body?
  162. A/C & Cooling Fan Connections
  163. 72 Blazer 4x4 LQ4 swap....a bit of progress
  164. which fuel pump?
  165. are ls1 tanks pressurized?
  166. Fuel pressure problem
  167. ls1 swap 78 nova
  168. 402 LS2 in a 1995 Z28
  169. 5.3 L in 69 camaro. Need info on oil pan!
  170. Do 97 LT1 gauges work with a 2000 LS1?
  171. Possible LS1 into 69 C10 swap in my future HELP!!!
  172. Will C5/C6 vette accessories fit an LS7?
  173. Supercharger
  174. 89Notch 5.3/T76 turbo/th400 etc Build Thread.
  175. New best n/a time
  176. ls1 swaps
  177. test fit of 4.8 in my 79 nova
  178. coolant temp sensor ?
  179. GTO oil pan and oil coolers
  180. MAF wiring????
  181. LS1 RX-7 Dyno numbers
  182. LS1 3rd gen, what lines up/needs custom done?
  183. Recommend me a conversion
  184. steam vent
  185. Is my cooling system plumbed right?
  186. engine removal question
  187. Confused?
  188. LS1 swap in 3rd gen, little help please with wiring!!!
  189. 3 pin or 5 pin maf
  190. My LS2 '68 Camaro is DONE!
  191. ls1 alternator, what to do about that stupid plug on it
  192. Sigh...Tried to start it tonight...No Fire. Ideas?
  193. The OG LS13 gets rephreshed
  194. where to get C220 and C230 mating connectors?
  195. Gen III LS1/LS6 engine swap
  196. Fuel sender ohms
  197. And the fun begins.......63 Nova LS1/T56
  198. Wiring and VAC diagrams for LS1 (2002 camaro)
  199. Stock wiring harness vs. Painless-Poll
  200. I Have A Speedo!!!
  201. thirdgen swap parts fs in the classifieds section
  202. BMW E36 LS2 swap front crossmember and engine mount pictures
  203. LS1 or LS2... that is the question
  204. last bit of swap help....
  205. 454 Ls6
  206. identify this sensor
  207. LS1 in a first gen mustang, has it been done?
  208. Fuel Gauge Issues. HELP!!!!
  209. Test Drive.. Holt sh** 95 V6 to V8 firebird swap
  210. LS1 A/C on first gen camaro ....how to?
  211. Carb vs Fuel Injection?
  212. LQ4 Harness interchange
  213. T56 picture...
  214. Daily driven Ls powered s-10's inside
  215. Gen III/VI Chevy G30 VAN Conversion ?
  216. LS1 in a 55 Belair 2 Post... Having PROBLEMS!
  217. bent crank pulley
  218. 3rd Gen LS1 Brakes: Combo Valve Needed?
  219. LS Fuel Pump Question
  220. LS1 harness differences question
  221. LS1 swap to LT1 coolant Temp sensor wire?
  222. Help!
  223. been lurking, my LS1 drift car (240sx)
  224. Do's and Dont's for the first up of a rebuilt engine?
  225. 6.0 in my 00' 4.3 S10 questions
  226. lets see your LT1 to LS1 conversion pics...
  227. truck pcm ?
  228. Coolant temp LIGHT sensor available?
  229. CTS -> CTS-V conversion..questions inside?
  230. ls1 wire harness
  231. Problem with reverse lights.
  232. 2003 LQ4 Harness diagram
  233. Couple Combo Questions
  234. Custom oil pan?
  235. parts?
  236. Where can I get a conversion done?
  237. sumped tank vs. out the top
  238. The Ls1 Runs today.. 95 firebird 3.4l V6 to Ls1 swap almost done..Help on gaudges
  239. stock or mild carbed combos
  240. T56 questions...
  241. Need PS Pump Part
  242. Bowtieoverdrive's 700R4 / LS1 "TV Made EZ" kit
  243. Power Steering Pressure
  244. ls1 mustang... headers?
  245. Custom radiator hose connections
  246. 66 nova ls1 conversion ?'s
  247. The LSZ project begins!
  248. Carb Ls1 Nitrous Combos
  249. >NEWBIE on here, HELP LS question<
  250. dipstick on aftermarket pan ?
