View Full Version : Conversions & Swaps
- Time to do it right...5.3 LM7 swap and need some help!
- Pump reservoir
- Can anyone guide me on a radiator for a 66 Chevy C10?
- LS2 Swap won't start with MAF connected
- 10 Facts about LS swapping a Tri-Five Chevy
- In tank fuel pump
- Intermittent Low Idle, Stalling
- 2000 4l60e tranny swap to a 2004 4l60e
- NEED HELP: Painless Wire Kit LS3 71 Chevelle
- What else should I pick for swap?
- B-Body Question - LQ9 with a blower, will it fit under the hood?
- LS1 swap transmission help
- Flex fuel injectors with non flex fuel computer and harness
- 911 LS3 Swap: Stalls and hard to start when hot
- Awesome Tool - Vise Brake
- LS3 swap into a "07 Mercedes Benz C280 Luxury
- Wheels for Pro-touring 68 Camaro
- Exhaust set-up for 67 Camaro
- Hello, first post with some questions
- 00 mustang gt swap
- Floatless sending unit
- 95 Sonoma 5.3 swap
- twin turbo g body with a/c
- L92 witha 4L60E
- Throttle pedal help 63 corvette ls swap
- 2011 LY6/6L90E Swap No-start. Video Included
- 77 turbo truck update PAINT JAIL
- ls with alu block identifikation
- Holley sniper intake
- Where to get small piece of thick adhesive hood liner material?
- Anyone stuff an 6th gen LT1 in an f-body yet?
- 1978 trans am carb ls2 alternator wiring question
- LS3 swap brake problems
- Catback for LS2 240SX?
- 04,trailblazer ext 5.3
- Crankcase Ventilation options for using vintage valve covers on LS2?
- swap rx8 to toyota 3s
- BMW + 427ci 7.0l + full-on build
- Who's running Torque app to read/monitor your engine swap?
- 08 6.0 swap buick. need harness work info.
- 87 mustang coupe 6.0 aje trans crossmember not working
- low mount alt bracket in 71 chevelle options?
- What shifter boot...T56 in first gen camaro?
- Throttle body wiring
- Planning an LQ4 Swap
- Frst gen T56 shifter location with Holley mounts
- LS2 sitting for 8 years... Pull heads?
- Lsx Swap into Jeep CJ7
- LS376/480 started but wouldn't run - here's what I did that "fixed" it
- 2002 s10 had 2.2 doing ls swap
- LS Swap Volvo No Start
- Can I use my stock temp gauge in my third gen?
- Build lq9 or new ls3 crate for 240sx
- electrical loss on hard accel (v6 to v8 build)
- Flywheel Bolts
- One Day Rat Rod Build
- Yet another P0171/74
- L96 into 2007 tahoe
- Pnp swap
- Another LS swapped s10 post!
- Shifting gears....literally! LS/CD009 swap in a E46 BMW
- Loking for some direction on curing codes p2101 and p1516
- 2004 911 LS1 swap
- I need help with wiring of a prndl and nss
- E-Fans years compatibility with F-Body Silverado Radiator
- 4 Awesome LS Swapped Cars
- '54 chevy pickup
- Cooling
- LS1 Harness Conversion - DK Blue Wire from C100?
- LT1 to LS1 swap
- Miata ls1 swap
- Loud "snap" with LQ4 pump with Mustang 2 power steering rack
- Silverado Short bed 4.8 to 02 6.0 Gap Flexplate to Converter
- Another Speedometer VSS question. 1989 Isuzu Pickup LS1 swap
- S10 swap guys, need your knowledge
- Need help with Hotwire Harness
- Where can I find a male 10mm quick disconnect tube end?
- lsx innovations ac bracket kit
- my '66 lwb, tuned and cruising!
- 4l60e tcc locked up ?
- Find the faults in the schematic I drew for my swap
- MAF options
- Another junkyard relay block
- Greetings from Europe,several swap questions from LS newbie
- O2 sensor plug pins
- L99 power steering bracket
- 2009 CTSV E67 ECU Pinout Needed
- 3-4" longer plug wires
- Need to fab LS3 exhaust manifold flanges
- A/C RPM switch, what did you use?
- LS7 in 2000 Camaro
- Lq4 ECU/wiring help
- Killed a PS Pump!
- PSI harness only C5 TAC module?
- 08 silverado trans
- For all the swappers: Complete LS engine rebuild kits a Ws6Store/RPMSpeed!!
- swapping DBW in 2001-2002
- engine swap shop
- Complete LSA swap into 1997 COBRA
- Pedal too long can I weld it ?
- Another E38 Brake Input Question...
- Insane LS-powered "Trophy Rat"
- Backwards intake on C3 LS swap
- M3 LS1 Swap Radiator fan issue
- S14 5.3, 4L80 swap
- SLP underdrive pulley
- 7.5 rear end
- Mount and Crossmember Conversion Kit for LS3
- 5.3 max cam lift clearance?
- GM LS3/4L65E Connect and Cruise Wire Diagram
- Throttle Cable: Difference between 99-99 and 00-02?
- Ls swap for 73 caprice
- 97 4L60e to LSx, Trans dust/inspection cover options?
- 1995 s10
- Drivetrain alignment after engine swap
- Lm7 in a first gen firebird questions
- LS 5.3 Swap into a 99 f150 single cab.
- 89 coupe with LY6
- $2500 budget 5.3/4L60e Chevelle. 312whp/320wtq.
- 5.3L Engine
- 1967 Camaro 5.3 Swap with 2000 camaro radiator and fans (not working)
- Trunk Mounted ECM - Length of Harness?
- '77 turbo truck new video --diy meth injection
- Aftermarket oil pan bolts
- Ford 8.8 in S10 chassis
- 7 Cars That Would be 100x Better with LS1 Power
- 2002 LQ4 6.0 DBC work with early 4L80e?
- Struggling at idle
- 5.3 LM7 Swap/Build Questions
- Compressor Compatible with Stock LS1 A/C System
- Swap Need Help.
- 91 notchback ls1/60e swap
- ls in h body
- ls motor in an avalanche
- A body with a little twist
- Radiator overflow tank
- LS swapping the 1978-87 GM G-Body and A-Body (photos)
- Gen IV motor question
- Ls swap problems
- Ls swap overfueling
- Re-Pin O2 Connector
- Ls swapping a dodge ram TC question
- motor mounts & CV crossmember video
- The little red box
- Wiring help
- Sick ls
- GM Service Information (GMSi) Reviews???
- LS Swapping the 1964-67 GM A-Body Intermediates (photos)
- 98 v6 firebird to LS - TCC wiring question
- P0103 issue
- New member doing an LS1 swap into Miata
- 1964 galaxie wagon 5.3 80e swap issues
- 2004 Tahoe fuse block pin outs
- what size ls will fit a 1963 c10 trck
- RX7 LS1 Oil Pressure Gauge
- Need shallower pan for LQ9
- Pcm swap question
- Former Rotary Enthusiast
- 5.7 vtech to 6.0 ls
- C10 swap project question
- LS Ford Focus
- High rise on injected lsi
- 2000 sonoma 5.3 wiring
- using ls harness in a swap?
- 6L90e manual shifter position help? (Silverado 2500HD donor)
- E38 rpm no injecotor or coil pulse
- 1941 Ford C5 Swap Tech II Tech 2 help needed
- Tr6060 in a fox help
- TAC wiring harness.
- Electrical Back Up battery
- mustang
- 5.3 swap in 02 3.8 firebird
- 2 Questions
- FPCM wiring questions
- 4.3L to a 5.7L
- 93 z28 5.3 swap truck acc power steering pressure hose part #
- Help with my first start!
- LS Swapping a 1973-87 GM Square Body Truck (photos)
- Oil pressure sender?
- 6.0 (L76) upcoming build
- 4.8 or 5.3 with 5 speed???
- Headers on a budget
- Lq swap on 77 camaro
- Any interest in can bus solutions for gen IV and gen v drivetrains?
- No tach signal output
- O2 sensor problems
- LS1 mating up to a Turbo 350 and Converter
- Combine grounds?
- Factory 1350 U Joint Driveshafts
- need help 90 caprice ls1 5.7 swap
- impala engine swap
- 94 Buick Roadmaster Wagon LS 6.0L Swap
- 5.3 fuel pressure issues
- 2015 Tahoe Dash in a 67 C10 project
- DBW Pedal Wiring Questions
- Injector question
- 99 6.0 into 93 Chevy HELP!!
- wiring help
- Who's running truck 6.0 w/VVT AND adding LSA Supercharger?
- Lpg????
- Vintage Air: Who's Installed It, And Results
- 04 Corvette Wiring Diagrams
- T56 swap rev limiter!
- 5.3 swap issues
- Need a part/number TR 6060
- Who has LT1 fans need help!
- 2nd gen camaro ls swap mounts
- DBW Issues - Turbo 5.3 Swap
- V6 to LS 5.3 in 97 C-1500 W/T
- engine swap question
- Truck accessory power steering pumps too much volume
- Stalling LM7 240SX with 300ZX Transmission
- 4.3 swap
- LS1 swap into 1994 Yukon
- Driveshaft lenght for LS swap 87 MCSS
- 2002 1500 Sierra denali lq4 swap
- Porsche 996 guys please help wtih tach issue
- LS3 and Tr6060 swap into LT1 Car
- 72 Nova Power Steering Gear Options
- L98 2010 Ecu running th400
- Wiring help
- T56 shifter location in first gen camaro with Holley mounts
- DBW troubles with swap
- Help pricing some parts!!
- 1966 Buick LeSabre
- 5.3 ca smog legal swap
- s14 240SX 5.3 Turbo Build
- 1984 C10 4 pin brake switch question
- 6L80 1969 Camaro no floor cutting.
- 89 fox vert swapping to a 5.3 need lots of advice please!!!
- Good deal on custom plug wires
- LS Swapping a Jeep Wrangler (photos)
- Turbo lm7 Losing fuel pressure when warming up
- 75 C10 swap
- VSS hookup?
- Instruments for my LS3, help needed
- oil cooler hose routing
- Overheating issues with this radiator hose set up?
- Ford 8.8 axle question
