PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175
  1. question about wire harness
  2. 6.0l Pan on LS1 in 72 Chev shortbox
  3. Close but yet so far......
  4. Oil Pan and Hedders for 80's G Body LS1 swap?
  5. need help with digital dash after conversion
  6. Our LS1 Powered Trucks 72 Chevy 53 International
  7. what should i do with the crossover coolent passage?
  8. 1980 Datsun 280ZX For Sale
  9. OBS 1994 Suburban swap info
  10. Fuel line kit
  11. Cam Sensor Wiring ?
  12. LS1 mock up motor
  13. Where's the VIN?
  14. 8.1ltr vortec ls1 in a 99t/a
  15. Trunkey ls1/ls6 cars for sale
  16. Can't close hood..
  17. need some help
  18. Are Stock LS1 Power Steering Pumps Garbage?
  19. Howdy I'm new looking for advice on conversion for a 67 SWB pickup
  20. s10 swap
  21. All parts needed for LS1 into 91 Camaro
  22. what break switch
  23. How hard to swap 4wd to 2wd?
  24. hyd. clutch bracket
  25. 99 LS1 Alternator problems with Painless Wiring Harness
  26. FC/LS1/4L60E, anyone done this yet ?
  27. early commodore,Ls1 vette pwr.
  28. Putting a ls1 in an old vette?
  29. Want to buy an El Camino with LS1
  30. RX7/LS1 first drive experiences. VIDEO!
  31. Fuel System Design
  32. 3rd Gen T/A with Turbocharged LS1
  33. 97 Vortec Engine Swap
  34. Where/how to find a motor and trans
  35. need hwlp bad ls1 performance after install
  36. now wont start
  37. 1985 or 1981 RX7 plus LS1/T56
  38. msd box for carb'd LS1's available????
  39. What to do with stock ls1 manifolds and Y pipe
  40. T56 Hydro Clutch For c3 Vettes
  41. quick question about wiring harness
  42. LS1 rx7 dyno #
  43. 6.0/power brakes, swaps, question for you
  44. Fuel return line for 6.0l
  45. what longtube headers for C4 Vette?
  46. 1st Gen and Nova owners
  47. Anyone going to power tour this year????
  48. Track Results
  49. Suspension parts for sale!
  50. first gen radiator
  51. Toyota 4Runner swap
  52. Ls1 in 81z28
  53. TP sensor signal on black 10 pin?!?
  54. quick water temp gauge question
  55. Wiring harness options. OPINIONS PLEASE
  56. power steering pulley question...
  57. 2nd gen rx7 questions....
  58. ?: 5.3(ls4) bellhousing bolt pattern vs ls1
  59. ls1 headers for a g/body malibu
  60. what fuel system for 1st gen.
  61. ls2 going into a 98 firebird!
  62. Pros and cons of ls1 swap into a 95 dakota
  63. Pics of my 89 s-10----its finished (almost!)
  64. Oil pan depth, F-body vs Truck pan
  65. how much? LS1 swap
  66. 99' Firebird getting an LS-1 - Whats needed and advice.
  67. custom center console
  68. 6.0 swap what radiator?
  69. LS1 swap into a 1986 Elcamino
  70. 2nd Gen Fuel Tank Questions
  71. a couple MORE questions about a '69 camaro
  72. first gen with ls1 t56
  73. I need Help!!!!!
  74. O2 placement on LTs
  75. Putting an ls1 in my truck...
  76. alternator?
  77. Ls1/t56 Idles High Till Stop
  78. Need help on Clutchpedal installation in Camaro 67
  79. My '69 in Popular Hotrodding Magazine...
  80. Those of you who had to remount the A/C I have some questions!
  81. just a thought, 302-ls1
  82. Anyone done a non-LS1 gen III sbc swap in their f-body?
  83. Where to buy a radiator core, just the core...
  84. EVAP wiring
  85. Federal Mogul catalog X4000
  86. What are these wires
  87. Dreaded Wiring - help and diagrams needed
  88. 55 and a ls1
  89. help!!! transmisson wont go into Drive
  90. Need INFO on S&P oil pans
  91. 98 flexplate & th350, who had to grind?
  92. LS1 240sx oil pan question.
  93. Vats
  94. Dismantling LS1 fuel pump unit.
  95. My 69 Camaro LS6/T56 in Super Chevy!!!
  96. How do i pull this motor and...
  97. LS1/A4 into a 1992 GMC Sierra (pickup) need help
  98. Parts for the swap.
  99. T 56 conversion
  100. anyone have dimensions for gto oil pan
  101. 84 Silverado Questions
  102. Lexus SC400
  103. LS6 Fuel Rail Inlet Size
  104. Oil Pressure sending unit part number
  105. Correct Belt w/o Power Steering
  106. air intake
  107. What would it take: LT1 to LS1???
  108. Security/ECM Question! LS1 swap almost done..
  109. speedo
  110. Check this out, sumthin different
  111. 1968 Camaro LS6
  112. 3rd Gen LS1 swap guys (shifter cable queston)
  113. 3RD GEN rear brake swap question
  114. suggestion for this forum: Sticky FAQ for various swaps?
  115. Moving an O2 bung
  116. Middle nipple on fuel pump unit
  117. Running no fuel level signal
  118. What Lokar Throttle cable do I need?
  119. 6.0 vs. LS1 in 1st gen conversion????
  120. LS1 into '93 RX7
  121. P/N's for Corvette serpentine brackets?
  122. 2nd Gen Questions
  123. Motor Mounts
  124. LS1 into an Impala SS
  125. LS1-T56 1st gen swap?
  126. 142 tooth flywheel for the LS1???
  127. 1st gen shifter cable question
  128. 2nd gen camaro shifter 4l60e
  129. Another Conversion Will Start Soon
  130. Help 6.0 swap in a jeep!
  131. truck pcm pnp switch input
  132. Headers for thirdgen
  133. fuel pump dilema
  134. Does this look ok? My oil pan mod for tacoma
  135. 1965 Chevy II 5.3/4L60E HELP!
  136. Woohoo! Ran 10s tonight in the '69
  137. Which sfc's to go with?
  138. clutch for my ls1 conversion 6 speed
  139. Just got my motor. Have some questions (6.0l)
  140. which wires for the scanner
  141. Cruise control with a painless harness?
  142. 6.0 with a 700r4 Flexplate choice?
  143. 6.0 swap?
  144. Abs
  145. Parts List
  146. 5.3 headers
  147. Converting PCM/Harness from '98 V6 car to '01 V8
  148. LS1/T56 In a first gen.
  149. i hear a clicking noise
  150. any ls1 in an A body 72 chevelle?
  151. v6 to LT1 swap
  152. power steering line/fitting size C4 rack
  153. What emission gear for retro guys? Carbon canisters
  154. oil pan modifications, what kind of aluminum?
  155. Grand Sport Update: CHASSIS COMPLETED!
  156. motor mount adapters
  157. Found headers to fit my 79
  158. oil pan gasket and crakced p/s pulley
  159. Vette Filter/Regulator Part Number?
  160. Power to Weight Ration - LS6 in TVR - Quick!
  161. video I made !
  162. T5 Transmission ??
  163. Which tranny for this project?
  164. Direction of cooling system flow?
  165. Heater hoses
  166. Wiring Woes
  167. Alright now, how about some more Fox Body LS1/T56 talk
  168. 6.0L Conversion: TKO vs T56
  169. Underhood space in LS1-RX7 question...
  170. Engine swap, '97 Vortech 454cid into a '87 Surburban. HELP!
  171. Need a question answered
  172. wiring harness/tranny question
  173. 700r4/ls1?
  174. 2000 bonneville check engine light
  175. 01X ZL-402 turbo
  176. Matching MAF to TB?
  177. 4th gen LT's in a 1st gen?
  178. fuel tank vent/ evap system help?
  179. Thanks to all that has helped get the conversion running
  180. Tubular K-member Mac mid length headers 3rd Gen
  181. considering LT1 for my conversion
  182. Fully wired FAST Standalone for sale
  183. ls1 in 93/97 f-bod?
  184. LS1 RX7, I did it, YOU should too! -pics-
  185. Westfield conversion rover/LSI
  186. ls1 & manual tranny to toyota tacoma, which tranny?
  187. which wire is for the temp gauge
  188. problem with new setup
  189. TRUCK motor for 68 Camaro convertible
  190. oil pressure wire
  191. is anyone using a martz chassis on their first gen camaro??
  192. Too much trouble, wiring factory cluster
  193. Wish
  194. LS1 with an old style push clitch
  195. Almost ran 10s. Damn rain!
  196. where to start looking for ls1/t56?
  197. coolant temp sensor
  198. Elbow into intake?
  199. She lives!!!
  200. 92 civic hatch + ls1 idea
  201. Motor Mounts For 71 C-10
  202. considering options...ls1 or 6.0 truck motor
  203. steam tube routing
  204. Anyone using Corvette manifolds in a 1st Gen?
  205. Is the truck ecm the same as F-body?
  206. 2000 monte carlo t-56/ls1 conversion possible?
  207. 2002 monte carlo
  208. The Big Conversion Questions, Once and For All
  209. where are you guys getting this elbow from i need one.
  210. help with Fly by wire
  211. started yesterday but not today
  212. What headers would fit a 64 chevy pickup??
  213. wiring ?s
  214. How bad is it really?
  215. wiring harness /1999>2000?
  216. Making Factory Gauges Work From 89 S10
  217. I put the car down for the winter's nap
  218. brake conversion ?
  219. clutch master cyl for a 64 pickup
  220. Did I post this already?
  221. Decisions...Decisions
  222. 67-69 camaro conversion question
  223. Help with Trans Mounting
  224. radiator hose for first gen
  225. stock ls1 exhuats manifold, can it be put on backwards
  226. lt1 transplant
  227. chevelle/ LS1
  228. using truck engine harness?
  229. LS1 with 605 Power Steering Box
  230. wiring people inside!!
  231. t type s10?
  232. Headers for LS1 into 69 Camaro.
  233. LT1 and 6 sp into C3 vette
  234. LT1 and 6 sp into 77 vette, how hard is it?
  235. what wiring harness are you guys using?
  236. 5.3 in a jeep.....
  237. 69 camaro/ls1 swap Questions. Please help
  238. Has NE1 swapped out an LS1/6 into an '99+ Astro/Safari Van??
  239. car wont turn over?!? speartech help
  240. coil pack relocation/heater box
  241. LS1-->RX7, it's done and on the road! pics!
  242. Alright guys.. Video of my Z32 LS1 ! =)
  243. Problem with OBD port not communicating, after engine swap
  244. LS1 T-56 into a 1964 Chevy PU
  245. Alot of LS1 swap photos!
  246. clutch pedal pressure
  247. vats question and starter wire question???
  248. LS1 driveshaft 82 camaro swap what lenght?
  249. LS1 wiring confusion
  250. G-Body Gen III swap
