PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Need advice on Powersteering pump
  2. Error on GM diagram: 04 Avalance
  3. Lamborghini Miura Replica with Corvette LS3 Power
  4. GTO oil pan on f-body LS1 questions
  5. Finding the 12v AC request wire: 70's GM
  6. 98 Camaro LS1 to 94 Caprice
  7. 1965 impala headers
  8. Dirty Dingo vs. Holley Low Mount Sanden AC
  9. 1987 Porsche 944 turbo LS1 Swap
  10. Swapping a LS1 in a 93 ford ranger
  11. Ls1 swapp
  12. Is this the Ultimate C1 Corvette Chassis Upgrade?
  13. swapping out 4.8 ro 6.0. Do I need a spacer plate? 2002 4l60e.
  14. comparison
  15. Stock 6.0L power steering pulley
  16. Ls1 Auto-Acceleration??
  17. 75 Dodge Dart Swinger turbo LS1/th400 swap
  18. MAF blowing fuse
  19. 4160e 2nd to 3rd problems
  20. Vacuum Port for Vacuum Reservoir
  21. JC72NOVA 4.8LS swap
  22. Budge Porsche 944 LSX Swap
  23. Well.....no oil pressure
  24. Need help identifying
  25. Ls1 swapp
  26. 1978 Chevrolet Caprice
  27. trying to see if we have a LQ4 or LQ9 by the serial number for a pleaseure craft
  28. LT4 Fuel Sender Unit vs. Fuel Guage Sending unit to trigger Evap test?
  29. GM performance LS3 crate motor evap purge valve.
  30. Need some quick help with fuel line routing
  31. Overflow and Steam Vent Locations
  32. Digital speedometer inrratic w/oem vss
  33. C3/LS9 That escalated quickly
  34. drum to disc
  35. GM Perf LS3 & wiring ...wires for speedo, manual trans
  36. Overheating LQ9
  37. standalone DBW system
  38. 72 El Camino fuel tank
  39. 93 RX-7 AC Setup - MS3 Gold Box
  40. custom hydraulic clutch line?
  41. gen4 swap questions
  42. LS Swap-low Vacuum/weak power ideas?
  43. Has anyone used the MA5 transmission....
  44. Single wire alt connector wire swap
  45. O2 Sensors
  46. What diff for a 400hp LQ9 in a 92 K1500?
  47. lsx swap
  48. Anyone know about HPT Vin swaps for swap applications?
  49. Lsa powered 2000 catera.
  50. LS swap motor mounts into "other" older GM vehicles
  51. PCM Fan control wire/vs be cool temp sender
  52. i want to swap engine
  53. What work should be done on a dropout LQ9?
  54. Making Sure I'm Wiring the Alternator Correctly
  55. Gen 4 wrong Cam sensor connecter
  56. DBW and MAF problems
  57. PCM controlled fans vs. BMW temp sensor....
  58. LS Swap into 1974 Cutlass
  59. Ls swapped S10
  60. 53 ford f100 ls6 swap
  61. 65 Impala SS Build
  62. ls accessories info
  63. AC system voltages
  64. Factory fuel pressure regulator question...
  65. Looking for instruction on a L77 6.0 caprice engine converting the harness to s a.
  66. New LS480 Starts-Dies
  67. 2018 Black Hills Corvette Classic
  68. Need help with a vintage air trinity switch wiring
  69. looking for input 1972 chevelle
  70. Lt1 conversion in 79 z28 first time
  71. LS Landrover issues
  72. 03 Gt 5.3 swap
  73. Tensionner swap truck vs camaro belt line?
  74. Steam Port Hose says "ENG"
  75. LS Swap Fuel System Discussions
  76. 90 degree down thermostat housing
  77. LQ9 LS/ 86 C10 Swap need a little help
  78. Oil pressure switch pigtail questions
  79. silverado v6-5.3 v8
  80. Need A/C Wiring Help On '94 Sierra LS Swap
  81. Fast 102 intake...... and throttle body... vacuum ports?
  82. LS in Cadillac XLR?
  83. Exhaust Flex Couplings
  84. 04 lexus ls430 swap with an LS engine
  85. 30 amp relay to power fusebox: ign+ buss
  86. Throttle body dilemma today
  87. Heat from Headers issue
  88. 82 C10 Carbureted 6.0L/400 trans questions
  89. Which injector is 1:
  90. Grounds
  91. Charging Issue 99 S10 5.3
  92. 4x4 Custom Camaro from Gas Monkey Garage
  93. Aftermarket ECM and Harness VS OEM cutdown
  94. 1964 Impala SS - 5.3, TKO 500 Swap/Restoration
  95. Alternator pigtail required for swap
  96. 5.3 swap
  97. Ls swap dilemmas!!
  98. ls376/525 starts then doesnt this one is bizzare
  99. Newb question about LS3 intake
  100. 2002 Camaro v6 "y87" opt, swap to 5.3 LS
  101. Ls1 swap starter solenoid relay wiring
  102. 99 4.3 Silverado to LQ4 fuel line question
  103. A-Body Fuel Filter Location
  104. Want to swap my V6 2011 Silverado engine to a V8
  105. LS3/4L80e Question about ECM/ TCM
  106. Ford Windstar fans, is one a pusher?
  107. Ly6
  108. Starter clicks but won't turn. New battery
  109. Wrong LS engine? No start
  110. New member needs help
  111. For those of you that do this for a living
  112. Extending Wiring Harness ?s.
  113. LS3 MAF wiring
  114. CA Smog legal
  115. Help identify rear end
  116. Smoke my fuel pump...
  117. MAP value not showing in the HP tuners scanner
  118. Corvette Accessory Drive.....A/C compressor?
  119. Is this the one?
  120. LS Oil filter confusion!!
  121. Ls1 swapped iroc high rpm stumble need help
  122. Volvo fan relay.....where did you put the temp sensor?
  123. Need a hand.. 66 Chevelle.. LSA, Tremec Magnum XL? or Regular?
  124. 1st Gen Fbody under hood space
  125. miss matched parts 4l60e questions
  126. LS1 Front Cam Sensor Conversion now I have a P0343 code
  127. Cheap easy throttle cables (should be a sticky)
  128. Liberate the Liberty
  129. Opinions on dual bussed fusebox for standalone harness
  130. A few wires left
  131. Best cam for setup...
  132. random miss / steady miss
  133. 1963 ford falcon twin turbo 5.3
  134. 4.8/5.3 into a 69 Firebird - What is useable
  135. 2015 5.3 L83 6l80e, who has swapped this yet?
  136. 64 abody swap- radiator hoses and air intake
  137. Harness swap, connector ID help (near Driver head)
  138. LS3 FEAD question
  139. 2003 jaguar s type r
  140. Which exhaust manifolds are these??
  141. Power steering lines with Corvette ACC drive and Jeep box
  142. Silver 99 Mustang LS 5.3L th400 swap
  143. Aftermarket harness......tips, suggestions.....
  144. Slip joint header collector
  145. Questions about testing firing engine on a stand...
  146. 5.3 swap cooling
  147. Fuel Systems....whats proven and what didn't work
  148. Smoked my MAF
  149. Standalone L99 Harness DIY
  150. Gen V Fuel system
  151. Free general admission to luguna seca
  152. knock nsors
  153. PLEASE Support LS3 Swap
  154. LS1 computer in cab of 53 chevy truck
  155. ACDelco Plug Wire too short: 19351911
  156. 5.3 swap, P0102 and idle kicks up after start
  157. Can anyone ID this connector on a 5.3 harness?
  158. 1971 Cutlass LQ4/Th400 S475 build thread
  159. LS3/6L80 into 69 Camaro
  160. Off Idle Whistle
  161. 84’ GT350 LQ4 84mm turbo 4L80
  162. Fuel Pump
  163. Simple pink (+12v switched) wire question
  164. 1995 4l60e
  165. lc9 truck engine being put in 2010 cts
  166. Ecu flash
  167. Best way to combine two (or more) wires together
  168. Cruisin' the Coast
  169. MLPS/ Park Neutral Switch Wiring
  170. LQ4 Swap/Rebuild Ford Ranger
  171. LS6 into 84 corvette- last 2 projects- wiper motor
  172. LS6 into 84 corvette- last 2 projects- A/C wiring
  173. 98 LS stapped stang with UPR front end. have a few questions.
  174. Why no audio swaps
  175. 5.3 harness rewire
  176. 4l70e in a 4th gen fbody
  177. GM Perf 376/480 accelerator ped shielding wire
  178. 300zx z32 ls6/t56 swap
  179. Bennett ZX-1: Coachbuilt 860 HP C6 Corvette
  180. ls2 cluth kit with LS motor
  181. Things to reprogram on a PCM
  182. 70 Chevelle LS swap
  183. 1157 to 3157 Taillight Bulb Conversion
  184. 00 silverado DBW to DBC wirering issues pls help!!
  185. 2nd Gen LS Swap
  186. Factory or Aftermarket Fuel & Return
  187. Help finding a fitting for my Holley EFI fuel rails
  188. LM7 5.3 Swap in a 64 Olds F-85
  189. 03 mustang GT lm7/T56 swap
  190. No Air High RPMS(2000 5.3)
  191. 1984 K10 w/ 2001 LM7 Build
  192. Impala Wagon Swap build.
  193. Turbo LSX New Edge build
  194. 5.3 Swapped 67' Buick Skylark - stalling
  195. 4l60e driveshaft measurement
  196. S10 LQ4 / TH400! Need Help Transmission Crossmember!
  197. Fuel pressure leak down to fast- LS swap
  198. F-Bum. 3K Hooptie Challenge car
  199. Pulling drivetrain from truck, what all do I need to yank?
  200. Superformance '63 Grand Sport
  201. 2003 LS1 Wiring help
  202. The Daily Dually
  203. electric remote exhaust cut outs LQ9
  204. only 3 AC bolts?
  205. 1974 C10 dashboards
  206. 5.3 temperature question
  207. 99-02 LS1/T56 swap, help me with one wire for my swap
  208. Plug in required in air intake?
  209. 93 Mustang, LQ4, MS3 - no tach signal. Help!
  210. 3/8 hardline to 4L60E fitting
  211. 2000 K3500 5.7 to LQ9 worth it
  212. First timer - 84 Camaro LR4 swap
  213. What's this part? Booster Reservoir?
  214. using truck speedo in 57 chevy ls swap
  215. LQ9 Wiring and Trans options
  216. 95 Mustang 5.3 LM7+s475/TH400
  217. wiring up for 72 nova
  218. LT4 pullout into 68 Camaro help needed
  219. 1967 Camaro RS Headlight Door Wiring
  220. 57 Chevy 2004 ls6 lsa supercharger throttle body wiring
  221. power to the fuse box.
  222. what best ls motor to put in a rx8
  223. Charging System Sizing Clarification
  224. DBW question on what to use
  225. Supercharged 6.0 build list
  226. 4.3 to 5.3 swap 1999 Silverado AC help
  227. PCM compatible with IAC drivers ?
  228. RTMR / RFRM fuse box difference
  229. What size relays to use?
  230. LS swaps in NY
  231. 5.3 swap issues
  232. Pin Green 18: Clutch Start Switch Signal
  233. 1990 K5 Blazer LM7 Swap P0449
  234. Vss settings
  235. L92 Swap - No Spark?
  236. What header to use
  237. LS1 T56 swapped C3 keeps dying ..
  238. Ls swap specialist
  239. Gear Selector Fork
  240. Transmission lines
  241. Cant go over 45mph
  242. LS6 into a 66 sedan
  243. c2 connector: Pin a9
  244. lm7 swap idle issues and running super rich?
  245. 5.3, installing a 4l80e...
  246. Condenser: Hardmount or Isolate?
  247. Standalone Harness: More Fuses The Better
  248. The story of Baby Blue
  249. Don’t know much about LS1
  250. What to pay: 5th gen exhaust manifolds
