View Full Version : Conversions & Swaps
- Injector splice method on Ls swapped v6 car
- Low and High Speed Electric Fan Temp Settings
- ThickkSarge's Turbo 88 Notch
- 4.8/5.3/6.0 1 wire oil pressure gauge resistance
- 96 lt1 f body tailhousing
- Chevy passcode security issues
- Swap Chevy Passcode issues!
- Mazda or ??? Ads
- Talk to me about wiring harnesses......
- 48 Studebaker LS3 swap Build Thread
- sn95 cooling system
- Camaro LS3 exhaust manifold users - source for flanges?
- LS3 Standalone wiring Help
- 1965 GTO LS Swap Fuel Sending Unit Question
- 6K wide open throttle shift points
- Power Steering Pump Shaft Play
- LS1 belt drive
- 48 Studebaker LS3 swap Beefing up differential
- 03 4.8 v8 swap help into a bone stock 92 s10 700r4
- Ls rx8 swap kit?
- Holley 4L80e trans x-member - Shiftworks tailhousing
- LQ9 swap in 68 Camaro
- Can someone explain some metri-pack terminology?
- Turbo Ls Foxbody starter wiring questions?
- 1979 TA LS1 swap. Engine help needed.
- Need help with a 06 lq4
- 91 2.3 auto Foxbody Ls1 swap 4l80e u joint question
- 5.3 Oil Sender
- Pressure build up in tank
- California Erod Install
- 68 mustang LS swap
- Radiator for Studebaker LS-3 conversion
- Brake issues
- HPTuner Settings for 160 degree thermostat
- LS6 1953 Ford Ranch Wagon Sits on a Z06 Chassis
- 5.3 4l80e in gbody malibu
- Engine Temps on New LS Swap (in cold weather)
- GMPP fuse block and ecu mounting ideas 2nd gen Fbody
- Gen V LT1 $th gen fbody swap!
- Looking for help LQ4 in a dodge charger
- 996 Carrera LS Swap - Keep Tiptronic?
- Gen 4 to Gen 3
- Hello and Help
- Where to source an engine to swap?
- Single plane intake engines/engine bay pics
- P1125, dead pedal, no pedal response: solved
- 1987 Chevette LS1 swap
- LS7 Swapped 240Z Makes Us Drool
- upgraded throttle body questions on intake swap
- LS3 - First gen Camaro- accessories
- The Benefits of Time Attack vs. Wheel to Wheel Racing
- ls1 swap shop in LA County
- Team Z Metal Matrix SBF K-memeber and Dirty Dingo LS mounts
- LC9 5.3L Swap - Long Crank When Hot Issue
- What year LS for donor?
- 08 escalade frame swap can bus questions
- Ls swaping my 98 c1500 need HELP
- Adding mini fuse to GMPP fuse box
- 2004 5.3 AC and Idle
- EFI Source says cam is installed 180 degrees out (LQ4)
- A/C Switch Connector Re-Pin
- Standalone Wiring Harness Build - Help ID my Last Wire
- Manual temp guage on GEN 3 LS
- 5.3 swap wont rev remove grd frm maf and works
- Early LQ4 fuel rail - blocking return line?
- Contour fan wiring--please help
- Lethal 1993 Turbo LS1 Foxbody Mustang LX
- D Port LS swap headers
- Abs inop
- My LS Swapped Sonoma (S10)
- Super T10 4 Speed to Extended Crank 6.0 from 1999
- Lh6 to ly2
- OBS Silverado/Sierra Engine Temp Gauge?
- New smaller A/C hoses ??
- OBS AC Wiring Help with 0411 5.3l Swap
- 1st LS wiring question
- V2 TR6060 to LQ4
- EZ LS 2.0 Cam signal ?
- 48 Studebaker,LS-3,TR6060 Conversion,alternator
- Holley 302-3 Windage Tray Cut
- Pinout for 94 fbody gauge cluster
- My first LS swap... 1984 Mustang GT
- Fuel system question
- Air pressure sound at fuel filter.
- Ferrari 550 Maranello Gets Twin Turbo LSX Swap
- 82 c10 5.3/TH350 swap
- LS swap 2nd Generation Camaro
- LS-1 MGBGT aka "Project Ginsu"
- ECM wiring to instrument gage panel
- JK Info
- 1964 Falcon LS powered Prostreet build
- LS3-Powered Pro Touring '66 Chevelle is a Clean Build
- Lsratrod
- Bolting Things To Firewall
- Porsche body on C5 drivetrain!!
- V6 to v8 conversion for 07-13 Silverados
- 2009 Colorado Factory 5.3L to 6.2L
- LS1 harness out of 2001 Camaro to stand alone harness
- Using stock foxbody k member
- Silverado 1500 swap
- Ls1 fuel lines and fittings
- AMC Hornet 5.3 twin turbo
- Helped my welding SHOCKINGLY GOOD !
- Jeep swap no spark!
- Speed Engineering Headers fit for 69 Pontiac Tempest
- LS3 in late model 4th gen Fbody
- 1st gen CTS LS swap?
- Intake and Fuel System Question
- Ignition coils
- 95 k1500 5.3 Swap
- 5th gen fuel pump/sending unit wiring
- Bouncing Voltage Gauge
- Toyota 86 Drifter Gets LSX Swap
- converter for cam for motor?
- 2015 GMC Sierra 5.3 to 6.2 swap
- Help A Newbie Out
- Ls swap into SS Montecarlo
- Canton Oil Pan
- Hi guys will lsx454 carby and filter fit under
- Project Blucifer (5.3 into a Poostang SN95)
- 6.0L LY6 Swap VSS question
- Swap and Clamshell Mounts
- LM7 into 59 Chevy Pickup problems
- Questions about L92 Swap into '03 Sierra w/ nv3500
- Bellhousing alignment - powdercoat removal
- LSA/LT4/Whipple Swaps - Tank Locations in Musclecar Era
- LM7 Mustang Swap running too Lean
- Injectors
- LS Swap Ignition (starter) Wiring
- LS Swap to '79 C10 - TCC Brake & O2 Sensors Needed?
- VSS Question
- LM7 Swap into my Jeep TJ 2000
- LS Swap help 1971 K10 VSS signal
- Cam Conversion
- What would you do, 5.3 Semi Budget Build Chevelle
- Blade or Boot MAF
- Cayman ls project begins
- LQ4 in 74 Coupe Deville
- GM DBW pedal for SN95
- Looking for Gen 4 connector/terminals parts number
- LS into S10 Wiring Harness
- LS Swap, EFI Fuel Systems, Tanks and Cells. CBM Motorsports
- LS Swap - 4WD Indicator Switch Wiring
- 48 Studebaker LS-3 conversion rear end Question
- Specific Steam Line Question...
- LS Swap info needed.
- Transmission Cable
- Engine mount question
- Timing Covers
- TCC 94 z28 (PSI CONVERSION HARNESS 1012)
- LT rack and pinion to LS
- 97-04 Harness & PCM experts
- 1998 Jaguar XJ8 VDP 5.3 Swap
- Can you use a 13 pin 4l60e with a 58x ECM/TCM?
- LQ9 swapped c10 suddenly won’t start but turns over
- Need to find a 4l60E to work with my LS Swap
- LS Oil Pan Mod / S10
- Converting coolant system to Surge/Expansion tank easy as T into Heater?
- Bellhousings
- 76 Blazer LS swap
- Silverado BCM swap?
- 4L65 Banjo Fittings
- Powertrain relay signal?
- park/neutral pin on ecm
- LT1 camaro STEERING LINKAGE TO LS1
- Lt1 steeringtlinkage to ls1
- Ready to play
- Opinion of these motor mounts??
- 1992 Pathfinder build
- 4.8 Voretc hard start and then high idle
- Electronics and ignition cylinder question
- Yet another '72 short bed build....
- Worth it to buy whole donor vehicle vs just engine?
- Radiator Hose Protector
- Controlling gauges without 0411 pcm
- Overcharging 15 volts idling
- 70 Nova LS2 swap 2005 GTO donor car
- cooling fan continue to run after warmup,not cycling
- need help picking crank
- DeWitts 2019 Annual Sale Notice!
- Used vs new 4l80e for lq4 3rd gen firebird
- 1967 Nova with LS3 DWB pedal help
- LS2 Harness HELP
- 1993 Trans am Ls1 swap 4l60 questions
- BMW E39 With 5.3, Cam, Springs, 4l80E and chinese GT45
- New Rear End Options
- Exhaust gasket
- Lt1 vs. Ls1 swap
- Sacrilegious's V8 Rx7 Feed Project
- Which oil pan for an LS swap into 70 Skylark
- Fuel Pressure Regulator
- A-body guys...shift linkage??
- Ls1- overflow radiator to use with steam line ??how to
- Dyno Results LS3 68 GTO Clone
- Tuners on Long Island?
- Sn95 5.3 questions
- Stock air intake question
- 5.3L LSx build in Indy
- engines
- Dbw or dbc setup for my swap
- How much wire loom for standalone harness??
- Interest in a CD009 SFI belhousing
- Help!!
- LS2 into a 1960 Cadillac
- Dodge Magnum
- Modifing Sensor Plug???
- JEGS Retrofit Oil Pan
- Project "9 Lives" - Toyota FJ60 L92/6L80
- PSI conversion harness 1012
- Hyrdoboost Questions
- L83 swap fuel pump control module
- What is it question. Lol
- F body shifter cable
- Torque monster 84 trans am lq4 4l80e swap
- starting a gbody build
- 2007 Silverado Classic V6 to LQ9 Swap
- I need help on 4.8 ls harness
- Does anyone have any experience with LPG?
- Pin Green 16 and the VSS
- Will this work for VSS in TH350 car?
- will 8L90E AT fit into 2007 C6 LS2 Corvette?
- 1966 Nova SS Gen V build
- Building a Top-Level Time Attack Car
- 85 c10 stepside
- Dry sump tank gen v lt4
- CD009 Trans in a Chevelle?
- 4.8L crank into L33 5.3L Aluminum Block
- Probably the 10000TH time you saw this question!!
- AC pressure/ cluch cycling info needed
- pics of speed engineering turbo headers and truck manifolds on chevelle
- 1972 Nova build 5.3 boost
- Lq9 jeep swap help
- LS6 TJ snow plow
- 2017 camaro 6 speed in 64-67 GM A body
- Project LS Faux (LQ4, TKO600 Build)
- Anyone have a 2007 Corvette BCM pinout?
- A/C compressor on l83 engine Swap
- Head Gasket Failure
- 1958 6 door brookwood wagon, 6.0/6L90 swap
- A/C compressor options
- Has anyone blocked off the heater hose tubes?
- 4l60e transmission line stripped
- E-rod LS3 and in tank fuel pump recommendation
- 1984 c10 5.3 turbo.
- Voltage drop from 14 to 12 when turning A/C (L83 swap)
- 1969 convertible camaro manual trans LS engine swap
- 302-3 Pan Baffle Consideration
- resting TPS on car with separate TAC
- what parts to get next?
- 2nd Gen Trans Am and LS3 swap Accessory ?s
