PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. PCM trouble? In and out of closed loop KPA in the 90s
  2. Best Mufflers for LS1 + Fox Mustang Street/Strip Car
  3. Announcing a "newish" LS-Swap and Retrofit publication, finally!!!
  4. Ls1 Blowing fuses
  5. Any 1 use Jiffy-tite fittings?
  6. LS motor in 53 Chevy 2 door.
  7. Not having much luck finding a tuner.
  8. Fuse Block Pinout
  9. LQ4/T56 into 05 Subaru Legacy
  10. 1947 Chevy 3100 5.3/4L80E
  11. Chevelle is getting a monster!!!
  12. 78 trans am motor swap questions?
  13. Project Volv8
  14. how about these shorty headers for fox swap
  15. what radiator did you guys use in your fox conversion?
  16. 5.3+T5=91 Camaro?
  17. 6.0 flywheel
  18. Fox LS-swap k-member options...
  19. 89 fox gt semi built lq4 swap!
  20. Project low budget
  21. EFI 383 LS1 powered Liberator jet boat - IT LIVES!
  22. Wolfe Race Craft pre-notched 10 point cage 1991 Mustang install and review
  23. Ls into a 92 burban
  24. Fuel question
  25. Anyone done a ls swap into a GTA?
  26. Need 97-04 Corvette wiring diagram
  27. G-body LS swap and a/c: my solution
  28. LSX Jet Boat..
  29. Trouble getting stock tach to read correctly
  30. o2 senser adapting ?s flat black,white squared.
  31. Can you run a FORd C4 with a LSx.....if so how?
  32. 2003 S10 L33 5.3 Swap
  33. 94 z
  34. fast xim or msd 6010??
  35. LS swap into '78 Power Wagon
  36. Wiring Help! Coil and rear defogger
  37. LS Swap into '78 Power Wagon
  38. Good deal on a lq9?
  39. no water cirrculation?
  40. Lq4 fox body engine mount question???
  41. Installing autometer gauges into foxbody
  42. 85 mustang coupe ls1 t56 swap
  43. Kooks vs Dynatech for mustang
  44. LQ4 A/C Compressor Fitment Question
  45. what does mlp switch actually control
  46. 1968 Firebird 400 - H/C LS1 swap
  47. LSx prep; electric fans
  48. 69 opel GT
  49. is mlp switch required ?
  50. 02 S10, Heads/Cam/Stalled 5.3 /4L60e
  51. '85 C10 LS radiator HELP!!
  52. 64 impala LS1 power steering help
  53. engine decision help
  54. 2000 Sonoma 5.3/t56 swap
  55. K member for 95M6 going LQ4
  56. Stock K member in Foxbody
  57. Opinions Wanted - what year 4L60e / 4L65e
  58. transmission help
  59. C5 EXHAUST on lSX CUTLASS
  60. V-Belt Crank Pully
  61. New project, need some ideas for 4.8 ls.
  62. Niiiice..... "7" with an LS!!!
  63. what year 4L60 / 4L65 ?
  64. Please Help Me With My WS6 LS1 To 69 Firebird Swap
  65. E38 ECM Brake Switch Wiring
  66. A.c. Wiring help
  67. Ls front assessories not in line?
  68. looking for info on installing LS in 71-75 GM Body
  69. which clutch disc
  70. swapping a 06 4.8l to a 6.0L what is interchangeable?
  71. Alternator wiring again!
  72. HP tuners question, VATS and Rear O2 sensors
  73. Any information on this car? 79 Malibu
  74. I need a MAF for my 6.0L - which one?
  75. Holley cast iron exhaust
  76. Y-body or F-body belt spacing? One any better than the other?
  77. Seriously thinking bout doing a twin midmount setup on my s10
  78. Dropping in an LS1 in a mustang
  79. LS motor in a boat?
  80. 5.3 to t56 tranny clutch and flywheel ?'s
  81. Confused on drive by wire
  82. 65-70 impala swap $$$
  83. any success using speedhut tach w/signal from ecm w/o using a resister?
  84. 2001 4.8 to 2006 6.0 Swap
  85. lq4 trouble codes
  86. What's the best handling car to implant LS1/T56?
  87. Can ecu control a spare wire as a signal wire to a relay?
  88. Can PCM be setup to control TH400 kickdown?
  89. 2003 express 5.3 wiring diagram
  90. any one made GEN II headers fit a GEN III/IV???
  91. 4L60E Trans wiring
  92. Lq9 in tj?
  93. Opinions wanted on lsx swap canidates
  94. What year 5.3 do i have?
  95. Ls1 brake swap help
  96. IS300 LSx Build / Initial Startup
  97. 99' Truck PCM which pin is TOW/HAUL?
  98. Trans Question
  99. PCV routing question
  100. 1972 Nova LQ4
  101. ls engine time/A-body
  102. Post pics, dreams, & ideas!
  103. Next build 2001 BMW 325Ci 4.8 or 6.0?
  104. New Jaguar LSx Conversion Gallery
  105. Ultimate Hybrid.
  106. 85 mustang ls1 swap
  107. What Throttle Cable For Fox Body?
  108. LQ4 low RPM, high load misfire and turn off rattle
  109. LS1 T56 Slave on TKO 600
  110. LS swap info, missing parts
  111. will my ls2 bolt up in my 95 z28
  112. 5.3 in 1993 T/A
  113. 94 Cobra swap to 5.3ls with th350
  114. Looking to trade CNC work for LSX wiring help
  115. ls1 ws6 too ls1 camaro z28 engine swap help/info
  116. no gauges!!!
  117. turbo s10 gen 4 5.3 build questions (read carefully)
  118. Who's solved the 158 MPH VSS input to E38 ECU for T56 swaps?
  119. cts-v
  120. Ctv-S
  121. New Website: '37 Chevy build
  122. chevelle NW 92mm throttle body air intake
  123. Foxbody Fuel system using stock tank and lines?
  124. Another accessory drive question
  125. Has anyone made/modified their own harness?
  126. Where to find OEM electrical pigtails/connectors
  127. Wiring Harness Plug Question
  128. power steering question
  129. Truck is giving me hell
  130. New LS1 compressor with G-body/Regal Evap/Dryer/system w.modified lines?
  131. Ls swap ac help
  132. Mustang Swap Fuel System
  133. 66 mustang proje ls1/4l60e
  134. 4L60-65E conversion to 4L80-85E using T42 TCM
  135. Help! Hydraulic Clutch Options
  136. LS1/4L60E into a Factory Five 33 Hot Rod -Need Help
  137. Help wiring problem on ls swap
  138. Anybody Need a Build Art Carr Overdrive Trans For Their Conversion? Link Inside!
  139. ANother third gen lsx swap
  140. p0740 after m6>a4 swap
  141. Stand alone wiring harness
  142. Help with finding wiring diagrams
  143. Lsxfox track times
  144. Tsquared 69 Camaro Build
  145. What does VATS do?
  146. Mount question
  147. Temp sender re-thread
  148. 67 Camaro using 4th gen radiator?
  149. Help!
  150. LS1/LS6 Injector EV1 connectors
  151. CBM LS7 Porsche 911 Swap + LSX TV
  152. Fuel line help
  153. 91 5speed trans on Ls engine
  154. Calling T56 swappers w/A-bodies!
  155. New A/c Bracket option
  156. lm7 startup issue
  157. 5.3l into 95 z28
  158. 71 Impala Twin Turbo LSX 440ci
  159. Fuel pressure to high?
  160. Help lt1 to ls1 alt wiring!!!!!!!
  161. Wild ride in my LS Daytona (autocross)
  162. v8 in s10 questions
  163. LS1 F-body headers
  164. fox headers?
  165. Harness help??!!!!
  166. LSX Jeep opinions?
  167. Exhaust for LS engines?
  168. 2000 Mustang Turbo 5.3L Build
  169. LM4 dip stick options?
  170. I must be missing something.
  171. Colorado lsx
  172. lq4 in 68 firebird 400
  173. '70 C10 truck engine initial startup
  174. DBW pedal/TB question.
  175. 1964 impala lq4/4l65e conversion
  176. cai pipe size
  177. MY foxbody..(warning...ford content)
  178. Electrical gauge options
  179. Help....blowing coolant out of radiator
  180. Regal 5.3 to ls3 swap?
  181. 4.6 motor mounts on 5.0 K-member?
  182. So why did you put and LSX in your mustang?
  183. Can anyone make power steering line?
  184. 2006 L59 won't pull past 4000 rpm
  185. Exhaust for 65 chevelle
  186. DBW pedal not responding to tb
  187. AZ Smog and emmisions Questions
  188. My LSX foxbody turbo hotside
  189. Jaguar LSXJ6
  190. Quick fuel rail question (LS1)
  191. stock tbi lines
  192. 92 chevy truck 4wd
  193. Losing MPH input @ ECM
  194. stock truck headers in foxbody?
  195. Fox body Header problem...Help
  196. Lets say I wanted AC
  197. Mustang LSX Swap Power Brakes and Steering Question
  198. DBW issues
  199. spectre swap intake on 67 camaro
  200. Alternator locations and options (Foxbody turbo 4.8)
  201. In tank fuel pump.....
  202. 9th Gen Square Body... To swap or not to swap..
  203. LS1 Daytona Coupe finally on the dyno
  204. Adding aftermarket fuse blocks to modded LS harness
  205. just another ls FD
  206. fuel filter with bracket
  207. Converting LS2 DBW to DriveByCable???
  208. anybody not use LY6 oil pressure sensor connector on your harness?
  209. injection issues
  210. rear mounted 3400 engine in a 36 chevy low cab
  211. Couple pictures of my nissan 240sx 5.3 turbo build
  212. Need help on decision making??
  213. My dream conversion/build
  214. ford t-5 behind a lsx
  215. '94 Chevy S10 Blazer LSX swap
  216. help: positive crankcase pressure, oil problem
  217. Damn 98 guages
  218. cutting primary tubes off header flange
  219. 5.3 question
  220. Fuel pressure on the return side?
  221. Engine cover assistance needed
  222. Does anybody make a set of 2" Stainless Longtubes for a Foxbody Mustang Swap
  223. pcv system w/ ls6 valley
  224. Registration Problems in Missouri
  225. How to connect T56 hydraulic clutch lines to MC and reservoir ?
  226. Knock Sensor Location?
  227. Need some help on my '95 TA
  228. Someone to tune?
  229. ignition wiring ???
  230. Hot August Nights
  231. what gauge wire for alternator?
  232. arp vs katech rod bolts
  233. Corvette filter/regulator 3/8 outlet fitting
  234. Lsx bg turbo kit with aje k member in fox mustang
  235. Gauge options?
  236. Initial ECM power up on LY6 shows P2138 DBW pedal code. Thoughts?
  237. no tach after lsx swap dakota vhx 67 camaro
  238. 95 Sonoma - LQ4, 4L80e, 76mm Turbo
  239. Trans crossmember?
  240. 5.3 ps pump pully on ls1 fbody ps pump???!
  241. Does anyone know how to get a hold of the guy from mc-machine?
  242. starter turns over slow
  243. LQ4 timing cover w/ Corvette Balancer
  244. Best price on dynatech mustang swap headers?
  245. g body power steering lines
  246. 1980 c10 6.0 swap
  247. G-body mounts ???
  248. 2005 lq9 s10 swap AC serial data/request?
  249. LS1 1992 TYPHOON project
  250. Is my racetronix walbro fuel pump DOA?
