View Full Version : Conversions & Swaps
- 69 camaro LS3 w/ YSI,hood clearance?
- My engine pictured in the newest issue of Car Craft!
- Putting a LT1/4L60E in to a 1984 El Camino What do I need?
- whats the cheapest route?
- Swap Question
- 79 malibu swap coming soon.
- AC Compressor spacing
- Beginning a LSx swap on a 1971 SWB
- Electrical Help: Starter/Ignition Relays
- 4l80 shifter help???(floor mount)
- HELP! Want to put an LS2 and 4L80E into 96 Dodge 4x4
- camaro shorty headers for 67 a body
- need some help with a 5.3 vortec swap...
- Beware:www.s10v8.com
- anyone here on A/C on a ls1 fox swap?
- Want to high flow muffler with low noise???
- LQ4 6.0 swap
- 95 4L60e to 04 4L60e wiring issues
- A-Body guys, anyone have pics of this mounting setup?
- LQ4/4L60E into 72 Monte
- Someone could make alot of money selling these
- Magnaflows ir Flowmaster ls1 69 camaro
- question about fuel system on stang
- Switched Hot to PCM; Amps?
- 4L60 E stock shifter solinoid
- wtb.......c5 balancer
- LS1 in an LT1 Camaro
- Fuel pics!
- Has anyone used BRP ls convertion kit
- Pin out for MLPS
- T56 in an automatic mustang
- Cam choice
- cracked Edelbrock carb intake
- firebird swap...opinions needed??
- v6-ls1
- F-body brakes on a Nova?
- lsx Turbo headers...
- motorplate
- Those running aftermarket gauges...
- 1995 3.4 V6 camaro to Ls1 or Lt1 swap, help me out
- Tach is still off, anything i can do ?
- 5.3 in a g-body
- LS1 front and rear covers on Iron 6.0
- aftermarket speedo on 4l80e
- LS1 swivel thermostat housings
- LY5 engine tight spot
- Pics of Mustang clutch modification inside
- 98 ls1 motor missing and reving by it self issues please help
- Inspiration for my Nova build
- 5.3 and the 6.0
- Who makes a oil cap for the GMPP valve covers?
- 63 Chevy II LS1 T56 question... mouting clutch master
- Short Circuit!! Datsun 280Z LQ4 swap
- LSX intot LTx info needed
- need help necessary
- LS1 into '66 Chevelle
- Calling all a-body owners
- Wiring questions / Connector ID
- 78vette LS swap
- lq4 coolant sensor thread size
- ls o2 sensor ????
- ls1 chevelles setup
- AWD LSX powered skyline Possible?
- Any BCM experts?
- Upper radiator hose question
- Difference between LS2 and LS1 waterpump?
- CSR thermostat housing question
- Custom Headers for Fox/Ls2....Any thoughts?
- 98 harness question
- ls1 & ls6 intake diff?
- 5.3 swap with 200-4r
- Air Charge Temperature Sensor
- first gen motor plates and headers ?
- LS vehicle transmission compatibility (Q)
- Mazda truck swap
- carbed 6.0 mighty demon 750 tuning questions
- Conversion Wiring Guys I Want To Use 4th Gen Wiring
- 04 LQ4 harness questions
- Gen IV won't start
- need headers
- LS Motor Swap into 2nd Gen Camaro
- 67 Firebird with 04 LS1 and 1" set back plates--which headers work best?
- Carb'd LS wont crank
- Finally, Side Exit Exhuast Sound Clip!
- GM Extended Pilot Busing
- Oil pan recommendation
- Pics please of Mustang clutch setups
- Stock truck alternator too big to clear hood..My Options?
- LSX A-body Conversion Parts
- L92/4L60E in 1980 camaro- pcm/harness???
- Do I need to keep the LS1 charcoal canister and vapor accum for EVAP to work right??
- If you have the BRP mounts with LH8 and A-Body, post here
- Big set back!
- Speartech Reworked Harness
- i have a 5.3 witch heads do i use?
- MAF class 101
- Someone help! Wiring issue.
- gto pan?
- Headers for LQ9 in a 2nd gen camaro?
- LSX k member for Fox mustang...Help!
- Any year LS1 to avoid?
- LS4 in to a Murcielago Replica rear wheel drive
- Finally underway!
- my lq4 s10 build
- LQ4 intake/throttle body question
- Battery disconnect switch wiring
- mustang ls1/t-56 swap
- any books
- Third Gen LQ4 Swap, cooling fan question...
- 48' Willys CJ2A Jeep LR4 4.8L swap and buildup.
- Right Forum???
- 99 fbody k member bolt problems
- 5.3 Question
- Clutch & Flywheel differences??
- LQ9 Swap, What to do ???
- I have a used GM Carbed L92 manifold for sale!
- MSD 6010 question
- Help me diagnose a driveline vibration!
- 6.0L into LT1 F-body
- Winter Mods are done!
- '72 Nova LQ4/ Richmond 5 speed
- RX7 swap coming along
- are camaro and trans am k members same?
- Kiesler Perfect Fit
- Vette Manifolds for thirdgen?
- 1982 indy pace car z28 with ls6
- 66 Nova with stock subframe with long tube headers
- **Please help me with my Ls1 into 3.8 '98**
- edelbrock headers forsale
- 3.8 to ls wiring questions...
- Car has to learn to idle everytime I start it
- VSS for Electric Speedo
- Routing Steam Vents
- Quick question: LQ9 + 99-02 F-body gas pedal. Will work?
- Fuel safety question
- Upper Hose Suggestion!
- fox body swap
- Need help with tuning msd 6010/carb setup.
- Motor specs for my nova.
- newbie with questions
- Syclone 354 LQ9 Turbo still AWD is running
- LS1 06 Maxima
- motor and trans are in
- how difficult....
- LS1 swap into 1996 4.6L mustang
- LS1 S14 swap
- need help? s10 ls1 and lq4 swap list
- 3rd gen wiper motor Q
- Updates to the camaro
- Ls1-in a 2000 mustang v6 need help.
- A couple manifold Qs
- Exp with Currentperformance Stand-Alone Fuse/Relay Module ?
- 67 ls1 t56 pics
- 6.0 LS Mustang sound clip
- Warning these pictures may contain material very disturbing to some people
- ECM mounting
- S-10 swap startup issues after motor swap. Need some input.
- my lsx iroc build
- cj series jeep with a ls or lq series engine?
- What resistor for alt?
- L59 Promblems....HELP !!
- Give me a list!!
- 440 LS3 in an 18ft jetboat!!!
- wiring question
- Wrangler LSx Radiator Hoses
- Need your input: 71 el camino ls6 drivetrain
- some pics of the swap more to come
- what gastank should i use?????
- No Speedo and Trans in Limp, whats wrong ???
- hi i havea ?
- 5.3 Thridgen swap.
- LS1 TJ Wrangler
- LS1 In a 1979 Datsun 280zx????????
- need help
- 6.90's in a junkyard 6.0
- Fabricated Valve Covers
- Need Help-Still No Tach
- What are you guys doing for clutch hydrolics
- Hose routing on Corvette PS pump...
- electric fan question
- ls1 swapped rx-8
- So has it been done? MKIV swap?
- 1978 Malibu LQ9/LS6 --TCI 4l60E Swap(updated 2-5-2010)
- Steam pipes fitment issue (LM7 vs. LS1 intake)
- C5 cast iron headers
- AFCO LS1 conversion radiators
- 68 camaro lq9 header question
- ls swap to 80 grand prix?
- Completing the LS1 in to LT1 swap, gauge problems now.
- 69 LSX Or Factory original??!>>?
- Swazo's '64 Impala SS L33 TH350 swap
- Fabricated brackets
- Autometer gauges from my conversion.
- 64 Malibu truck mani question
- lets see how you mounted you computers under the hood
- LS2 Oil Pan parts help needed
- LT1 to LS1 motor mount question
- Carbed setup guys, what tranny are you running?
- What would this take?
- ls1 airbox on lt1 motor and hood?
- Started the car, ran they wouldnt start again, please Help...
- v6 3.8 camaro fuel pump running a 5.3
- Fuel filter/Reg fittings
- VATS with LQ?
- My 97 is getting an LS1
- Headers for '66 Chevelle w/ GTO LS2/T56
- differences in actual block size between LS1, LS2, and the rest of them...
- transadapt 4575
- ls1/t56 into 70 LeMans
- My Budget LS Engine Swap Guide <$1500
- conversion wiring
- this is my body donor for ls1 swap!!! 4 grand in seattle
- Swapping ls1 into v-6 4th gen?
- Pics of PCM mounting
- Wiring and Fuses for Radiator Fans
- 69 camaro ls1 swap help needed.
- Working on my harness, have a few questions
- Finally got her painted
- RX7 swap possibility
- Ls1 T56 Chevy II clutch setup!
- After market balancer??
- hooking up parking brake to pcm
- 5.3 in 99 camaro, which starter?
- lt1 in 65 skylark. Do I need a new oil pan?
- 6.0 swap
- Mustang u-joint?
- what wiring harness and PCM can be used?
- Big or small block engine mounts for F body?
- msd 6010
- LS2 w/ cable throttle body question.
- DBW question
- E67 pinout and CTS-V schematics
- Corvette fuel filter
- 98 ls1 into a 93 caprice
- Wiring Harness Options 6.0 Retrofit
- Which motor mount frame stands do I have? (67 F body)
- Another soulless FD RX7
- My 3rd gen IROC swap
- Nova 1966 LS2
- 4l60-e?
- aje motor mount dimensions
- 69-2002 ls1 help needed.
- Soon to be ls swapped 88 mustang. Looking for suggestions/opinions
- Oil pan problems
- LS1 Header Tube Size
- LS1 / Gen1 F-Body swap headers
- Killer '64 Twin Turbo LS6 Impala
- DBW wiring
- carb'd 5.3 in a 93 gt
- do it yourself LS2 harness conv.
