PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. AC wiring with ECM control clutch/fans
  2. Need help ASAP
  3. Water pump options for 5.3 swap?
  4. Planning LS retrofit--seeking Engine/ECU suggestions
  5. ls1 oil dipstock from fbody on lq .Need answer quick
  6. Ls1 to th400 starter issue
  7. Anyone Have stock manifolds fit in a 1st Gen with Hooker 12618HKR Mounts?
  8. 2004 GTO PCM emissions wiring data needed
  9. PCM wiring pinout 5.3 2013
  10. Any suggestions on the best gas tank to use in my ls1 swap into 67 Camaro?
  11. Sunbeam Alpine - Sabertooth
  12. tablet gauge cluster?
  13. hydroboost PS pump?
  14. ls1 Chevette
  15. Anyone know how i can contact Hiltsy?
  16. Want more performance and improvements in Horse Power
  17. Any ideas for more performance and improvements in Horse Power
  18. LS-6 power steerting pump in a 71 nova
  19. 83 rx-7
  20. CBM Motorsports On Line LS Store. New Products.
  21. 83 K20 swap questions
  22. LS1 to LS3 coils swap Help needed.
  23. 5.3 lm7 build
  24. Anyone know who makes these headers?
  25. Fuel pump question
  26. '95 Toyota Pickup V8 Swap for Drag Racing
  27. What headers fit
  28. Neutral Switch Wiring with PCM inputs
  29. 90s 4l80 onto 04 6.0?
  30. 67 chevelle. Lsx 454
  31. Catchcan
  32. Quick question for my 79k10 ls swap
  33. power steering brakcet
  34. Speartech LT4/8L90 in 69 C10 Truck Underway!
  35. Alternator Wiring question 5.3 swap in C3 Corvette
  36. Andy's 66 Caprice LS Conversion
  37. 2002 LS-1 in a 72 El Camino
  38. 5.3 swap possible MAF or O2 sensor issue?
  39. '74 Corvette MS3Pro powered 5.3/TH400 1/8 mile ICE DRAG CAR
  40. LQ4/4L80 swap 1969 Mercedes
  41. LS swap into a 2006 ford panther
  42. Voltage Fluctuations
  43. trans mount question.
  44. 600$ 94 GT 5.3/4L80 swap
  45. Where to find a 4 only relay fuse block?
  46. soooo.... 4 volts coming back through nss ground??
  47. Looking for a new project
  48. 86 K10 L83/6L80 5.3 swap project
  49. 2007 Silverado 4.3 to 6.2LS3
  50. New Holley Accessory Drive Systems Coming Soon
  51. DIY 5th Gen Fuel Pump Assembly in stock 1968 Camaro Tank
  52. Ls radiator with steam port and return port
  53. CA legal conversion
  54. Obd2 scan tool suggestions
  55. Diagnostic Codes -- CEL's
  56. 4.8 LY2 Build Thread
  57. 02 mustang ly6 turbo harness question
  58. Crate vs Junkyard LS3 into '62 Impala?
  59. 1985 Chevette LS1/6 Swap
  60. Gonna go buy an truck LS tomorrow...
  61. A-Body LS powered T56 swappers step on in...
  62. Speedometer not working
  63. Need help with my 4l80e conversion
  64. LNC-2000 issue
  65. In's and Out's of Cooler Lines
  66. GEN V Swap info!
  67. How do I ID a 5.3 vs 4.8 in a truck.
  68. 94 c1500 5.3 ls swap what gear ratio should I use
  69. P1518 Code for DBW in PCM after Swap
  70. Wiring Sanden 508 AC compressor in LS swap
  71. 94 c1500 5.3 ls swap what gear ratio should I use
  72. Ac question for C10 ls swap
  73. Mounting Stereo Next to PCM?
  74. Torque app and tans temps
  75. Porsche 997 C4S LS Swap
  76. 1st Start-Up Precautions for an AL Block Stored for 5 Years
  77. Truck AC unit on High Mount AC conversion in LS SWAP?
  78. Can this be an oil pressure port ?
  79. Picked up a 6 liter...
  80. lS SWAP 1975 - 1981 2ND GEN FIREBIRD - CAMARO (VIDEO SERIES)
  81. New 5.3 Swap El Camino Idle problems P0101 code
  82. Should I buy this short block?
  83. Radium Engineering Coolant expansion / swirl
  84. clutch recommendation? ?
  85. 1st time swap advice
  86. 93 Silverado 5.3/4l60 swap shifter linkage. ..?
  87. 1981 Chevy Malibu - LQ4 w/ T4 S475
  88. What is it worth?
  89. High Mount A/C Bracket
  90. 71 nova build advice LS6 install
  91. Are all 5-wire MAF's the same?
  92. Went drag racing last night, give me your thoughts.
  93. LS2 to a L92 swap
  94. Hanging high idle when coming to a stop
  95. Questions before LsX s2000
  96. Cooling issues on Track - HELP! with pics
  97. 02 V6 Mustang to Turbo LSX, Whos K-Member to Get?!?!?
  98. Making stock tach work in a 93 Silverado
  99. 4l80 in a fairmont question
  100. 5.3 swap RX8 continuation
  101. 67 Chevelle Malibu w/ 6.0L LQ4 + T56 Trans...
  102. Help Identify Hose Please
  103. fan wiring questions for LS1 with American autowire
  104. How to ID Pedal compatibility
  105. 2006 LS to 94 4L60E flex plate
  106. native sensors for the dash and LS sensors for the PCM
  107. Blew up th350! 4l80e swap part #s! Please help.
  108. Running good
  109. What belt?
  110. What belt?
  111. Power steering pump
  112. 1994 k1500 ls swap
  113. Adding electric fans to antique car
  114. ECU schematics?
  115. 1970 GTO-R Build
  116. '79 T/A need help with 2012 Camaro bcm with L92
  117. LQ4 Drive by Cable Cruise Control Switch Wiring
  118. Accessory brackets
  119. LS Swap/Build...
  120. BMW E46 awaiting
  121. LS newbie needs help with OBD2
  122. LM7 accessory vacuum from EVAP purge?
  123. 90 735i
  124. radiator hoses
  125. GM TYPE II PS PUMP PULLEY options
  126. Cant Get LS2 Swap To Fire
  127. BMW e36 M3 ls1 swap - pics n vid
  128. Ls swap in a 98 bird won't idle
  129. autometer coolant gauge/adapter reading wrong?or cooling system issue?
  130. Ca converts, tank interchangeability?
  131. Wiring harness question gen iii vs gen iv
  132. Pinout help
  133. ls1 gas tank wont fit my 3rd gen 91 camaro
  134. New Gen V swap products from Holley
  135. LS2 gas pedal MIA
  136. Need a little wiring insight
  137. Direct wire Dakota Digital BIM-01-2?
  138. Have a 95gt - I want a 10.50 to 10.70 Car
  139. 1972 c20 5.3 help
  140. 2014 L99 6.0 with VVT. Is T56 not a good choice? Auto better?
  141. What shifter cable for 4L80E in Fox body
  142. genIV shortblock with gen3 truck intake. throttle body ?
  143. 5.3 cat delete, test pipe, off road pipe question?
  144. Ls2 or lq9 for OBS truck 1995
  145. 2002 LS1 PCM programming - fuel gauge
  146. LS1 + 07 Corvette T56 TRANSAXLE?!?!?!?
  147. LS1 PCM controlled Fans with Vintage Air Trinary Switch
  148. Fuel tank mod, adding a recessed panel with Epoxy
  149. communication issues e67
  150. What'd buy? 4.8 or 5.3?
  151. Alternator mounting ?s.
  152. 1998 Durango lQ4, 80E, and ??
  153. Fan Mech or Elec?
  154. 5.3 Manifold question
  155. Foxbody LS6 intake question....
  156. Question about the moroso electric water pump
  157. Throttle cable in an s10 help
  158. 1985 k10 5.3 w/ 4L60E 4x4 vss troubles
  159. E28 BMW LS1-Y Swap
  160. LS3 in 82 Volvo 242
  161. 12 mpg, running rich?
  162. 89 S10 Cameo LQ4/4L60e build
  163. LM7/LS1 Swap into Chevy LUV
  164. ls 5.3 cam question
  165. HELP LQ4 swap wont start
  166. Cheap manual transmissions for an LS.
  167. 1950 F-1 5.3/60e swap complete
  168. Worlds First: 416" ls3 twin turbo in Cadillac XLR
  169. mickey thompson ss
  170. Vacuum operated heater control valve
  171. swap done, but has no power
  172. LQ9 doesn't like MAF plugged in
  173. 5.3 Swap/ 96 GT- Stock K Member and Downpipe Questions
  174. Gas pedal WAY TO SOFT!
  175. Boxster ls3 change to 996
  176. new to ls1,oil pan question
  177. question about throttle body swap.
  178. 6l80 in a 72' c10 4x4
  179. '99 S10 Blazer swap, truck harness questions
  180. How much of the harness should I remove from the donor?
  181. L77 wiring resources needs
  182. Fuel venting hose fumes
  183. 07 Trailblazer 5.3>6.0
  184. Best Value LS3 Swap?
  185. Headers installed, no exhaust yet or O2 Sensors-> Start?
  186. Possibility of adapting Colorado gauge cluster for LS swap
  187. LS1 and 4l60 swap into 36 chevy truck shift issues
  188. 1969 GTO LQ4 4l80e build
  189. 58x ls2 4l60 e38/t42 os
  190. heads milled
  191. A few basic questions for you pros out there
  192. 3rd gen to 4th gen swap
  193. Holley efi tuning issues
  194. throttle becomes unresponsive at wot
  195. Adapting stock trans lines.
  196. '96 Impala Round 2: LQ9/TMS 370, T56
  197. Steam Vent Conflict -
  198. 97 lt1 z to 5.3
  199. 89 Fox Body LSX
  200. Connector ID
  201. GM TPS Sensor starting at 100% while idle
  202. 1984 c10 LS3/60e swap
  203. sanoma motor mounts
  204. Step-by-Step Harness Install
  205. E38 ECM. what trans can be used? best place to buy harrness also?
  206. LS swap starts and run, 2nd attempt to start no go
  207. long cranking/hard starting 5.3 before/after swap
  208. Sikky - Are they REALLY worth all the extra cash for an S13 swap kit.
  209. Radiator cooling system routing help!
  210. c5/01-02 truck DBW swap wiring/tuning
  211. LS Swap labor time estimate/ Legal Advice!
  212. LS2 into my Z32 yehoo
  213. LS1 in a 79' TA
  214. lS SWAP 1975 - 1981 2ND GEN FIREBIRD - CAMARO (VIDEO SERIES)
  215. Holley LS Retro-Fit oil pan vs ARP bolts
  216. 99 ranger 5.3 to 6.2 build
  217. Need some help with lq4 accessory kit
  218. Does LS1 have a VIN or serial number that gives away the year?
  219. Porsche 911 - LS1 swap
  220. PCM for 4l60e controlling 4l80e
  221. Gen III 6.0 HO in Mud Truck
  222. T56 Reverse Lockout with E-brake
  223. Which Yoke for a 4L80e?
  224. 6-on-the-floor
  225. ls1 over heating
  226. Transmission bellhousing bolts on oil pan - how important?
  227. AC wiring question.... yes I did search
  228. AC Manifold
  229. Peddle Question
  230. 68' C10 5.3/4L60 "Blue Belle"
  231. Dakota Digital Engine Coolant Temp
  232. Turbo Fox body using 4 lug brakes
  233. Where to put an LS1 Blazer..?
  234. Speartech LSA Wiring Harness and Monte Carlo Pedal
  235. GTO exhaust manifolds for fox swap
  236. Beater Bomb 1320
  237. 1984 chevy C10 LS1 Dakota digital VHX system
  238. 1984 chevy C10 LS1 Dakota digital VHX system
  239. LS3 Issues
  240. Which A/C compressor?
  241. Is this the correct 700r4 flex plate for LQ9 swap?
  242. 93 Mustang 6.0 Turbo (eventually) Lots of pics.
  243. 98 Z28 4L80E Swap
  244. ET estimate on turbo 5.3 foxbody
  245. After 5 years the 1963 Econoline Hip-E-Van breathes for the first time!
  246. Microsquirt with a/c and traction control, is it possible?
  247. Question for you Cutlass/442 guys
  248. Post Your Pick-n-Pull Creativity
  249. Corvette filter/regulator AN adapter question
  250. 5.3 4th gen z28 pwr str hose part #
