PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Chevelle LM7 swap for under $3000
  2. LS2 conversion no throttle
  3. where to find out wiring year and model?
  4. 91 IROC-Z LS1 & T56 Conversion
  5. LQ4 into 66 Chevelle
  6. electric water pump tapped for coolant crossover line?
  7. longshot - anyone with an LSx in a 39 Ford coupe?
  8. 05 GTO LS2 & M6 into 92 Camaro
  9. 66 Mustang
  10. LS6 jetboat
  11. Need help with engine serial number
  12. Cracked Edelbrock Victor Jr
  13. This belong to someone here? '67 Chevy II Pro Street LS1
  14. Stock LS1 Spark Plug of Choice?
  15. '71 Nova 6.0 Conversion
  16. pics of miata with motor plate???
  17. 4.8 + 5spd 4X4 into 3rd gen
  18. Wiring my swap, 1994 mustang
  19. ls4 into a 240sx
  20. LS1 in a 1960 Nomad Needs ECM
  21. LS Vega
  22. bolt a 4L60E to an LS6?
  23. ls motor in a 62 chevy II
  24. G-body swap questions
  25. camaro help
  26. LS1 powered 2001 Blazer Xtreme?
  27. Some pictures of the Talledega Grand Prix track this weekend.
  28. msd 6010 box
  29. Looking for a specific wiring thread!!!
  30. Differences in versions of 4L60E's
  31. msd 6010
  32. sbc swap into rx7
  33. LS1 swap into 02 Honda S2000
  34. 86 Elcamino LS1 Swap G body.....which oil pan has best ground clearance????
  35. Will this Radiator leak ??
  36. Mini-starter
  37. bbc to ls1/lt1 car??
  38. LT1 to LS1 swap
  39. Fast Eddie - LS1 miata race car
  40. Good harness mod writeup
  41. How much will it cost
  42. LS1 6 speed into 67 A- body
  43. Will a stock f body oil pan work on a frist gen camaro if it has no rear steer?
  44. 6sp ls6 swap in 97-03 540 bmw
  45. Project L33 Cherk
  46. Finishing wiring help ls1 swap
  47. 6L90e swap 1st gen fbody
  48. 1966 Chevy Nova SS ls1 gasser style video
  49. what headers 64-67 abody
  50. Stupid ? but IDK about intake bolts
  51. LS3 A6 into C5
  52. 6.0 in 70 chevelle
  53. LS1 in a 97 Firebird
  54. Source for super tight tuck headers?
  55. 6.0 Mustang Engine pic
  56. Cats....Yes or No
  57. What offset headers?
  58. T56/LS1 swap in a fox body?
  59. LM7 Conversion question
  60. Cam gear install question
  61. Pair of interesting swap adapters...
  62. Help LS1 engine into 91 Iroc Z
  63. Vintage Air & Two Speed Fan Question
  64. Polished EGR plates for LS1 intake...
  65. I think I have a DBW harness - should I convert it or trade it?
  66. ls1 nova(do or dont....???)
  67. 4000 pulse or 8000 pulse/mile
  68. Clutch difference LS-1 vs LS-3
  69. Frame building questions
  70. waterpump
  71. Converter(un lock) lock up switch question
  72. newbie questions, sbc to ls conversion in my Ultima
  73. I need a charging/start schmematic for a 2004 gto
  74. LS1 Swap help
  75. Barry Grant Fuel Filter
  76. C4 Ls1/T56 twin turbo
  77. anyone running stand alone trans controllers?
  78. Wiring harness questions
  79. torque arm mount not the same, input needed.
  80. 1994 Mustang Gt Swap
  81. LS1 swap in LT1 WS6 Ram Air
  82. will 4l80e fit in s10
  83. Are these the right parts?
  84. LT1/ 2nd gen Firebird
  85. MSD 6010 Buy direct from msd or go F.I.
  86. 87 Shelby Charger
  87. 06 escalde dash cluster.
  88. GTO Automatic Transmission Controls Schematics (All Years)
  89. PCM/tranny question
  90. LS2 350z project begins...
  91. 93s10 with lt1/t56 swap...
  92. 84 camaro lsx swap
  93. How hard to swap ls1 into a 3.8 car
  94. Fuel Pump Conversion
  95. ac questions for conversion
  96. Cheapest Gen III headers for 84 C10 P/U?
  97. 1984 Silverado is FINALLY Alive
  98. Custom CNC machined valley cover
  99. 2007 motor in a 2000 silverado 1500 truck
  100. Linkage problems/solutions for aftermarket shifter?
  101. Factory Five GTM 5.3 instead of LS1
  102. does ARH make a swap header for the 87-93 stang?
  103. Info needed
  104. Where can i get a GTO oil pan and pick up?
  105. Alternator questions
  106. Truck oil pan question.
  107. FS 5.3 twin turbo swap everything...
  108. Wiring questions
  109. Confused about AC with conversion
  110. 1956 Belair 4 door build.
  111. My LSX swap game plan..
  112. LM7 into Jeep Willys MB
  113. 94 Trans Am Change Over
  114. LQ4 wiring questions
  115. 5.3l in a 65 mustang
  116. 6.0 M6 67 camaro
  117. Anyone with and LS1 in a 1965-70 Chevy B-Body?
  118. oil pan fitment, fox ls1 conversion
  119. Frame measurements for a 1964 Buick Special
  120. LS1 or LS2 ???????? ..................
  121. My Nova's LM7 Transplant
  122. Check Engine Light
  123. Help me pick an intake/cam
  124. Brake fittings - quick question
  125. lt1 t-56 able question
  126. What should I charge to put an LS1 in to an LT1 f-body?
  127. Starting problems After tranny swap
  128. Chevelle or Camaro for new project?
  129. Whats the best way to put an older 4-spd behind a ls
  130. I found a 5.3 combo, should I buy it?
  131. LSX Mustang Sticky?
  132. Want to buy 2000+ ls1 + t56
  133. 6.0L 64 Impala
  134. MAss area fabricators needed$$$Olds bravada needs lsx engine swap
  135. Attention Massachusetts fabricators..$$$$$$$
  136. New dual exhaust on the Miata, and 1/4 mile time
  137. need pin-out diagram for an '01 LQ4
  138. Corvette 2002 LS1 Swap To LS376/480
  139. What do I do next?
  140. ? on cam selection
  141. Brembo Calipers off Dodge SRT8????
  142. swapping LQ4 into '91 Camaro, have some questions
  143. LSx powered late model Nissan 300-ZX, aka Z-32
  144. What is the name of this fitting?
  145. LSx swap in a Shelby replica body????
  146. questions about a 5.3 into 94 z28
  147. looking for relay diagrams
  148. starting wiring harness few questions
  149. help engine has no power
  150. T56 with carb, wiring??
  151. Simple wiring questions
  152. ls2 in a 02 trans am
  153. How much clearance between exhaust manifolds and other parts?
  154. 4.8 info
  155. LS1 into is300, e36 m3, porsche 944
  156. carb,tpi,lt1,ls1into a 3rd gen?
  157. edelbrock headers 69 camaro
  158. 305 700r4 to 5.3 60E 87 Chevy 4x4
  159. A taste of our own medicine
  160. found a book on swaps
  161. ls1 controller
  162. Fox manual trans options?
  163. my thirdgen finally lsx powered!
  164. any pics of the ls1 swap with a maf in the mustang?
  165. need some answers???
  166. speedometer
  167. ls1 in a 96 tacoma
  168. LS1 in 72 TA
  169. 97 to ls1 harness, almost complete, few questions
  170. Wiring Harness for LS2/58x
  171. wiring cooling fans to e38 pcm in l76
  172. How to find circuit load
  173. Fuel pump circuit not working
  174. factory ls1 cars
  175. No brake switch = No electric throttle?? WTF?
  176. 1970 chevelle lsx swap questions!!!!! HELP
  177. cts-v t56 into rx7? Help!
  178. LS1/t56 Z32: Grocery List??
  179. Universal dual 3'' to 4'' Y pipe?
  180. ???anyone have PINOUTS to the BIG INTERIOR HARNESS.....
  181. Neutral Safety Switch Questions
  182. T56 hydraulics setup
  183. exaughst for 1968 Camaro LS2
  184. 89 caged notch 6.0 swap
  185. New to LS1 need advice
  186. What is the deal with head gaskets?
  187. what upper radiator hose did you use?
  188. TAC for '06 LQ4 motor?
  189. Advice Needed
  190. LM7 Swap into 95 caprice.
  191. O2 sensors
  192. 68-72 gm a-body swaps
  193. Header selection
  194. McLeod 8710-01 modular bellhousing...
  195. Swapping a 5.3 into a 2000 z28 ?
  196. LT for an LS
  197. 6.0L in a S10
  198. wanted: t-56 foxbody mustang interior pictures
  199. what to use for pre filter
  200. First trip to the strip in the Chevelle swap
  201. Ls motor in a 6 Nova
  202. LS1 into 78-87 ElCamino
  203. LS1 in 93 v6 camaro body - quick steering q
  204. Walbro 255, custom tank ???
  205. LS2/T56 in 1st Gen. Camaro VSS question
  206. 2007 corvette pinout help
  207. Fabricating a GTO Vortech for a WS6
  208. ? for those who have remote mounted coils...
  209. Help with 99-02 cluster in 98 car please!
  210. best fuel set up for ls1
  211. Throttle body to maf connection
  212. 6L80 shifter
  213. Cpu/harness?
  214. Anybody know where I can get some info on building an exhaust system?
  215. carbed ls1 into 69 nova
  216. 68 carbed ls1?
  217. Fuel system set ups
  218. Truck intake to F-Body intake switch
  219. Mustang headers/55 Chevy..
  220. Pcm guide
  221. PINOUT for 1999 Silverado (V6)
  222. wiring: fuel enable circuit and connector pin ID
  223. LS4 (fwd) into 1994 Acura Legend coupe
  224. Male C10* connectors
  225. my 73 nova project, 6.0 LQ9/4L70E please help...
  226. BRPhotrod headers with John B. mounts anyone? (G-body)
  227. My cheap fuel system for a body swap
  228. please help with any and all info
  229. transdapt lsx swap mounts.
  230. Hello, just thought Id drop a line...
  231. i have some 5.3s for sale.
  232. Mast Motorsports LY6 HO VVT---2009 Special
  233. Best engine combo for 1990 Miata.
  234. i need help with lq4 in a third gen formula
  235. some help please.
  236. Starting Mustang LSX swap, but I'm doing it different.
  237. 1st gen nova guys.... What steering?
  238. 2nd gen tank with a 3rd gen sender?
  239. what radiator for the 79-93 mustang ls1 swap?
  240. 4l60e trans out of a truck
  241. t5 to ls1
  242. Reservoir to clutch master hose routing ok?
  243. Thirdgen fbody ls1 swap headers
  244. 6.0L vs 5.7L - Opinions please
  245. Fbody v8 swap help
  246. Pin-outs for 2007 truck harness...
  247. Custom LS1 A/C Hoses
  248. What do I need to do to get my fuel system ready? It's been sitting for 7 years!
  249. F car T56 bellhousings
  250. Transmission gear indication ?
