PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174 175
  1. S-10 4x4 LS1 Swap Started
  2. Whats the difference in Fuel Rails??
  3. What Year?
  4. Wilwood MC adapted to T-56 OE s/s line
  5. Hybrid Needed
  6. Name The Grounds...
  7. HELP conversion wont start no fuel?
  8. still no spark.....
  9. electrical connectors and reverse backup light
  10. 2wd/4wd trans electronics interchangeable?
  11. 03-05 ls1's same dimensions as 98-02???
  12. Sound clip of the 240Z LT1 with open headers
  13. Cad drawings of ls1 and t-56 transaxle
  14. Turbo headers for a 69 camaro with LS1 ?
  15. Wiring experts come in here please! I need your help.
  16. Unidentified Plug!!
  17. No spark????
  18. Oil pan question
  19. Carbed LS1 Question
  20. Kook's weld up kit in my '69
  21. FS: LS1 FC Granny's mounts complete and NEW!!
  22. Factory LS1 A/C compressor work with R12?
  23. VSS Setup for 3rd gen Firebird Speedo
  24. Over Fueling
  25. LS1 in a 3rd gen camaro question
  26. MAF Position in LS6 ?? How close to throtlebody ?
  27. ls1 fan runtime????
  28. Hybrid Pics mocking engine up not for 56k
  29. Wiring question...
  30. exhaust flanges to fit factory manifolds
  31. question about a/c recharge after engine swap
  32. Using a donor LT1 and converting a V6 F-body to an LT1
  33. 1 of 3 Ls1 miata's here on the board
  34. In need of a ls1 fbody pick up tube and windage tray
  35. Rainier oil pan
  36. 88 rx7 with chevy 355 for sale
  37. LT1 vs LS1 in 94' Camaro
  38. LS1 FD For Sale
  39. Headers for 97 GMC Sierra LS1 5.7
  40. LS1 Porsche
  41. LS1 in a 2nd Gen Z28 ('78)
  42. IATsensor
  43. Project car has been sitting for a year, drain gas?
  44. Quick question on sensor for 6.0(anyone and everyone)
  45. Has anyone done a 240sx S13 swap?!?!
  46. 1952 p/u
  47. LS1 in '68 camaro with factory air???
  48. ok all you 3rd gen swoppers need help.
  49. ecm is junk.
  50. Best place for aftermarket fuel lines
  51. getting ready for the upgrade!!!
  52. 10 Point cage in my FD LS1 RX7
  53. 5.3 truck fuel pump line requirements for chevelle?
  54. TKO600 bell housing and clutch
  55. LS1 in a 36 chev
  56. wanting to convert 95 v-6 3.4 liter to ls1 v-8
  57. 240z LS1 Headers
  58. third gen LS1 question
  59. TX vs AC
  60. Need Recommenation for 55 truck with LS1
  61. LS1 pace setter header in a 67 PICS
  62. LS1 conversion help
  63. Conversion folks please list your DREAM conversion in here
  64. Degreaser
  65. A/C conversion experts LS1 vs LT1 compressor
  66. PCV idea
  67. idle problems
  68. FAQ Posts
  69. fuel/oil/shifter location on 69 camaro?
  70. Cheaper to convert computer/go carb???
  71. LS! and 6spd into 69 chevelle
  72. Started it up today!
  73. My project update :)
  74. 4L60e/LS1 harness Wiring Question
  75. engine swap
  76. How to get the VIN# from the engine block
  77. how to bolt a old style stick shift to an ls1
  78. 1994 Lexus LS400 LS1/T56 wiring ?s
  79. 3.8v6 rx7
  80. didnt fire?????
  81. 66 skylark and a 4.8
  82. Belt tensioner ideas needed!
  83. where to find gm instrument cluster wiring harness
  84. 1st Gen Camaro LS1 swap (pictures inside)...
  85. LS1 S-10 Swap
  86. Two dipstick holes?
  87. swap ls1 out for ls6
  88. temp gage fitting needed
  89. I Drove My Car!!!!!!!!!!!!!!!!!!!!!!
  90. Northstar info
  91. Oil pressure guage?
  92. need wiring diagram-98 truck trans
  93. Looking for Hins LS1Fc mounts.
  94. LS1/Powerglide.
  95. Grand Sport Update: See the entire photo album.
  96. Should I do the swap?
  97. Anyone tried any of his these products....
  98. Disc brake kits....
  99. alternator cooling...
  100. here go's nothing.
  101. coolant vent tube
  102. Starting My LS1
  103. Can any of the LS1's run mid-grade 89 octane fuel?
  104. My new project LS1 hybrid
  105. I'm new and have a Q.
  106. Chevelle LS1's?
  107. Fuel Question for LS1 in 94 S10
  108. Nearly there.......
  109. cross member..
  110. LS1 in 91 mustang coupe
  111. 5.3 fitting into 71 Chevelle
  112. 97 LS1 Swap...
  113. LS1 motorcycle ideas
  114. LS1 dimensions
  115. k member difference
  116. CHECK OUT THE LS1 carb C3
  117. Not Engine Swap -> Body Swap
  118. 98 pcm/harness with 99+ fuel system?
  119. has anyone done a swap on a 95- 99 truck?
  120. Mail Order Pcm Tuner
  121. What's the best way to flush the old coolant out?
  122. 434 shafiroff with holley FI in 72' vette?
  123. PNP switch signal??
  124. 1998 Harness 220 and 230 dash harness plugs
  125. Fired up the LT1 in the 240Z tonight!!!
  126. Inside diameter of clutchmaster on a LS1 Camaro or Vette
  127. 69 camaro fuel tank and system
  128. wiring diagrams!!!
  129. sending pcm in for a tune...what do i need
  130. Tanks Inc. first impressions...
  131. computer differences?
  132. o2 sensors different ones?
  133. >>>Paging Mr. Speartech<<< Question about cruise control wiring...
  134. Anyone have a neutral safety switch wiring diagram?
  135. 3.8 camaro to ls-1 questions...please help!!!
  136. 6.0L IROC almost done!
  137. Quick starter question...
  138. 3rd gen m6 ls1 swap
  139. LS1/T56 setup in a 83 RX7!!!
  140. What engine for my Ultima GTR? LS1? LS6?
  141. any late 80's 300zx - LS1 info?
  142. LS1 running out of room.
  143. dummy ls1 block
  144. connecting an f-body ls1 fuel pump/sender to fuel line??
  145. LS1 Trike
  146. new project need parts
  147. "World's Quickest Mini" is coming together (pics)
  148. 408 Swap Header Question
  149. >>>Paging MrDude_1<<<
  150. LS1 w/4L60E fit problems in 76 corvette
  151. Ls1 Maf In Tpi
  152. lt1 wiring
  153. LS1 swap and emissions...
  154. BRP mounts for 71 Chevelle
  155. LT1 in a Cobra
  156. 3rd Gen F-body LT Headers UPDATE
  157. Holy Crap!!!
  158. Vette filter/regulator ?
  159. Chevy Monza Swap in progress
  160. Hose sizes?
  161. Engine number etched on front passenger side
  162. 1969 Camaro LS1 T56 Swap !!Eye Candy!!
  163. hey rudy at hardwired
  164. Glowing headers!
  165. Fuel tank, sending unit, and fuel pump for '86 Elcamino LS1 swap
  166. Those that have done full aftermarket gauges. got some questions
  167. cant find fuel rail to 3rd gen fuleline adapters?
  168. Air diverter Sol question.
  169. g-body conversion parts for sale
  170. Everything for sale
  171. fabing ls1 motor mount adaptors sae or metric???
  172. Oxygen sensor wiring qurestion:
  173. runs 5 seconds and dies
  174. 5.3L aluminum in G-body Malibu?
  175. exhaust flange help
  176. 98 5.7L or 99 5.3 swap?
  177. camaro v6 to LS1
  178. Its Alive!! Finally
  179. sub 1000$ motor
  180. oil pressure hookup?
  181. Steerin Colunm
  182. FS: CableX speedometer adapter
  183. speartech phone#
  184. ebay
  185. hose routing
  186. LSx swap question!
  187. 2nd Gen headers
  188. 2001 complete LS1 w/98ecm and parts 4-sale
  189. Out of Space Harness???
  190. For Sale: LS1TECH Project 1969 Camaro SS
  191. what does TCC stand for in the pin outs?
  192. 5/16" fuel line instaed of 3/8" for LS1
  193. fuse box wiring diagram
  194. Few more questions about cooling and first start up
  195. radiator hose info
  196. LSx harness
  197. Unidentified harness connectors question
  198. lt1 engine swap for ls1 engine
  199. what material to use for oil pan notch?
  200. Oil pan mods for s10 swap
  201. NP241C Speed Sensor
  202. LS or ZZ383
  203. How do I tell it's a '98 LS1
  204. anyone using the LIM?
  205. LS1 weight vs Standard SB 350?
  206. Engine Harness Question.
  207. LSx swap help with th350
  208. Anyone installed a BW Super T10 behind an LS1?
  209. V6 Radiator Compatibility
  210. clutch don't feel right
  211. Can someone run my VIN?
  212. Anyone used the Edelbrock Carb intake kit?
  213. Throttle Cable Question.
  214. Conversion parts for sale Knock Sensors and covers
  215. DSE weld in tranny x-member. anyone tried it?
  216. LS1 swap in 944 turbo
  217. 69 corvette ls1
  218. fuel systems...
  219. Any T56 Fox LS1 conversions yet?
  220. Supercharged 2nd gen
  221. Help!!! My tranny (A4) rolls off when in Park! Drives in Neutral!
  222. Who makes a 396 LS1 kit in MI?
  223. 1st gen S&P mount users, how far from the firewall?
  224. 99 to 76 conversion pictures
  225. 5.3 in Rock Crawler, won't run smooth
  226. LS1 in supra
  227. hows this for a hybrid??? HOLY $H!T
  228. LS1 thermostat inlet or outlet hose?
  229. Which year harness/PCM preferred?
  230. Cleaned up the wiring, routing question
  231. Help... Ls1 identification!
  232. ls1 rx-7, won't fire, help
  233. LS1 in 1967-1972 Trucks
  234. what mount kits can I use for my 68 C10?
  235. Converting LS-1 headers to LT-1 use
  236. LS1 pace setter headers in a 67, who has tried it?
  237. What about the alternator?
  238. LS1 idiot light
  239. LS1 swap - Chevy G20 van
  240. Jaguars Anyone?
  241. Ok new problem
  242. 5.3 going in Jeep
  243. stock ls1 exhaust doesnt line up.
  244. I think I want to cry...
  245. its done, completed, finished, finito....
  246. check out my newest girl
  247. To swap cams or not to swap cams....
  248. Some pics I took tonight..
  249. LS1 in a 61 Vette...Ever been done?
  250. Advice on project car
