View Full Version : Conversions & Swaps
- crossmember
- 2005 Jeep LJ.......LS2 Swap
- 69 Javelin LS Swap
- Ls2 and ls3 map and cam sensor plug help
- Anyone acually got an On3 Foxbody LSX kit to run? Fairytale?
- Innovative swap mod vid !!
- 6.0 NA LS build for Dezert racing 1400 truck
- BMR Suspension Teams Up With Speedway Motors on a Bad 67 Camaro!
- Jeep YJ LY6 6.0L swap wiring issue
- Can someone help me with my Cutlass?
- T56 in 69 Camaro
- Where to get a shifter for 6 speed
- Toolbox Turbo Sonoma Build
- 55 Chevy, 6.0, Turbo, Holley
- New to ls1 tech and also 5.3 swaps lol
- Computer Communication Concerns
- Lq4 build help needed going in 69 elkky
- BMW E36 M3- LS1 swap wiring questions
- 81 elky build help
- Mustang AJE motor mount options. Poly, rubber...?
- 93 Chevy C1500 4.3 to 6.0 swap HELPPPP
- New build lq4 turbo got some questions anything helps
- Cheap 04' CTS for carbed 6.0/th400 swap
- Holley Dominator or Hp?
- 1988 Lotus Esprit LS1 Swap Intro
- 2002 Porsche C4S (996) LS3 525HP
- aftermarket gauges
- LT1 Swap to LS2
- 1965 Chevy Nova parts list. Please check it out and provide input
- Question about exhaust...
- 4.8 to 6.0 Swap
- Light, cheap, RWD chassis for road course?
- no spark in coils
- gen5 throttle pedal wiring diagram.
- Fuel system--choices?
- Windage tray
- LS to Foxbody w/hydroboost question
- power steering pump plumbing
- Corvette Alternators
- 1972 Monte Carlo 5.3 TT and A/C mounts
- LS dash/display
- L33 question for s10
- Gto long tubes in gbody
- 2000 LQ4 to TH350
- Starting my 240sx LS3 swap
- 1991 V3500 with 6.0l LS
- 1970 Datsun 240Z with LS1 / T56 swap
- Lq9/th400 swap question
- What parts do I need to pull from an Escalade donor?
- 4L60E semi-locked up torque converter
- 4.8 ls in a 1974 mgb
- 408 into 2013 SS help please
- A/c questions for new edge twin turbo for my wife
- Hydroboost brakes l76
- HP Tuner
- LS Swap 68 Olds Cutlass Complications
- Question about Donor Trk Swap?
- Keeping AFM / VVT in a swap?
- LS 5.3 swap
- 2010 LS3 Fuel Pump runs continuously (and shouldn't)
- LM7 5.3L DBC to DBW swap - doesn't start
- tr6060 and ls3 to 1967 camaro
- LS1 into 64 Camino
- 1972 RS Camaro/Z28 clone
- Lsx in a viper? Been done?
- Radiator inlet/ outlet
- will a butterfly intake/street catcher hood scoop work with efi
- Putting a 5.3 in a 65 gto.
- Tranny Recommendations
- fuel problem ??
- 1970 Chevelle Turbo LQ4 Build – From Start to Finish
- Someone to tune my car in Oklahoma
- muscle car oil pan fitment
- Gen V LT1 3D model
- Intake Options for A-Body's?
- Finishing hybrid conversion and having some electrical issues
- Cam roller, worn cam lobe, need collective wisdom please.
- 4L70E crossmember
- 1986 gmc c-1500 (c10), lq4, t56
- In car oil pan rem.
- 1994 Lexus sc300
- Won't start Need help 98 Camaro LS1
- car dies with maf plugged in
- Spal vs Flex-A-Lite
- Cooling system questions
- 1984 Mercedes-Benz 500SE to LS
- 1993 Mustang Coupe LS1 Tremec 3550
- sonoma ls 5.3swap
- Lq9 into a '70 charger? Anyone?
- LSX Conversion Oil Pan
- EWP on thermostatic switch instead of thermostat?
- 72 turbo 6.0 nova trans options
- Looking for PDF from Hot Rod Lane about a swap into a 96 Tahoe
- Swap my 350 to ls1
- Throttle bracket for Holley high rise
- Which harness and ecu can I use?
- How to remove the upper water neck????
- fox mustang radiator cooling question
- Anyone used a 2005ish Tahoe fuel pump assembly?
- 4 door hard top 61 Impala 5.3 turbo
- Outlaw 996 Porsche build
- Intake swap
- Can't get cruise control to set in 57 Belair with 2005 CTS-V LS6 and 4L60E transmissi
- Red Tail Willys 5.3
- TechFlex wire harness wrap?
- Gen v swap lazy pedal
- Poor Fuel Economy Troubleshooting Help Needed
- Harness Pin Out
- Wiring Question- '99 Z28 Drivetrain into '97 V6 Body
- Ls 4x4 s10 blazer
- 67-69 Camaro/Firebird LS1 headers ebay
- Need transmission recommendations
- schematic help please
- 02 sensors on a gen3 ecu swap
- L94 Swap into 07' Denali (L92 ECU)
- G20 ls3
- 1961 Impala 2 door hard top mild custom
- V6 Bird ls1 swap Cost
- What injectors for an LS3 intake and 411 PCM?
- 6.0 with kooks long tubes
- LQ4 Exhaust
- Current Performance SA-1000 opions
- How to diable C5 instrument cluster warning lights?
- '99 Sierra 4.3->lq4 0411 swap question
- LQ4 into a 1940 Ford coupe
- Touareg Swap?
- Turquiose 69' c10 stepside LQ9 4l80e
- 1946 Chevy Truck
- LS1 or LS3 in 1946 Chevy Truck? Help!!
- Fan removal, truck front access. dr
- Pulling a 5.3 advice...
- LM7/ LS1 porsche 944 conversion
- LS1 in a jeep
- 1986 Chevy C10 6.0/80e swap
- 1955 F100 - LS swap - Longtube headers?
- Cam
- Is anyone using the moroso BBC electric water pump?
- Injector size question
- LQ9 Swap water pump
- Hooker 8510HKR Cast Iron Turbo Manifolds
- 2009 LFA tahoe 6.0 aluminum 243 heads. Is this a good motor?
- will rear from 3500 chevy van fit in my 68 impala?
- Ls2 stroker tt
- Th400 to lq9 issue
- Fuel Delivery - S-10
- Need some help putting together a truck LS power train...
- 2000 6.0 to 4L60E
- 4l69e to 4l70e swap
- Ls1 into v6 body
- Removing LT1 AFM Lifters
- LT1 Crate Engine Throttle Body
- LT1 -LS2 Swap
- LS swap to 2007 AWD 3.6 STS??
- What fans are you running on foxbody?
- Ls1 t56 to 65 mustang...
- LS2/T56 E40 No Crank
- LS3 wiring issue, need help
- LS1 Swap question into 79 camaro
- 5.3/TH350 starter issue
- Transmission help
- Need help with Jeep Grand Wagoneer LS1 Corvette conversion
- Yet anoither sloppy Volvo 940 wagon 6.0L 4L80 swap
- Not a wiring guy, having trouble with crank sensor
- Belt Tensioner Options, Need Help
- Aftermarket valve covers and pcv
- Hooker LS Engine Mounts - 58-64 Impala
- Gas pedal on 1962 impala?
- Porsche 996 LS3 Conversion
- Key-on DBW behavior?
- quick connect fitting for tanks in fuel module??
- 5.3 swapped 66 Chevelle no spark! 😭😔
- O2 sensor wiring
- speedway tru ram manifolds
- New Gen V LT1 Hot cam crate engine.
- Yawn.Another 5.3 Jeep Swap...
- 1959 Biscayne 2 door wagon
- 5.3 240sx
- Driveline vibration
- P0175 p0172 p0650 long fuel trim -25.0
- Fuel cell exposed to sun?
- Holley efi intake question
- '03 5.3 engine : 02 sensors and wiring
- My 10 year old sons first build
- 1962 vette project
- Cooling system
- Front Fender emblems
- Corvette transaxle in Exocet
- 66 LeSabre EFI Tank
- Motown ls motor
- 4.8 Chevy Cylinder head question in 2006 van?
- 6.0 intoa dakota.. escalade hybrid trans question
- LQ4 into 80 Malibu - what motor mounts?
- Cruising RPM 700r4 LSX 454
- DBW: what would you do?
- Project CrowdMower: Ford Chassis, Chevy Motor, Nissan Trans
- 1970+ Chevelle Headers
- LQ9 Swap
- Help with O2 sensors wiring
- LS oil pan gasket change while in car
- Possible Alternator Overcharging
- Gas Monkey 911 LS build
- Ls1 swap in 95 gmc
- LM4 Swapped E30 - "Snow White"
- LS2 Swap C1 Pin#10 issues, sensor relay
- 70 chevelle lq9
- LS into Toyota Land Cruiser
- Running a single O2 sensor?
- 4.3 to 5.3 Swap 99 Silverado 1500
- Where's P on the 6L80 ?
- No power steering
- Size of CAI for blade style MAF
- Mass air flow question
- what ls an and accessories for a fox body swap
- Mass question
- Changing to AN at Water Pump
- New Hooker 1st-gen F-body/3rd-gen X-body LT Swap Preview Thead
- FEAD Not available Chev 19257325 Corvette Style Accessory Drive System
- What company has the GPS speedo conversion?
- PCV on LS3
- Engine Run-On
- Ls swap wiring help
- Help with ls harness standalone
- Gen iii lq4 fast intake
- Looking for help on cam specs??
- Name this swap/build...
- Ls6 350z conversion
- Building an LS1 Powered Widebody Porsche 911
- 1980 GMC c1500 lq4 6.0/4l80e swap
- A UK E46 M3 with a LS3
- shift parameters for 4L60E
- 94 4L60E Transmission
- Fuel tank conversion
- No start, PCM possible cause?
- 6L80e/6L90e transmissions not popular with swaps?
- P0010 Cam Actuator Sensor on a 2010 5.3
- Infiniti M45 Conversion
- Difference between 5-wire and 3-wire MAF?
- Pinouts needed
- 05 GMC Sierra Crew Cab - Swap Suggestions
- help with accessory brackets
- LS3 w/ hot cam crate motor controller question
- A Few Questions...
- New Hooker Fox Body Mustang LS Swap System Preview Thread
- ATS or Meanstreets Performance clutch master bracket??
- c5 ls1 motor mount brackets measurement needed
- PCM Plugs on 2010
- P0748 1999 4.8l/4l60e swap help!
- 69 Chevelle LS1/4L60E Gear ratio?
- Swapping from 4.3 to 5.3 on 97 chevy k1500
