View Full Version : Conversions & Swaps
- 5.3 Turbo Thirdgen winter project
- BRP Swap Mounts REVIEW
- 1BadBlazer - 1993 Fullsize/Turbo'd LSx
- test run my LS1
- fbody idler pulley
- Starter and alternator nuts
- LS1-LS6 diferences
- -50 degrees
- Sheobox install: difference between GTO and F-body accessories?
- homebuild bellhousing ?
- 1969 GTO with ls2 and 6 speed
- help.car wont start!!!
- G-body fuel tank and sending unit ?
- Needed, 99' cluster pinouts.
- Truck Alternator Wiring Question
- NEW LS2 V8 Miata Video, Kinda
- Harness question
- LS3 controller #19201861 question.
- Bored with the LS1 1st gen starting on an LS4 dune buggy now
- WTT: 5.3 intake and ecu for carb stuff
- 99' LS1 pin out for low oil level output to lamp?
- What Do You Think People About My LS2
- Who has run a carbureted LS4?
- how hard is it to make the truck harness from the lq4 stand alone?
- Need a scanner for my mod, which is decent/cheap/godd etc....
- LQ4 in a 1971 Nova
- Skyline R32 LS3 - Build Thread
- Hood clearance
- Chevelle floor question
- lsx in a 2008 4 door wrangler? Help me with it
- 5.3l LS1 in a 1995 Silverado,
- Does an 4-Barrel DBW TB exist?
- 60's Vette speedo and tach hookup
- LY6 VVT swap into 69 camaro
- Couple Q's on L92 ECM setup.
- LS 1 in 68 El Camino
- i got some problems
- Fox swap headers (New choice)
- Carbureted Fuel System
- cts-v pan fitment into 67 camaro
- Trying to figure out the DBW pedal differences
- ls1 mustang w/gto oil pan?
- Wiring done...correct fuse amps?
- Skyline R32 LS3
- Factory air box on to of engine
- dont know where to post..
- air intake for my 69 camaro
- Love gm for making ls engines like doritos...
- Carshop Inc motor plates
- my s13 570sx build
- Need HELP!!! 68 Chevelle with LS2
- truck wiring
- Late model radiator into a first gen Camaro...
- No readin from my new Coolant Temp Sensor...
- Cable throttle body on LS3 - Mounting ??
- TRANSMISSION COOLER 4l60
- ls1 and ford tranny help
- 2000 lq4 flexplate/spacer ?'s
- Miata wiring harness for LS1 conversion??
- Need small diameter (no ribs) idler pulley
- LS1 oil sender ohm range? anyone know?
- 6.0l VVT LY6 conversion to carb
- THIRD GEN LSX TURBO preview pics.
- G-body LS1 swap question.
- Welding 99 Camaro motormount stands?
- I have lost faith in ls1tech
- Engine mounts to keep my trans in same place
- '68 Mustang LM7
- Anyone know who makes this? ( Tramission speedo adapter )
- Project Budget 69 C-10 5.3 Swap
- fuel pumps in old tanks?
- Anybody know about 69' Opel GT's?
- 1999 4.3 write failure
- Stupid question, but what color is the tach wire 02 ls1
- LS1 auto 1996 F-150 prerunner!!!!!
- What Oil
- anyone have spare pcm connectors
- Help me figure out the last few wires!
- 4l80 into chevelle....what to look out for
- best oil pan for a g-body
- Msd ignition box
- Gauge Help?
- Quick K Member and Intake question
- alternater / coil pack questions please help
- Guestion on wiring harnesses???
- Lt1 to l92 swap ???
- Ls1 4l60e trans crossmember
- please help s10 swap ls1 0r lq4
- LS1_catera running rich
- 6.0 motors from the yard
- has anyone got a 5.3 bored
- Does E38 ECM Need Oil Pressure To Run?
- 2007 6.0 from a van?
- LSX in 1965 mustang?
- Traction control questions
- 2nd gen f-body ls2 motor mounts
- lq4 headaches into Monte SS
- LS2 in 69 Z/28?????
- 2002 Camaro vacuum lines ?
- LS1 in 69 Camaro, Stock Speedo and tach???
- Fox wiring question
- ls1 in a 86 elco help
- New turbo 402 LS1 Chevy II project
- 98-02 crown vic swap?
- Gauges, stepper motors, and 85mph speedos
- swapping from 355 (4 bolt main) to lm7
- LS3 swap harness?
- Car occasionally runs like crap?
- T56 Tail Housing swap for shifter relocation
- Miro's LS1 240 Drift Build
- My Twin Turbo ls2 Chevelle
- 2004 Hummer ECU pinouts
- Differences in LS2 engine harnesses?
- GTO LS1/6 spd manual fit in 1991 Camaro RS
- 3rd and 5th gear problems!
- drive-by-wire to drive-by-cable?
- What fuel rail with Vette filter/regulator
- Ls2 on 97 camaro
- VSS compatability - 4L60-E VS 4R70W
- 06 LS2 Drive By Wire (DBW) on an 04 Esc LQ9 question???
- ls2 in a 2nd gen firebird
- 4th gen. rear in a 1st gen camaro?
- Lsx fuel line swap questions
- 11.5 mpg in my 5.3/4l60e wrangler
- How many options for alternator relocation?
- What year 4l60e fit a 5.3?
- Aftermarket (S&P) harness to stock gauge cluster 98?
- so... I have been thinking about putting my lq4 motor in her!!!!should I?
- LS1 into 97 camaro header question
- Fuel lines
- any supercharged ls swaps
- Denny's driveshaft
- Cruise Control
- L92 in a 65 Malibu
- Gto ls2 fuel rail covers for sale
- CTS-V engine accessory drive
- Anyone ever put an LSx in a diesel 95-99 fullsize GM truck?
- LS1 Nova Motor Mounts???
- Truck driveshaft a bad idea?
- 06 LQ4 4l80e what should I remember to get off of the truck
- excessive fuel pressure???
- LS1 Swap
- Gauge issues for LS2 swap
- Intake Manifold
- Stock Manifolds FS
- Alternative to LS1 motor mount adapter plates
- Fittings for sending units.
- LS1 and hydroboost
- L92 engine swap ?s
- 8.1 in a 4th Gen Camaro
- oil preasure sending unit pinouts 99 pcm
- I need some thoughts on this problem....
- where are the pinout stickys?
- pro street ZO6 LS7 1932 truck update
- lh8 oil pan???
- harness identification
- 5.3 460le cruise control ???
- mustang swap & ls1/ls6 question
- lsx with t56 trans on a 91 s10 blazer 2wd. 2dr.
- Questions on ls1 swap on 89 mustang
- ls2 throttle body?
- 6 speed auto
- Headers are high price for my app.
- Procharged Ls motor into a 69 Camaro any body done one ?
- Where to get 4" rubber air tube coupler?
- C10 Headers?
- LS1 mounts
- have the engine.. what do i need for the FI?
- MSD 6010 now causing horrible missfiring?! WTF?
- Why so cold???
- header build?
- 1990 240 begging for a v8 swap please look inside
- 350z
- transgo hd-2 shift kit. worth it??
- This car is one of my favorite builds.
- What options of headers should I get for Fox LS1 swap?
- Best cam for carb
- Kwik A/C setup...belt size?
- Serpentine Systems - Vet vs F-body vs Truck?
- 2004 LQ4 4L80e wiring questions
- 69 Chevelle LS1 oil pan
- 4l60e not locking up??
- Tranny dilema, please give opinion!
- GSL392 internal check valve?
- LQ9 Swap!!!!! Help
- Major parts needed for swap into v6 car
- 5.3 swap
- Guess I'll post my track times
- msd by edelbrock vs 6010 msd help!!!
- Electrical connectors for L92 engines
- Starting a Miata Build got some Q's!!
- Have a complete ls1/t56 6 speed I might sell
- Drive by wire pedal idea for 73-91 Chevys
- 2001 lq4 pan versus lh8
- Lq4 engine with ls6 and ls1 mods
- 5.3 into v6 camaro
- TAC module location on 2004 Vette??
- LSX and 4l80 into a gbody
- Ls1 wiring
- Took the Chevelle to the Track
- 4.3 to a 5.3 2000 Blazer
- 98 engine harness on 99 engine
- edelbrock 1st gen camaro mounts & header pics
- FPR w/quick disconnect
- I made it to the track
- Alternator Help!!!!
- ls1 and lh8 oil pan into 69 Camaro -question
- 220 and 230 plugs
- Well here I go LQ9 Build for a '67 Camaro
- Mustang ls swap and ac
- LT1 power steering pump pressure
- Timing issues/ MSD 6012
- need help
- My LS2 Monte SS runs 11's!
- Removing intake MAP fitting?????
- I'm Fed up, My 240sx LS1 is depressing me!!!
- Chrysler Conquest swap
- Gauges for 240sx with LSX swap (Post your pics w/ specs)
- Have you done a Caterham install yet?
- project JYD Nova coming together.
- T56 Swap in 71 Bird
- installing LS3 into 1985 c10
- What is the value of a 98 LS1, S&P Harness, and 4L60E?
- aftermarket radiator help ( mounting )
- Headers
- FWD 5.3 ??s
- almost there.. won't start
- D & D T56 Questions
- swaping as ls in a 97 ta questions
- Anyone need a swap radiator?
- Kooks TBSS on a first gen conversion
- Need some help on this one
- obd2 connecter difficulty... :(
- another 5.3 tj running!!
- LS1/T56 swap in 1987 LS
- Welding the oil pan?
- L92 vvt - 05 gto question
- Did you See Chris442's LS7 68 Camaro ?
- LSX Block
- What can I get rid of?
- 1963 Impala / LS1
- LY6 Swap need help with Dbw pedal
- More wires than sensors. Need help
- Heater Hosse Fittings
- 98 Donor Z28 car for sale
- Pre bent fuel lines?
- value of 03 silverado engine harness and pcm...tried search
- Jaguars with LS1/LSx Power
- Drive by wire conversion to cable throttle LS1?
- Help on A-body headers
