View Full Version : Suspension & Brakes
- Line Lock Question
- Drop Springs..
- Which SS Replacement Endlinks are best? OEM Revised Endlinks any good?
- Strano Sways Lubing?
- Suspension question?
- Suggestions wanted
- Best Suspension Bushings package?
- Motor mounts!
- Panhard bar
- Eradispeed?
- UMI Drag bar set up?
- how to tell if shocks & struts r bad?
- Need Help With Drop..
- Power Steering Rack Bolt... wtf...
- Strano Performance: I'm open, back from racing--and a video inside.
- Brakemotive review, after install!
- Torque arm bolt help please.
- What street/strip shocks to use?
- Brake line issue?
- Road Atlanta HP Driving Event Setup Questions?
- School me on LCA's
- Daily driver suspension
- brakes driving me nuts
- Simple Question About Koni Shocks
- Suspension upgrades for a DD 400hp camaro?
- Panhard bar design question
- brake problems
- Drivers Side Panhard Relocation
- NAsty wheel hop..
- should i keep the wilwoods
- Best bushings on high hp street car?
- Springs and shocks
- Upgraded Caliper Replacement?
- Koni Double Ajustables
- Brake opinions
- Info on control arm bushings
- Spohn vs UMI
- Looking to find some powdercoated calipers
- Leveling car out, new struts on front
- lower control arm not long enough
- Strano springs on Bilstein shocks: what to expect?
- Eibach at its finest.
- How the hell do you remove this brake line? *PICS*
- Rear brake bracket
- Maximum tire size % difference to trigger ABS??
- Looking to get UMI LCA's and brackets. Any sales?
- Which Torque Arm for Street / Strip / Autocross ?
- Converted to corvette brakes, but somethings not right
- 2010 SS Camaro Brembos with Vibration counterweights fit?
- KYB adjustable good?
- brake pedal firm but not much braking (in rain)....
- strano adjustable rear sway bar?
- sorry that there isnt a brake section to post in
- bilstein hd, slp bilstein, tokicos, or kyb adjustables?
- line lock picture
- My Full UMI Suspension Pictures.
- I ordered from Brakemotive today...
- caster after strano springs?
- antiroll bar install help
- rear end is to far back....moser 12 bolt
- Prep for 12bolt, which mod will be better?
- Suspension or tires
- LOWERING SPRINGS- Is there any brands that work good besides Eibach
- Strange front shocks
- Finished the switch!
- Cross your fingers for.....
- Replacing rear brake rotors
- Strano Performance Parts will be closed 3/9-3/14... time to go thrash some cars!
- setting ride height on strange shocks
- Used set of C6 Z06 calipers on fleabay about to end
- I need help with torque arm install...
- Rear Sway Bar slapping Rear Diff Cover
- ACDelco Coil Spring Specs??
- Line lock from LT1 F-body on LS1 F-body?
- summit lowering springs?
- Does anyone have any before and after lowering pics with Prostars
- Need temporary sway bar
- cross drilled/slotted rotors?
- spohn torque arm problem
- C5 brake swap bolts question
- ***UPATED*** my first attempt at lowering my car....
- So how bad did I screw up this brake caliper? Pic.
- Anyone Using Adjustable Sway End Links?
- My front shock/spring install - corrosion issues
- BMR Relocation bracket question...help?
- BMR Trak Pak and Subframe Questions
- Parts ordered for front suspension, anybody have insite?
- '07 CTS Sways Upgrade?
- Can you replace master cylinder reservoir without bleeding the brakes?
- New rotors, now I need help with pads..
- Spherical rod end replacement
- horrible when hitting bumps after m9 install??
- Rod End Spacers and Sleeves
- Is it possible to convert my 9inch non-abs to abs???
- Strange Double Adjustable Knob Clicks?
- my WS.6 got the bmr treatment (pics)
- About to flush/bleed and re master .. This sound right??...
- Rear sway bar bushing size ?
- replacing ls1 brake hardlines
- Good blank rotor replacements
- Best Brake Pad?
- Front sway bar bracket bolts.
- Torque Arm Bushing Help...
- C5 Zo6 brakes V.S. LS1 brakes
- bmr suspension dealer
- Any tips for replacing rear bushings
- Anyone?
- upper front arm bushings
- 2000 camaro camer kit??????
- Help!?!
- need ideas??
- I have a dumb questions about a tubular k-member
- help on centering the rear?
- replacing shocks/struts
- Rear sway bar
- 3rd gen suspension work on a 4th gen?
- Really weird suspension issue
- Intrax Springs?
- Car pushing to right.
- Bmr extreme anti roll bar kit with results & pics???
- Stuck between Mods
- ARB on a lowered car
- Strano springs: roll rear fender lip??
- What parts to buy first?
- stiff brake pedal when raining wtf
- ABS delete help
- Line Lock Installation?
- Need help w/ decision on sway bars
- torque arm question
- coil springs
- Missing bump stops, need help!!
- Another Koni/Strano Believer..
- kyb struts problem
- Need help with vibration
- Need help with vibration sound
- suspension?
- Crooked Rack mounts on UMI K-member?
- UMI k-member and ABS delete installed
- Parking Brake
- Parking brake not staying up.
- c5 brakes up front, what about rear?
- stock spring perches
- Need help with a broken K-member bolt
- Quiet Suspension Wanted 408ci
- when is it time to upgrade suspension?
- Loose Parking Brake... How to adjust ?
- Track setup questions
- Rebuilding Koni DA's
- Bleeding brakes on ABS/TCS car
- TTII's and sportlines?
- 2001 Camaro Sway Bars "Stock SS" vs "Strano-Hollow"
- so i ordered some super cheap pads and rotors
- Pinion angle
- lower a camaro
- help me set up my car fellow drag racers!
- Re-powdercoating springs?
- What is that annoying squeak??
- questions on installing SFC's & LCA's
- SJM delete w/ pics
- Brake and Rotor install
- Rear shocks rubber insulators / nuts
- TCS/ ASR OFF 1998 Camaro SS
- "loose" steering wheel
- Brake upgrade ????
- pinion angle ?
- midwest chassis...
- LG Style Front Control Arms?
- k member/arms bolt kit?
- Strut tower brace, sub frame conn, and traction bar.
- Rear suspension rattle?
- LineLock Kit... Brakelines anyone?
- WS6 suspension weak points?
- Jegster Adj. Torque arm ?
- Another Brake Problem thread
- qa1's??
- Fbody guys running KW V3 Coilovers?
- new brakes....which ones are the cheapest upgrade?
- Stainless Rear brake lines only
- Alignment after Suspension added
- WoULD THIS BE A STRAIGHT REPLACEMENT DISK ROTOR?
- Want to reinstall ABS module, anybody sell factory style braided lines??
- short vs long torque arm
- Rear Trans Am Bumpstops
- Lower Springs
- best drag shocks for the buck?
- remove front sway bar ????
- What shocks do I have in my car?
- Stock sway bars
- Holy crap
- Soft braking
- is this possible?
- Opinions on Koni Rear Shocks.
- rear end bump stops
- installing new front shocks. help !!
- Question about lowering kit
- 2 "AC Delco" shock mounts look completely different
- Koni Double adjustable shocks
- inputs/opinions needed on extreme front susp
- can someone post up a pic of there installed relocation brackets
- Fays 2 watts link / vendors question
- e brake help:bang:
- Knocking noise around turns towards rear of car
- Grease for neoprene bushings?
- CTS-V Brake Upgrade Installed. (PICS)
- What brakes can I fit inside Torq Thrust 2s 17 inch
- No owner looking for a rake stance
- tubular k-member or whole front end??
- Eibach Pro-kit sits too low???
- Thumping noise after aftermarket suspension install
- Changing bushing on BMR LCA
- my car leans..
- Poly MM's, still hitting floor board...
- Couple of questions for LT1 to C5 z06 brake swap
- Speed bleeders or vaccum pump
- What suspension changes for new iron block?
- Another motor mount comparison thread.
- Pictures of UMI solid motor mounts installed.
- Torque specs? Umi torque arm
- Weld-in UMI 3pt SFC's?
- pbr 1LE caliper mounting bracket BROKE!!!
- maybe a bad shock???
- Post your Strano Suspension Pics!
- Shock Help
- Matching the Rear Sway with Front
- So I made my own subframe connectors...
- My Trans Am Sways at WOT???
- LT1 to LS1 brake swap. Did a search.
- Ordering K Member....
- whats needed to run c6 zo6 calipers besides the kore 3 bracket?
- BMR Lower control arms with rubber bushings!!!
- Stupid question.. Lol
- MWC Sway Bar
- which (turbo) k member?
- Which drive shaft safety loop do i get?
- stupid rear spring question?
- what else do i need to install front konis?
- Wofe Roll bars
- UMI drag bar video results. before, after
- rear rotor swap, parking brake ?
- CTS-V Brakes with Spare Tire
- Shocks singles or double adjustables
- Jeep Bump Stop Mod (the sh*t simple approach)
- c5 Z06 conversion
- Rear coilover options with MWC Fab9 Rear
- New hub/bearings or rotors
- front control arm busing material?
- Wilwood SL4R BBK.. Install and First Impressions..
- Konis, first impression after install
- Front Hub assembly/bearing
- need help ASAP
