View Full Version : Forced Induction
- STS systems Jump on in here!
- 2 step rev limiter question
- any cooling issues with FMIC
- Cable acuated 100mm TB
- For those asking about the GP on Turbo blankets......
- Critique my APS TT Forged Motor
- Looking for some input on the rebuild...
- 2 stage boost controllers
- shorty headers flipped
- Exhaust suggestions for T76 LT1 build
- LS1TT Nova project
- pics of my sdce 8 rib setup!!!
- ls1 block quik question ?
- turbo 5.3L or 6.0L?
- 79 Camaro build-up / 6.0 L92 with twin S366's build pics inside
- Good eng. combo for torbo my engine build ?
- BDS blowers... whats the difference?
- FI and road trips
- New MAF for FI guys?
- Non-FI related, but Quickin Related!!
- need some opinions on my 6.0L iron block
- gt35 to small for 600hp tt lq4? Or gt45's?.
- tt lq4 buildup Best cam/Intake manifold etc.ADvice please?
- Lq4....How much boost hp till I kill it?Need Advice
- Lq4 fi questions......
- Twin Turbo Takes The Show !
- Question? Just Curious....
- Selling my Speed Inc GT35R Twin turbo set-up.
- Need BOost Advice with 91 Octane, 8.5:1 & AFR225 Heads
- Turbo air filter??
- Any APS guys have a problem with the windshield washer bottle?
- Piston Rings ? And Eng. Compression Help
- Minor upgrade to my Procharger kit.
- Vette Doctors 1000 rwhp APS twin turbo ZO6 build up
- My Introduction WITH PICS (ST80 build)
- New video's of the car running.
- a few quick pics of my pt88 mock-up
- anybody use this shop East Coast Supercharging
- Main girdle for FI
- APS guys, I have a question about the wastegate filter.
- Post Picts of any F body APS Exhaust
- FI and strut tower braces
- What Turbo Kit would you go with?
- KB Vs D1sc Discussion
- Meth water mix
- air filters, the bigger the better? for best flow!
- diamond or mahle pistons
- Cooling a boosted motor
- FI and solid roller set up's?
- All those FI street cars with more than 850 RWHP take a step inside...
- LS2 carbed aluminum intake or LS6 for FI
- Kenne Bell install with numbers now as well.
- Where can I find a 2.75" V band clamp?
- Fuel Injection Concepts hooked me up
- Truck MAF to IAT. Is this correct?
- Spark Plug Gap?
- Which BOV for my application???
- Roots Style vs Centrifugal Blower
- Catch can in APS PCV set-up
- Vortech overheating? Aftercooler or innercooler?
- Almost 700 rwhp with 10.5 psi APS TT kit
- Twin turbo lq4 buildup< :devil:
- TWIN s475's ON LS2/364 CUBES
- I found this Maggie MP122 video
- Mazda RX7 with LS1/ATI ProCharger D-1SC back at EPP again for more updates
- pros and cons
- Billet High Fow Fuel Rails!!
- 6 rib crank pulley
- Lets see those APS exhaust pics
- Does denser air give up more #Boost?
- PTBlank-Non Sponsor Turbo Kit Ground Clearance Pictures - Help
- best electric fan 4 front mount turbo systems
- S series turbo - what filter?
- intake on smokinhawks car
- best cooling fan
- Cast turbo manifolds?
- NOS cooling Procharger F-body kit
- snow performance methanol injection stage 1 or 2??
- Injector Size for F1A Procharger 14-16#
- How many centri guys run lots of overlap and centerlines under 114?
- Best Direct Replacement for 76GTS?
- aps manifold ?
- PCV what to do with it?
- Trick Flow heads okay for twin turbo 427?
- Welcome everyone..So we all meet again..
- Can anyone overlay some dyno charts or turbo,centrifical and magnacharger....
- Stock LS1....how much boost?
- Procharger P600B on LS1???
- Pictures of my new APS blow off valves
- pt88 size vs 76gts
- Anyone running the kentucky turbo system?
- street killer
- Recent TT progress shots & tech question!
- Crazy thoughts in my head (twin turbo Avalanche)
- STS after-turbo muffler?
- How much boost for 4.8 short block?
- gotta a turbo and three cams?? need lelp
- Help with ST80 dimensions
- STS oil pump?
- help me... procharger project
- Drain line for turbo? oil pan?
- Oiling the turbo
- Oil Pump?
- Who want's 8 rib tensioner pulley's?
- how far can I push my 60lbs injectors with FI
- PA racing K member with the APS TT
- Anybody tried mounting a blower like this?
- 10-12lbs of boost fuel system upgrade?
- Turbo selection, please help!
- Planning to get truck coils, round or square?
- duel 2.5 inch pipe
- looking for charts of boost from idle to redline of procharger or other supercharger
- Need some Help with my build!!!
- Won't idle
- 5.3 vs 6.0 manifold
- Supercharger question
- APSs warranty police GOOD or BAD ???????
- Thank you
- How many of you are DD your FI cars?
- TT APS GTO Dyno Results
- 4" downpipe guys come in
- 408 + ?Boost? for 600 - 700 rwhp
- D1SC & maf?
- newbie needing help!
- Turbo and MS4
- FI FUEL plumbing question
- Proper Adjustment for Vortech Race Bypass
- Solid motor mounts?
- Finally Mounted My FMIC
- 427 Warhawk For Boost Setup?
- FMIC Relocation Project (PICS)
- Electric Vacuum Pump from SSBC
- iron block for boost.....6 bolts per cylinder
- most power made on stock 6.0l short block
- which torque converter for FI? Planning 650 whp
- Roots sc for LS1
- Let's see those FI under the hood pics....
- New Motor and blower
- Crappy Vid Of LT1 Roots Blower In Action
- UMI K-member with CUSTOM turbo setup pix wanted
- lq9 block, missing hole for j bracket mount
- Vortech?
- LT4 valve springs with FI?
- Procharger getting quieter
- Testing out the APS twins and BOV's
- Question for APS!
- HP potential with 408+2.8L twin screw?
- Aluminum 6.0 head for turbo?
- strongest factory gen3 block?
- STS problems help!!!!!!!!
- another crank pinning question
- cam choice for sts
- E boost 2 routing for twin turbo's
- G5X3 cam with turbo good or bad?
- Procharger question - space it takes up?
- Using my APS washer fluid tank as meth tank.... who can modify for me?
- Aps Kit?
- Review my plans please.
- sts turbo tailpipe problem
- intercooler restrictions
- A few turbo questions
- couple turbo spec ?'s
- Whipple 2.2L
- TurboCharging my 89 GMC Sierra with a 5.3
- Purchasing D-1SC Tuner kit for Stock 98 F-Body. What else do I need?
- newb turbo Q
- Kmember question?
- Do i need to rebuild my turbo?
- Turbo Blankets...question.
- lq9's under the curve
- who all has 370 FI
- Finally, 700+ rwhp stock LS2 = BOOM
- Remember this car ????
- Speed Inc. procharger F1A results 800rwhp
- Anyone running the .........
- How much boost is Safe?
- Anyone else blow out freeze plugs?
- Turbo ls1 help
- boost with 5.3L heads
- New project...big one Need advice on Magnuson
- Intercooler charge pipe technical questions
- Corvette Roots S/C on T/A???
- Foxbody Mustang 5.0 with TTI T61 Turbo ... how fast is this guy?
- good piston rings & head gaskets kit to rebuild 5.3-5.7L ?
- Heat wrap
- Does anyone have a running ST80 setup or will I be the first?
- Procharged 408 build questions?
- Forge -bov & Actuators Incon
- Wanted:Piston ring part #
- How many of you procharger guys hit 800rwhp with a 347?
- Turbo Damaged in Shipping?
- 10-Rib C5 Novi 2000 Conversion.. Video, Pics Coming..
- Frustrated
- Can you use 317 casting heads on a 3.90 bore LS1 motor?
- Mondo Pics on Twin Intercoolers Wanted
- 8 rib conversion for my truck. anyone?
- affordable a2w cooling pump
- looking for pics of procharger installation
- Magna Charger Headers Exhaust ????
- Procharger question!
- Wideband O2 Sensors?
- Need help, sponsors chime in too, wanting to build/buy forged 347 longblock
- OFI Kit - oil drain
- 383 stroker and S91 turbo??
- Oil Regulator for turbo oil inlet
- Check it out! Borg Warner 85MM
- Will there ever be a roots blower mass production system for the 98-02 Fbody?
- Remove Maf...........Procharger
- Advancing Cam for decreased SCR?
- Procharger guys!
- What point are new pushrods needed?
- Turbo Piping and Intercooler inlet/outlet sizes
- Magnusson specialist needed
- side gapped plugs
- Help
- Build A New Setup And Could Use Some Ideas....
- turbo mounting location possible problem?
- intake for a fi
- spohn k-mamber. aps build
- gasket questions
- My build - Lots of pics
- another 03 chevy truck twin turbo.
- spring for my wg?
- Sts
- Balancer?
- Check out the Caddy CTS-V we are building. Naturally it has an ATI ProCharger!
- What rockers and lifters??
- maggie
- Finally getting close to completion-pics
- How much more timing can/should you run with 9:1 compr.?
- 4150 style tb
- misty vapors coming out of pcv breather
- What is safe boost for this setup?
- hiding a front mount
- Turbonetics Failures?
- Turbo Question?
- gear selection advice
- This can't be good...
- ATI Procharger users
- Lsa for turbo
- CR for big boost...
- Good vendor for procharger?
- How much H.P can this turbo support
- question for sts snorkel kit users
- Got a new toy!
- running vette procharger setup on f-body
- Aps F Body Price?
- twin 60-1's
- New numbers
- Dual inlet intercooler for single turbo?
