PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 [169] 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Turbo cam Question
  2. Dry sump
  3. BBK SSI manifold
  4. First time at the track.
  5. Going to a different car setup
  6. IAT Placement on Turbo car?
  7. Magna-charged LS1
  8. spark plug problems
  9. Some TTi kit oiling questions before install
  10. Should I switch to race gas???
  11. BOV issues...
  12. do i need a restrictor for my oil feed?
  13. A couple of ?'s
  14. Some Vid of my Turbo SS
  15. Boosted 346 build
  16. what size cam?
  17. 2 milestones for the sts SS!!
  18. just installed procharger...help!
  19. turbo headers with different primary sizing
  20. what kind of hp can I make with my disc, what parts?
  21. Something funny happend the other day
  22. best heads for turbo?
  23. Under hood temps
  24. Finally got some track results
  25. Iron block preparation
  26. Whats any one's opinion on the GMR Twin Turbo setup for LS1 Camaros?
  27. At what temperature will you not run your turbo setup???
  28. check out my drawings
  29. Center gauge mounting
  30. Turbo & 6.0L heads
  31. Dyno time once again
  32. need a pic of a GT42
  33. Procharger guru's inside
  34. Final Tune/Dyno done...
  35. Video of roots blower setup on F-Body
  36. Best tool for notching a k member?
  37. Thickest headgasket recommended for FI setup???
  38. any ideas on this? graph inside
  39. STS...worth $5k??
  40. Replace a/c condensor with intercooler
  41. Precision Turbos
  42. t3/t4 hardware kit?
  43. Alt's to Vortech heat exhanger and pump??
  44. Hi-Flo Install pictorial
  45. how hot is your supercharger!
  46. procharger drain bolt leak!
  47. vortech T Trim
  48. Where to tap boost for boost gauge
  49. ATI procharger IAT sensor
  50. Need help!!
  51. Did anyone add the Supercharger, Turbo, etc to their insurance?
  52. Turbo whine.......question
  53. Vortech Crank Pully bolt??
  54. FI + Injector question
  55. Incon spark plug wires
  56. LT1 vs LS1
  57. How Hard do you SPIN your Blower??
  58. STS owners - OIL LEAK
  59. EPP front mount intercooler kit?
  60. Turbo Money...too low?
  61. Post pics of where your FI Guages are located
  62. I found the solution Procharger inlet hat problems
  63. Please look at this thread
  64. What kind of alternator are you FI guys running in the hot weather?
  65. Someone explain this
  66. F-body Turbo Kit
  67. Pro Charger and G5x4
  68. PTK 1 wire high output alternator question
  69. Turbo Ls1 sand rail
  70. Procharger single fan shroud? (+ add #2 fan)
  71. trt turbo
  72. log headers vs. full headers
  73. Marko's old Supra on eBay
  74. Big Stuff 3 - Turbo guys, need help
  75. gapping Iridium plugs.. yes or no?
  76. Too much compression?
  77. Need help with identifying TTi kit
  78. Does anyone know this Pro Mod car???
  79. something interesting with a blower I got to work on today
  80. Before i install my LQ9 heads...............
  81. Intercooler and fan mounted
  82. Relocated alternator guys: fuel rail interference?
  83. Katech + S/C
  84. Need info on a streetable stroker with D1SC
  85. turbo info that I'm confussed on
  86. reichard racing pulley and Dez racing
  87. What's missing? Vortech V-9
  88. *****Futral F15 & F.I???s
  89. Need help
  90. Maggie Cam Selection
  91. Help me reach 550rwhp/650rwtq with STS LT1
  92. Problem after turbo install
  93. LS1 Style Blower Manifold
  94. What is 227 kpa and 50 kpa equal to in boost and vacume??
  95. can my car meet the boost?
  96. Twin Turbo Size?
  97. What spark plug to run with supercharger?
  98. Stainless or Steampipe for Turbo Manifold ?
  99. Crank pulley coming loose with Procharger?
  100. Cooling issues with D1SC
  101. Comp 918's on boosted motor
  102. Forged 346 good enough??
  103. twin gts 70's are alive and well
  104. My Incon install thread... (Pics)
  105. SDCE kit
  106. Dynomax ultraflow Q
  107. Will This Fit?
  108. need masterpower turbo seals!
  109. Anyone running a oil scavange pump that doesn't really need it?
  110. how can i tell if my turbo is bad or goin bad?
  111. Another PCV questions (pics)
  112. Best Alternator Relocation Bracket
  113. Turbo Oil everywere...damn
  114. garrett turbo
  115. TB upgrade for ProCharged application?
  116. Anyone running the GMR Speed turbo kit?
  117. G5xb
  118. how do your support the nose?
  119. Mti Just Finished My D1SC Procharger Kit!!!
  120. how much boost
  121. STS charge pipe(s) PICS needed ASAP!!!!!!!
  122. My motor went :(
  123. Article comparing Eaton vs Kenne Bell vs Vortech vs HP Twin Turbo
  124. car is stuttering at WOT!! whats going on?
  125. master power turbo
  126. turbo support???
  127. Filterin' the F1...
  128. Some interesting turbo info
  129. is an underdrive pulley good?
  130. trying 2 make custom oil lines.
  131. Auto or Manual
  132. Quse LT1 F1R
  133. Where to get afr 225's?
  134. ls6 valley cover?
  135. WI or W/AI pre-IC and Meth pre-TB set-up...
  136. Pump gas limits?
  137. turbine housing q?
  138. some body help me
  139. how much boost?
  140. anybody punch out CATS???
  141. understanding turbo specs..
  142. Who can recommend a good turbo cam grind?
  143. SC belt hitting the water pump???
  144. Need Turbo Info (Very general)
  145. Congrats to INTMD8
  146. World's Fastest Turbo LS1
  147. cost of hot and cold side exhaust
  148. O ring block questions .
  149. Need place to tap Oil from motor!!
  150. What would it take?
  151. ATI D1SC or P1SC
  152. I'm Proud of my little Z.
  153. STS Guys, Which Y-Pipe 2 1/2 or 3
  154. How noisy is a YSi compared to a T-trim?
  155. Methanol with aftercooler?
  156. For $400 what would be better 6.0 heads or turbo cam?
  157. ATTN- Procharger users. any NOT using SDCE with success?
  158. Forced induction cam for 402 CI 8.5:1 engine
  159. Some of the projects that we have going on at the shop!!
  160. Will ls1 GTO manifolds work?
  161. Lean rear cylinders with boost?
  162. LS6 cam-good for turbo?
  163. FI and rear gear choice
  164. cam for my magnacharger.
  165. looking for the best blower heads, 6.0's?
  166. Why buy Procharger?...
  167. Thinkin about goin STS
  168. Pre Vortech install setup questions
  169. STS Turbo
  170. STS Turbo
  171. Turbo Guys: What Cams Are You Running?
  172. ATI or Turbo For An Auto
  173. Can I turbo this set up
  174. 1998 lq9 heads?
  175. More pics of my Twin GT40 setup
  176. Best heads for turbo motor?
  177. 4.25"?
  178. POLL: What do you think is a fair price for a turbo kit?
  179. Hmmmm.... What do you guys think of a pair of GT42's?? (pics within)
  180. Need dyno #'s for TTi street kit for WS6
  181. Help me with a filter location issue
  182. finally a little bit of progress
  183. STS on stock bottom end???
  184. fmic + zip ties
  185. ATI S/C...buy whole kit, or piece together????
  186. Project Complete...
  187. 18mpg!!
  188. dipstick pushed out one time
  189. STS oil leak
  190. What do you guys think?
  191. Shortblocks for boost?
  192. ProCharger inlet help...
  193. GT-70 Turbo
  194. Is direct port and a blower a good combo?
  195. 4 busted ringlands
  196. What all is necessary for D-1SC buildup?
  197. Tube Thickness?
  198. alternator relocating bracket
  199. Twin turbo alt. relocation probs.
  200. STS my car?
  201. How does this cam look for FI?
  202. NEED some help
  203. OK, so how many guys can really care less if their car has A/C or not?
  204. Just got off the W2W Engine Dyno and....
  205. Sts - Wrapped Exhaust -- Inside!!!!!
  206. devils own kit and boost
  207. Turbo Oiling Problem!!!!!
  208. Aussie Burb with Whipple
  209. need help with my alternator bracket
  210. Mocal pump
  211. hey guys will the thunder racing cheatr cam be good for boost?
  212. turbo & heads ?
  213. need Pulley ???
  214. 700+rwhp - LS2 vs. LS6
  215. What's a good A/R combination?
  216. couple questions
  217. where to put the oil return?
  218. How many guys here have big hp TRUE street cars.
  219. Question for those who have stood their radiator up
  220. how much compression?
  221. Crazy Incon Question
  222. Another 98 Camaro SS, T-88, 370 Iron Block Build
  223. Finally got the car back, but A/F gauge gives error...
  224. Stock engine. 4.6 SOHC=520RWHP!!!! HELP!!!!
  225. a lil' bita help por favor...
  226. This has got to be a little restrictive, right?
  227. ProCharged Iron Block 408 what should I expect?
  228. Kenne Bell pics on a 03 Z06 (not mine)
  229. How much boost on a cammed/stock LS2?
  230. Procharger Pulley needed
  231. Vortech Question
  232. TRTturbo Custom Grind Cam
  233. Looking to discuss f/i options for my 02 SS
  234. Will this turbo work for me?
  235. What is the largest turbo that can fit under the back of a F-Body?!?
  236. help please!!
  237. Uttt ohhh my car is acting funny. Please help me diagnose
  238. 5% fuel change and 4* timing made a HUGE difference!!!
  239. 1999 silverado magna charger on 98 f-body
  240. Chance to get a free ATI kit
  241. Holy air/fuel ration batman!
  242. Turbo guys, I need advice again :-)
  243. Need help.....i am confused
  244. Procharger Belt
  245. LT1 turbo kit pics
  246. Hot cam plus maggie 112
  247. Phamspeed/TURBO guys inside...
  248. affect of nitrous shot on FI Vs. NA.
  249. 5.3 turbo size
  250. meth pump and mounting??
