PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Loud superchargers
  2. Almost finished pics
  3. which cubic inches is good for a TT??
  4. Another Twin Turbo Update
  5. 500-550 RWHP Daily Driver. FI or H/C?
  6. How many run Rotrexs?
  7. BOV Before or after the I/C on high boost setup?
  8. fitting for boost vac reference??
  9. Procharger 4.5" IC and Coolant Reservoir Don't Play Nice
  10. Fmu
  11. Fuel vapor smell help!
  12. More parts more $$
  13. Ls2 or L92 for D1sc
  14. Cog setup on the street???
  15. True tech performance F1R bracket???
  16. Turbo Timer
  17. What does this Vette have?
  18. Vortech Mondo Dump to atmosphere or back into piping?
  19. blow off valve "S" or "H" type
  20. Head selection
  21. Pics of a custom header for a 1200 HP Honda
  22. Turbo manifold construction
  23. ICS Head gaskets
  24. Ohio Forced Induction
  25. ECS meth controller, wideband, liinelock Ashtray Panel
  26. Sts turbo and SLT LT headers
  27. Those who run a FMIC - how much difference did it make?
  28. changing to a larger A/R?
  29. rear mount oiling???
  30. FI: Thin Oil Issues?
  31. Need help tracing a turbo leak.
  32. where to get aluminum piping
  33. Head question for 402 with F1C
  34. Please help with turbo size on 408
  35. turbo kit
  36. LOUD Scavenge Pump
  37. T76GTS vs GT47
  38. pics of my setup...
  39. Incon & K-Member
  40. replacement supercharger elbow?
  41. How's this for an intercooler?
  42. STS turbo Exhaust gasket???
  43. blown car doesnt respond to a quick rev in N or gear
  44. Best oil for FM turbo car?
  45. Anyone know the details on Hinsen's twin turbo RX7 combo?
  46. FI guys and your fuel systems
  47. what more do i need?
  48. Project Stingray 6.0L Turbo Build Thread
  49. importance of flow on intake side of heads?
  50. Supercharger Questions
  51. Truck Manifolds
  52. stainless steel or coated or..
  53. having problems loading the car agains the T-brake and foot brake
  54. tangential vs. on-center
  55. Will my TnT power ring hold boost?
  56. part # for o2 sensor from aem a/f gauge
  57. INTERCOOLER Help
  58. Do you have pictures of a modified/tilted C5 radiator?
  59. Stock ls1 with 95000
  60. My good luck has ran out...
  61. STS Wastegate setting?
  62. Procharger issues
  63. o.f.i 723rwhp 724rwt @14psi 93 octane.
  64. 1550+* egt
  65. putting a turbo sytem together need help!
  66. It's alive!!!!CDN Perf 347 and F1R
  67. turbo sizing
  68. 5psi on stock ls1
  69. TT pipes back from the coater.
  70. what turbo system?quality, type, size??
  71. Unit213...what a joke
  72. Should it be forged?
  73. FMIC install
  74. A few pics of our latest Twin Turbo build.
  75. some kind of combination of intercooler or meth
  76. Turbo PT 1st gen pics
  77. how much torco/octanium to raise.... (i already asked in fuel section)
  78. what do you think of this?
  79. Computer to use with FI
  80. basic bolt ons for STS
  81. 716 RWHP pump gas KB Cobra.
  82. has anyone used this forged piston kit?
  83. STS twins
  84. A pillar who makes a complete one?
  85. vortech with air/water intercooler, maf, and mondo all mounted up top? is it possible
  86. FI guys-fuel bypass regulator Q's
  87. New Supercharger
  88. Can you clock a d1-sc?
  89. C5 with ATI ProCharger D-1SC - 740 rwhp on our Mustang Chassis Dyno
  90. Magnuson Roots Kit
  91. Going turbo!!...stay 408 or go 370??????
  92. Pushin water
  93. DTC p1516 and p2101 after STS install
  94. BOUGHT A PROCHARGER-what other mods do i need
  95. D1SC needed.
  96. s/c belts
  97. Turbo header help
  98. O.F.I Turbo kit pics installed
  99. Methanol injection
  100. 10.75 CR safe for 5 pounds???
  101. Ceramic coating questions – any good shops?
  102. Traction ?
  103. Intercooler or turbo cam???
  104. cartech FMU
  105. procharging 422 stroker
  106. I bought a Procharger is this normal (Video)
  107. Is there a difference between a new engine setup for super vs turbocharger?
  108. polishing head surface smart???
  109. is this normal?
  110. how about this cam for a twin turbo setup
  111. Proper procharger Y-body setup
  112. Whats a used GT67 worth?
  113. turbo id and help on finding flange
  114. MS4 and procharger
  115. Possible O.F.I. Turbo setup?????
  116. thick gaskets
  117. Need Help With Turbo Kit
  118. Procharger w/N2O
  119. some simple to answer DIY questions
  120. valves for FI
  121. Eaton Roots Blower for LS1 no cutting???
  122. 408 w/ twin 67's or single 80?
  123. vortech heat?
  124. manual boost comtroller ????? with T.T.
  125. Give me some info on this turbo cam - specs inside
  126. different intake elbows?
  127. What are you running for a Blower cam?
  128. Beehives and boost?
  129. Aftermarket Overflow Tank
  130. Final Cooling question
  131. New numbers
  132. MY 04 GTO with a 76mm set up..
  133. Twin turbo intake air temp?
  134. Stuck on the fence - Procharger or TTI Single Turbo???
  135. anyone have any dyno graphs of an FI setup without a cam then with one??
  136. what is the best exhaust heat wrap?
  137. Cuda dyno #'s
  138. which turbo
  139. Vortech oil feed hose replacement?
  140. Turbo compressor spinning faster = Hotter compressed air ?
  141. Breaking in turbo engine with turbo or without?
  142. Anyone running a mild-aggressive turbo cam?
  143. How will big cam respond to boost?
  144. how bout this
  145. twins for my setup
  146. How do you adjust Tial 50mm BOV??
  147. Eboost2 Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  148. Bracing
  149. Turbo "sock"?
  150. new best at the local short track
  151. STS Oil Pump High Pitch Annoying Whine
  152. Very intersting results going from 3" exhaust to 4" exhaust on rear mount setup
  153. Dyno'd again, still some problems...(hiflo)
  154. TRT vs STS
  155. Remote Mount Turbos Daily Driven...
  156. Hard miss at ~3800RPM ?????
  157. Fuel needs in low boost application?
  158. New bests with the D1SC @ 15psi
  159. stock internals vs. boost
  160. F body Procharger users--relocate alternator?
  161. Twin Turbo 403 LS2 on the way
  162. Turbo cam recomendation from Cam Motion
  163. becool part number
  164. New Build for the 67
  165. BOV Comparison...
  166. D1 vs F1 drivebility
  167. How much money for diy turbo?
  168. general timing question
  169. Turbo pics
  170. Swaping heads for FI will this work with my setup?
  171. How good will this cam be?
  172. 2,300 HP...454ci TT...daily driver, 950 rpm idle, A/C, all accessories.
  173. adjust mondo bypass valve?
  174. Something New to Help the Twins
  175. difference between stock and STS pcv?
  176. Supercharger HELP!!!
  177. are these any good?
  178. Got my little air filter for my GT47 turbo
  179. How many are on 113lsa cams with F/I???
  180. Kenne Bell supercharger?
  181. Is my vacum low?
  182. If you ever wondered.... Hi Flo hot parts
  183. Boost Pistons
  184. need pictures of sts intercooler set up
  185. Looking for the final say on a Procharger
  186. magna charged F-body
  187. Garrett turbo question.
  188. How much more timing are you adding with Methanol?
  189. Twins + E85?
  190. Gen-TT G8 Development Complete and Shipping
  191. Traveling with Meth
  192. what do you guys think?
  193. Underhood Temps. Is there a Fix?
  194. Eye Candy
  195. Those using nitrous jets for restrictors come in!
  196. wastegate pressure connection
  197. Official STS help thread
  198. Complete new ProCharger 4.5" intercooler assembly - $850.00 shipped at EPP!
  199. LT1 procharger pics
  200. Highest HP TT Z06
  201. Any sponsors sell carb'd procharger kits?
  202. 2.65 or 2.75
  203. Ninetres's new forged 364 build thread
  204. Turbo's are here!!!!
  205. Please help can't pass emissions in colorado?
  206. Looking to lower my compression ratio?
  207. new toys :D ( pics )
  208. 9seconds or faster running drag radials?
  209. sts guys, how much oil do you use?
  210. Opinions on "turbo cam" vs Z06 cam in a 408
  211. 6.0L heads part number
  212. Innovative or AMS 1000 Boost Controller
  213. ignition & PSI & Power
  214. Open Down Pipe?
  215. Problem with missing/bogging above 6 psi
  216. routing intercooler plumbing...
  217. 67 TT camaro Build
  218. Procharger IAT's
  219. Help me decide
  220. Whats easier to install? Turbo or charger
  221. modified TTi street kit ( is it possible)
  222. Good Blower Cam
  223. FP and Octane
  224. will you be ordering one of the first aps TT kits
  225. Turbo choice for true street class....
  226. Turbo Oiling
  227. F-Body D1SC Head Unit Problem/Question
  228. anyone have a parts list of a homemade rear turbo?
  229. How much is my car worth?
  230. Guess Dyno #
  231. help!!!!! i need to drop the comp.what is the stock combustion size of a ls1 head
  232. The Truth about Traction
  233. I'm Baaaaack
  234. More problems
  235. Newbee at Turbos. Will this work?
  236. supercharger cam
  237. Pusher Fans
  238. LT1 Boost?
  239. procharged Z06 track times with vids
  240. 1 7/8 turbo headers?
  241. What coating companies have you guys used for turbo hot parts?
  242. 224/236/114LSA blower cam?
  243. Boost controller for supercharger
  244. Turbo compressor surge causes MAF reading fluctuations?
  245. What gears for a procharged car?
  246. Noob Water/Methanol injection Question
  247. Procharger Question
  248. 2 bar map and adapter part #s
  249. TA's with STS kit....POST PICS!!!
  250. Need help with turbo setup
