PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 [162] 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. 88mm turbo guys, mounting question
  2. bov/sts question
  3. What Intake Manifold
  4. 383 + Blower + Nitrous - Fuel = Ouch!
  5. mp t-70 dimensions vs TC-76MPS
  6. Best location for WG?
  7. Can going to a .060 copper head gasket drop comp enough?
  8. Carburating and supercharged
  9. hey FM 6.0 guys , do any of you run your exhuast over the K member?
  10. Max boost with a 98 PCM?
  11. Boost and Winter Gas!
  12. Turbo questions
  13. When is Intake Change Necessary?
  14. Info for Procharger
  15. GT500 w/ Kenne Bell - 810rwhp/745rwtq
  16. turbo kit
  17. Bov and Wg
  18. guys will 3100 cfm of air from the fan cool the car fine
  19. Same cam for turbo/SC?
  20. Measuring blower speed
  21. 2-speed supercharger at the SEMA
  22. Aftermarket heads?
  23. question about a VERY VERY VERY small turbo
  24. TTi T-76 Street Kit Turbo System FS (Link to FS section)
  25. Has anyone run a set of L92s with boost yet?
  26. Please Help! Thunder blower 214-230 Cam
  27. Need Help Ati Crank Pin!!
  28. New Turbo kit manufacture
  29. VTG or VATN turbos
  30. Turbo questions..
  31. W2W on e-bay
  32. LT1 guys inside..turbo/engine ?
  33. help me choose a blower cam....
  34. Belt Size
  35. gt40 oil inlet flange
  36. I'll be listing my car for sale next week
  37. Set-up for turbo on stock z28 advice.
  38. Why do I have boost before throttle body but not after and into the manifold
  39. I just got the Mondo Bypass valve and found this
  40. Possible Turbo Problems? HELP!!!
  41. Boosted Engine Life
  42. Procharger Intake Air Temps IAT
  43. Bone Stock other than rear turbo and stall?
  44. Will a 12 rib fit on an F-body?
  45. Thinking about selling my TTi Street Kit
  46. sts kit questions
  47. How bad are chinese turbos?
  48. High boosted (16psi+) PCV setups?
  49. Clipped Wheel Thread
  50. Finally!!!
  51. AZPS 750TT package on 91 octane... vid inside!
  52. Turbine sizing -- how small is too small?
  53. Th400
  54. WOW ... not for the weak at heart....
  55. 2005 Procharged Vette
  56. Blower Cars, what stall speed you running?
  57. Ohio Forced Inductions Inc 93-97 LT1 Hot parts pics
  58. New T76mm Turbocharger on it's way to mi casa!
  59. Poll - stay FI or back to n/a
  60. New GT-K and GT-M series turbos
  61. Got a Street/Strip Single Turbo LT1?
  62. Victor Jr EFI intake on a 346 with D1-is it worth it?
  63. Procharger P-1SC or D-1SC
  64. which will spool faster?
  65. Good Electronic Boost Controller?
  66. carb style manifold, how to attach map sensor
  67. what size twins?
  68. Twins or Single???
  69. Urgent Members With Relocated Alt Come Inside
  70. wastegate springs- need more boost
  71. Timing Question
  72. 408ci Twin 67mm preliminary dyno results...
  73. Supercharger Qusestion
  74. Cam with STS question
  75. Reverse STS question.
  76. ebay threads
  77. dropped my turbo and down pipe off to get coated...
  78. Thunder 214-230 600/575 117LSA Blower cam?
  79. what rwhp are you seeing on boost w/stock bottom end?
  80. Nothing mindblowing, but made some clean hits in the Formy
  81. My C5 Corvette Single turbo kit is for sale
  82. procharger question
  83. T76 and Nitrous
  84. Forged 346 + Blower for the street ... what to expect?
  85. 1st thread ever! I am condering a Procharger..
  86. Powerblock Horsepower TV Procharger
  87. Cooling fan
  88. Fan settings
  89. anyone tried these turbos?
  90. Procharger P1SC
  91. Those who have done turbo builds
  92. For those of you waiting
  93. I had a Blast racing at Richmond Yesterday
  94. Ohio Forced induction hot parts installed
  95. Can I see Procharger setups on your fbody?
  96. 11.5:1 compression
  97. Blown pistons and sleeve... Lots of rebuilding and ?'s... Paging EPP and KP
  98. Planning for a Procharger... questions
  99. d1sc intake hat
  100. How much lift? Cam selection
  101. Lifetime of a 408 w/ boost???
  102. Now I guess turbos are cheating too.
  103. what is a turbonetics MPS turbine wheel?
  104. How much do you have in your motor?
  105. What cam? T-76,ported heads,stock cubes.
  106. Turbo vs Blower rear gear question
  107. Lbs of boost same as PSI?
  108. What stall with a big single mount?
  109. A new MP70??
  110. How much compression
  111. STS Muffler Pic!
  112. HP potential on a built 346ci
  113. School me on PSI????
  114. What do you like better about your boost setup or n/a or spray?
  115. M6 rear gear?
  116. sts t61
  117. Deliberate 383 split personality?
  118. Boosted LT1's need some suggestions
  119. Harlan 2 step
  120. How much boost?
  121. over heating procharged 408... my solution.. hope it works
  122. launching a turbo automatic
  123. how much hp/boost can a built lt1 take?
  124. STS Twin Turbo For C5 Corvette
  125. Reason for switching to a carb intake??
  126. FI Cars: What gear ratio are you running?
  127. FI help needed- Dyno Tuning problems
  128. something has to be wrong...
  129. LT1 vs LS1 boostwise
  130. Truck Manifold TT build: few questions
  131. c5+forced induction questions.
  132. Should i go twin turbo or just on big turbo???
  133. nitrous to Forced induction...need some advice
  134. Solution for the ATI heating inpaired: Be Cool
  135. 382 stroker motor w/ -21.4 mahle pistons
  136. New 60mm Piston Driven Wastegates!!
  137. I'm rear mounting my 402, need help........
  138. Who's running cats with thier S/C?
  139. FI intake airflow , and egts
  140. **** Cartek P-1 Procharged C6 Vette breaks into the 9-second zone ****
  141. Whats the difference between these two?
  142. install procharger?
  143. Just a couple of rear mount pics
  144. Procharger F1C
  145. Hogan Intake or carburated conv.?
  146. rear mount turbo oiling??
  147. intercooler piping to tb
  148. wtb d1 procharger
  149. T88 FM and a 370CI.....do you have this combo?
  150. How do you find the BEST comp. ratio for a power level?
  151. high HP, what recommended mods for Oiling system?
  152. how many cubes will the gt70 support
  153. Cats with Rear Mount?
  154. Cats and PE Mode!
  155. PT88 rear mount... so far... it sucks LOL
  156. smaller runner VS large runner on FI
  157. cam selection
  158. What do I need to do to make my car reliable
  159. Procharger rebuild
  160. Ported manifolds/TB's?
  161. STS Turbo Questions
  162. 6L manifold kit with twin T61s good idea?
  163. so im trying to plan my friends turbo build ... questions
  164. question for EPP or someone good with cams
  165. My video and slip
  166. Turbo question
  167. My 408 is here (Cam decision)
  168. Goodbye to boost for a while
  169. procharger parts
  170. Lt1 buildup for boost - Need help for set-up
  171. What transmission would you go with for my Twin Turbo set up?
  172. Advice pls, if you are not too busy!
  173. A little advice....2-Step
  174. New D1 Price?
  175. Venting crankcase pressure
  176. will meth kill a fuel injector?
  177. Last 1/8 mile passes on this combo..
  178. superchargers
  179. turbo motor
  180. Do you have to change out the computer and wiring for a twin turbo setup????
  181. Question about parasitic loss with centrifugal sc
  182. If you were me would you sell your Incon TT kit?
  183. low gear for turbo
  184. Placement of Oil cooler
  185. Truck Manifold ?
  186. Hot part clearance
  187. New personal Best 7.54 @ 187.89
  188. 355 LT1 built for boost
  189. What size single with stock cube motor?
  190. I owe Devil's Own an apology
  191. T6 flange
  192. New Best 10.45@136.32 STOCK MOTOR!
  193. Got 2 new Rides...
  194. Decided to sart tossing another kit together... pics
  195. T.Smart Ultra gate..good for 5psi on a t70?
  196. SEMA Show-New Magnuson Blower
  197. how streetable is TT?
  198. Super Charger, rear gears 3.42 0r 3.90
  199. Max boost?
  200. a2a intercooler...
  201. supercharger worth it?
  202. how many members have blown there motors at 5 psi
  203. roots/twin screw intake manifolds
  204. Best friends or worst enemies (pic)
  205. Pick my turbo cam!
  206. will GTO ATI kit fit on a Fbody (vette thread deleted)
  207. New build - have questions
  208. my sts install pics
  209. Wastegate on a supercharger
  210. E-85 fuel more efficient for FI
  211. to let everyone no tondss is no longer my name.....this is!
  212. Does alky injection help N/A motors at all?
  213. intake and throttle plate
  214. Which turbos for twin setup? Like Incon but cheaper...
  215. turning 6.0ltr manifolds upside down?
  216. Where can i get ....
  217. Internals for procharger on a LS1
  218. P1-SC question?
  219. tt manifolds
  220. ...Need some 6.0L truck manif. anyone got an extra set?
  221. Well, IT HAS BEGUN!!!
  222. What racing classes are you guys looking at?
  223. Boost Reference Nitrous Controller
  224. Building Own Rear Mount Turbo??!!
  225. can the engine handle it?????
  226. OFI F-body Hot Parts coated on engine
  227. What Stall converter are FI SC guys having luck with?
  228. Help with TTiX and Motor build
  229. Professional Dyno Tuners Come inside: Advice Needed
  230. what trim housing is this a/r.96?
  231. 1/2 inch stainless flanges??
  232. So who's the fastest STS car?
  233. Compression Ratio for Turbo?
  234. Help! Supercharger Newbie with a few questions.
  235. 7 second rear mount C5 video
  236. CA Smog Legal Forced Induction
  237. procharger
  238. 402 or 408 gt67 or gt70
  239. Which Bypass Valve (Vortech)
  240. Custom Turbo
  241. ohio forced induction parts on the way!
  242. is a t76 to small?
  243. turbo or blower on stock motor
  244. LS7 heads and intake vs. Dart heads and LS6 intake
  245. New here ,doing conversion WITH BOOST!!
  246. Boost 402-408 short blocks in stock!!
  247. My ATI + new alternator adventure...
  248. Stenod Performance Twin Turbo T/A...Done!
  249. Can someone`explain to me how to line the procharger belt up?
  250. have any of you heard of a turbo using a "foil bearing"??
